Smart 1080p Security Cameras: Panoramic View & Motion Alerts
Smart 1080p Security Cameras with Panoramic View, Motion Alerts, and Custom Detection Zones
When it comes to securing your home or business, having a smart security camera that offers a panoramic view, precise motion alerts, and customizable detection zones is essential. Below, we explore top Wyze cameras that meet these needs, combining advanced technology with user-friendly features to keep you connected and protected.
Wyze Cam Pan v3: 360° Panoramic Security with Motion Tracking
Wyze Cam Pan v3 in snowy outdoor setting Experience full outdoor protection with Wyze Cam Pan v3’s weather-resistant design.
Key Features:
  • 360° Pan and 180° Tilt: Covers every angle of your room or outdoor space with smooth, automatic panning and tilting.
  • 1080p HD Video: Clear, detailed video quality for day and night monitoring.
  • IP65 Weather Resistance: Designed for both indoor and outdoor use (requires Wyze Outdoor Power Adapter for outdoor).
  • Automatic Motion Tracking: The camera detects motion, follows the subject quietly, and records automatically.
  • Custom Detection Zones: Set specific areas to monitor, reducing false alerts and focusing on what matters most.
  • Motion and Sound Alerts: Receive instant notifications on your phone when motion or sound is detected.
  • Privacy Mode: Easily disable the camera’s view by pointing it downward when privacy is needed.
  • Two-Way Audio: Communicate through the camera with clear sound, perfect for interacting with family or pets.
  • Color Night Vision: See vivid colors even in low light, thanks to the advanced Starlight sensor.
Why Choose Wyze Cam Pan v3?
This camera is perfect for users who want a versatile, panoramic security solution that works rain or shine. Its quiet tracking motor and extensive tilt range make it ideal for monitoring large indoor spaces or outdoor areas like porches and backyards.
Wyze Cam v4: Enhanced 2.5K Clarity with Motion-Activated Spotlight
Key Features:
  • 2.5K QHD Resolution: Crystal-clear video with enhanced detail and vibrant colors.
  • 115.9° Diagonal Field of View: Wide-angle lens captures broad scenes with sharp clarity.
  • Enhanced Color Night Vision: See more detail and color in the dark than traditional night vision.
  • IP65 Weather Resistance: Suitable for outdoor installation without worry.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and loud siren.
  • Custom Motion Detection Zones: Tailor alerts to specific areas to avoid unnecessary notifications.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection.
  • Two-Way Audio: Clear communication through the camera.
  • 24/7 Local Recording: Continuous recording to microSD card (up to 256GB) without subscription.
  • Smart Assistant Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
Ideal Use Cases:
Wyze Cam v4 is designed for users who want superior video quality and smart home integration. Its spotlight and siren add an extra layer of security, making it a great choice for front doors, driveways, or any outdoor area needing vigilant monitoring.
Wyze Battery Cam Pro: Wire-Free 2.5K Security with Radar Motion Detection
Key Features:
  • 2.5K HDR Video: High-resolution video with rich detail.
  • Wire-Free Design: No hub required, powered by removable rechargeable batteries lasting up to 6 months.
  • IP65 Weatherproof: Built to withstand harsh weather conditions.
  • Radar + PIR Motion Detection: Advanced dual-sensor technology for accurate motion alerts.
  • Integrated Spotlight & 100 dB Siren: Illuminate and deter unwanted visitors.
  • 134° Field of View: Wide coverage for comprehensive monitoring.
  • Two-Way Audio: Speak and listen through the camera.
  • Supports 2.4 & 5 GHz Wi-Fi: Flexible connectivity options.
  • Local Storage: Supports up to 256GB microSD cards.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
Why It Stands Out:
The Battery Cam Pro is perfect for locations without easy access to power outlets. Its wire-free setup and long battery life make it ideal for remote areas, garages, or rental properties where wiring is impractical.
Custom Detection Zones & Motion Alerts: Tailor Your Security
All these Wyze cameras support custom detection zones, allowing you to define specific areas within the camera’s field of view to monitor for motion. This feature helps reduce false alarms from irrelevant movements like passing cars or tree branches, ensuring you only get alerts that matter.
“Custom detection zones empower you to focus your security on what’s important, enhancing both convenience and peace of mind.”
Motion alerts are sent instantly to your smartphone, keeping you informed in real-time whether you’re home or away. With options for person, package, pet, and vehicle detection (available with Cam Plus subscription), your security system becomes smarter and more responsive.
Summary: Which Camera Fits Your Needs?
FeatureWyze Cam Pan v3Wyze Cam v4Wyze Battery Cam Pro
Resolution1080p HD2.5K QHD2.5K HDR
Panoramic View360° Pan, 180° TiltFixed Wide Angle (115.9°)Wide Angle (134°)
Motion AlertsYesYesYes
Custom Detection ZonesYesYesYes
Weather ResistanceIP65IP65IP65
Power SourceWired (Outdoor adapter req.)WiredBattery (Rechargeable)
Night VisionColor Night VisionEnhanced Color Night VisionColor Night Vision
Two-Way AudioYesYesYes
Additional FeaturesAutomatic Motion TrackingSpotlight & SirenRadar Motion Detection
Enhance Your Security with Wyze Cameras
Choosing a Wyze smart security camera means investing in reliable, feature-rich devices that offer panoramic views, smart motion alerts, and customizable detection zones. Whether you prefer wired or wireless, indoor or outdoor, Wyze has a solution tailored to your security needs.
