Neutral Required Smart Light Switch for Smart Bulbs – Wyze
If you're looking to upgrade your home lighting with a neutral wire required smart light switch that can seamlessly control your smart bulbs, the Wyze Switch is the perfect solution. Designed to work flawlessly with Wyze Bulbs and other smart devices, this switch lets you turn your smart bulbs on and off with ease, while maintaining power to the bulbs to keep automations intact.
Wyze Switch: The Ultimate Smart Light Switch with Neutral Wire
Smart Control for Your Smart Bulbs
The Wyze Switch is engineered specifically to work with smart bulbs, including the Wyze Bulb Color. Unlike traditional switches that cut power completely, the Wyze Switch uses Smart Control mode to toggle your smart bulbs on or off without interrupting their power supply. This means your bulbs stay connected and ready for automations, voice commands, and app control.
Key Features:
  • Neutral wire required for stable and reliable installation.
  • Control your lights from anywhere using the Wyze app.
  • Multi-tap functionality to control other Wyze devices like cameras, locks, and robot vacuums.
  • Create schedules, timers, and automations to fit your lifestyle.
  • Vacation Mode simulates occupancy when you're away.
  • Power Loss Recovery automatically restores your settings after outages.
  • Easy installation with clear instructions.
Why Choose Wyze Switch?
The Wyze Switch is affordable and integrates perfectly into the Wyze ecosystem, making it a smart choice for anyone wanting to upgrade their home lighting with smart bulbs. Wyze Switch in Kitchen Lifestyle Smart light switch controlling kitchen lighting with voice assistants
Wyze Bulb Color: Perfect Companion for Wyze Switch
Brilliant 16 Million Colors and Tunable White
Pair your Wyze Switch with the Wyze Bulb Color to unlock the full potential of smart lighting. This bulb offers an impressive 16 million colors and a tunable white range from 1800K to 6500K, allowing you to customize your lighting ambiance for any mood or occasion.
Features:
  • Brightness up to 1100 lumens for vivid illumination.
  • Compatible with Alexa, Google Assistant, and IFTTT for voice and automation control.
  • Dimmable without needing a separate dimmer switch.
  • Suitable for damp locations, perfect for kitchens, bathrooms, and covered outdoor areas.
  • Long lifespan of 25,000 hours ensures years of use.
  • Operates on standard E26 base fitting.
Enhance Your Smart Home Lighting
With the Wyze Bulb Color and Wyze Switch combo, you get a seamless smart lighting experience that’s easy to control via app or voice, with the reliability of a neutral wire switch that keeps your bulbs powered and ready. Wyze Bulb Color in Living Room Vibrant smart bulb color lighting in a cozy living room setting
Why Neutral Wire Matters for Smart Switches
Many smart switches require a neutral wire to function properly. The neutral wire provides a return path for the current, allowing the switch to stay powered even when the light is off. This is especially important when controlling smart bulbs, as cutting power completely can disable the bulb’s smart features and automations. The Wyze Switch requires a neutral wire, ensuring:
  • Stable power delivery to smart bulbs.
  • Continuous connectivity for automations and remote control.
  • Compatibility with a wide range of smart bulbs, including Wyze Bulb Color.
Additional Smart Lighting Options: Wyze Light Strip
For accent lighting that complements your smart bulbs and switch, consider the Wyze Light Strip. It offers brilliant LED accent lighting with easy app control and voice assistant compatibility.
Highlights:
  • Available in 16.4 ft and 32.8 ft lengths.
  • 16 million colors with customizable zones.
  • Easy adhesive backing for versatile mounting.
  • Music sync feature using built-in microphone.
  • Indoor use only.
This strip is perfect for under cabinets, behind sofas, or anywhere you want to add vibrant, customizable lighting.
Summary
For a neutral wire required smart light switch that works flawlessly with smart bulbs, the Wyze Switch is your best choice. It keeps your smart bulbs powered, supports multi-device control, and integrates seamlessly with the Wyze ecosystem. Pair it with the Wyze Bulb Color for stunning, customizable lighting that you can control from anywhere. Upgrade your home lighting today with Wyze’s smart switch and bulbs for a smarter, more connected living space.
