Non-Standalone Leak Sensor Probe with Hub for Water Alerts
Non-Standalone Leak Sensor Probe with Hub Integration for Water Alerts
Protect your home from unexpected water damage with advanced leak detection technology that integrates seamlessly with your smart home hub. If you're searching for a reliable non-standalone leak sensor probe that works with a hub for instant water alerts, the Wyze Sense Leak Sensor & Probe combined with the Wyze Sense Hub offers an efficient and smart solution.
Wyze Sense Leak Sensor & Probe: Smart Leak Detection Made Simple
Key Features and Benefits
  • Hub-Dependent Operation: This leak sensor probe is designed to work exclusively with the Wyze Sense Hub, ensuring centralized control and reliable alert delivery.
  • Instant Leak Notifications: Get notified immediately on your smartphone when water is detected, helping you prevent costly water damage.
  • Compatibility: Works with Wyze Sense v2 and Wyze Home Monitoring systems, but not compatible with Wyze Sense v1.
  • Operating Conditions: Designed for indoor use with an operating temperature range of 32-104°F (0 to 40°C) and humidity tolerance up to 85% at 86°F (30°C).
  • Extended Sensor Range: Communicates with the hub up to 500 feet away, allowing flexible placement throughout your home.
  • Multiple Variants: Available in packs with 2 probes or 3 sensors plus 1 probe, catering to different monitoring needs.
The Wyze Sense Leak Sensor & Probe is an essential addition to any smart home setup, providing peace of mind by alerting you to leaks before they cause damage.
Wyze Sense Hub: The Central Brain for Your Leak Sensors
Why You Need the Wyze Sense Hub
  • Centralized Connectivity: The hub connects all Wyze Sense sensors and probes, managing communication and sending real-time alerts to your devices.
  • Robust Communication: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF for reliable sensor connections.
  • Long Sensor Range: Maintains communication with sensors up to 500 feet away, ideal for larger homes or multi-room monitoring.
  • Battery Backup: Features a built-in rechargeable battery with up to 10 hours of backup power, ensuring continuous operation during power outages.
  • Indoor Use: Designed for indoor environments with operating temperature and humidity ranges matching the leak sensor probe.
  • Expandable System: Supports up to 100 sensors, allowing you to build a comprehensive home monitoring network.
The Wyze Sense Hub is the perfect companion to the leak sensor probe, providing the intelligence and connectivity needed for a smart, responsive water alert system.
Why Choose a Non-Standalone Leak Sensor Probe with Hub Integration?
Advantages Over Standalone Sensors
  • Centralized Alerts: All sensors report to a single hub, reducing false alarms and streamlining notifications.
  • Scalability: Easily add more sensors and probes to cover multiple areas such as basements, kitchens, bathrooms, and laundry rooms.
  • Integration: Works within a broader home monitoring ecosystem, allowing you to combine leak detection with other security and automation devices.
  • Reliable Communication: Hub-based systems typically offer stronger and more stable connections than standalone WiFi sensors.
Enhance Your Home Monitoring with Wyze Ecosystem
While the Wyze Sense Leak Sensor & Probe and Wyze Sense Hub form the core of your water alert system, consider complementing your setup with other Wyze products for full home security and automation:
  • Wyze Cam v4: Indoor/outdoor smart camera with color night vision and motion detection.
  • Wyze Video Doorbell v2: Monitor your front door with 1080p HD video and two-way audio.
  • Wyze Lock Bolt: Smart lock with fingerprint sensor and keypad for secure access.
These devices integrate smoothly with Wyze Home Monitoring, creating a comprehensive smart home environment.
Home Monitoring Lifestyle Stay connected and protected with smart home monitoring solutions.
Summary
For those seeking a non-standalone leak sensor probe with hub integration for water alerts, the Wyze Sense Leak Sensor & Probe paired with the Wyze Sense Hub offers a reliable, scalable, and smart solution. This combination ensures you receive timely notifications of leaks, helping you safeguard your home from water damage effectively.
Product Specifications at a Glance
FeatureWyze Sense Leak Sensor & ProbeWyze Sense Hub
Requires HubYesN/A
Sensor RangeUp to 500 feetSupports sensors up to 500 feet
Operating Temperature Range32-104°F (0 to 40°C)32-104°F (0 to 40°C)
Operating Humidity Range≤ 85% at 86°F (30°C)≤ 85% at 86°F (30°C)
CompatibilityWyze Sense v2, Wyze Home MonitoringConnects Wyze Sense sensors
Battery BackupN/A10 hours built-in rechargeable
Indoor/Outdoor UseIndoor onlyIndoor only
TypeHome MonitoringHome Monitoring
PurposeDetects leaks and notifiesConnects monitoring components and sends alerts
CompatibilityRequires Wyze Sense v2 or Wyze Home MonitoringCore of Wyze Home Monitoring System
Standalone FunctionalityNo, requires Wyze Sense HubYes
Variants2 Probes ($13.98), 3 Sensors and 1 Probe ($55.98)Single variant ($45.98)
Price$13.98 - $55.98$45.98
RequiresWyze Sense HubN/A
Use CaseLeak detectionCentral hub for all Wyze Sense sensors
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the Wyze Sense Leak Sensor & Probe?The Wyze Sense Leak Sensor & Probe is a smart water leak detection device designed to work with the Wyze Sense Hub. It provides instant water alerts to your smartphone, helping you prevent costly water damage in your home.
Does the Wyze Sense Leak Sensor & Probe require a hub to operate?Yes, the Wyze Sense Leak Sensor & Probe is a non-standalone device and requires the Wyze Sense Hub for operation. The hub manages communication and sends real-time alerts to your devices.
Is the Wyze Sense Leak Sensor & Probe compatible with Wyze Sense v1?No, the Wyze Sense Leak Sensor & Probe is not compatible with Wyze Sense v1. It works with Wyze Sense v2 and Wyze Home Monitoring systems.
How far can the Wyze Sense Leak Sensor & Probe communicate with the hub?The Wyze Sense Leak Sensor & Probe can communicate with the Wyze Sense Hub up to 500 feet away, allowing flexible placement throughout your home.
What are the operating conditions for the Wyze Sense Leak Sensor & Probe?The Wyze Sense Leak Sensor & Probe is designed for indoor use, with an operating temperature range of 32-104°F (0 to 40°C) and humidity tolerance up to 85% at 86°F (30°C).
What are the benefits of using a non-standalone leak sensor probe with hub integration?A non-standalone leak sensor probe with hub integration offers centralized alerts, scalability for monitoring multiple areas, integration with other smart home devices, and more reliable communication compared to standalone WiFi sensors.
How many sensors can the Wyze Sense Hub support?The Wyze Sense Hub can support up to 100 sensors, allowing you to build a comprehensive home monitoring network.
Does the Wyze Sense Hub have battery backup?Yes, the Wyze Sense Hub features a built-in rechargeable battery that provides up to 10 hours of backup power, ensuring continuous operation during power outages.
Can I use the Wyze Sense Leak Sensor & Probe outdoors?No, both the Wyze Sense Leak Sensor & Probe and the Wyze Sense Hub are designed for indoor use only.
What other Wyze products can I integrate with the Wyze Sense Leak Sensor & Probe?You can integrate the Wyze Sense Leak Sensor & Probe with other Wyze products such as Wyze Cam v4, Wyze Video Doorbell v2, and Wyze Lock Bolt for a complete smart home security and monitoring system.
Can you explain how the Wyze Sense Hub works with the leak sensor probe?What are the operating conditions for the Wyze Sense Leak Sensor & Probe?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Sense Leak Sensor & Probe?
