Reliable Home Monitoring System with Local Alerts & Sensors
Reliable Home Monitoring System with Local Alerts and Sensor Integration
When it comes to securing your home, having a reliable monitoring system that offers local alerts and seamless sensor integration is essential. The Wyze Sense product lineup provides a comprehensive solution designed to keep your home safe, informed, and connected. From the central hub that powers the system to specialized sensors that detect motion, leaks, and environmental changes, Wyze Sense offers everything you need for a smart, responsive home monitoring experience.
Core of the System: Wyze Sense Hub
The Brains Behind Your Home Security
At the heart of the Wyze Sense home monitoring system is the Wyze Sense Hub. This device acts as the central command center, connecting all your sensors and sending instant alerts to your smartphone or local devices. Designed to be the core of every Wyze Home Monitoring setup, the hub ensures that all components work in harmony for real-time monitoring and quick response.
  • Price: $45.98
Key Features:
  • Connects multiple sensors seamlessly
  • Sends instant alerts for any triggered sensor
  • Supports up to 100 sensors per hub
  • Essential for all Wyze Sense sensors to function
  • Compact and unobtrusive design
The Wyze Sense Hub is indispensable for anyone looking to build a reliable and integrated home monitoring system.
Wyze Sense Hub Lifestyle Wyze Sense Hub integrates your home security sensors seamlessly
Easy and Quick Control: Wyze Sense Keypad
Arm and Disarm Your System Remotely
The Wyze Sense Keypad offers a convenient way to arm or disarm your home security system without needing to use your phone. Place it anywhere in your home for quick access, and use the emergency button to send alerts to first responders instantly.
  • Price: $27.98
Key Features:
  • Remote disarming capability
  • Emergency button for immediate help
  • Requires Wyze Sense Hub and Wyze Home Monitoring subscription
  • Simple setup and user-friendly interface
  • Portable and compact design for flexible placement
This keypad enhances your home security by providing local control and peace of mind.
Comprehensive Sensor Integration for Full Home Coverage
Wyze Sense Motion Sensor
Detect movement with precision using the Wyze Sense Motion Sensor. Perfect for monitoring entryways, hallways, or any area where motion detection is critical.
  • Price: $20.98
Key Features:
  • Detects motion up to 25 feet with a 120° field of view
  • Adjustable sensitivity settings
  • Easy installation with adhesive or screws
  • Battery life up to 18 months
  • Compatible with Wyze Sense Hub and Wyze Home Monitoring
Wyze Sense Entry Sensor
Keep track of doors, windows, cabinets, or any entry points with the Wyze Sense Entry Sensor. It alerts you immediately when something opens or closes.
  • Price: $41.98 (3 Pack)
Key Features:
  • Detects open/close status of doors and windows
  • Requires Wyze Sense Hub for operation
  • Compact and easy to install
  • Compatible with Wyze Sense v2 and Wyze Home Monitoring
Protect your home from water damage with the Wyze Sense Leak Sensor & Probe. It notifies you instantly if a leak is detected, helping you prevent costly repairs.
  • Price: $13.98 (2 Probes)
Key Features:
  • Detects water leaks quickly and reliably
  • Works with Wyze Sense Hub and Wyze Home Monitoring
  • Indoor use only, with up to 500 feet sensor range
  • Easy to place in vulnerable areas like basements or under sinks
Wyze Sense Climate Sensor
Monitor your home's temperature and humidity with the Wyze Sense Climate Sensor. Ideal for maintaining comfort and protecting sensitive areas like basements or attics.
Key Features:
  • Tracks temperature and humidity with high accuracy
  • 500 ft wireless range for flexible placement
  • Sleek, unobtrusive design with adhesive or screw mounting
  • Long battery life of 1.5 years
  • Indoor use only, compatible with Wyze Sense Hub
Wyze Sense Sensors Lifestyle Wyze sensors blend seamlessly into your home environment
Why Choose Wyze Sense for Your Home Monitoring?
Wyze Sense offers a reliable, integrated home monitoring system that combines local alerts with smart sensor technology. Whether you want to detect motion, monitor entry points, track environmental conditions, or get notified of leaks, Wyze Sense has you covered.
  • Easy integration with Wyze Home Monitoring subscription
  • Local control with keypad and instant emergency alerts
  • Long battery life and flexible installation options
  • Scalable system supporting up to 100 sensors per hub
  • Affordable pricing for comprehensive home security
Conclusion
For a reliable home monitoring system with local alerts and sensor integration, the Wyze Sense lineup is an excellent choice. The combination of the Wyze Sense Hub, Keypad, and a variety of sensors ensures your home is protected, informed, and easy to manage. With Wyze Sense, you get peace of mind knowing your home is monitored intelligently and responsively.
FeatureWyze Sense HubWyze Sense KeypadWyze Sense Motion SensorWyze Sense Entry SensorWyze Sense Leak Sensor & ProbeWyze Sense Climate Sensor
DescriptionConnects monitoring components and sends alerts. Core of Wyze Home Monitoring System.Disarm home security remotely. Requires Wyze Sense Hub.Detects motion. Requires Wyze Sense Hub.Detects when things open/close. Requires Wyze Sense Hub.Notifies of leaks. Requires Wyze Sense Hub.Tracks temperature and humidity. Requires Wyze Sense Hub.
