Security Cameras with Wide Field View & Advanced Motion Detection
Discover Security Cameras with Extended Field of View and Advanced Motion Detection
When it comes to home or business security, having a camera that offers a wide field of view combined with advanced motion detection is essential. Whether you want to monitor your front yard, keep an eye on your pets, or secure your indoor spaces, Wyze offers a range of cutting-edge cameras designed to meet these needs with exceptional clarity, smart features, and weather resistance. Explore the best Wyze security cameras that deliver extended viewing angles and intelligent motion tracking to keep you informed and your property safe.
Wyze Cam v4: Crystal-Clear Vision with Smart Motion Detection
Wyze Cam v4 is the clearest Wyze camera ever made, boasting a 2.5K QHD resolution that captures every detail with stunning clarity. Its 115.9° diagonal field of view ensures you see more of your surroundings, while the Enhanced Color Night Vision lets you monitor your property in vibrant color even in low light.
Key Features:
  • Extended Field of View: 115.9° diagonal, 98.5° horizontal, and 53.1° vertical angles cover wide areas.
  • Advanced Motion Detection: Sends instant alerts on motion or sound, with customizable detection zones to reduce false alarms.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren.
  • 24/7 Local Recording: Supports microSD cards up to 256GB for continuous recording without subscription fees.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection.
  • Smart Assistant Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
  • Weather Resistant: IP65 rating allows outdoor installation in rain or shine.
"Wyze Cam v4 gives you superhero vision with its enhanced hardware that pierces through darkness, unveiling details even the human eye can’t catch."
Wyze Cam v4 in action
Wyze Cam Pan v3: 360° Pan and 180° Tilt for Complete Coverage
For those who want to monitor every corner, the Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt, allowing you to see the entire room or outdoor area without blind spots. Its automatic motion tracking follows moving objects silently, ensuring you never miss a moment.
Highlights:
  • Full 360° Pan & 180° Tilt: Covers every angle with smooth, quiet motorized movement.
  • IP65 Weather Resistance: Perfect for outdoor use when paired with the Wyze Outdoor Power Adapter.
  • Color Night Vision: Starlight sensor technology delivers vivid nighttime images.
  • Custom Patrol Routes: Set up to 4 waypoints for automatic camera patrols.
  • Privacy Mode: Easily disable the camera view by pointing it downward.
  • Two-Way Audio: Communicate through the camera with clear sound.
  • Advanced Motion & Sound Alerts: Receive notifications for motion, sound, and even smoke or CO alarms.
"Wyze Cam Pan v3 is like having a vigilant security guard that quietly follows any movement, day or night."
Wyze Cam Pan v3 weather resistant
Wyze Cam OG: Reliable 1080p Security with Smart Detection
The Wyze Cam OG is a trusted choice for those seeking a balance of performance and affordability. It features a 120° field of view and a CMOS Starlight Sensor for clear images day and night. With 3X faster notifications and improved two-way audio, it keeps you connected and informed.
Features at a Glance:
  • 1080p Full HD Resolution: Crisp video quality for indoor or outdoor use.
  • Wide 120° Field of View: Covers broad areas with fewer cameras.
  • Built-in Spotlight & 90 dB Siren: Enhance security with light and sound deterrents.
  • Custom Detection Zones: Focus alerts on important areas.
  • Supports up to 256GB microSD: Local storage for continuous recording.
  • IP65 Weather Resistance: Durable for outdoor environments.
  • Smart Home Integration: Compatible with Alexa and Google Assistant.
"Wyze Cam OG offers quick live streaming and smart alerts, making it a reliable security companion."
Wyze Cam OG Telephoto: Zoom In on What Matters
If you need to focus on distant details, the Wyze Cam OG Telephoto is equipped with a 3X telephoto lens that narrows the field of view to capture faraway objects clearly. It maintains the same trusted 1080p resolution and smart features as the OG model.
Telephoto Camera Benefits:
  • 3X Telephoto Lens: DFOV 27°, HFOV 23.6°, VFOV 13.6° for detailed zoomed-in views.
  • 1080p HD Video: Clear images with night vision.
  • IP65 Weather Resistant: Suitable for outdoor use.
  • Two-Way Audio & Siren: Communicate and deter intruders.
  • Supports microSD Storage: Up to 256GB for local recording.
  • Smart Assistant Compatible: Works with Alexa, Google Assistant, and IFTTT.
"Perfect for monitoring specific zones or distant areas with precision."
