Best Home Security Cameras with Scheduled Spotlight Privacy
Best Home Security Cameras with Scheduled Spotlight Rules for Privacy
When it comes to securing your home, having a security camera that offers scheduled spotlight rules is essential for maintaining privacy while ensuring safety. Spotlight scheduling allows you to control when the camera’s bright lights activate, preventing unwanted illumination during private moments and enhancing security when needed. Below, we explore top Wyze home security cameras that feature advanced spotlight controls, perfect for privacy-conscious homeowners.
Wyze Cam v4 – Advanced Spotlight with Privacy Scheduling
Experience crystal-clear security with the Wyze Cam v4, a versatile wired camera designed for both indoor and outdoor use. It features a powerful motion-activated spotlight that can be scheduled to turn on only during specific times, giving you full control over your privacy.
Key Features:
  • 2.5K QHD Resolution for sharp, detailed video day and night.
  • Enhanced Color Night Vision with 4 IR LEDs plus 2 white spotlight LEDs (72 lumens).
  • Motion-Activated Spotlight with customizable schedules to protect your privacy.
  • Wi-Fi 6 Support ensures fast, reliable connectivity.
  • 24/7 Local Recording with microSD card support up to 512 GB.
  • Smart Assistant Integration with Alexa, Google Assistant, and IFTTT.
  • Multiple Mounting Options including magnetic wall mount for flexible installation.
  • Weather Resistant (IP65) for reliable outdoor use.
This camera’s spotlight scheduling lets you define when the light activates, so you can avoid unnecessary illumination during private hours while still deterring intruders when you want.
Wyze Battery Cam Pro – Wire-Free Spotlight with Smart Scheduling
For those seeking a wireless solution, the Wyze Battery Cam Pro offers a spotlight with scheduling capabilities combined with the freedom of wire-free installation.
Highlights:
  • 2.5K HDR Video Resolution with vivid color and clarity.
  • Integrated Spotlight & Siren that can be scheduled to activate only during your chosen times.
  • Radar + PIR Motion Detection for precise alerts and spotlight triggers.
  • Up to 6 Months Battery Life with removable, rechargeable 6200mAh battery packs.
  • Dual-Band Wi-Fi Support (2.4 & 5 GHz) for stable connections.
  • IP65 Weatherproof design for all-season outdoor use.
  • Smart Home Compatibility with Alexa, Google Assistant, and IFTTT.
The Battery Cam Pro’s spotlight scheduling ensures your privacy is respected while maintaining high security, especially in areas where wiring is impractical.
Wyze Cam Floodlight v2 – Powerful Lighting with AI-Powered Scheduling
If you want to dominate the dark with bright, smart lighting, the Wyze Cam Floodlight v2 is a wired floodlight camera that offers scheduled spotlight rules combined with AI-powered light control. Wyze Cam Floodlight v2 illuminating driveway at night Bright, AI-controlled floodlight for home security
Features:
  • 2800 Lumens of Bright LED Light with two dimmable panels.
  • 2K Video with Color Night Vision and a wide 160° diagonal field of view.
  • AI-Powered Light Control that activates lights only for selected objects like people or vehicles.
  • Dusk-to-Dawn Automation and customizable spotlight schedules for privacy.
  • 105dB Siren and two-way audio for active deterrence.
  • IP65 Weather Resistance for reliable outdoor performance.
  • Supports up to 256 GB microSD local storage and integrates with Alexa, Google Assistant, and IFTTT.
This floodlight camera’s intelligent scheduling and AI detection make it ideal for homeowners who want bright security lighting without compromising privacy.
Wyze Bulb Cam – Discreet Spotlight with Scheduling in a Light Bulb
For a subtle security solution, the Wyze Bulb Cam combines a 2-in-1 outdoor security camera and smart LED light bulb with scheduled spotlight control. Wyze Bulb Cam installed in outdoor light fixture Discreet security camera and smart bulb with scheduling
What Makes It Stand Out:
  • 2K HD Video with Color Night Vision for clear monitoring.
  • Up to 800 Lumens Brightness with adjustable color temperature (3000K).
  • Motion-Activated Light with Scheduling to control when the spotlight turns on.
  • Fits Standard E26 Socket for easy installation in most fixtures.
  • Local Storage Support up to 256 GB microSD card, no subscription needed.
  • IP65 Weatherproof for outdoor use.
  • Two-Way Audio and 95 dB Siren for communication and deterrence.
  • Smart Controls including manual, motion-activated, ambient light, and schedule modes.
The Bulb Cam is perfect for those who want a low-profile camera with spotlight scheduling integrated into their existing outdoor lighting.
Wyze Cam OG – Affordable Spotlight Camera with Scheduling
The Wyze Cam OG is a budget-friendly option that still offers a built-in spotlight with scheduling capabilities to protect your privacy.
