Best Surveillance Cameras: Wide View & PIR Motion Detection
Surveillance Cameras with Wider Field of View and PIR Motion Detection
When it comes to securing your home or business, having a surveillance camera that offers a wide field of view combined with reliable PIR (Passive Infrared) motion detection is essential. These features ensure you capture more area with fewer blind spots and receive accurate alerts triggered by human or animal movement, reducing false alarms. Below, we explore top Wyze surveillance cameras designed to meet these needs, highlighting their specs and unique advantages.
Wyze Cam v4: Crystal-Clear Vision with Smart Motion Detection
Wide Field of View and Enhanced Night Vision
The Wyze Cam v4 offers a diagonal field of view of 115.9°, horizontal 98.5°, and vertical 53.1°, providing broad coverage to monitor large areas effectively. Its 2.5K QHD resolution delivers crystal-clear video, capturing fine details day or night.
PIR Motion Detection with Spotlight and Siren
Equipped with a motion-activated spotlight and a 99 dB siren, the Wyze Cam v4 not only detects motion but also deters intruders actively. The PIR sensor enhances motion detection accuracy by sensing body heat, minimizing false alerts from non-living objects.
Weather-Resistant and Versatile Installation
Rated IP65 weather-resistant, this wired camera is suitable for both indoor and outdoor use. Its magnetic mount allows easy, screw-free installation anywhere around your property.
Smart Features and Connectivity
  • Supports Wi-Fi 6 for a stronger, more reliable connection.
  • Compatible with Alexa and Google Assistant.
  • Offers 24/7 local recording with microSD card support up to 256GB.
  • Advanced AI features like auto-zoom and smart focus track important activity.
Experience unmatched security with the clearest Wyze Cam ever made, designed to keep your home safe with vibrant color night vision and smart motion alerts.
Wyze Cam v4 in use Two-way audio and clear communication with Wyze Cam v4
Wyze Cam Pan v3: 360° Pan and 180° Tilt for Maximum Coverage
Full Room Coverage with Pan & Tilt
The Wyze Cam Pan v3 features a 360° horizontal pan and 180° vertical tilt, allowing you to monitor every corner of a room or outdoor space without blind spots. This makes it ideal for wide-area surveillance.
PIR Motion Tracking and Weatherproof Design
With built-in PIR motion detection, the camera automatically tracks moving objects silently, ensuring you never miss important activity. Its IP65 rating means it can withstand rain, snow, and other harsh weather conditions when paired with the Wyze Outdoor Power Adapter.
Enhanced Night Vision and Audio
  • Color Night Vision powered by a Starlight Sensor.
  • Two-way audio lets you communicate through the camera.
  • Privacy Mode spins the camera downward to disable viewing when needed.
Smart Patrol and Custom Zones
Set up patrol routes with up to 4 waypoints and customize detection zones to focus on specific areas, reducing unnecessary alerts.
Perfect for those who want a dynamic, weatherproof camera that can cover every angle with smart motion tracking.
Wyze Cam Pan v3 outdoor lifestyle Wyze Cam Pan v3 braving snowy weather with full 360° coverage
Wyze Battery Cam Pro: Wire-Free with Advanced PIR and Radar Detection
Wide Field of View and High-Resolution Video
The Battery Cam Pro offers a 134° diagonal field of view, wider than many competitors, with 2.5K HDR video resolution for sharp, detailed footage.
Dual PIR and Radar Motion Detection
This camera combines PIR sensors with radar technology to detect motion more precisely, reducing false alarms caused by environmental factors like wind or shadows.
Wire-Free Convenience and Long Battery Life
  • Completely wire-free with removable, rechargeable 6200mAh batteries lasting up to 6 months.
  • Supports both 2.4 GHz and 5 GHz Wi-Fi for flexible connectivity.
  • IP65 weatherproof for reliable outdoor use.
Additional Features
  • Integrated spotlight and 100 dB siren for deterrence.
  • Two-way audio with built-in speaker and microphone.
  • Local storage support up to 256GB microSD card.
Ideal for users seeking a flexible, wireless camera with advanced motion detection and wide coverage.
Wyze Cam Floodlight v2: Bright Illumination with Wide-Angle Surveillance
Ultra-Wide 160° Field of View
The Floodlight v2 covers a broad 160° diagonal field of view, perfect for monitoring driveways, yards, and large outdoor spaces.
