Setup Wyze Indoor Leak Sensors for Smart Water Damage Prevention
Setup Indoor Wyze Leak Sensor System for Water Damage Detection and Home Integration
Protecting your home from unexpected water damage is crucial, and the Wyze Sense Leak Sensor & Probe offers an affordable, reliable solution for early leak detection. Designed specifically for indoor use, this system integrates seamlessly with your smart home setup, providing peace of mind through instant notifications and smart automations.
Why Choose Wyze Sense Leak Sensor & Probe?
The Wyze Leak Sensor & Probe is engineered to detect water leaks early, helping you prevent costly damage to your home. It works exclusively indoors and pairs with the Wyze Sense Hub, which acts as the central communication point for all your Wyze sensors.
Key Benefits:
  • Instant leak notifications on your smartphone
  • Long wireless range up to 500 feet from the hub
  • Battery-powered with up to 18 months of life
  • Sleek, compact design fits in tight spaces
  • Compatible with Wyze Home Monitoring for enhanced security
Product Features and Specifications
Wyze Sense Leak Sensor & Probe Overview
  • Indoor Use Only: Designed to monitor areas prone to leaks such as under sinks, dishwashers, water heaters, and crawlspaces. Not suitable for outdoor use.
  • Detection Capability: Detects water leaks only, not other liquids or fumes.
  • Sensor Range: Up to 500 feet from the Wyze Sense Hub, ensuring reliable connectivity even in basements or attics.
  • Operating Conditions: Works within 32°F to 104°F (0°C to 40°C) and humidity up to 85% at 86°F (30°C).
  • Battery Life: Powered by a CR2450 battery lasting up to 18 months, minimizing maintenance.
  • Probe Attachment: The included ultra-thin probe extends about 1 meter, allowing detection in hard-to-reach places like beneath dishwashers or crawlspaces.
  • Compatibility: Requires Wyze Sense Hub and works with Wyze Sense v2 or Wyze Home Monitoring subscription.
  • Pack Options: Available in packs with 2 probes or 3 sensors and 1 probe.
How It Works
The leak sensor detects moisture through two sensors on its base spaced about 0.8 inches apart. When both sensors detect water, the system immediately sends an alert to your Wyze app, specifying whether the leak was detected by the sensor or the probe.
Step-by-Step Setup Guide
Step 1: Prepare Your Wyze Sense Hub
The Wyze Sense Hub is essential for connecting your leak sensors to the Wyze app and enabling notifications. You only need one hub per setup, which comes free with an annual Wyze Home Monitoring subscription.
Step 2: Add the Leak Sensor & Probe
  • Open the Wyze app and tap Home.
  • Tap the plus sign (+) and select Device > Sensors > Wyze Leak Sensor.
  • Select your Wyze Sense Hub to pair.
  • Remove the battery tab from the sensor and press the reset button until the light flashes.
  • For the probe, simply plug it into the leak sensor.
  • Name your sensor and customize notifications or automations as desired.
Step 3: Place Sensors Strategically
Install sensors in high-risk areas such as:
  • Under kitchen and bathroom sinks
  • Near dishwashers and washing machines
  • Around water heaters and sump pumps
  • Crawlspaces or basements prone to moisture
The slim design and probe allow placement in tight or hidden spots.
Integrating Wyze Leak Sensors with Your Smart Home
Wyze Leak Sensors work seamlessly with the Wyze Home Monitoring system, allowing you to:
  • Receive instant push notifications on your phone when leaks are detected.
  • Automate actions such as turning off smart water valves or triggering alarms.
  • Monitor multiple sensors from a single app interface.
  • Combine with other Wyze sensors (entry, motion, climate) for comprehensive home security and environmental monitoring.
“Wyze services and products have always proven 100% time and times again.” — Las Vegas, NV
Important Usage Notes
  • Indoor Use Only: The sensors are IP67 rated for dust and brief water exposure but are not weatherproof for outdoor use.
  • No Hardwiring Needed: Battery-powered for flexible placement without wiring hassles.
  • Subscription Required: Wyze Home Monitoring subscription is required to activate the hub and enable full sensor functionality.
  • Wi-Fi Requirements: Must connect via 2.4 GHz Wi-Fi networks; 5 GHz is not supported.
  • Range Considerations: Walls and interference may reduce the effective sensor-to-hub range.
