Cameras with 3x Faster Motion Alerts & Enhanced Two-Way Audio
Cameras with 3x Faster Motion Alerts and Enhanced Two-Way Audio
When it comes to home security, speed and clarity are paramount. If you're searching for a camera that delivers 3x faster motion alerts combined with enhanced two-way audio, Wyze offers cutting-edge solutions designed to keep you connected and informed in real-time. Below, explore the standout Wyze cameras that meet these exact needs, featuring advanced notification systems and crystal-clear communication capabilities.
Wyze Cam OG: The Next Generation Security Camera
Lightning-Fast Motion Alerts
The Wyze Cam OG is engineered with an improved chipset and revamped software that delivers 3x faster motion notifications compared to previous models. This means you get instant alerts the moment motion is detected, giving you peace of mind and the ability to respond quickly.
Communicate clearly with anyone near your camera thanks to an upgraded microphone and revamped speaker system. The enhanced two-way audio ensures your voice comes through loud and clear, whether you're checking in on pets or deterring unwanted visitors.
Additional Features
  • 120° wide field of view to capture the big picture.
  • Built-in 40-lumen spotlight and 90-decibel siren for active deterrence.
  • IP65 weather resistance for reliable indoor/outdoor use.
  • Quick live-streaming with video loading 50% faster than other Wyze cameras.
  • Supports local storage up to 256GB microSD cards.
  • Compatible with the Wyze app’s new live view and customizable detection zones.
"Back to the basics, with a huge leap forward."
Wyze Cam OG Two-Way Audio Experience crystal-clear two-way communication with Wyze Cam OG.
Wyze Cam OG Telephoto: Zoom In on Details
3x Telephoto Lens for Closer Views
The Wyze Cam OG Telephoto takes security to the next level with a 3x telephoto lens that magnifies distant subjects without losing image quality. Perfect for focusing on specific areas or objects, this camera ensures you never miss the finer details.
Fast Motion Alerts & Clear Audio
Like the Wyze Cam OG, this model also boasts 3x faster motion notifications and upgraded two-way audio for seamless communication. Whether indoors or outdoors, you’ll receive instant alerts and clear audio feedback.
Robust Features
  • 27° field of view with telephoto zoom.
  • Color night vision for vivid nighttime monitoring.
  • IP65 weatherproof rating for all-weather protection.
  • 90-decibel user-activated siren.
  • Quick live HD video streaming, 50% faster than other models.
  • Supports microSD cards up to 256GB.
"Capture the little things with 3x zoom."
Wyze Cam v4: Crystal-Clear 2.5K QHD Security
Superior Video Quality & Fast Alerts
Wyze Cam v4 offers 2.5K QHD resolution for ultra-clear video footage, paired with 3x faster motion alerts to keep you instantly informed. Its advanced CMOS Starlight sensor enhances image quality even in low light.
Enhanced Two-Way Audio & Spotlight
Enjoy simultaneous two-way talk with noise and echo cancellation, ensuring conversations are crisp and natural. The camera also features a motion-activated spotlight that brightens the scene when activity is detected.
Key Highlights
  • Wide 115.8° diagonal field of view.
  • 99dB waterproof speaker and built-in siren.
  • Wi-Fi 6 support for faster, more reliable connections.
  • 24/7 local recording with microSD card support up to 512GB.
  • Compatible with Alexa, Google Assistant, and IFTTT.
  • IP65 weather resistance for indoor/outdoor use.
"Get unmatched security with Wyze Cam v4."
Wyze Cam Pan v3 Outdoor Reliable outdoor security with Wyze Cam v4 and Pan v3 series.
Wyze Bulb Cam: Security Meets Smart Lighting
3x Faster Motion Alerts with 2K HD Video
Wyze Bulb Cam combines a 2-in-1 outdoor security camera and smart LED light bulb. It delivers instant motion alerts and captures clear 2K HD video with color night vision, ensuring you see every detail day or night.