Powerful Lighting and PIR Motion Detection
With 2800 lumens of dimmable LED light panels and color night vision, this camera illuminates dark areas while detecting motion with PIR sensors. The built-in 105 dB siren adds an extra layer of security.
Smart Home Integration and Weather Resistance
  • IP65 rated for all-weather durability.
  • Compatible with Alexa, Google Assistant, and IFTTT.
  • Features AI-powered light control and dusk-to-dawn automation.
Local Storage and Two-Way Audio
Supports up to 256GB microSD cards and includes two-way talk functionality for real-time communication.
A perfect choice for those who want to combine bright security lighting with wide-angle surveillance and smart motion detection.
Wyze Cam Floodlight v2 lifestyle Wyze Cam Floodlight v2 lighting up a driveway with smart motion alerts
Wyze Bulb Cam: Discreet Wide-Angle Security with PIR Motion Detection
160° Field of View in a Light Bulb Form Factor
The Wyze Bulb Cam combines a wide 160° field of view with a smart LED bulb, making it an unobtrusive security solution that fits into standard light fixtures.
PIR Motion Detection and Color Night Vision
Detects motion accurately with PIR sensors and provides clear 2K HD video with color night vision, ensuring you never miss a detail.
Easy Installation and Smart Controls
  • Fits standard E26 sockets for quick setup.
  • Motion-activated light and ambient light controls.
Supports microSD cards up to 256GB and includes two-way audio for communication.
Ideal for users wanting a subtle, multi-functional security camera integrated into their existing lighting.
Wyze Bulb Cam installed Wyze Bulb Cam installed in an outdoor light fixture for discreet surveillance
Conclusion
For surveillance cameras with a wider field of view and PIR motion detection, Wyze offers a versatile lineup:
  • Wyze Cam v4 for high-resolution wired security with spotlight and smart AI features.
  • Wyze Cam Pan v3 for dynamic 360° coverage and weatherproof pan-tilt functionality.
  • Wyze Battery Cam Pro for wire-free, long-lasting outdoor monitoring with advanced radar + PIR detection.
  • Wyze Cam Floodlight v2 for bright illumination combined with wide-angle surveillance.
  • Wyze Bulb Cam for discreet, wide-angle security integrated into your lighting.
Choose the model that best fits your environment and security needs to enjoy comprehensive, smart home protection.
# Product Tags Summary
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Battery Cam ProWyze Cam Floodlight v2Wyze Bulb Cam
TypeWired Security CameraWired Pan & Tilt Security CameraWire-Free Battery Security CameraWired Floodlight Security CameraWired Bulb Security Camera
Video Resolution2.5K QHD (2560x1440)2.5K (2560x1440)2.5K HDR (2560x1440)2K (2304x1296)2K (2304x1296)
Field of View115.9° (D) x 98.5° (H) x 53.1° (V)360° Pan, 180° Tilt134° (DFOV), 108° (HFOV), 56° (VFOV)160° Diagonal160° Diagonal
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight Sensor)2 IR LEDs + 2 White LEDs (Color NV)Color Night VisionColor Night Vision + IR Night Vision
AudioTwo-way talk, 99dB sirenTwo-way talkTwo-way audio, 100 dB sirenTwo-way talk, 105 dB sirenTwo-way audio, 95 dB siren
SpotlightMotion-activated spotlightNoIntegrated Spotlight2 dimmable LED light panelsSmart LED light bulb
Power SourceWired (Indoor 5V/1A adapter)WiredRemovable, Rechargeable BatteryHardwired (110-120V AC)Hardwired (120V AC)
Weather ResistanceIP65IP65IP65IP65IP65
WirelessWi-Fi 6 (2.4 GHz)Wi-Fi (2.4 GHz)Wi-Fi 2.4 & 5 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHz
Local StoragemicroSD up to 512 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GB (ExFAT)microSD up to 256 GB (ExFAT)
Cloud StorageSubscription availableSubscription availableSubscription availableSubscription availableCloud storage (AWS)
Mounting OptionsStand, Wall, Ceiling, MagneticWall, CeilingWall mount includedWall, CeilingStandard E26 Socket
Dimensions2" x 2" x 2 3/8"Not specified2.5" x 1.8" x 3.5"9.5" x 7.7" x 7.0"Bulb size standard E26
Weight0.49 lb (222 g)Not specified0.94 lb2.76 lbs (1.25 kg)Not specified
Bluetooth Version5.2Not specifiedBLE 5.1Not specifiedBluetooth 4.2 / BLE
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Special FeaturesAI Auto-Zoom, Motion-activated spotlight, 24/7 local recording, Wi-Fi 6 support360° pan & 180° tilt, motion tracking, privacy modeWire-free, removable battery, radar + PIR motion detection2800 lumens LED floodlight, AI-powered light control, dusk-to-dawn automation2-in-1 smart LED bulb & camera, motion-activated light, ambient light mode
Price (1 Pack)$35.98$39.98$159.98$89.98$49.98
What are the benefits of surveillance cameras with a wide field of view and PIR motion detection?Surveillance cameras with a wide field of view and PIR (Passive Infrared) motion detection provide broader coverage with fewer blind spots and deliver more accurate motion alerts by detecting body heat from humans or animals. This reduces false alarms caused by non-living objects and ensures you capture important activity across larger areas.
