Top Motion Detection Cameras for Smart Home Security 2024
Best Motion Detection Cameras for Smart Home Security
When it comes to securing your home with advanced motion detection cameras, Wyze offers a diverse lineup tailored to meet various needs—whether you want wired or wireless, indoor or outdoor, floodlight or compact designs. Explore the top Wyze motion detection cameras that combine cutting-edge technology, smart integrations, and reliable performance to keep your property safe day and night.
Wyze Cam Floodlight v2: Powerful Outdoor Security with Brilliant Illumination
Experience unmatched security with the Wyze Cam Floodlight v2, designed to dominate darkness and detect motion with precision.
  • 2800 Lumens LEDs provide bright, clear lighting to illuminate your driveway, porch, or backyard.
  • 2K video resolution with Color Night Vision ensures vivid, detailed footage even in low light.
  • 160° wide-angle view captures a broad area, minimizing blind spots.
  • AI-Powered Light Control and dusk-to-dawn automation make it smart and energy-efficient.
  • IP65 weather resistance guarantees durability in rain, snow, or shine.
  • Two-way talk lets you communicate directly through the camera.
  • 24/7 local recording keeps your footage safe without monthly fees.
  • Seamless integration with Alexa and Google Assistant for voice control.
This floodlight camera is perfect for outdoor areas where both lighting and security are essential. Wyze Cam Floodlight v2 illuminating driveway at night Bright outdoor security with motion detection
Wyze Battery Cam Pro: Wire-Free, High-Resolution Motion Detection Anywhere
For flexible placement without wiring hassles, the Wyze Battery Cam Pro offers premium features in a compact, wireless design.
  • 2.5K HDR video resolution delivers crystal-clear images with vibrant colors.
  • Radar + PIR motion detection enhances accuracy by combining radar sensing with passive infrared.
  • Integrated spotlight and siren provide instant deterrence when motion is detected.
  • Removable, rechargeable 6200mAh battery packs ensure long-lasting power and easy charging.
  • Supports both 2.4GHz and 5GHz WiFi for reliable connectivity.
  • IP65 weatherproof for dependable outdoor use.
  • No hub required, making setup quick and simple.
Ideal for locations where running power cables is impractical, this camera keeps your home secure with smart motion alerts and vivid video.
Wyze Cam v4: Wired Camera with Enhanced Color Night Vision and Motion Spotlight
The Wyze Cam v4 is a versatile wired camera that excels in both indoor and outdoor environments with advanced motion detection.
  • 2.5K QHD resolution for sharp, detailed video.
  • Enhanced Color Night Vision lets you see full-color footage even in darkness.
  • Motion-activated spotlight automatically lights up when movement is detected.
  • Wi-Fi 6 support ensures faster, more stable connections.
  • Compatible with Alexa and Google Assistant for hands-free control.
  • 115.8° diagonal field of view covers wide areas.
  • Durable polycarbonate body with glass and plastic lens materials.
This camera is perfect for users wanting high-quality wired security with smart features and excellent night vision.
Wyze Cam Pan v3: 360° Pan and 180° Tilt for Complete Motion Coverage
Cover every angle with the Wyze Cam Pan v3, a weather-resistant camera designed for both indoor and outdoor use.
  • 360° horizontal pan and 180° vertical tilt allow you to remotely control the camera to track motion anywhere in its range.
  • Fully IP65 weather resistant for outdoor durability (requires separate outdoor power adapter).
  • Motion tracking automatically follows detected movement.
  • Available in black or white to match your decor.
  • Ideal for monitoring large spaces like backyards, garages, or living rooms.
This camera’s dynamic motion detection and wide coverage make it a versatile choice for comprehensive home security. Wyze Cam Pan v3 outdoor in snowy environment Weather-resistant pan and tilt camera for full coverage
Wyze Bulb Cam: Discreet Motion Detection with Smart LED Lighting
The Wyze Bulb Cam combines a 2-in-1 outdoor security camera with a smart LED light bulb, perfect for subtle surveillance.
  • 2K HD video with color night vision captures clear footage day and night.
  • Instant motion alerts keep you informed of activity.
  • Fits most standard light fixtures for easy installation.
  • Supports local video storage with no subscription fees.
  • IP65 rated for outdoor use.
  • Control lighting remotely via the Wyze app.
This camera is ideal for users who want a low-profile security solution integrated with smart lighting. Wyze Bulb Cam installed in outdoor light fixture Smart LED bulb camera for discreet outdoor security
Why Choose Wyze Motion Detection Cameras?
Wyze motion detection cameras combine high-resolution video, smart AI-powered alerts, and robust weather resistance to provide reliable home security solutions. Whether you prefer wired or wireless, floodlight or compact designs, Wyze offers options that integrate seamlessly with your smart home ecosystem.
With features like two-way audio, color night vision, and easy app control, these cameras empower you to monitor your property anytime, anywhere.
Enhance your home security today with Wyze’s advanced motion detection cameras designed to keep you safe and informed.