Wyze Cam v4 Home Security Bundle: All-in-One Protection
For comprehensive coverage, the Wyze Cam v4 Home Security Bundle includes multiple cameras with 2.5K QHD resolution, enhanced color night vision, and motion-activated spotlights. This bundle is ideal for securing multiple areas inside and outside your home.
Bundle Advantages:
  • Multiple Cameras Included: Extended security coverage.
  • 128GB microSD Card: Ready for 24/7 local recording.
  • Wide Field of View: 115.8° diagonal for broad surveillance.
  • Improved Two-Way Audio: Clear communication.
  • IP65 Weather Resistance: Use indoors or outdoors.
  • Smart Home Integration: Alexa and Google Assistant compatible.
"Get unmatched security with a complete set of Wyze Cam v4 cameras and accessories."
Why Choose Wyze Security Cameras?
Wyze cameras combine advanced motion detection, wide-angle lenses, and smart home compatibility to provide a security solution that is both powerful and user-friendly. Whether you want panoramic coverage with the Pan v3, crystal-clear detail with the v4, or zoomed-in focus with the OG Telephoto, Wyze has a camera tailored to your needs.
"Protect your home with cameras that see more, detect smarter, and keep you connected anytime, anywhere."
Summary of Featured Products
Product NameField of ViewResolutionMotion Detection FeaturesWeather ResistanceSpecial Features
Wyze Cam v4115.9° diagonal2.5K QHDAdvanced zones, spotlight, sirenIP65Color Night Vision, Wi-Fi 6, 24/7 recording
Wyze Cam Pan v3360° pan, 180° tilt1080pAuto-tracking, custom patrolIP65Privacy Mode, two-way audio
Wyze Cam OG120°1080pCustom zones, spotlight, sirenIP65Faster notifications, built-in spotlight
Wyze Cam OG Telephoto27° telephoto1080pCustom zones, spotlight, sirenIP653X zoom lens
Wyze Cam v4 Home Security Bundle115.8° diagonal2.5K QHDPerson detection, spotlightIP65Multiple cameras, 128GB microSD included
Enhance Your Security with Wyze Cameras
Invest in Wyze security cameras to enjoy peace of mind with extended field views and intelligent motion detection. Whether for indoor or outdoor use, these cameras provide vibrant video quality, smart alerts, and robust weather resistance to keep your property safe around the clock.
Images Used
1. Wyze Cam v4 outdoor security camera lifestyle 2. Wyze Cam Pan v3 outdoor security camera in snowy weather
Protect your home with Wyze — where advanced technology meets smart security solutions.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam OGWyze Cam OG TelephotoWyze Cam v4 Home Security Bundle
Video Resolution2.5K QHD (2560x1440)Not specified (assumed 1080p)1080p (1920x1080)1080p (1920x1080)2.5K QHD (2560x1440)
Field of View (DFOV)115.8°360° pan, 180° tilt120°27° (telephoto)115.8°
Night VisionEnhanced Color Night Vision (4 IR LEDs + 2 white spotlight LEDs, 72 lumens)Color Night Vision (Starlight Sensor)4 IR LEDs (850 nm)4 IR LEDs (850 nm)Enhanced Color Night Vision (4 IR LEDs + 2 white spotlight LEDs, 72 lumens)
Audio99dB waterproof speaker, simultaneous two-way talk, noise & echo cancellationTwo-way audioBuilt-in speaker & mic, noise & echo cancellationBuilt-in speaker & mic, noise & echo cancellationImproved 2-way audio
SirenBuilt-in siren (99 dB)Not specified90 dB user-activated sirenNot specifiedNot specified
SpotlightMotion-activated spotlightNot specifiedBuilt-in spotlight (40 lumens)Not specifiedMotion-activated spotlight
Weather ResistanceIP65IP65IP65IP65IP65
ConnectivityWi-Fi 6, Bluetooth 5.2Wi-Fi (802.11 b/g/n)Wi-Fi 2.4 GHz (802.11 b/g/n)Wi-Fi 2.4 GHz (802.11 b/g/n)Wi-Fi 6
Local StoragemicroSD card up to 512 GB (required)microSD card support (up to 256 GB)microSD up to 256 GBmicroSD up to 256 GB128GB microSD included
Cloud StorageAvailable with subscriptionAvailable with subscriptionAvailable with subscriptionAvailable with subscriptionAvailable with subscription
Motion DetectionYes, with detection zonesYes, with detection zonesYes, with detection zonesYes, with detection zonesYes, with detection zones
Sound DetectionYesYesNot specifiedNot specifiedYes
Smoke & CO AlertsYesYesYesNot specifiedYes
Dimensions2in x 2in x 2 3/8in (51 x 51 x 60 mm)Not specified1.89in x 1.89in x 1.89in (48mm)1.89in x 1.89in x 1.89in (48mm)2in x 2in x 2 3/8in (51 x 51 x 60 mm)
Weight0.49 lb (222 g)Not specified4.1 oz (116 g)4.1 oz (116 g)0.49 lb (222 g)