FeatureWyze SwitchWyze Bulb Color
TypeConnected Home - Smart Light SwitchSmart Lighting - Smart Color Bulb
ControlWiFi light switch, app control, multi-tap for other Wyze devicesApp control, voice control (Alexa, Google Assistant)
Smart FeaturesTimers, schedules, vacation mode, power loss recovery, custom actions (single, double, triple press, press-and-hold)16 million colors, dimmable, custom presets, white light temperature control, sleep routines, music mode, vacation mode
IntegrationWorks with Wyze ecosystem devices (Cams, Lock, Robot Vacuum, Sprinkler Controller)Works with Wyze app, groups with Wyze Light Strip and other bulbs
InstallationEasy to installStandard bulb installation (E26 base)
ConnectivityWiFiWiFi (802.11 b/g/n 2.4GHz), Bluetooth
PowerWired switch9.5 watts
Size/Pack Options1 Pack ($14.99), 3 Pack ($41.98)2 Pack ($26.26), 4 Pack ($44.44), 6 Pack ($64.98)
Special FeaturesSmart Control mode for Wyze Bulbs to keep power and automations intactBrightness up to 1100 lumens, 90+ CRI, color notifications
CompatibilityControls Wyze devices and normal lightsCompatible with Wyze app, Alexa, Google Assistant, IFTTT
Return Policy30-day hassle-free returns30-day hassle-free returns
What is a neutral wire required smart light switch?A neutral wire required smart light switch is a switch that needs a neutral wire in your wall for installation. The neutral wire provides a return path for electrical current, allowing the switch to stay powered even when the light is off. This is essential for smart switches like the Wyze Switch, as it ensures stable power delivery and keeps smart bulbs connected for automations and remote control.
Why does the Wyze Switch require a neutral wire?The Wyze Switch requires a neutral wire to maintain continuous power to your smart bulbs, even when the switch is off. This allows your bulbs to stay connected to your smart home system, enabling automations, voice commands, and app control without interruption.
Can the Wyze Switch control smart bulbs without cutting power?Yes, the Wyze Switch is designed with Smart Control mode, which toggles your smart bulbs on or off without cutting their power supply. This ensures your bulbs remain connected and ready for automations, voice commands, and app control.
Is the Wyze Switch compatible with other Wyze devices?Absolutely. The Wyze Switch features multi-tap functionality, allowing you to control other Wyze devices such as cameras, locks, and robot vacuums directly from the switch.
What are the key features of the Wyze Switch?Key features of the Wyze Switch include: neutral wire required for installation, remote control via the Wyze app, multi-tap support for controlling other Wyze devices, scheduling and automation options, Vacation Mode for simulating occupancy, Power Loss Recovery, and easy installation with clear instructions.
What makes the Wyze Bulb Color a good companion for the Wyze Switch?The Wyze Bulb Color pairs perfectly with the Wyze Switch, offering 16 million colors, tunable white light from 1800K to 6500K, up to 1100 lumens of brightness, voice assistant compatibility, dimmability, and a long lifespan. Together, they provide a seamless and customizable smart lighting experience.
Can I control my Wyze smart lighting from anywhere?Yes, you can control your Wyze Switch and Wyze Bulb Color from anywhere using the Wyze app. This allows you to turn lights on or off, adjust brightness, change colors, and set schedules remotely.
Is the Wyze Bulb Color compatible with voice assistants?Yes, the Wyze Bulb Color works with Alexa, Google Assistant, and IFTTT, allowing you to control your lighting with voice commands and integrate with other smart home automations.
What is Vacation Mode on the Wyze Switch?Vacation Mode is a feature on the Wyze Switch that simulates occupancy by automatically turning your lights on and off while you're away, helping to deter potential intruders.
What happens to my settings if there is a power outage?The Wyze Switch features Power Loss Recovery, which automatically restores your previous settings after a power outage, ensuring your smart lighting setup remains consistent.
Are there other smart lighting options from Wyze?Yes, Wyze also offers the Wyze Light Strip, which provides vibrant LED accent lighting with 16 million colors, customizable zones, music sync, and easy app and voice assistant control. It's available in 16.4 ft and 32.8 ft lengths and is ideal for indoor accent lighting.
Where can I install the Wyze Bulb Color?The Wyze Bulb Color is suitable for use in kitchens, bathrooms, covered outdoor areas, and other damp locations. It fits standard E26 base sockets and offers a long lifespan of up to 25,000 hours.
Do I need a separate dimmer switch for the Wyze Bulb Color?No, the Wyze Bulb Color is dimmable through the Wyze app or voice assistants, so you do not need a separate dimmer switch.
Can you tell me more about the installation process for the Wyze Switch?What features does the Wyze Bulb Color offer?What is the warranty policy for the Wyze Switch?
