Secure Home Monitoring System with 24/7 Instant Notifications
Secure Home Monitoring System with Round-the-Clock Notification Service
Protecting your home has never been easier or more reliable. With the latest Wyze Sense home monitoring products, you can build a comprehensive, secure home monitoring system that keeps you informed 24/7. From detecting motion and leaks to monitoring climate and controlling your security remotely, these devices work seamlessly together to provide peace of mind.
The Heart of Your System: Wyze Sense Hub
The Wyze Sense Hub is the central brain of your home monitoring setup. It connects all your sensors and devices, ensuring real-time alerts and notifications are sent directly to your phone.
  • Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1+ BLE 5.1, and 915MHz RF communication.
  • Range: Covers up to 500 feet to sensors, allowing placement throughout your home.
  • Battery Backup: Built-in rechargeable battery with 10 hours of backup power.
  • Siren: Loud 88db siren at 2 feet to deter intruders.
  • Capacity: Supports up to 100 sensors for extensive coverage.
  • Design: Matte white base with a grey speaker top, compact size (4.5” x 4” x 1”).
Included with the hub are power adapter, Ethernet cable, window decals, and a quick start guide to get your system up and running quickly.
The Wyze Sense Hub is the essential command center that keeps your home monitoring system connected and responsive at all times.
Home Security Lifestyle
Comprehensive Sensor Suite for Total Home Awareness
Wyze Sense Entry Sensor
Detects when doors or windows open or close, providing instant alerts to prevent unauthorized access.
  • Compatibility: Requires Wyze Sense Hub.
  • Range: Up to 500 feet.
  • Pack Size: Available in 3-packs for multiple entry points.
  • Indoor Use: Designed for indoor environments.
  • Installation: Easy peel-and-stick or screw mounting options.
Wyze Sense Motion Sensor
Keep an eye on movement inside your home with this highly sensitive motion detector.
  • Detection Range: Up to 25 feet with a 120° field of view.
  • Adjustable Sensitivity: Customize detection to reduce false alarms.
  • Battery Life: Up to 18 months on a single battery.
  • Installation: Adhesive back or screws for secure placement.
  • Compatibility: Works with Wyze Sense Hub and Wyze Home Monitoring.
Protect your home from water damage by getting notified immediately of leaks.
  • Sensor Range: Up to 500 feet from the hub.
  • Operating Conditions: 32-104°F, indoor use only.
  • Variants: Options with multiple probes and sensors for versatile placement.
  • Compatibility: Requires Wyze Sense Hub and works with Wyze Sense v2 or Wyze Home Monitoring.
Wyze Sense Climate Sensor
Monitor temperature and humidity throughout your home to maintain comfort and prevent issues like mold.
  • Range: 500 feet from the hub.
  • Battery Life: Up to 1.5 years on a CR2032 battery.
  • Mounting: Peel-and-stick adhesive or optional screws.
  • Design: Sleek, unobtrusive white matte finish.
Control and Convenience: Wyze Sense Keypad
Arm or disarm your home security system remotely with the Wyze Sense Keypad, adding an extra layer of control and safety.
  • Functionality: Arm/disarm system and send first responders in emergencies.
  • Emergency Button: Quick access for urgent situations.
  • Installation: Permanent adhesive for indoor use.
  • Compatibility: Requires Wyze Sense Hub and Wyze Home Monitoring.
Smart Home Control
Why Choose Wyze Sense for Your Home Monitoring?
Wyze Sense products are designed to work together seamlessly, providing a robust, scalable, and easy-to-install home monitoring system. With round-the-clock notification services, you stay connected and informed no matter where you are.
  • Scalable System: Add up to 100 sensors to cover every corner of your home.
  • Reliable Notifications: Instant alerts for motion, entry, leaks, and climate changes.
  • User-Friendly: Simple installation with adhesive or screws and intuitive app control.
  • Battery Efficient: Long-lasting batteries reduce maintenance.
  • Indoor Focused: Designed for indoor use with weather-resistant components.
Lifestyle Smart Home
Conclusion
Building a secure home monitoring system with Wyze Sense products ensures your home is protected with intelligent sensors and a powerful hub that delivers real-time notifications. Whether you want to monitor entry points, detect motion, track climate, or get leak alerts, Wyze Sense offers a comprehensive solution tailored for your peace of mind. Start securing your home today with Wyze Sense — the smart choice for round-the-clock home monitoring.
Product Summary
  • Wyze Sense Hub: Central control unit with wide sensor support and siren.
  • Wyze Sense Entry Sensor: Detects door/window open and close.
  • Wyze Sense Motion Sensor: Monitors movement with adjustable sensitivity.
  • Wyze Sense Leak Sensor & Probe: Alerts you to water leaks promptly.
  • Wyze Sense Climate Sensor: Tracks temperature and humidity.
  • Wyze Sense Keypad: Remote arm/disarm and emergency response control.
Experience a safer home with Wyze Sense — your trusted partner in home security and monitoring.