Requires-Wyze Sense HubWyze Sense HubWyze Sense HubWyze Sense HubWyze Sense Hub
Standalone FunctionYesNoNoNoNoNo
CompatibilityWyze Home MonitoringWyze Home MonitoringWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home Monitoring
Price (USD)45.9827.9820.9841.98 (3 Pack)13.98 (2 Probes) / 55.98 (3 Sensors + 1 Probe)41.98 (3 Pack)
Detection Range / Sensor RangeN/AN/A25 ftN/AUp to 500 ft500 ft
Field of View / CoverageN/AN/A120°N/AN/AN/A
Sensitivity / SettingsN/AN/AAdjustableN/AN/AN/A
Battery LifeN/AN/AUp to 18 monthsN/AN/A1.5 years
Installation MethodN/APlace anywhereAdhesive back, screws for securityN/AN/AAdhesive back, optional screws
Indoor UseYesYesYesYesIndoor use onlyIndoor use only
Operating Temperature RangeN/AN/AN/AN/A32-104°F (0-40°C)32-104°F (0-40°C)
Operating HumidityN/AN/AN/AN/A≤85% at 86°F (30°C)≤85% at 86°F (30°C)
Emergency ButtonNoYesNoNoNoNo
Additional NotesCore device for systemDoes NOT work standalone or with Wyze Sense v1Requires Wyze Sense HubDoes NOT work standalone or with Wyze Sense v1Incompatible with Wyze Sense v1Sleek white design, tracks temp & humidity
What is the Wyze Sense Hub and why is it essential for home monitoring?The Wyze Sense Hub is the central command center of the Wyze home monitoring system. It connects and manages all Wyze Sense sensors, sending instant alerts to your smartphone or local devices. The hub supports up to 100 sensors and is required for all Wyze Sense sensors to function, making it indispensable for a reliable and integrated home security setup.
How does the Wyze Sense Keypad enhance home security?The Wyze Sense Keypad allows you to arm or disarm your home security system without using your phone. It features an emergency button for immediate alerts to first responders and offers a simple, user-friendly interface. The keypad requires the Wyze Sense Hub and a Wyze Home Monitoring subscription for operation.
What types of sensors are available in the Wyze Sense lineup?The Wyze Sense lineup includes a variety of sensors: Motion Sensor (detects movement), Entry Sensor (monitors doors and windows), Leak Sensor & Probe (detects water leaks), and Climate Sensor (monitors temperature and humidity). All sensors are designed for easy installation and seamless integration with the Wyze Sense Hub.
How do Wyze Sense Motion Sensors work?Wyze Sense Motion Sensors detect movement up to 25 feet with a 120° field of view. They feature adjustable sensitivity settings, easy installation with adhesive or screws, and a battery life of up to 18 months. These sensors require the Wyze Sense Hub and are compatible with Wyze Home Monitoring.
What is the function of the Wyze Sense Entry Sensor?The Wyze Sense Entry Sensor monitors the open/close status of doors, windows, cabinets, or other entry points. It sends instant alerts when an entry point is opened or closed. The sensor is compact, easy to install, and requires the Wyze Sense Hub for operation.
How does the Wyze Sense Leak Sensor & Probe help prevent water damage?The Wyze Sense Leak Sensor & Probe detects water leaks quickly and reliably, sending instant notifications to help you prevent costly water damage. It is designed for indoor use, has a sensor range of up to 500 feet, and is easy to place in vulnerable areas like basements or under sinks. It works with the Wyze Sense Hub and Wyze Home Monitoring.
What are the benefits of the Wyze Sense Climate Sensor?The Wyze Sense Climate Sensor tracks temperature and humidity with high accuracy, helping you maintain comfort and protect sensitive areas like basements or attics. It offers a 500 ft wireless range, long battery life of 1.5 years, and can be mounted with adhesive or screws. The sensor is for indoor use only and requires the Wyze Sense Hub.
How many sensors can the Wyze Sense Hub support?The Wyze Sense Hub can support up to 100 sensors, allowing you to scale your home monitoring system for comprehensive coverage.
Is a subscription required to use Wyze Sense products?A Wyze Home Monitoring subscription is required for certain features, such as using the Wyze Sense Keypad and receiving professional monitoring services. The sensors and hub can be used for local alerts and monitoring without a subscription, but advanced features may require one.
Why should I choose Wyze Sense for my home monitoring needs?Wyze Sense offers a reliable, affordable, and integrated home monitoring system with local alerts and smart sensor technology. It provides easy installation, long battery life, flexible placement, and supports up to 100 sensors per hub. With options for motion, entry, leak, and climate monitoring, Wyze Sense ensures your home is protected and connected.
What are the key features of the Wyze Sense Hub?How does the Wyze Sense Keypad enhance home security?Do you have any deals, ongoing sales, discounts, or promotions?
