Professional Home Monitoring System with Integrated Leak and Climate Sensors
Creating a secure and smart home environment requires a reliable monitoring system that not only detects intrusions but also keeps track of environmental conditions and potential hazards like leaks. The Wyze Sense product line offers a comprehensive professional home monitoring system with integrated leak and climate sensors designed to keep your home safe, comfortable, and well-monitored.
Wyze Sense Hub: The Central Brain of Your Home Monitoring System
At the heart of the Wyze Sense ecosystem is the
Wyze Sense Hub, the essential control center that connects all your sensors and devices seamlessly.
- Connectivity: Supports Ethernet, WiFi (802.11 b/g/n, 2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF communication.
- Range: Up to 500 feet (152 meters) to sensors, allowing flexible placement throughout your home.
- Battery: Built-in rechargeable 3.7V, 2600 mAh battery with 10 hours of backup power.
- Siren: Loud 88db alarm at 2 feet to alert you instantly.
- Capacity: Supports up to 100 sensors, making it scalable for large homes or multiple rooms.
- Design: Compact matte white base with a grey speaker top, measuring 4.5” x 4” x 1” (114.3 x 101.6 x 25.4 mm).
Included with the hub are power adapter, Ethernet cable, window decals, and a quick start guide to get your system up and running quickly.
The Wyze Sense Hub acts as the "brains behind the brawn," ensuring all your sensors communicate effectively and alerts reach you promptly.
Wyze Sense Climate Sensor: Monitor Temperature and Humidity Anywhere
Maintaining optimal climate conditions is crucial for comfort and protecting your home from moisture-related damage. The
Wyze Sense Climate Sensor is designed to track temperature and humidity levels in any room.
- Compatibility: Works exclusively with Wyze Sense v2 and the Wyze Sense Hub.
- Range: 500 feet RF range for placement in distant rooms, basements, or attics.
- Design: Sleek, unobtrusive matte white finish that blends into any environment.
- Mounting: Place on any surface or use peel-and-stick adhesive backing for wall mounting.
- Battery Life: Long-lasting CR2032 battery with up to 1.5 years of operation.
- Operating Conditions: Functions reliably between 32°F to 104°F (0°C to 40°C) and up to 85% humidity at 86°F.
This sensor helps you maintain a healthy indoor environment by providing real-time climate data accessible through the Wyze app.
Wyze Sense Leak Sensor & Probe: Early Leak Detection to Prevent Damage
Water leaks can cause significant damage if left unnoticed. The
Wyze Sense Leak Sensor & Probe offers peace of mind by alerting you immediately when leaks are detected.
- Compatibility: Requires Wyze Sense Hub and works with Wyze Sense v2 or Wyze Home Monitoring.
- Sensor Range: Up to 500 feet, allowing placement in hard-to-reach or vulnerable areas.
- Operating Range: 32°F to 104°F (0°C to 40°C) and up to 85% humidity at 86°F.
- Indoor Use: Designed specifically for indoor environments.
- Variants: Available in configurations with 2 probes or 3 sensors and 1 probe for versatile monitoring needs.
By integrating this sensor into your home monitoring system, you can catch leaks early and avoid costly repairs.
Additional Wyze Sense Sensors to Enhance Your Home Security
While the focus is on climate and leak detection, the Wyze Sense ecosystem also includes other sensors to complete your professional home monitoring setup:
- Wyze Sense Motion Sensor: Detects movement within a 25 ft range and 120° field of view. Adjustable sensitivity and up to 18 months battery life.
- Wyze Sense Entry Sensor: Monitors when doors or windows open or close, helping secure entry points.
- Wyze Sense Keypad: Allows remote arming and disarming of your security system with an emergency button for quick response.
These sensors integrate seamlessly with the Wyze Sense Hub, providing a comprehensive security and monitoring solution.
Why Choose Wyze Sense for Your Home Monitoring Needs?
Wyze Sense offers a professional-grade home monitoring system that is scalable, easy to install, and integrates advanced sensors for climate and leak detection. Its long-range communication, reliable battery life, and sleek design make it ideal for any home environment.
With Wyze Sense, you get:
- Centralized control with the Wyze Sense Hub.
