Cost-Effective Home Monitoring System with Secure Shared Access
When it comes to protecting your home without breaking the bank, Wyze offers a comprehensive and affordable home monitoring system designed to keep your space safe, secure, and easily manageable. Whether you want to monitor entry points, detect motion, or control your security remotely, Wyze’s lineup of smart devices provides a seamless and secure experience with shared access capabilities.
Wyze Home Monitoring Core Starter Kit: Your All-in-One Security Solution
The
Wyze Home Monitoring Core Starter Kit is the perfect entry point for anyone seeking a cost-effective, reliable home security system. This kit bundles essential components that work together to safeguard your home 24/7.
Key Features:
- Comprehensive Protection: Includes 1 Wyze Sense Hub, 2 Entry Sensors, 1 Motion Sensor, and 1 Keypad.
- Professional Monitoring: Comes with 3 months of professional monitoring included, ensuring expert response when needed.
- Wireless Sensors: Entry and motion sensors operate wirelessly with up to 18-month battery life.
- Siren Alarm: Loud 88db siren to deter intruders.
- Range & Compatibility: Supports up to 100 sensors with a 500 ft range, perfect for most homes.
- Indoor Use: Designed for indoor environments with operating temperatures from 32°F to 104°F.
- Secure Shared Access: Control and monitor your system remotely via the Wyze app, allowing multiple users secure access.
Stay worry-free knowing your home is protected by a smart system that’s easy to install and manage.
Wyze Home Monitoring Core Starter Kit in action, showing easy installation and entry sensors in a home setting.
Wyze Sense Hub: The Central Brain of Your Security System
At the heart of the Wyze monitoring system is the
Wyze Sense Hub, the device that connects all your sensors and sends real-time alerts to your phone.
Why Choose Wyze Sense Hub?
- Robust Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1+ BLE 5.1, and 915MHz RF communication.
- Long Battery Backup: Built-in rechargeable battery with up to 10 hours of backup power.
- Wide Sensor Support: Connects up to 100 sensors, allowing you to expand your system as needed.
- Loud Siren: 88db siren at 2 feet to alert you and neighbors.
- Compact Design: Matte finish with dimensions of 4.5” x 4” x 1” fits discreetly in any room.
- Indoor Use: Designed specifically for indoor environments.
The hub ensures your entire system works in harmony, providing seamless alerts and control.
Wyze Sense Keypad: Remote Arm and Disarm with Emergency Button
The
Wyze Sense Keypad adds convenience and security by allowing you to arm or disarm your system remotely without needing your phone.
Standout Features:
- Remote Control: Arm and disarm your home security system from anywhere.
- Emergency Button: Quickly trigger first responders in case of an emergency.
- Wireless & Indoor Use: Easy to install with permanent adhesive and designed for indoor use.
- Supports Up to 100 Accessories: Integrates smoothly with your existing Wyze Sense Hub and sensors.
This keypad is ideal for family members or trusted users who need quick access without compromising security.
Wyze Sense Keypad providing secure and easy access control for your home.
Additional Sensors to Enhance Your Home Security
Wyze Sense Motion Sensor
- Detects motion within a 25 ft range and 120° field of view.
- Adjustable sensitivity settings to reduce false alarms.
- Wireless with up to 18 months battery life.
- Requires Wyze Sense Hub for operation.
Wyze Sense Entry Sensor
- Detects when doors or windows open or close.
- Wireless and easy to install with adhesive or screws.
- Compatible with Wyze Sense Hub and supports multiple sensors.
- Alerts you immediately to water leaks to prevent damage.
- Indoor use only with a sensor range up to 500 feet.
- Compatible with Wyze Sense Hub and Wyze Home Monitoring.
These sensors can be added individually or as part of the starter kit to customize your home monitoring system according to your needs.
Wyze Sense Motion Sensor placed strategically to detect movement and enhance home security.
Why Choose Wyze for Your Home Monitoring?
Wyze offers a cost-effective, easy-to-install, and expandable home monitoring system with secure shared access through the Wyze app. Control your home security remotely, share access with family members, and receive instant alerts — all without expensive contracts or complicated setups.
With Wyze, you get professional-grade security features at a fraction of the cost, making it the smart choice for modern homeowners.
Summary of Featured Products
Wyze Sense Hub
Wyze Sense Keypad
Secure your home affordably and effortlessly with Wyze’s smart home monitoring system — designed for peace of mind and easy shared access.
What is included in the Wyze Home Monitoring Core Starter Kit?
The Wyze Home Monitoring Core Starter Kit includes 1 Wyze Sense Hub, 2 Entry Sensors, 1 Motion Sensor, and 1 Keypad. It also comes with 3 months of professional monitoring, providing comprehensive protection for your home.How does Wyze home monitoring provide secure shared access?
Wyze home monitoring allows you to control and monitor your security system remotely through the Wyze app. You can securely share access with multiple users, such as family members, so everyone can stay informed and manage the system as needed.Is professional monitoring included with Wyze home security systems?
Yes, the Wyze Home Monitoring Core Starter Kit comes with 3 months of professional monitoring included. This ensures expert response and added peace of mind for your home security.How many sensors can the Wyze Sense Hub support?
The Wyze Sense Hub can support up to 100 sensors, allowing you to expand your home monitoring system as needed for comprehensive coverage.What is the battery life of Wyze wireless sensors?
Wyze wireless entry and motion sensors offer up to 18 months of battery life, ensuring long-lasting and reliable home security with minimal maintenance.Can I control my Wyze security system remotely?
Yes, you can control and monitor your Wyze security system remotely using the Wyze app. This allows you to arm, disarm, and receive real-time alerts from anywhere.What is the range of Wyze sensors?
Wyze sensors have a range of up to 500 feet from the Wyze Sense Hub, making them suitable for most homes and allowing flexible placement throughout your property.Is the Wyze home monitoring system easy to install?
Yes, the Wyze home monitoring system is designed for easy installation. The sensors and keypad are wireless and can be installed using adhesive or screws, making setup quick and hassle-free.What features does the Wyze Sense Keypad offer?
The Wyze Sense Keypad allows you to arm and disarm your security system remotely and features an emergency button to quickly trigger first responders. It is wireless, easy to install, and integrates seamlessly with the Wyze Sense Hub.Are Wyze sensors suitable for indoor or outdoor use?
Wyze sensors and the Wyze Sense Hub are designed specifically for indoor use, with operating temperatures ranging from 32°F to 104°F.What types of sensors can I add to my Wyze home monitoring system?
You can add Wyze Sense Motion Sensors, Entry Sensors, and Leak Sensors & Probes to your Wyze home monitoring system. These sensors help detect motion, monitor entry points, and alert you to water leaks.Does the Wyze Sense Hub have a backup battery?
Yes, the Wyze Sense Hub features a built-in rechargeable battery that provides up to 10 hours of backup power in case of an outage.How loud is the Wyze siren alarm?
The Wyze siren alarm is 88 decibels at 2 feet, which is loud enough to deter intruders and alert you and your neighbors to potential security breaches.Why should I choose Wyze for home monitoring?
Wyze offers a cost-effective, easy-to-install, and expandable home monitoring system with secure shared access. You get professional-grade security features, remote control, and instant alerts without expensive contracts or complicated setups.
