Wyze Leak Sensor Detection: Smart Home Water Leak Protection
Leak Sensor Detection Capabilities: Protect Your Home from Water Damage
Water leaks can cause significant damage to your home if left undetected. Wyze offers specialized leak detection solutions designed to alert you immediately when water is detected, helping you prevent costly repairs and maintain peace of mind. This page highlights the Wyze Leak Sensor & Probe and related smart home security products that enhance your home's safety with advanced leak detection and monitoring capabilities.
Wyze Sense Leak Sensor & Probe: Precision Leak Detection for Your Home
Reliable Water Leak Alerts
The Wyze Sense Leak Sensor & Probe is engineered specifically to detect water leaks indoors. It does not detect other liquids, fumes, or outdoor moisture, ensuring focused and accurate leak monitoring.
  • Water Leak Detection Only: Designed to sense water leaks under sinks, dishwashers, crawlspaces, and other critical areas.
  • Probe Attachment: The optional probe extends about 1 meter, allowing detection in hard-to-reach places where leaks often start.
  • Indoor Use Only: Not suitable for outdoor use; placing it outside voids the warranty.
  • Battery Powered: No hardwiring needed; runs on a CR2450 battery lasting up to 18 months.
  • Operating Conditions: Works best between 32ºF to 104ºF (0ºC to 40ºC) and humidity ≤ 85% at 86ºF (30ºC).
  • Sensor Range: Up to 500 feet from the Wyze Sense Hub for reliable connectivity.
  • Notification: Receive instant alerts via the Wyze app, which identifies whether the leak sensor or probe detected the leak.
"Get notified of leaks before they cause damage."
How It Works
The sensor detects moisture when both sensors on its base sense water simultaneously (about 0.8 inches apart). The probe extends detection reach, wrapping around pipes or fitting into tight spaces.
Pack Options
  • Available in packs with multiple sensors and probes to cover various areas of your home.
Ultimate Security Bundle: Comprehensive Home Protection Including Leak Detection
For those seeking an all-in-one solution, the Ultimate Security Bundle (13-piece) integrates leak detection with a full suite of smart home security devices.
Leak Detection Included
  • Comes with Wyze Sense Hub, Motion Sensor, and Entry Sensors that work seamlessly with the Wyze Leak Sensor & Probe.
  • Centralized monitoring and instant alerts through the Wyze app.
  • Protects your home from water leaks, unauthorized entry, and motion detection.
Advanced Security Features
  • Wyze Cam Duo Doorbell: Dual cameras for full door coverage with two-way audio.
  • Wyze Lock Bolt: Keyless entry with fingerprint reader and illuminated keypad.
  • Wyze Cam Pan v3 & Cam v4: Pan-and-tilt cameras with motion tracking and color night vision.
  • Wyze Battery Cam Pro: Wire-free cameras with AI detection for hard-to-reach spots.
This bundle ensures your home is protected from multiple threats, including water leaks, with smart automation and easy app control.
Wyze Cam Pan v3: Smart Camera with Pan, Tilt & Motion Tracking
While primarily a security camera, the Wyze Cam Pan v3 complements leak detection by providing visual monitoring of areas prone to leaks or water damage.
Key Features
  • 360° Horizontal & 180° Vertical View: Covers every angle in a room.
  • IP65 Weather Resistant: Suitable for indoor and outdoor use (with outdoor power adapter).
  • 1080p HD Video: Clear day and night vision with 4 IR LEDs.
  • Two-Way Audio: Communicate through the camera via the Wyze app.
  • Motion Tracking: Automatically follows movement for comprehensive coverage.
  • Storage: Supports up to 256 GB microSD card for local video storage.
Ideal for monitoring basements, laundry rooms, or utility areas where leaks may occur.
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 offers weather-resistant, 360° coverage for indoor/outdoor monitoring.
Why Choose Wyze Leak Sensor & Related Products?
  • Early Leak Detection: Prevent costly water damage by receiving instant alerts.
  • Easy Installation: Battery-powered, wireless, and adhesive-backed for flexible placement.
  • Smart Home Integration: Works with Wyze Sense Hub and Wyze app for centralized control.
  • Extended Reach: Probe attachment detects leaks in hard-to-access areas.
  • Reliable Notifications: Know exactly which sensor detected the leak via app alerts.
  • Complementary Security: Combine with Wyze cameras and sensors for full home protection.
Summary of Leak Detection Products
ProductLeak Detection CapabilityAdditional Features
Wyze Sense Leak Sensor & ProbeDetects water leaks indoors; probe extends reachBattery-powered, app notifications, indoor use only
Ultimate Security BundleIncludes leak sensors plus cameras, locks, motion sensorsComprehensive home security and leak detection
Wyze Cam Pan v3Visual monitoring of leak-prone areasPan/tilt, weather resistant, two-way audio
Protect your home from water damage with Wyze's reliable leak detection technology combined with smart home security. Whether you need a dedicated leak sensor or a full security system, Wyze offers solutions tailored to your needs.