FeatureWyze Cam Floodlight v2Wyze Battery Cam ProWyze Cam v4Wyze Cam Pan v3Wyze Bulb Cam
TypeFloodlight CameraBattery CameraWired CameraPan/Tilt Wired CameraBulb Camera
Video Resolution2K (1600p approx.)2.5K HDR2.5K QHD (2560x1440)1080p (1920x1080)2K (2304x1296)
Field of View160° wide-angleNot specified (wide)DFOV 115.8°, HFOV 98.5°, VFOV 53.1°120° FOV160° (diagonal 166°)
Night VisionColor Night VisionColor Night VisionEnhanced Color Night VisionIR Night Vision (4 IR LEDs)Color Night Vision + IR Night Vision
Lighting2 floodlight heads, 2800 lumensIntegrated 150 lumens spotlight2 white spotlight LEDs (72 lumens)No integrated lightSmart LED bulb, up to 800 lumens
Motion Detection270° PIR motion detectionRadar + PIR motion detectionYesYesYes
Two-Way AudioYesYesYesYesYes
Siren105 dB loud sirenIntegrated sirenBuilt-in sirenNo siren95 dB siren
Local StoragemicroSD up to 256 GBmicroSD (size not specified)microSD up to 512 GBmicroSD up to 256 GBmicroSD up to 256 GB
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional subscription planOptional subscription planCloud storage via AWS
Power SourceWiredBattery (removable, rechargeable)WiredWiredWired (standard E26 socket)
Weather ResistanceIP65IP65IP65IP65IP65
Wi-Fi Support2.4 GHz2.4 & 5 GHz dual-band2.4 GHz & Wi-Fi 62.4 GHz only2.4 GHz
Smart Assistant IntegrationAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Special FeaturesAI-Powered Light Control, Ambient Light Mode, Dusk-to-Dawn AutomationWire-free, Solar Panel compatible, Radar + PIR detectionWi-Fi 6 support, Enhanced Color Night Vision360° pan, 180° tilt, 8x digital zoom2-in-1 camera and smart LED bulb, motion-activated light
DimensionsNot specifiedNot specified2in x 2in x 2 3/8in124mm x 60mm x 63mmTelescoping length 1.18 in (3 cm)
WeightNot specifiedNot specified0.49 lb (222 g)11.29 oz (320 g)Not specified
Price (USD)$89.98$89.98 (1 pack)$107.94 (1 pack)$114.94 (1 pack)$49.98
What are the best Wyze motion detection cameras for home security?Wyze offers a range of top-rated motion detection cameras for home security, including the Wyze Cam Floodlight v2, Wyze Battery Cam Pro, Wyze Cam v4, Wyze Cam Pan v3, and Wyze Bulb Cam. Each model is designed to meet different needs, from powerful outdoor floodlights to discreet smart bulb cameras.
What features does the Wyze Cam Floodlight v2 offer for outdoor security?The Wyze Cam Floodlight v2 features 2800 lumens LEDs for bright illumination, 2K video resolution with color night vision, a 160° wide-angle view, AI-powered light control, dusk-to-dawn automation, IP65 weather resistance, two-way talk, 24/7 local recording, and integration with Alexa and Google Assistant.
Is the Wyze Battery Cam Pro truly wireless and suitable for outdoor use?Yes, the Wyze Battery Cam Pro is a wire-free security camera with a rechargeable 6200mAh battery, 2.5K HDR video resolution, radar + PIR motion detection, integrated spotlight and siren, IP65 weatherproof rating, and supports both 2.4GHz and 5GHz WiFi. It is ideal for outdoor locations where wiring is impractical.
What makes the Wyze Cam v4 a good choice for indoor and outdoor security?The Wyze Cam v4 is a versatile wired camera with 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, Wi-Fi 6 support, compatibility with Alexa and Google Assistant, a 115.8° diagonal field of view, and a durable polycarbonate body, making it suitable for both indoor and outdoor use.
How does the Wyze Cam Pan v3 provide complete motion coverage?The Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt, allowing remote control to track motion anywhere in its range. It features motion tracking, IP65 weather resistance (with an outdoor power adapter), and is available in black or white, making it ideal for monitoring large spaces indoors or outdoors.
What is the Wyze Bulb Cam and how does it work?The Wyze Bulb Cam is a 2-in-1 outdoor security camera and smart LED light bulb. It provides 2K HD video with color night vision, instant motion alerts, local video storage with no subscription fees, IP65 weather resistance, and remote lighting control via the Wyze app. It fits most standard light fixtures for easy installation.
Do Wyze motion detection cameras require a subscription for video storage?Many Wyze motion detection cameras, such as the Wyze Cam Floodlight v2 and Wyze Bulb Cam, support local video storage, allowing you to save footage without monthly subscription fees.
Are Wyze motion detection cameras compatible with smart home systems?Yes, Wyze motion detection cameras integrate seamlessly with popular smart home systems, including Alexa and Google Assistant, enabling voice control and easy app management.
What are the benefits of using Wyze motion detection cameras for home security?Wyze motion detection cameras offer high-resolution video, smart AI-powered alerts, robust weather resistance, two-way audio, color night vision, and easy app control. These features provide reliable and convenient home security, allowing you to monitor your property anytime, anywhere.
What features does the Wyze Cam Floodlight v2 offer for outdoor security?Can you explain how the motion detection works in the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions available?
