Smart Doorbell Lock Systems with Fingerprint Sensor and Keypad
Enhance your home security with the latest smart doorbell lock systems that combine advanced fingerprint sensors, backlit keypads, and high-definition video doorbells. These integrated solutions offer convenience, safety, and seamless control right from your smartphone or via voice assistants. Whether you want to monitor your front porch or unlock your door with a touch, these products deliver cutting-edge technology tailored for modern smart homes.
Wyze Lock Bolt: Ultra-Fast Fingerprint Sensor & Keypad
Experience keyless entry like never before with the
Wyze Lock Bolt, a Bluetooth-enabled smart lock designed to replace your existing deadbolt. This lock features an ultra-fast fingerprint sensor and a backlit keypad with anti-peep technology, allowing you to unlock your door securely and effortlessly.
Key Features:
- Fingerprint Sensor: Unlock your door in less than a second with a simple touch.
- Backlit Keypad: Enter your code easily even in the dark, with anti-peep protection to keep your PIN safe.
- Auto-Lock Function: Never worry about forgetting to lock your door; it locks automatically.
- Lock History: Track who enters and exits your home via the Wyze app.
- Built-in Alarm: Detects jams and alerts you immediately.
- Emergency One-Time Codes: Provide temporary access to guests or service providers.
- Weather Resistant: Rated IPX5, suitable for various climates.
- Battery Life: Powered by 4 AA batteries lasting 10-12 months.
Available in Matte Black and Satin Nickel finishes, the Wyze Lock Bolt blends security with sleek design to complement any front door.
Secure your home with Wyze Lock Bolt’s fingerprint and keypad technology.
Wyze Video Doorbell v2: Crystal-Clear 2K Video & Smart Alerts
Complement your smart lock with the
Wyze Video Doorbell v2, a wired video doorbell that offers stunning 2K resolution and local microSD storage for continuous recording. This doorbell ensures you never miss a moment at your doorstep.
Highlights:
- 2K HD Video: Capture detailed head-to-toe views of visitors and packages.
- Local Storage: Continuous 24/7 recording with onboard microSD card slot.
- Two-Way Audio: Speak directly to visitors from anywhere using the Wyze app.
- Motion-Activated Voice Deterrence: Automatically warns unwanted visitors with a voice prompt.
- Pre-Roll Motion Recording: Records 3-6 seconds before motion events for full context.
- Weatherproof: IP65 rating to withstand rain, snow, and harsh weather.
- Night Vision: Award-winning starlight sensor for clear color night vision.
- Works with Alexa & Google Home: View live feeds and receive smart alerts on your voice assistant devices.
- Chime Controller Included: Retain your existing doorbell chime functionality.
For angled door frames or porches with stairs, the
Wyze Video Doorbell v2 Wedge Kit accessory allows you to adjust the viewing angle for maximum coverage and eliminate blind spots.
Monitor your front porch with Wyze Video Doorbell v2’s sharp 2K video.
The Front Porch Security Bundle: All-in-One Smart Security Solution
For a comprehensive smart home entry system, the
Front Porch Security Bundle combines the Wyze Lock Bolt with the Wyze Video Doorbell v2 or Pro, offering seamless integration and control from a single app.
Bundle Benefits:
- Remote Lock/Unlock: Control your door lock remotely and view lock history.
- 1080p or 2K Video Doorbell: Choose between the Wyze Video Doorbell v2 or the Pro model for HD video monitoring.
- Two-Way Audio: Communicate with visitors instantly.
- Smart Notifications: Receive alerts for motion, packages, and people.
- Easy Integration: Manage both lock and doorbell from the Wyze app.
- Voice Assistant Compatibility: Works with Alexa and Google Assistant for hands-free control.
This bundle is perfect for those who want a unified, smart front porch security system with fingerprint access and video monitoring.
Wyze Video Doorbell Pro: Wider View & Wireless Convenience
Upgrade to the
Wyze Video Doorbell Pro for a wider viewing angle and flexible power options. This battery-powered doorbell installs in 30 seconds and offers HD video with smart detection alerts.
Features:
- Ultra-Wide Viewing Angle: Capture more of your porch and surroundings.
- Battery or Hardwired: Choose wireless convenience or wired power.
- Motion-Activated Security Light: Enhances visibility and deters intruders.
- Smart Detection: Person, package, vehicle, and pet detection with Cam Plus subscription.
- Two-Way Audio & Quick Responses: Communicate with visitors easily.
- Customizable Chime: 20 unique tunes and 8 sound levels.
- Unlock Integration: Works seamlessly with Wyze Lock Bolt for remote door unlocking.
This doorbell is ideal for users seeking a versatile, high-performance video doorbell with smart lock compatibility.
Why Choose a Smart Doorbell Lock System with Fingerprint Sensor and Keypad?