Enhanced Two-Way Audio & Smart Controls
Communicate effortlessly with built-in digital microphone and two-way audio. Control your lighting remotely via the Wyze app, with options for manual, motion-activated, ambient light, scheduling, and automation.
Features at a Glance
  • Fits standard E26 light sockets for easy installation.
  • 160° field of view with digital zoom.
  • 95 dB siren volume for deterrence.
  • IP65 weather resistance for outdoor durability.
  • Compatible with Android 7.0+ and iOS 14.0+.
"Protect your home day and night with Wyze Bulb Cam."
Wyze Bulb Cam Outdoor Installation Seamless outdoor security and lighting with Wyze Bulb Cam.
Why Choose Wyze Cameras for Faster Alerts and Enhanced Audio?
Wyze cameras are designed to provide rapid response times and clear communication, essential for effective home security. With 3x faster motion alerts, you’re always the first to know when something’s happening. The upgraded two-way audio lets you interact in real-time, whether to check on loved ones, pets, or to deter intruders.
All these cameras come with weatherproof designs, color night vision, and easy app integration, making them versatile for any home or business environment.
Summary of Featured Cameras
Camera ModelMotion Alerts SpeedTwo-Way AudioSpecial FeaturePrice Range
Wyze Cam OG3x fasterEnhancedBuilt-in spotlight & sirenFrom $29.98
Wyze Cam OG Telephoto3x fasterEnhanced3x telephoto zoom lensFrom $25.98
Wyze Cam v43x fasterEnhanced2.5K QHD resolution, Wi-Fi 6From $35.98
Wyze Bulb CamInstant alertsEnhanced2-in-1 camera & smart LED bulb$49.98
Choose the Wyze camera that fits your security needs and enjoy faster alerts and clearer communication today.
FeatureWyze Cam OGWyze Cam OG TelephotoWyze Cam v4Wyze Bulb Cam
Release YearNext generation (2023)2023 generationLatest generationNot specified
Price (1 Pack)$29.98$25.98$35.98 (with 32GB MicroSD)$49.98
Field of View (FOV)120°27° (3x Telephoto)DFOV 115.8°, HFOV 98.5°, VFOV 53.1°Diagonal 166°, Horizontal 144°, Vertical 82.5°
ZoomNo3x Telephoto Zoom8x Digital ZoomDigital Zoom
Video ResolutionHD (not specified exact)HD (not specified exact)2.5K QHD (2560x1440)2K (2304x1296)
Night VisionColor Night VisionColor Night VisionEnhanced Color Night VisionColor Night Vision + IR Night Vision
Built-in SpotlightYes (40 lumens)NoYes (72 lumens)Yes (Smart LED bulb)
Siren Volume90 dB90 dB99 dB Waterproof95 dB at 4 in
Two-Way AudioUpgraded 2-way audioUpgraded 2-way audioYes, improved 2-way audioYes
Weather ResistanceIP65IP65IP65IP65
Indoor/Outdoor UseIndoor/OutdoorIndoor/OutdoorIndoor/OutdoorOutdoor
MicroSD Card SupportUp to 256GBUp to 256GBUp to 512GBUp to 256GB (exFAT format)
Cloud StorageCam Plus subscription availableCam Plus subscription availableSubscription plan availableAWS Cloud storage
Wi-Fi SupportNot specifiedNot specified2.4 GHz Wi-Fi, Wi-Fi 62.4 GHz b/g/n Wi-Fi
Smart Home IntegrationNot specifiedNot specifiedAlexa, Google Assistant, IFTTTNot specified
DimensionsNot specifiedNot specified2in x 2in x 2 3/8inNot specified
WeightNot specifiedNot specified0.49 lb (222 g)Not specified
Power AdapterWiredWiredWired (Indoor 5V/1A)120V AC (bulb socket)
Mounting OptionsNot specifiedNot specifiedStand, Wall, Ceiling, MagneticStandard E26 Socket
Special FeaturesBuilt-in spotlight, 3x faster notifications, improved 2-way audio3x Telephoto lens, 3x faster notifications, improved 2-way audio2.5K QHD, motion-activated spotlight, Wi-Fi 6, 24/7 local recording2-in-1 camera and smart LED bulb, motion-activated light, digital zoom
WarrantyNot specifiedNot specified1 Year1 Year
What Wyze cameras offer 3x faster motion alerts?Wyze Cam OG, Wyze Cam OG Telephoto, and Wyze Cam v4 all feature 3x faster motion alerts compared to previous models. Wyze Bulb Cam also delivers instant motion alerts for rapid notifications.