Enhance Your Home Safety with Wyze Leak Sensors
Installing Wyze Leak Sensors is a smart, cost-effective way to safeguard your home from water damage. With easy setup, reliable notifications, and smart home integration, you can detect leaks early and take action before they cause serious problems. Family checking smart home devices
Summary
FeatureWyze Sense Leak Sensor & Probe
Use CaseIndoor water leak detection
Sensor RangeUp to 500 feet from Wyze Sense Hub
Battery LifeUp to 18 months (CR2450 battery)
Operating Temperature Range32°F to 104°F (0°C to 40°C)
Humidity Range≤ 85% at 86°F (30°C)
Probe LengthApproximately 1 meter
CompatibilityWyze Sense v2, Wyze Home Monitoring
Pack Options2 Probes or 3 Sensors + 1 Probe
Final Thoughts
The Wyze Sense Leak Sensor & Probe system is an essential addition to any smart home focused on water damage prevention. Its easy integration, long battery life, and precise leak detection make it a top choice for homeowners seeking peace of mind. Protect your home today with Wyze Leak Sensors — smart, simple, and effective. Wyze home security lifestyle
FeatureWyze Sense Leak Sensor & Probe (2 Probes)Wyze Sense Leak Sensor & Probe (3 Sensors and 1 Probe)
Product TypeHome MonitoringHome Monitoring
CompatibilityRequires Wyze Sense v2 or Wyze Home Monitoring; Requires Wyze Sense Hub; Not compatible with Wyze Sense v1Requires Wyze Sense v2 or Wyze Home Monitoring; Requires Wyze Sense Hub; Not compatible with Wyze Sense v1
FunctionLeak detection and notificationLeak detection and notification
Number of Probes21
Number of Sensors03
Price$13.98 USD$55.98 USD
AvailabilitySold out / UnavailableSold out / Unavailable
Return Policy30-day hassle-free returns30-day hassle-free returns
Instant Discount28% off Wyze Sense Sensors with Wyze Home Monitoring Annual plan28% off Wyze Sense Sensors with Wyze Home Monitoring Annual plan
What is the Wyze Sense Leak Sensor & Probe and how does it work?The Wyze Sense Leak Sensor & Probe is an indoor water leak detection system designed to alert you to leaks before they cause significant damage. It works by detecting moisture through two sensors on its base or via an ultra-thin probe. When water is detected, it sends instant notifications to your Wyze app, allowing you to take immediate action.
Where should I place Wyze Leak Sensors in my home?Wyze Leak Sensors should be placed in high-risk areas for water leaks, such as under kitchen and bathroom sinks, near dishwashers and washing machines, around water heaters and sump pumps, and in crawlspaces or basements prone to moisture. The slim design and included probe make it easy to install in tight or hidden spots.
Is the Wyze Leak Sensor system suitable for outdoor use?No, the Wyze Leak Sensor & Probe is designed for indoor use only. While the sensors are IP67 rated for dust and brief water exposure, they are not weatherproof and should not be used outdoors.
What is required to set up the Wyze Leak Sensor & Probe?To set up the Wyze Leak Sensor & Probe, you need a Wyze Sense Hub, which connects the sensors to the Wyze app and enables notifications. The hub is included with an annual Wyze Home Monitoring subscription. You also need a 2.4 GHz Wi-Fi network, as 5 GHz is not supported.
How do I install and connect the Wyze Leak Sensor & Probe?To install the Wyze Leak Sensor & Probe, open the Wyze app, tap the plus sign (+), and select Device > Sensors > Wyze Leak Sensor. Pair it with your Wyze Sense Hub, remove the battery tab, and press the reset button until the light flashes. Plug the probe into the sensor if needed, then name your sensor and customize notifications or automations.
How long does the Wyze Leak Sensor battery last?The Wyze Leak Sensor is powered by a CR2450 battery that lasts up to 18 months, minimizing maintenance and ensuring reliable leak detection.
What is the wireless range of the Wyze Leak Sensor?The Wyze Leak Sensor has a wireless range of up to 500 feet from the Wyze Sense Hub, allowing reliable connectivity even in basements or attics. However, walls and interference may reduce the effective range.
Does the Wyze Leak Sensor detect other liquids or fumes?No, the Wyze Leak Sensor is designed to detect water leaks only. It does not detect other liquids or fumes.
Can I integrate Wyze Leak Sensors with my smart home system?Yes, Wyze Leak Sensors integrate seamlessly with the Wyze Home Monitoring system. You can receive instant push notifications, automate actions like turning off smart water valves or triggering alarms, and monitor multiple sensors from the Wyze app.
Is a subscription required to use the Wyze Leak Sensor system?Yes, a Wyze Home Monitoring subscription is required to activate the Wyze Sense Hub and enable full functionality of the leak sensors, including notifications and smart home integration.
What are the available pack options for Wyze Leak Sensors?Wyze Leak Sensors are available in packs with either 2 probes or 3 sensors and 1 probe, allowing you to customize your setup based on your home's needs.
What are the operating temperature and humidity ranges for the Wyze Leak Sensor?The Wyze Leak Sensor operates within a temperature range of 32°F to 104°F (0°C to 40°C) and can handle humidity up to 85% at 86°F (30°C).
Do I need to hardwire the Wyze Leak Sensor?No, the Wyze Leak Sensor is battery-powered, so no hardwiring is required. This allows for flexible placement throughout your home.
How do I integrate the Wyze Leak Sensor with my existing smart home system?Can I monitor multiple Wyze Leak Sensors from the Wyze app?What are the best locations to install the Wyze Leak Sensor for optimal performance?
