Smart Home Leak Sensor Kit with Wyze Sense Hub Connection
Protect your home from unexpected water damage with a smart leak sensor kit that integrates seamlessly with the Wyze Sense Hub. Designed for reliable, real-time leak detection, this system ensures you get instant alerts to prevent costly repairs and maintain peace of mind. Below, explore the essential components of the Wyze smart home leak sensor kit that requires the Wyze Sense Hub connection.
Wyze Sense Hub: The Central Brain of Your Smart Home Monitoring
Alt: Wyze Sense Hub smart home monitoring device in modern home environment
The
Wyze Sense Hub is the core of your smart home monitoring system. It connects all your Wyze sensors, including leak sensors, entry sensors, and motion detectors, and sends instant alerts to your smartphone. This hub is essential for the operation of the leak sensor kit, as the sensors cannot function independently without it.
Key Features:
- Connectivity: Supports Ethernet and WiFi (2.4 GHz), Bluetooth 4.1+ BLE 5.1, and 915MHz RF for sensor communication.
- Range: Up to 500 feet sensor range in ideal conditions, ensuring coverage throughout your home.
- Siren: Built-in 88db siren to alert you locally during emergencies.
- Battery Backup: 10-hour rechargeable battery backup to keep your system running during power outages.
- Sensor Support: Connects up to 100 sensors, allowing for extensive home coverage.
- Indoor Use: Designed for indoor environments with operating temperature from 32°F to 104°F.
The Wyze Sense Hub is the "brains behind the brawn," making it indispensable for a professional-grade home monitoring experience.
Wyze Sense Leak Sensor & Probe: Early Water Leak Detection
Alt: Wyze Sense Leak Sensor & Probe detecting water leak under a sink
The
Wyze Sense Leak Sensor & Probe is your first line of defense against water damage. Designed to detect leaks early, it sends immediate notifications through the Wyze app when water is detected, helping you act fast to prevent damage.
Why Choose Wyze Leak Sensors?
- Requires Wyze Sense Hub: These sensors must be paired with the Wyze Sense Hub to function.
- Multiple Styles: Available in packs with sensors and probes, or just probes for flexible placement.
- Indoor Use Only: Perfect for basements, kitchens, bathrooms, and laundry rooms.
- Operating Range: Works reliably within 32°F to 104°F and up to 85% humidity.
- Long Wireless Range: Up to 500 feet from the hub, ensuring placement in hard-to-reach areas.
- App Differentiation: The Wyze app can distinguish between leak sensors and probes for precise alerts.
Note: The leak sensor probe cannot operate without the leak sensor, but the leak sensor can work independently.
Additional Wyze Sense Sensors Compatible with the Hub
To enhance your smart home monitoring system, consider adding these sensors that also require the Wyze Sense Hub:
Wyze Sense Entry Sensor
Detects when doors or windows open or close, providing an extra layer of security and monitoring.
- Battery Life: Up to 18 months.
- Range: 500 feet max from the hub.
- Indoor Use: Yes.
- Detection Zone: 25 feet with 120° field of vision.
- Compatibility: Works only with Wyze Sense Hub (v2), not with older v1 sensors.
Wyze Sense Motion Sensor
Detects motion within your home to alert you of unexpected activity.
- Detection Range: 25 feet with 120° field of view.
- Adjustable Sensitivity: Customize detection to reduce false alarms.
- Installation: Adhesive backing or screws for secure mounting.
- Indoor Use: Yes.
- Compatibility: Requires Wyze Sense Hub.
Why Choose Wyze for Your Smart Leak Sensor Kit?
Wyze offers a comprehensive and affordable smart home monitoring ecosystem that integrates leak detection with other security features. The Wyze Sense Hub acts as the central controller, ensuring all sensors communicate effectively and alerts are delivered promptly. This system is ideal for homeowners who want reliable, professional-grade monitoring without the complexity or high cost of traditional security systems.
With Wyze, you get peace of mind knowing your home is protected from leaks and other potential hazards, all managed conveniently through a single app.
Summary of Products for Your Leak Sensor Kit
Product | Purpose | Key Requirement |
Wyze Sense Hub | Central hub for sensors | Required for all sensors |
Wyze Sense Leak Sensor & Probe | Detects water leaks | Requires Wyze Sense Hub |
Wyze Sense Entry Sensor | Monitors door/window status | Requires Wyze Sense Hub |
Wyze Sense Motion Sensor | Detects motion | Requires Wyze Sense Hub |
Protect your home today with the Wyze Sense Leak Sensor Kit powered by the Wyze Sense Hub — the smart, connected solution for leak detection and home monitoring.
What is the Wyze Sense Hub and why is it required for the leak sensor kit?
The Wyze Sense Hub is the central controller for all Wyze sensors, including leak, entry, and motion sensors. It connects these devices and sends instant alerts to your smartphone. The leak sensor kit requires the Wyze Sense Hub to function, as the sensors cannot operate independently without it.How does the Wyze Sense Leak Sensor Kit help prevent water damage?
The Wyze Sense Leak Sensor Kit detects water leaks in real time and sends immediate notifications to your phone via the Wyze app. This early detection allows you to act quickly and prevent costly water damage in areas like basements, kitchens, bathrooms, and laundry rooms.Can the Wyze Sense Leak Sensor and Probe be used without the Wyze Sense Hub?
No, the Wyze Sense Leak Sensor and Probe require the Wyze Sense Hub to function. The sensors communicate with the hub, which then sends alerts to your smartphone.Where can I install the Wyze Sense Leak Sensor and Probe?
The Wyze Sense Leak Sensor and Probe are designed for indoor use only. They are ideal for placement in basements, kitchens, bathrooms, laundry rooms, or any area prone to water leaks.What is the wireless range of the Wyze Sense Leak Sensor Kit?
The Wyze Sense Leak Sensor Kit offers a wireless range of up to 500 feet from the Wyze Sense Hub in ideal conditions, allowing you to cover large areas of your home.Does the Wyze Sense Leak Sensor work independently from the probe?
Yes, the Wyze Sense Leak Sensor can work independently, but the probe cannot operate without being connected to the leak sensor.What other sensors are compatible with the Wyze Sense Hub?
In addition to leak sensors, the Wyze Sense Hub supports Wyze Sense Entry Sensors (for monitoring doors and windows) and Wyze Sense Motion Sensors (for detecting movement). All these sensors require the Wyze Sense Hub to function.Is the Wyze Sense Leak Sensor Kit suitable for outdoor use?
No, the Wyze Sense Leak Sensor Kit is designed for indoor use only, with an operating temperature range of 32°F to 104°F and up to 85% humidity.How does the Wyze app differentiate between leak sensors and probes?
The Wyze app can distinguish between leak sensors and probes, providing precise alerts so you know exactly which device detected water.What are the power and backup features of the Wyze Sense Hub?
The Wyze Sense Hub features a 10-hour rechargeable battery backup, ensuring your home monitoring system continues to operate during power outages. It also includes an 88db built-in siren for local alerts.How many sensors can I connect to the Wyze Sense Hub?
You can connect up to 100 sensors to a single Wyze Sense Hub, allowing for extensive home coverage and monitoring.What makes Wyze a good choice for smart home leak detection?
Wyze offers an affordable, comprehensive smart home monitoring system that integrates leak detection with security features. The Wyze Sense Hub ensures reliable communication between sensors and delivers instant alerts, all managed through a single, user-friendly app.
