Smart Cameras with Separate Control for Spotlight and Camera Power
When it comes to securing your home with smart cameras, having separate control for the spotlight and camera power offers unmatched flexibility and convenience. Whether you want to illuminate your property only when needed or manage camera power independently, the right smart camera system can make all the difference. Below, we explore the top Wyze products designed to give you this level of control and smart home integration.
Pan v3 + Lamp Socket v2 Bundle: Power and Control Without Outlets
Flexible Power Solution for Wyze Cam Pan v3
The
Pan v3 + Lamp Socket v2 Bundle is a game-changer for outdoor security setups. This bundle allows you to power the Wyze Cam Pan v3 directly from your existing outdoor lamp socket, eliminating the need for additional outlets or unsightly wiring.
- Seamless Power Integration: The Lamp Socket v2 harnesses electricity from your outdoor light fixture to power the Pan v3 camera continuously.
- No Extra Wiring: Installation is as simple as screwing in a lightbulb, making it safe and hassle-free.
- Smart Lighting Control: Control your outdoor lights and camera independently through the Wyze app, enabling motion-activated lighting and scheduling.
- Compatibility: Works with Wyze Cam v3, v3 Pro, v4, Cam OG, OG Tele, and Cam Pan v3.
- Dusk to Dawn Automation: Automatically turns lights on at dusk and off at dawn, saving energy and enhancing security.
This bundle is perfect for those who want to upgrade their existing outdoor lighting into a smart security system with separate control over the camera and spotlight power.
Wyze Cam Spotlight Bundle: Integrated Spotlight with Camera Control
Motion-Activated Spotlight and Camera in One
The
Wyze Cam Spotlight Bundle combines a high-quality Wyze Cam v3 with a dedicated motion-activated spotlight, both controllable independently for ultimate security customization.
- Spotlight Brightness: 70 lumens of powerful illumination to deter intruders and light up dark areas.
- Separate Power Controls: Manage the spotlight and camera power separately via the Wyze app, giving you precise control over your security setup.
- Weather Resistant: IP65 rating ensures reliable performance in rain, snow, or dust.
- 1080p HD Video: Clear video with a 120° diagonal viewing angle and night vision capabilities.
- Two-Way Audio & Siren: Communicate through the camera and sound an 80 dB siren if needed.
- Easy Installation: Includes wall mount plates and cables for quick setup.
This bundle is ideal for users who want a dedicated spotlight that can be turned on or off independently from the camera, enhancing both security and energy efficiency.
Wyze Plug Outdoor: Smart Power Control for Your Outdoor Devices
Independent Control for Multiple Outdoor Devices
For those looking to control outdoor lighting or other devices separately from their cameras, the
Wyze Plug Outdoor offers a versatile solution.
- Two Outlets, Two Controls: Each outlet can be controlled independently, allowing you to power your spotlight and camera separately.
- Extended Wi-Fi Range: Up to 300 feet in open space, so you can place plugs almost anywhere outdoors.
- Energy Monitoring: Track energy consumption and set alerts to optimize power usage.
- Weather Resistant: IP64 rating protects against rain, dust, and snow.
- Voice and App Control: Compatible with Alexa and Google Assistant for hands-free operation.
Pairing the Wyze Plug Outdoor with your smart camera setup gives you the freedom to manage power for spotlights and cameras independently, perfect for complex outdoor security systems.
Wyze Bulb Cam: 2-in-1 Security Camera and Smart LED Light Bulb
Integrated Camera and Spotlight with Smart Controls
The
Wyze Bulb Cam is a unique smart camera that doubles as an LED light bulb, offering both surveillance and illumination from a single fixture.
- 2K HD Video with Color Night Vision: Capture clear footage day and night with a wide 160° field of view.
- Smart Lighting Controls: Control the light manually, via motion activation, ambient light sensing, or scheduling.
- Separate Spotlight Control: Adjust lighting independently from the camera’s power, all through the Wyze app.
- Easy Installation: Fits standard E26 sockets, making it a perfect upgrade for existing outdoor light fixtures.
- Weather Resistant: IP65 rating ensures durability in outdoor environments.
- Two-Way Audio & Siren: Built-in microphone and speaker for communication and deterrence.
This product is perfect for users who want a compact, all-in-one solution with separate control over lighting and camera functions.
Why Choose Smart Cameras with Separate Spotlight and Camera Power Control?