- Precise climate monitoring to maintain comfort and prevent mold.
- Early leak detection to protect your home from water damage.
- Expandable sensor network for comprehensive security coverage.
- User-friendly app integration for real-time alerts and control.
Invest in a smart home monitoring system that goes beyond security to protect your home’s environment and infrastructure.
Summary of Wyze Sense Products for Home Monitoring
Product | Key Features | Price (USD) |
Wyze Sense Hub | Central hub, 500 ft range, 88db siren | 45.98 |
Wyze Sense Climate Sensor | Temperature & humidity, 1.5-year battery life | 41.98 (3 Pack) |
Wyze Sense Leak Sensor & Probe | Leak detection, up to 500 ft range | 13.98 - 55.98 |
Wyze Sense Motion Sensor | Motion detection, 25 ft range | 20.98 |
Wyze Sense Entry Sensor | Open/close detection | 41.98 (3 Pack) |
Wyze Sense Keypad | Remote arm/disarm, emergency button | 27.98 |
By choosing Wyze Sense, you equip your home with a professional, integrated monitoring system that safeguards your property and enhances your living environment.
What is the Wyze Sense professional home monitoring system?
The Wyze Sense professional home monitoring system is a comprehensive solution designed to secure your home and monitor environmental conditions. It features a central hub and a range of integrated sensors, including climate and leak sensors, to detect intrusions, track temperature and humidity, and provide early leak detection for enhanced safety and comfort.How does the Wyze Sense Hub work in a home monitoring system?
The Wyze Sense Hub acts as the central control center for your home monitoring system. It connects all Wyze Sense sensors and devices via Ethernet, WiFi, Bluetooth, and RF communication, supporting up to 100 sensors with a range of up to 500 feet. The hub features a built-in rechargeable battery for backup power and an 88db siren for instant alerts.What sensors are included in the Wyze Sense ecosystem?
The Wyze Sense ecosystem includes a variety of sensors: Climate Sensor (for temperature and humidity), Leak Sensor & Probe (for water leak detection), Motion Sensor (for movement detection), Entry Sensor (for monitoring doors and windows), and a Keypad (for remote arming/disarming and emergency alerts).How does the Wyze Sense Climate Sensor help maintain indoor comfort?
The Wyze Sense Climate Sensor monitors temperature and humidity levels in any room, helping you maintain a healthy and comfortable indoor environment. It provides real-time climate data through the Wyze app, allowing you to prevent moisture-related damage and optimize comfort.What is the range and battery life of Wyze Sense sensors?
Wyze Sense sensors have a wireless range of up to 500 feet from the hub, allowing flexible placement throughout your home. The Climate Sensor uses a CR2032 battery with up to 1.5 years of life, while the Motion Sensor offers up to 18 months of battery life.How does the Wyze Sense Leak Sensor & Probe protect against water damage?
The Wyze Sense Leak Sensor & Probe detects water leaks early and sends instant alerts to your phone via the Wyze app. With a 500-foot range and versatile placement options, it helps you catch leaks in vulnerable or hard-to-reach areas, preventing costly water damage.Are Wyze Sense sensors easy to install?
Yes, Wyze Sense sensors are designed for easy installation. The hub comes with a quick start guide, and sensors can be placed on any surface or mounted using peel-and-stick adhesive. The system is user-friendly and integrates seamlessly with the Wyze app for setup and control.Can I expand my Wyze Sense home monitoring system?
Absolutely. The Wyze Sense Hub supports up to 100 sensors, making it easy to expand your system as your needs grow. You can add more climate, leak, motion, and entry sensors to cover additional rooms or areas in your home.What are the benefits of using Wyze Sense for home security and monitoring?
Wyze Sense offers professional-grade security with centralized control, real-time climate and leak monitoring, long-range wireless communication, reliable battery life, and a sleek, unobtrusive design. It provides comprehensive protection for your home’s security and environmental health.Is the Wyze Sense system compatible with the Wyze app?
Yes, all Wyze Sense sensors and the hub integrate with the Wyze app, allowing you to receive real-time alerts, monitor sensor data, and control your home monitoring system from anywhere.