FeatureWyze Sense HubWyze Sense Entry SensorWyze Sense Motion SensorWyze Sense Leak Sensor & ProbeWyze Sense KeypadWyze Sense Climate Sensor
TypeHome Monitoring HubEntry Sensor (3 Pack)Motion Sensor (1 Pack)Leak Sensor & Probe (2 Probes / 3 Sensors + 1 Probe)KeypadClimate Sensor (3 Pack)
Price (USD)45.9841.9820.9813.98 / 55.9827.9841.98
DescriptionConnects monitoring components and sends alertsDetects when things open/closeDetects motionNotifies of leaksDisarm home security remotelyTracks temperature and humidity
Requires-Wyze Sense HubWyze Sense HubWyze Sense HubWyze Sense HubWyze Sense Hub
CompatibilityCore of Wyze Home MonitoringWyze Sense v2 or Wyze Home MonitoringWyze Sense v2 or Wyze Home MonitoringWyze Sense v2 or Wyze Home MonitoringWyze Home MonitoringWyze Sense v2 from Wyze Home Monitoring
Standalone FunctionalityYesNoNoNoNoNo
Detection RangeN/AN/A25 ftUp to 500 ftN/A500 ft
Field of ViewN/AN/A120°N/AN/AN/A
Sensitivity SettingsN/AN/AAdjustableN/AN/AN/A
Battery LifeN/ANot specifiedUp to 18 monthsNot specifiedNot specified1.5 years
Indoor UseYesYesYesYesYesYes
Weather ResistanceN/AN/AN/AIndoor use onlyNot weatherproofIndoor use only
Mounting/InstallationN/AN/AAdhesive back, screws for securityN/APermanent adhesiveAdhesive back, optional screws
Emergency ButtonNoNoNoNoYesNo
Max Accessories per HubN/AN/A100N/A100N/A
What is the Wyze Sense Hub and how does it work?The Wyze Sense Hub is the central control unit for your Wyze home monitoring system. It connects all your Wyze sensors and devices, providing real-time alerts and notifications directly to your phone. The hub supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1+ BLE 5.1, and 915MHz RF communication, covers up to 500 feet, and includes a built-in 10-hour battery backup and an 88db siren to deter intruders.
Which sensors are compatible with the Wyze Sense Hub?The Wyze Sense Hub is compatible with Wyze Sense Entry Sensors, Motion Sensors, Leak Sensors & Probes, and Climate Sensors. It also works with the Wyze Sense Keypad for remote system control. All these devices require the Wyze Sense Hub for operation and seamless integration.
How do Wyze Sense Entry Sensors enhance home security?Wyze Sense Entry Sensors detect when doors or windows are opened or closed, sending instant alerts to your phone to help prevent unauthorized access. They are easy to install with peel-and-stick or screw mounting options and are designed for indoor use.
What is the range of Wyze Sense sensors from the hub?Wyze Sense sensors, including Entry, Motion, Leak, and Climate Sensors, have a range of up to 500 feet from the Wyze Sense Hub, allowing you to place them throughout your home for comprehensive coverage.
How does the Wyze Sense Motion Sensor work?The Wyze Sense Motion Sensor detects movement within a 25-foot range and a 120° field of view. It features adjustable sensitivity to reduce false alarms and offers up to 18 months of battery life. Installation is simple with adhesive or screws.
What features does the Wyze Sense Leak Sensor & Probe offer?The Wyze Sense Leak Sensor & Probe alerts you immediately to water leaks, helping prevent water damage. It operates within 32-104°F, is designed for indoor use, and can be placed up to 500 feet from the hub. Multiple probes and sensors are available for versatile placement.
How can I monitor temperature and humidity with Wyze Sense?The Wyze Sense Climate Sensor tracks temperature and humidity throughout your home, helping you maintain comfort and prevent issues like mold. It has a 500-foot range from the hub, up to 1.5 years of battery life, and can be mounted with adhesive or screws.
What is the Wyze Sense Keypad and what are its benefits?The Wyze Sense Keypad allows you to arm or disarm your home security system remotely and includes an emergency button for urgent situations. It is installed indoors with permanent adhesive and requires the Wyze Sense Hub and Wyze Home Monitoring for operation.
How many sensors can the Wyze Sense Hub support?The Wyze Sense Hub can support up to 100 sensors, making it easy to scale your home monitoring system to cover every corner of your home.
Are Wyze Sense products easy to install?Yes, Wyze Sense products are designed for easy installation with peel-and-stick adhesive or optional screws. The system is user-friendly and comes with a quick start guide to help you set up your home monitoring quickly.
Do Wyze Sense devices provide real-time notifications?Yes, Wyze Sense devices send instant, real-time notifications to your phone for motion, entry, leaks, and climate changes, ensuring you are always informed about your home's status.
Are Wyze Sense products suitable for outdoor use?Wyze Sense products are primarily designed for indoor use. While some components are weather-resistant, it is recommended to use them indoors for optimal performance and longevity.
What makes Wyze Sense a good choice for home monitoring?Wyze Sense offers a robust, scalable, and easy-to-install home monitoring system with round-the-clock notification services. Its seamless integration, reliable alerts, long battery life, and user-friendly design make it a smart choice for comprehensive home security.
What features does the Wyze Sense Hub offer for home monitoring?How does the Wyze Sense Hub connect to other sensors in the system?Do you have any deals, ongoing sales, discounts, or promotions?