FeatureWyze Sense Leak Sensor & ProbeUltimate Security Bundle (13-piece)Wyze Cam Pan v3
TypeHome MonitoringSmart Home Security SystemSecurity Camera
PurposeLeak detectionComprehensive home security (cameras, locks, sensors)Indoor/outdoor pan-tilt camera
Requires HubYes, Wyze Sense Hub (v2)Yes, includes Wyze Sense HubNo
Sensors IncludedLeak sensors and probesMotion Sensor, Entry Sensors, Wyze Sense HubN/A
Cameras IncludedNoWyze Cam Duo Doorbell, 2× Wyze Cam Pan v3, 2× Wyze Cam v4, 2× Wyze Battery Cam Pro1 camera
Lock IncludedNoWyze Lock BoltNo
AudioN/ATwo-way audio on cameras and doorbellBuilt-in speaker and microphone; 2-way audio
Video ResolutionN/AMultiple cameras with 1080p and higher1920 x 1080 (1080p)
Pan/Tilt CapabilityN/AYes, with Wyze Cam Pan v3360° horizontal, 180° vertical
Night VisionN/AColor night vision on cameras4 IR LEDs (850 nm), color night vision
Weather ResistanceN/ACameras with indoor/outdoor capabilityIP65 rated
ConnectivityWorks with Wyze Sense HubWyze app connectivity802.11 b/g/n 2.4GHz Wi-Fi
Price$13.98 (2 Probes), $55.98 (3 Sensors + 1 Probe)$499.99$39.98 (single), $114.94 (3-pack)
CompatibilityWyze Sense v2 or Wyze Home MonitoringWyze appAndroid 9.0+, iOS 15.0+
StorageN/AN/ASupports up to 256 GB microSD
AlertsLeak notificationsInstant alerts for motion, entry, and leaksPush notifications
WarrantyNot specifiedNot specified1-Year
What does the Wyze Sense Leak Sensor & Probe detect?The Wyze Sense Leak Sensor & Probe is designed specifically to detect water leaks indoors. It does not detect other liquids, fumes, or outdoor moisture, ensuring focused and accurate leak monitoring in your home.
Where can I place the Wyze Leak Sensor & Probe in my home?You can place the Wyze Leak Sensor & Probe under sinks, dishwashers, crawlspaces, and other critical indoor areas prone to water leaks. The optional probe attachment allows you to detect leaks in hard-to-reach places, such as around pipes or tight spaces.
Is the Wyze Leak Sensor suitable for outdoor use?No, the Wyze Leak Sensor & Probe is intended for indoor use only. Using it outdoors will void the warranty and may result in inaccurate readings.
How does the Wyze Leak Sensor notify me of a water leak?When the Wyze Leak Sensor or its probe detects water, you receive instant alerts through the Wyze app. The app identifies which specific sensor or probe detected the leak, allowing you to respond quickly and prevent water damage.
What is the battery life of the Wyze Leak Sensor & Probe?The Wyze Leak Sensor & Probe is battery powered and uses a CR2450 battery, which can last up to 18 months depending on usage and environmental conditions.
How far can the Wyze Leak Sensor be placed from the Wyze Sense Hub?The Wyze Leak Sensor has a range of up to 500 feet from the Wyze Sense Hub, providing reliable connectivity throughout most homes.
What is included in the Wyze Ultimate Security Bundle?The Wyze Ultimate Security Bundle (13-piece) includes the Wyze Sense Hub, Motion Sensor, Entry Sensors, Wyze Leak Sensor & Probe, Wyze Cam Duo Doorbell, Wyze Lock Bolt, Wyze Cam Pan v3, Wyze Cam v4, and Wyze Battery Cam Pro. This bundle offers comprehensive home protection, including leak detection, motion detection, entry monitoring, and video surveillance.
Can the Wyze Cam Pan v3 help with leak detection?While the Wyze Cam Pan v3 is primarily a security camera, it complements leak detection by providing visual monitoring of areas prone to leaks or water damage, such as basements, laundry rooms, or utility areas.
How easy is it to install the Wyze Leak Sensor & Probe?The Wyze Leak Sensor & Probe is easy to install. It is battery-powered, wireless, and comes with adhesive backing for flexible placement in your home. No hardwiring is required.
Does the Wyze Leak Sensor integrate with other Wyze smart home products?Yes, the Wyze Leak Sensor & Probe works seamlessly with the Wyze Sense Hub and the Wyze app, allowing for centralized control and integration with other Wyze smart home security devices.
What are the operating conditions for the Wyze Leak Sensor?The Wyze Leak Sensor operates best between 32ºF to 104ºF (0ºC to 40ºC) and in environments with humidity levels up to 85% at 86ºF (30ºC).
Are there pack options available for the Wyze Leak Sensor & Probe?Yes, the Wyze Leak Sensor & Probe is available in packs with multiple sensors and probes, allowing you to cover various areas of your home for comprehensive leak detection.
Can you explain how the Wyze Sense Leak Sensor & Probe works in more detail?What are the operating conditions for the Wyze Sense Leak Sensor & Probe?Do you have any ongoing sales or promotions for the Wyze Leak Sensor or related products?