Features:
  • 1080p Full HD Video with 120° field of view.
  • Built-in 40 Lumen Spotlight that can be scheduled to activate only when needed.
  • 3X Faster Notifications and improved two-way audio.
  • Supports up to 256 GB microSD local storage.
  • IP65 Weather Resistance for indoor/outdoor use.
  • Smart Home Integration with Alexa, Google Assistant, and IFTTT.
  • User-Activated 90 dB Siren for added security.
This camera is ideal for those who want reliable spotlight scheduling without breaking the bank.
Wyze Cam Floodlight Pro – AI-Driven Spotlight with Wide-Angle Coverage
For the ultimate in smart floodlight security with scheduled spotlight rules, the Wyze Cam Floodlight Pro offers advanced AI detection and powerful lighting. Wyze Cam Floodlight Pro with bright security lighting AI-powered floodlight camera with scheduled spotlight control
Top Features:
  • 2.5K QHD Video with Color Night Vision and 180° wide-angle lens.
  • 3,000 Lumens of Adjustable LED Brightness with 3 dimmable light panels.
  • AI Computer Vision to detect people, vehicles, and more, triggering spotlight only for selected objects.
  • Scheduled Spotlight Rules and dusk-to-dawn automation for privacy and convenience.
  • 105 dB Siren and two-way audio for active home defense.
  • Dual-Band Wi-Fi (2.4 & 5 GHz) for reliable connectivity.
  • IP65 Weatherproof and supports up to 256 GB microSD local storage.
  • Works with Alexa, Google Assistant, and IFTTT.
This floodlight camera is perfect for homeowners who want a smart, powerful security light that respects privacy through customizable spotlight scheduling.
Why Choose Scheduled Spotlight Rules for Your Home Security?
Scheduled spotlight rules allow you to balance security and privacy by controlling when your camera’s bright lights activate. This prevents unwanted illumination during private times, reduces light pollution, and ensures your home is only spotlighted when necessary to deter intruders.
All the Wyze cameras listed above support scheduled spotlight or light rules, giving you peace of mind and control over your home’s security lighting.
Summary Table of Spotlight-Enabled Wyze Cameras
ModelSpotlight TypeVideo ResolutionWirelessWeatherproofSpotlight SchedulingSmart Assistant Integration
Wyze Cam v4Motion-Activated LED2.5K QHDNoIP65YesAlexa, Google, IFTTT
Wyze Battery Cam ProIntegrated Spotlight2.5K HDRYesIP65YesAlexa, Google, IFTTT
Wyze Cam Floodlight v22800 Lumens LED Panels2K Color NightNoIP65Yes (AI-powered)Alexa, Google, IFTTT
Wyze Bulb CamSmart LED Bulb2K HDNoIP65YesAlexa, Google
Wyze Cam OGBuilt-in 40 Lumen LED1080p HDNoIP65YesAlexa, Google, IFTTT
Wyze Cam Floodlight Pro3000 Lumens LED Panels2.5K QHDNoIP65Yes (AI-powered)Alexa, Google, IFTTT
Protect your home with confidence and privacy by choosing a Wyze security camera with scheduled spotlight rules. Whether you prefer wired or wireless, floodlight or bulb cam, Wyze offers a solution tailored to your needs.