Combining biometric access with video monitoring enhances your home’s security and convenience. You can grant access without keys, monitor visitors in real-time, and receive instant alerts—all controlled from your smartphone or voice assistant.
Summary
For a smart doorbell lock system featuring fingerprint sensors and keypad access, the
Wyze Lock Bolt paired with the
Pro offers an unbeatable combination of security, convenience, and smart home integration. The
Front Porch Security Bundle provides an all-in-one solution for seamless control and monitoring. Accessories like the
Wedge Kit ensure perfect installation angles for optimal coverage.
Secure your home with these advanced smart devices and enjoy peace of mind with effortless access and vigilant monitoring.
What is a smart doorbell lock system with fingerprint sensor and keypad?
A smart doorbell lock system with fingerprint sensor and keypad combines advanced biometric access, a backlit keypad, and a high-definition video doorbell. This integrated solution allows you to unlock your door with a fingerprint or PIN code, monitor your front porch in real-time, and control everything from your smartphone or voice assistant for enhanced home security and convenience.What are the main features of the Wyze Lock Bolt smart lock?
The Wyze Lock Bolt features an ultra-fast fingerprint sensor for keyless entry, a backlit keypad with anti-peep technology, auto-lock function, lock history tracking via the Wyze app, a built-in alarm for jam detection, emergency one-time codes for guests, weather resistance (IPX5), and a battery life of 10-12 months using 4 AA batteries.How does the Wyze Video Doorbell v2 enhance home security?
The Wyze Video Doorbell v2 offers 2K HD video for clear head-to-toe views, local microSD storage for continuous 24/7 recording, two-way audio to communicate with visitors, motion-activated voice deterrence, pre-roll motion recording, weatherproof IP65 rating, award-winning starlight night vision, and compatibility with Alexa and Google Home for smart alerts and live feeds.What is included in the Front Porch Security Bundle?
The Front Porch Security Bundle includes the Wyze Lock Bolt smart lock and your choice of Wyze Video Doorbell v2 or Pro. This bundle allows for remote lock/unlock, HD video monitoring, two-way audio, smart notifications for motion and packages, easy integration through the Wyze app, and voice assistant compatibility for hands-free control.What are the benefits of using a fingerprint sensor on a smart lock?
Using a fingerprint sensor on a smart lock provides ultra-fast, secure, and keyless entry. It eliminates the need for physical keys or remembering PIN codes, reduces the risk of unauthorized access, and allows you to unlock your door in less than a second with just a touch.Can I control the Wyze Lock Bolt and Video Doorbell from my smartphone?
Yes, both the Wyze Lock Bolt and Wyze Video Doorbell can be controlled and monitored from the Wyze app on your smartphone. You can unlock your door, view lock history, watch live video feeds, communicate with visitors, and receive instant security alerts.Is the Wyze Lock Bolt weather resistant?
Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance, making it suitable for various climates and outdoor installation.What is the battery life of the Wyze Lock Bolt?
The Wyze Lock Bolt is powered by 4 AA batteries, which typically last between 10 to 12 months depending on usage.Does the Wyze Video Doorbell v2 support local video storage?
Yes, the Wyze Video Doorbell v2 features a microSD card slot for local storage, allowing for continuous 24/7 video recording without relying solely on cloud storage.What is the difference between Wyze Video Doorbell v2 and Pro?
The Wyze Video Doorbell v2 offers 2K HD video, local storage, and wired installation, while the Wyze Video Doorbell Pro provides a wider viewing angle, wireless (battery-powered) or wired installation, motion-activated security light, and advanced smart detection features with Cam Plus subscription.Can I integrate Wyze smart doorbell and lock systems with Alexa or Google Home?
Yes, Wyze smart doorbell and lock systems are compatible with Alexa and Google Home, allowing you to view live video feeds, receive smart alerts, and control your devices using voice commands.What is the purpose of the Wyze Video Doorbell v2 Wedge Kit?
The Wyze Video Doorbell v2 Wedge Kit is an accessory that allows you to adjust the viewing angle of your doorbell camera, making it ideal for angled door frames or porches with stairs to eliminate blind spots and maximize coverage.How does the auto-lock function work on the Wyze Lock Bolt?
The auto-lock function on the Wyze Lock Bolt automatically locks your door after a set period, ensuring your home remains secure even if you forget to lock it manually.Can I provide temporary access to guests with the Wyze Lock Bolt?
Yes, the Wyze Lock Bolt allows you to generate emergency one-time codes, enabling you to provide temporary access to guests or service providers without sharing your main PIN or fingerprint.What finishes are available for the Wyze Lock Bolt?
The Wyze Lock Bolt is available in Matte Black and Satin Nickel finishes, allowing you to choose the style that best matches your front door.