How does enhanced two-way audio improve Wyze cameras?Enhanced two-way audio in Wyze cameras provides clearer, louder, and more natural communication. Upgraded microphones and speakers ensure your voice is heard clearly, making it easy to check in on loved ones, pets, or deter intruders in real-time.
What are the key features of Wyze Cam OG?Wyze Cam OG offers 3x faster motion notifications, enhanced two-way audio, a 120° wide field of view, built-in 40-lumen spotlight, 90-decibel siren, IP65 weather resistance, quick live-streaming, and support for up to 256GB microSD cards.
What makes Wyze Cam OG Telephoto different from other Wyze cameras?Wyze Cam OG Telephoto features a 3x telephoto lens for close-up monitoring, 3x faster motion alerts, enhanced two-way audio, a 27° field of view, color night vision, IP65 weatherproof rating, and a 90-decibel siren. It is ideal for focusing on specific areas or distant objects.
What video quality does Wyze Cam v4 provide?Wyze Cam v4 delivers ultra-clear 2.5K QHD resolution video, ensuring detailed footage. It also features a CMOS Starlight sensor for enhanced low-light performance.
Does Wyze Cam v4 support smart home integration?Yes, Wyze Cam v4 is compatible with Alexa, Google Assistant, and IFTTT, allowing seamless integration with your smart home devices.
What is special about Wyze Bulb Cam?Wyze Bulb Cam combines a 2K HD security camera with a smart LED light bulb, offering instant motion alerts, color night vision, enhanced two-way audio, a 160° field of view, and remote lighting control via the Wyze app.
Are Wyze cameras suitable for outdoor use?Yes, all featured Wyze cameras, including Wyze Cam OG, OG Telephoto, v4, and Bulb Cam, have IP65 weather resistance, making them reliable for both indoor and outdoor security.
How much local storage do Wyze cameras support?Wyze Cam OG, OG Telephoto, and Bulb Cam support up to 256GB microSD cards for local storage, while Wyze Cam v4 supports up to 512GB microSD cards for continuous 24/7 recording.
How quickly can I access live video on Wyze cameras?Wyze Cam OG, OG Telephoto, and v4 offer live video streaming that loads 50% faster than previous Wyze models, ensuring you can view real-time footage with minimal delay.
Do Wyze cameras have night vision?Yes, all featured Wyze cameras are equipped with color night vision, allowing you to monitor your property clearly even in low-light or nighttime conditions.
What security features do Wyze cameras offer for deterrence?Wyze cameras include built-in sirens (up to 99dB), spotlights, and instant motion alerts to actively deter unwanted visitors and enhance your home security.
Can I customize motion detection zones with Wyze cameras?Yes, Wyze cameras support customizable detection zones through the Wyze app, allowing you to focus on specific areas for motion alerts.
What is the price range for Wyze cameras with faster alerts and enhanced audio?Wyze Cam OG starts from $29.98, Wyze Cam OG Telephoto from $25.98, Wyze Cam v4 from $35.98, and Wyze Bulb Cam is priced at $49.98.
What are the key features of the Wyze Cam OG?Can you tell me more about the enhanced two-way audio in Wyze cameras?Are there any ongoing sales or discounts for Wyze cameras?