Mounting OptionsStand, wall mount, ceiling mount, magnetic wall mount (adhesive)Not specifiedStand, wall mount, ceiling mountStand, wall mount, ceiling mountStand, wall mount, ceiling mount, magnetic wall mount (adhesive)
Power SourceWired (Indoor adapter included, outdoor adapter sold separately)Wired (Outdoor adapter sold separately)WiredWiredWired (includes power adapter)
BluetoothYes, Bluetooth 5.2Not specifiedNot specifiedNot specifiedNot specified
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTNot specifiedAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Price (Single Pack)$35.98$39.98$29.98$25.98$169.99 (bundle)
Release Year2024Not specified (latest version)Not specified20232024
What are the key features of Wyze security cameras for home and business protection?Wyze security cameras offer advanced motion detection, wide-angle lenses for extended field of view, high-resolution video (up to 2.5K QHD), color night vision, weather resistance (IP65 rating), two-way audio, and smart home compatibility with Alexa, Google Assistant, and IFTTT. These features ensure comprehensive monitoring and reliable alerts for both indoor and outdoor security.
How does the Wyze Cam v4 enhance home security?The Wyze Cam v4 features a 2.5K QHD resolution for crystal-clear video, a 115.9° diagonal field of view, enhanced color night vision, advanced motion detection with customizable zones, a motion-activated spotlight and 99 dB siren, 24/7 local recording with microSD support, Wi-Fi 6 connectivity, and IP65 weather resistance for reliable outdoor use.
What makes the Wyze Cam Pan v3 ideal for complete room or outdoor coverage?Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt, allowing you to monitor every corner without blind spots. It features automatic motion tracking, color night vision, custom patrol routes, privacy mode, two-way audio, advanced motion and sound alerts, and IP65 weather resistance for versatile indoor and outdoor use.
What is the field of view and resolution of the Wyze Cam OG?The Wyze Cam OG provides a wide 120° field of view and 1080p Full HD resolution, making it suitable for monitoring broad areas with fewer cameras. It also includes a CMOS Starlight Sensor for clear images day and night.
How does the Wyze Cam OG Telephoto differ from the standard OG model?The Wyze Cam OG Telephoto is equipped with a 3X telephoto lens, offering a narrower field of view (27° diagonal) to capture distant objects with greater detail. It maintains 1080p HD resolution, night vision, two-way audio, a siren, and IP65 weather resistance, making it ideal for monitoring specific zones or faraway areas.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 cameras, a 128GB microSD card for 24/7 local recording, and accessories. The cameras feature 2.5K QHD resolution, enhanced color night vision, motion-activated spotlights, improved two-way audio, a wide 115.8° diagonal field of view, IP65 weather resistance, and smart home integration.
Are Wyze security cameras weather resistant for outdoor use?Yes, most Wyze security cameras, including the Wyze Cam v4, Cam Pan v3, Cam OG, and Cam OG Telephoto, have an IP65 weather resistance rating. This makes them suitable for outdoor installation in various weather conditions, including rain and snow.
Do Wyze cameras support local video recording without a subscription?Yes, Wyze cameras support local video recording via microSD cards (up to 256GB for most models). This allows for continuous 24/7 recording without the need for a subscription, providing added security and peace of mind.
Can Wyze security cameras be integrated with smart home systems?Wyze security cameras are compatible with popular smart home platforms, including Amazon Alexa, Google Assistant, and IFTTT. This enables voice control, automation, and seamless integration with other smart devices in your home.
What motion detection features do Wyze cameras offer?Wyze cameras provide advanced motion detection with customizable detection zones to minimize false alerts. Some models also offer sound detection, motion-activated spotlights and sirens, automatic motion tracking, and instant notifications to keep you informed of any activity.
What are the key features of the Wyze Cam v4?Can you tell me more about the advanced motion detection capabilities of the Wyze cameras?What is the warranty policy for Wyze security cameras?