Which Wyze camera offers the widest field of view?The Wyze Cam Floodlight v2 and Wyze Bulb Cam both offer an ultra-wide 160° diagonal field of view, making them ideal for monitoring large outdoor spaces, driveways, or wide areas with minimal blind spots.
How does PIR motion detection work in Wyze cameras?PIR (Passive Infrared) motion detection in Wyze cameras senses body heat from humans and animals, which helps minimize false alerts from moving shadows, wind, or other non-living objects. Some models, like the Wyze Battery Cam Pro, combine PIR with radar technology for even more precise motion detection.
What is the difference between Wyze Cam v4 and Wyze Cam Pan v3?The Wyze Cam v4 is a wired camera with a 115.9° diagonal field of view, 2.5K QHD resolution, and features like a motion-activated spotlight, siren, and advanced AI. The Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt for full-room coverage, PIR motion tracking, and is weatherproof for both indoor and outdoor use.
Is there a wire-free Wyze camera with wide field of view and PIR motion detection?Yes, the Wyze Battery Cam Pro is a completely wire-free camera with a 134° diagonal field of view, dual PIR and radar motion detection, and a rechargeable battery that lasts up to 6 months. It is IP65 weatherproof and supports both 2.4 GHz and 5 GHz Wi-Fi.
Can Wyze cameras be used outdoors in harsh weather?Many Wyze cameras, including the Wyze Cam v4, Wyze Cam Pan v3, Wyze Battery Cam Pro, and Wyze Cam Floodlight v2, are rated IP65 weather-resistant, making them suitable for outdoor use in rain, snow, and other harsh conditions.
Do Wyze cameras support local video storage?Yes, all featured Wyze cameras support local video storage via microSD cards up to 256GB, allowing for 24/7 recording and playback without relying solely on cloud storage.
Are Wyze cameras compatible with smart home systems?Wyze cameras are compatible with popular smart home platforms such as Alexa and Google Assistant. Some models, like the Wyze Cam Floodlight v2, also support IFTTT for advanced automation.
What is the Wyze Bulb Cam and how does it work?The Wyze Bulb Cam is a discreet security camera integrated into a smart LED bulb. It offers a 160° field of view, PIR motion detection, 2K HD video with color night vision, and fits standard E26 sockets for easy installation. It also supports two-way audio and local storage.
Which Wyze camera is best for monitoring large outdoor areas at night?The Wyze Cam Floodlight v2 is ideal for large outdoor areas at night, offering a 160° field of view, 2800 lumens of dimmable LED lighting, color night vision, PIR motion detection, and a 105 dB siren for added security.
Do Wyze cameras offer two-way audio communication?Yes, all the highlighted Wyze cameras, including Wyze Cam v4, Wyze Cam Pan v3, Wyze Battery Cam Pro, Wyze Cam Floodlight v2, and Wyze Bulb Cam, feature two-way audio, allowing you to listen and speak through the camera using the Wyze app.
What advanced features do Wyze cameras offer for motion detection and alerts?Wyze cameras offer advanced features such as AI-powered motion detection, auto-zoom, smart focus, customizable detection zones, patrol routes, and dual PIR plus radar detection (on select models) to ensure accurate alerts and comprehensive coverage.
What are the key features of the Wyze Cam v4?How does the PIR motion detection work in the Wyze cameras?Are there any ongoing promotions or discounts for Wyze cameras?