Having separate control over your spotlight and camera power means you can customize your security system to fit your lifestyle and needs. Turn on the spotlight only when necessary to save energy, or keep the camera running continuously for 24/7 surveillance. This flexibility enhances security, convenience, and energy efficiency.
Summary of Top Products for Separate Spotlight and Camera Power Control
Product | Spotlight Control | Camera Power Control | Weather Resistant | Video Resolution | Special Features |
Pan v3 + Lamp Socket v2 Bundle | Yes | Yes | Yes (IP65) | 1080p HD | Powers camera via lamp socket |
Wyze Cam Spotlight Bundle | Yes | Yes | Yes (IP65) | 1080p HD | Motion-activated spotlight |
Wyze Plug Outdoor | Yes (via plug) | Yes (via plug) | Yes (IP64) | N/A | Two outlets with independent control |
Wyze Bulb Cam | Yes | Yes | Yes (IP65) | 2K HD | Camera + smart LED bulb combo |
Wyze Bulb Cam installed in outdoor light fixture for smart security and lighting
Motion-activated lighting and security with Wyze Bulb Cam at night
With these smart camera options, you can enjoy the convenience of separate spotlight and camera power control, enhancing your home security while optimizing energy use. Choose the product that best fits your outdoor setup and start securing your home smarter today!
What are the benefits of smart cameras with separate spotlight and camera power control?
Smart cameras with separate spotlight and camera power control offer enhanced flexibility, allowing you to customize your security system. You can turn on the spotlight only when needed to save energy, while keeping the camera running for continuous surveillance. This setup improves security, convenience, and energy efficiency.How does the Wyze Pan v3 + Lamp Socket v2 Bundle work for outdoor security?
The Wyze Pan v3 + Lamp Socket v2 Bundle powers your Wyze Cam Pan v3 directly from your existing outdoor lamp socket, eliminating the need for extra outlets or wiring. It allows you to control your outdoor lights and camera independently through the Wyze app, supports dusk-to-dawn automation, and is compatible with several Wyze camera models.Can I control the spotlight and camera separately with the Wyze Cam Spotlight Bundle?
Yes, the Wyze Cam Spotlight Bundle allows you to manage the spotlight and camera power independently via the Wyze app. This means you can customize when the spotlight is on without affecting the camera’s operation, enhancing both security and energy efficiency.What devices are compatible with the Wyze Lamp Socket v2?
The Wyze Lamp Socket v2 is compatible with Wyze Cam v3, v3 Pro, v4, Cam OG, OG Tele, and Cam Pan v3, making it a versatile solution for various Wyze camera models.How does the Wyze Plug Outdoor help with separate power control for cameras and spotlights?
The Wyze Plug Outdoor features two independently controlled outlets, allowing you to power your spotlight and camera separately. It offers extended Wi-Fi range, energy monitoring, weather resistance, and can be controlled via the Wyze app, Alexa, or Google Assistant.What features does the Wyze Bulb Cam offer for security and lighting?
The Wyze Bulb Cam is a 2-in-1 device that combines a 2K HD security camera with a smart LED light bulb. It offers separate control for lighting and camera functions, color night vision, motion-activated lighting, two-way audio, a built-in siren, and easy installation in standard E26 sockets.Are Wyze smart camera products weather resistant for outdoor use?
Yes, most Wyze smart camera products designed for outdoor use, such as the Pan v3 + Lamp Socket v2 Bundle, Wyze Cam Spotlight Bundle, and Wyze Bulb Cam, have IP65 weather resistance. The Wyze Plug Outdoor is rated IP64, making them suitable for rain, snow, and dust.Can I use voice assistants to control Wyze smart cameras and plugs?
Yes, Wyze Plug Outdoor is compatible with Alexa and Google Assistant, allowing you to control your outdoor devices, including cameras and spotlights, using voice commands for added convenience.What is the video resolution of Wyze smart cameras with separate spotlight control?
Wyze Cam Spotlight Bundle and Pan v3 + Lamp Socket v2 Bundle offer 1080p HD video resolution, while the Wyze Bulb Cam provides 2K HD video with a wide 160° field of view and color night vision.How easy is it to install Wyze smart cameras and accessories?
Wyze smart cameras and accessories are designed for easy installation. The Lamp Socket v2 installs like a regular lightbulb, the Wyze Bulb Cam fits standard E26 sockets, and the Wyze Cam Spotlight Bundle includes wall mount plates and cables for quick setup.