Wyze Cam Floodlight v2 lifestyle image showing driveway security Brighten and secure your outdoor spaces with Wyze Cam Floodlight v2.
# Product Tags Summary
TypeWired Indoor/Outdoor PTZ CameraWired Indoor/Outdoor CameraWireless Battery-Powered Camera
Video Resolution1080p HD2.5K QHD (2560x1440)2.5K HDR (2560x1440)
Field of View360° Pan, 180° Tilt115.9° (D) x 98.5° (H) x 53.1° (V)134° (DFOV), 108° (HFOV), 56° (VFOV)
Night VisionColor Night Vision (Starlight Sensor)Enhanced Color Night Vision (Starlight Sensor)2 IR LEDs (850 nm), 2 White LEDs (5500K, 187 lumens)
Pan & TiltYes (360° pan, 180° tilt)NoNo
SpotlightNo (sold separately)Yes, motion-activatedIntegrated Spotlight
SirenNoYes, 99 dBYes, 100 dB SPL @ 0.1m
Two-Way AudioYesYes, enhancedYes
Power SourceWired (requires Wyze Outdoor Power Adapter for outdoor use)WiredRemovable, Rechargeable Battery Packs
Battery LifeN/AN/AUp to 6 Months
WirelessNoNoYes (2.4 & 5 GHz WiFi)
Local StoragemicroSD card support (up to 256GB)microSD card support (up to 512GB)microSD card support (up to 256GB)
Motion DetectionYes, with automatic motion trackingYes, with AI Smart Focus and detection zonesYes, Radar + PIR Motion Detection
Sound DetectionYesYesYes
Smart Assistant IntegrationYes (Alexa, Google Assistant via app)Yes (Alexa, Google Assistant, IFTTT)Yes (Alexa, Google Assistant, IFTTT)
ConnectivityWiredWired (Wi-Fi 6 support)Wireless (Wi-Fi 2.4 & 5 GHz, BLE 5.1)
DimensionsNot specified2in x 2in x 2 3/8in2.5 x 1.8 x 3.5 inches
WeightNot specified0.49 lb (222 g)0.94 lbs
Price Range$39.98 - $114.94 (depending on pack)$35.98 - $107.94 (depending on pack)$89.98 - $219.98 (depending on pack)
What are the key features of Wyze Cam Pan v3 security camera?Wyze Cam Pan v3 offers 360° panoramic panning, 180° tilt, 1080p HD video, IP65 weather resistance, automatic motion tracking, custom detection zones, motion and sound alerts, privacy mode, two-way audio, and color night vision. It is suitable for both indoor and outdoor use (outdoor use requires the Wyze Outdoor Power Adapter).
How does the Wyze Cam v4 enhance home security?Wyze Cam v4 features 2.5K QHD resolution for crystal-clear video, a 115.9° wide-angle lens, enhanced color night vision, IP65 weather resistance, a motion-activated spotlight and siren, custom motion detection zones, Wi-Fi 6 support, two-way audio, 24/7 local recording to microSD card, and compatibility with Alexa, Google Assistant, and IFTTT.
What makes Wyze Battery Cam Pro ideal for outdoor and remote locations?Wyze Battery Cam Pro is wire-free, powered by removable rechargeable batteries lasting up to 6 months, and requires no hub. It offers 2.5K HDR video, IP65 weatherproofing, radar and PIR motion detection, an integrated spotlight and 100 dB siren, a 134° field of view, two-way audio, support for both 2.4 and 5 GHz Wi-Fi, local storage up to 256GB, and smart home integration.
What is a custom detection zone and how does it improve security?A custom detection zone allows you to define specific areas within the camera’s field of view to monitor for motion. This reduces false alerts from irrelevant movements, such as passing cars or swaying trees, ensuring you only receive notifications for activity that matters most.
Do Wyze security cameras send instant motion alerts to smartphones?Yes, all featured Wyze cameras send instant motion and sound alerts to your smartphone, keeping you informed in real-time whether you are at home or away. With a Cam Plus subscription, you can also receive person, package, pet, and vehicle detection alerts.
Are Wyze security cameras weather-resistant for outdoor use?Yes, Wyze Cam Pan v3, Wyze Cam v4, and Wyze Battery Cam Pro all feature IP65 weather resistance, making them suitable for outdoor installation. For Wyze Cam Pan v3, an outdoor power adapter is required for outdoor use.
Can Wyze cameras record video locally without a subscription?Yes, Wyze Cam v4 and Wyze Battery Cam Pro support 24/7 local recording to microSD cards (up to 256GB), allowing you to store footage without a subscription.
Do Wyze security cameras support two-way audio communication?Yes, all the featured Wyze cameras—Wyze Cam Pan v3, Wyze Cam v4, and Wyze Battery Cam Pro—offer two-way audio, enabling you to listen and speak through the camera.
Which Wyze camera is best for panoramic or wide-angle security coverage?For full panoramic coverage, Wyze Cam Pan v3 offers 360° pan and 180° tilt. Wyze Cam v4 provides a 115.9° wide-angle view, while Wyze Battery Cam Pro offers a 134° field of view for broad scene coverage.
Are Wyze security cameras compatible with smart home assistants?Yes, Wyze Cam v4 and Wyze Battery Cam Pro are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless smart home integration.
What are the main differences between the Wyze Cam Pan v3 and the Wyze Cam v4?Can you explain how the custom detection zones work on the Wyze cameras?Do you have any deals, ongoing sales, discounts, or promotions available for Wyze cameras?
