Affordable Home Monitoring System with Professional Human Monitoring
Protecting your home doesn’t have to be complicated or expensive. With Wyze’s affordable home monitoring solutions, you get professional-grade security combined with easy-to-use technology and 24/7 human monitoring to keep your family and property safe around the clock. Whether you want to detect motion, monitor entry points, or quickly disarm your system remotely, Wyze offers a comprehensive lineup of products designed to work seamlessly together.
Core Components of Wyze Home Monitoring
Wyze Home Monitoring Core Starter Kit
The perfect starting point for anyone seeking reliable home security with professional monitoring included. This kit bundles essential devices that safeguard your home from unwanted intrusions and hazards.
- Includes: Wyze Sense Hub, 2 Entry Sensors, 1 Motion Sensor, 1 Keypad
- Professional Monitoring: 3 months included, providing real-time human response
- Range: Up to 500 feet wireless connectivity
- Battery Backup: 10 hours for uninterrupted protection during power outages
- Siren: Loud 88db alarm to deter intruders
- Sensors Supported: Up to 100 sensors for scalable security
- Operating Conditions: Indoor use, 32°F to 104°F, humidity ≤ 85%
- Entry Sensors: Detect open/close status with left-open alerts
- Motion Sensor: 25 ft detection range, wireless, 18-month battery life
- Keypad: Wireless with backlit keys and emergency button for quick access
Stay worry-free 24/7 with a system that not only alerts you but also connects you to professional monitoring services for immediate assistance.
Secure your home effortlessly with Wyze’s easy-to-install entry sensors.
Essential Monitoring Devices
Wyze Sense Hub
The central brain of your home monitoring system, the Wyze Sense Hub connects all your sensors and devices, sending instant alerts to your phone and the monitoring center.
- Role: Core controller for all Wyze Sense devices
- Connectivity: Ensures seamless communication between sensors and app
- Compatibility: Required for all Wyze Sense sensors and keypad
- Price: Affordable at $45.98, making it accessible for any budget
Wyze Sense Motion Sensor
Detects movement within your home to alert you of any unexpected activity.
- Detection Range: 25 feet with a 120° field of view
- Sensitivity: Adjustable to reduce false alarms
- Installation: Easy adhesive back or secure screws
- Battery Life: Up to 18 months for long-term use
- Compatibility: Works with Wyze Sense Hub and Wyze Home Monitoring
Place motion sensors in key corners to maximize home security coverage.
Wyze Sense Entry Sensor
Keep track of doors and windows opening or closing to prevent unauthorized access.
- Function: Detects open/close status with wireless connectivity
- Battery Life: Long-lasting 18 months
- Installation: Simple setup with adhesive or screws
- Compatibility: Requires Wyze Sense Hub and works with Wyze Home Monitoring
Convenient Control and Emergency Features
Wyze Sense Keypad
Arm or disarm your home security system quickly from anywhere inside your home.
- Features: Backlit keys for easy use in the dark, emergency button for first responders
- Remote Control: Disarm your system remotely via the Wyze app
- Compatibility: Requires Wyze Home Monitoring and Wyze Sense Hub
- Price: Budget-friendly at $27.98
The keypad adds an extra layer of convenience and safety, allowing you to control your system instantly and call for help when needed.
Quickly arm or disarm your system with the intuitive Wyze Sense Keypad.
Why Choose Wyze for Your Home Monitoring?
- Affordable Pricing: Get professional-grade monitoring without breaking the bank.
- Professional Human Monitoring: 24/7 monitoring ensures immediate response to emergencies.
- Scalable System: Add up to 100 sensors to customize your security setup.
- Easy Installation: No tools required for most sensors, perfect for renters and homeowners alike.
- Reliable Wireless Connectivity: Long-range communication keeps your system connected throughout your home.
- Backup Power: Stay protected even during power outages with built-in battery backup.
Wyze’s home monitoring system offers peace of mind with professional support, smart technology, and affordability all in one package.
Summary of Wyze Home Monitoring Products
Product | Key Features | Price |
Wyze Home Monitoring Core Starter Kit | Includes hub, sensors, keypad, 3 months professional monitoring | $111.98 |
Wyze Sense Hub | Central controller for all sensors | $45.98 |
Wyze Sense Motion Sensor | 25 ft range, adjustable sensitivity | $20.98 |
Wyze Sense Entry Sensor | Detects open/close status, wireless | $41.98 (3-pack) |
Wyze Sense Keypad | Arm/disarm, emergency button, backlit keys | $27.98 |
Protect your home affordably with Wyze’s trusted home monitoring system featuring professional human monitoring. Start with the Core Starter Kit and customize your security with additional sensors and convenient keypad control. Stay safe, connected, and worry-free every day.
What is included in the Wyze Home Monitoring Core Starter Kit?
The Wyze Home Monitoring Core Starter Kit includes a Wyze Sense Hub, 2 Entry Sensors, 1 Motion Sensor, and 1 Keypad. It also comes with 3 months of professional human monitoring, providing real-time response to emergencies.How does Wyze professional human monitoring work?
Wyze offers 24/7 professional human monitoring, which means your home is monitored around the clock by real people. If an alarm is triggered, the monitoring center is notified immediately and can dispatch emergency services if needed.Is Wyze Home Monitoring affordable?
Yes, Wyze Home Monitoring is designed to be budget-friendly. The Core Starter Kit is priced at $111.98 and includes essential devices and 3 months of professional monitoring. Additional components like the Wyze Sense Hub, Motion Sensor, Entry Sensor, and Keypad are also affordably priced.Can I expand my Wyze Home Monitoring system?
Absolutely. The Wyze Home Monitoring system supports up to 100 sensors, allowing you to customize and scale your security setup to fit your home’s needs.How easy is it to install Wyze home monitoring devices?
Wyze home monitoring devices are designed for easy installation, with most sensors using adhesive backing or screws. No special tools are required, making it ideal for both renters and homeowners.What happens if there is a power outage?
The Wyze Sense Hub features a 10-hour battery backup, ensuring your home monitoring system remains operational and your home stays protected even during power outages.How does the Wyze Sense Hub work?
The Wyze Sense Hub acts as the central controller for all Wyze Sense devices, connecting sensors and the keypad to the Wyze app and the professional monitoring center. It ensures seamless communication and instant alerts.What is the range of Wyze home monitoring sensors?
Wyze home monitoring sensors have a wireless connectivity range of up to 500 feet, providing reliable coverage throughout your home.How long do the batteries last in Wyze sensors?
Both the Wyze Sense Motion Sensor and Entry Sensor offer up to 18 months of battery life, ensuring long-term, low-maintenance operation.Can I control my Wyze Home Monitoring system remotely?
Yes, you can arm or disarm your Wyze Home Monitoring system remotely using the Wyze app, providing convenient control from anywhere.What features does the Wyze Sense Keypad offer?
The Wyze Sense Keypad features backlit keys for easy use in the dark, an emergency button for quick access to first responders, and allows you to arm or disarm your system from anywhere inside your home.Are Wyze home monitoring devices suitable for renters?
Yes, Wyze home monitoring devices are perfect for renters as they require no permanent installation and can be easily moved or expanded as needed.What is the price of individual Wyze home monitoring components?
The Wyze Sense Hub is $45.98, the Wyze Sense Motion Sensor is $20.98, the Wyze Sense Entry Sensor (3-pack) is $41.98, and the Wyze Sense Keypad is $27.98.What operating conditions are supported by Wyze home monitoring devices?
Wyze home monitoring devices are designed for indoor use and operate in temperatures from 32°F to 104°F with humidity up to 85%.