# Product Tags Summary
FeatureWyze Cam v4Wyze Cam Floodlight ProWyze Cam Floodlight v2Wyze Bulb CamWyze Cam OGWyze Battery Cam Pro
Video Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2K (2304x1296)2K (2304x1296)1080p (1920x1080)2.5K (2560x1440)
Field of View (Diagonal)115.8°180°160°166°120°134° (DFOV)
Night Vision4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens), Color Night VisionColor Night VisionColor Night VisionColor Night Vision + IR Night Vision4 IR LEDs (850 nm)2 IR LEDs (850 nm), 2 White LEDs (5500K, 187 lumens)
AudioBuilt-in speaker (99dB, waterproof), Two-way talk, Built-in sirenSiren 105dB, Two-way audioSiren 105dB, Two-way audioSiren 95dB, Two-way audioBuilt-in speaker & microphone, Noise & Echo Cancellation, Two-way audioTwo-way audio with built-in speaker and microphone, Siren 100 dB SPL
Connectivity2.4 GHz Wi-Fi, Wi-Fi 6, Bluetooth 5.22.4 & 5 GHz dual-band Wi-Fi2.4 GHz Wi-Fi2.4 GHz Wi-Fi2.4 GHz Wi-Fi2.4 & 5 GHz Wi-Fi
Power SourceWired (Indoor 5V/1A adapter)Hardwired 110-120V ACHardwired 110-120V AC120V AC (Standard E26 Socket)Wired (Indoor 5V/1A adapter)Removable, Rechargeable Battery Packs
Weather ResistanceIP65IP65IP65IP65IP65IP65
Dimensions2in x 2in x 2 3/8in10.2in x 9.1in x 7.8in9.5in x 7.7in x 7.0inNot specified1.89in x 1.89in x 1.89in2.5in x 1.8in x 3.5in
Weight0.49 lb (222 g)2.9 lbs (1.32 kg)2.76 lbs (1.25 kg)Not specified4.1 oz (116 g)0.94 lbs
Mounting OptionsStand, Wall, Ceiling, Magnetic wall mount (adhesive)Wall, CeilingWall, CeilingStandard bulb socket (E26)Stand, Wall, CeilingWall mount included, 1/4" - 20 standard
Local StoragemicroSD up to 512 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GB
Cloud StorageSubscription plan requiredSubscription plan requiredSubscription plan requiredStored in AWS cloudSubscription plan requiredSubscription plan required
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Special FeaturesEnhanced Color Night Vision, Motion-activated spotlight, 24/7 local recordingAI computer vision, 3000 lumen adjustable LED lights, motion detection by object typeAI-Powered Light Control, Ambient Light Mode, dusk-to-dawn automation2-in-1 camera and smart LED bulb, motion-activated light, ambient light, schedulingBuilt-in spotlight (40 lumens), 3X faster notifications, smoke and CO alertsWire-free, no hub required, radar + PIR motion detection, removable battery, up to 6 months battery life
Price (approx.)$107.94 (varies by pack)$149.98$89.98$49.98$29.98 (single pack)$159.98 (single pack)
Warranty1 Year1 Year1 Year1 Year1 Year1 Year
What are scheduled spotlight rules in home security cameras?Scheduled spotlight rules allow you to control when your security camera’s spotlight or bright lights activate. This feature helps maintain privacy by preventing unwanted illumination during private times and ensures your home is only spotlighted when necessary to deter intruders.
Which Wyze security cameras support scheduled spotlight rules?Wyze offers several security cameras with scheduled spotlight rules, including Wyze Cam v4, Wyze Battery Cam Pro, Wyze Cam Floodlight v2, Wyze Bulb Cam, Wyze Cam OG, and Wyze Cam Floodlight Pro. All these models allow you to customize when the spotlight activates for enhanced privacy and security.
How does spotlight scheduling enhance privacy with Wyze cameras?Spotlight scheduling lets you define specific times for the camera’s lights to turn on or off. This prevents unnecessary illumination during private moments, reduces light pollution, and ensures the spotlight is only used when needed for security.
Can I use Wyze security cameras with scheduled spotlight rules outdoors?Yes, all the Wyze cameras listed, including Wyze Cam v4, Wyze Battery Cam Pro, Wyze Cam Floodlight v2, Wyze Bulb Cam, Wyze Cam OG, and Wyze Cam Floodlight Pro, are IP65 weatherproof and suitable for outdoor use.
Do Wyze security cameras with scheduled spotlight rules support smart home integration?Yes, Wyze security cameras with scheduled spotlight rules are compatible with popular smart home platforms such as Alexa, Google Assistant, and IFTTT, allowing for seamless integration and voice control.
What is the difference between AI-powered and standard spotlight scheduling in Wyze cameras?AI-powered spotlight scheduling, available in models like Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro, uses artificial intelligence to activate the spotlight only for selected objects, such as people or vehicles. Standard scheduling allows you to set specific times for the spotlight to turn on or off, regardless of detected objects.
Which Wyze camera is best for wireless installation with scheduled spotlight rules?The Wyze Battery Cam Pro is the best option for wireless installation. It features a wire-free design, integrated spotlight with scheduling, and up to 6 months of battery life, making it ideal for areas where wiring is impractical.
Is there a discreet Wyze security camera with scheduled spotlight control?Yes, the Wyze Bulb Cam is a discreet option that combines a security camera and smart LED bulb. It fits standard E26 sockets and offers scheduled spotlight control, making it perfect for subtle security in existing outdoor light fixtures.
What is the most affordable Wyze camera with spotlight scheduling?The Wyze Cam OG is the most budget-friendly option with a built-in 40 lumen spotlight and scheduling capabilities, providing reliable security and privacy without a high price tag.
How much local storage do Wyze cameras with scheduled spotlight rules support?Wyze cameras with scheduled spotlight rules support local storage via microSD cards, with capacities up to 256 GB or 512 GB depending on the model. This allows for 24/7 recording without a subscription.
What are the key features of the Wyze Cam v4?Can you explain how the spotlight scheduling works on the Wyze cameras?Do you have any ongoing sales or discounts for Wyze cameras?
