Replace Phone Unlocking with Wyze Lock Keypad Option
If you're looking to replace your phone unlocking method with a more convenient and secure keypad option for your Wyze Lock, the
Wyze Lock Keypad is the perfect accessory. Designed specifically for the Wyze Lock system, this keypad allows you to unlock your door without needing your phone or a physical key, offering a seamless and flexible access solution.
Wyze Lock Keypad: Unlock Without Your Phone or Key
Key Features
- Standalone Keypad Access: Enter a 4-8 digit code to unlock your door, eliminating the need for your phone or keys.
- Easy Installation: Comes with a mounting plate, adhesive, screws, and batteries for quick setup.
- Bluetooth Connectivity: Connects directly to your Wyze Lock via Bluetooth for secure communication.
- Secure Local Storage: Access codes are stored locally on the Wyze Lock, ensuring your codes are private and not accessible via the cloud.
- Compatible Only with Wyze Lock: Note that the keypad does not work as a standalone device or with the Wyze Lock Bolt.
Setup and Installation
Setting up the Wyze Lock Keypad is straightforward:
1. Mount the keypad using the included adhesive and screws.
2. Insert the batteries and attach the keypad to the mounting plate.
3. Use the Wyze app to add the keypad to your Wyze Lock.
4. Create your personal access code in the app and start unlocking with ease.
The keypad offers a reliable alternative to phone unlocking, especially useful for family members, guests, or anyone who prefers a code over app control.
Wyze Lock Keypad offers convenient keyless entry
Wyze Lock: The Smart Lock Hub for Your Keypad
Why Choose Wyze Lock?
- Retain Your Existing Deadbolt: Wyze Lock adds smart functionality without replacing your entire lock.
- Multiple Access Methods: Use the Wyze app, keypad, or auto-unlock feature for versatile entry.
- Remote Access & Control: Lock or unlock your door from anywhere using your smartphone.
- Voice Assistant Integration: Compatible with Alexa and Google Assistant for hands-free control.
- Auto-Unlock & Auto-Lock: Automatically unlocks when you approach and locks after you leave.
- Secure Communication: Uses Bluetooth and Zigbee with AES-128 bit encryption for safe data transmission.
Specs & Compatibility
- Works indoors with IPX5 weather resistance.
- Compatible with most single cylinder deadbolts.
- Battery-powered with 4x AA batteries included, lasting 5-6 months.
- Supports Android 5.0+ and iOS 9.0+ devices.
The Wyze Lock is the essential smart lock that pairs perfectly with the Wyze Lock Keypad, providing a comprehensive and secure access management system.
Wyze Lock Bolt: Advanced Smart Lock with Keypad and Fingerprint
If you want a more integrated smart lock solution with a built-in keypad, consider the
Wyze Lock Bolt. This device replaces your deadbolt entirely and offers advanced features:
Key Features
- Backlit Keypad with Anti-Peep: Enter your access code discreetly even in the dark.
- Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a fingerprint scan.
- Auto-Lock Function: Automatically locks your door after closing.
- Lock & Unlock History: Track access events via the Wyze app.
- Emergency One-Time Codes: Provide temporary access to guests or service providers.
- Weather Resistant: Rated IPX5 for outdoor durability.
- Easy Installation: Fits standard door thickness and backset sizes.
Access Code Management
- Add up to 20 unique access codes.
- Codes are encrypted and stored locally on the device.
- Manage user access schedules and reset codes easily through the Wyze app.
Wyze Lock Bolt with keypad and fingerprint sensor for secure access
Why Switch to Wyze Lock Keypad Option?
Replacing your phone unlocking method with the Wyze Lock Keypad offers convenience, security, and flexibility. It’s ideal for households where not everyone uses a smartphone or prefers a quick code entry. The keypad integrates seamlessly with your existing Wyze Lock, maintaining your home’s security while enhancing access options.
Additional Smart Home Integration
For a fully connected home security experience, consider pairing your Wyze Lock and Keypad with other Wyze products:
- Wyze Sense Keypad: For remote disarming of your home security system.
- Wyze Switch: Control your home lighting and automate scenes that include your lock status.
- Essential Security Bundle: Includes Wyze Lock Bolt, cameras, and video doorbell for comprehensive protection.
Summary
Product | Price (USD) | Key Benefit |
Wyze Lock Keypad | 23.99 | Unlock without phone or key |
Wyze Lock | 123.99 | Smart control of existing deadbolt |
Wyze Lock Bolt | 79.98 | Smart deadbolt with keypad & fingerprint |
Upgrade your home access today by replacing your phone unlocking method with the Wyze Lock Keypad option — a smart, secure, and user-friendly solution.
What is the Wyze Lock Keypad and how does it work?
The Wyze Lock Keypad is an accessory designed for the Wyze Lock system that allows you to unlock your door using a 4-8 digit code, eliminating the need for your phone or a physical key. It connects to your Wyze Lock via Bluetooth and stores access codes locally for enhanced security.Can I use the Wyze Lock Keypad without a Wyze Lock?
No, the Wyze Lock Keypad is only compatible with the Wyze Lock and does not function as a standalone device. It is not compatible with the Wyze Lock Bolt or other smart locks.How do I install the Wyze Lock Keypad?
Installation is simple: mount the keypad using the included adhesive and screws, insert the batteries, attach the keypad to the mounting plate, and use the Wyze app to pair it with your Wyze Lock. You can then create your personal access code in the app.Is the Wyze Lock Keypad secure?
Yes, the Wyze Lock Keypad is secure. Access codes are stored locally on your Wyze Lock, not in the cloud, and communication between the keypad and lock uses secure Bluetooth technology.What are the benefits of replacing phone unlocking with the Wyze Lock Keypad?
Switching to the Wyze Lock Keypad offers convenience, security, and flexibility. It’s ideal for households where not everyone uses a smartphone or prefers quick code entry, and it provides a reliable alternative for family members, guests, or service providers.What devices are compatible with the Wyze Lock and Keypad?
The Wyze Lock and Keypad are compatible with most single cylinder deadbolts and support Android 5.0+ and iOS 9.0+ devices. The lock is designed for indoor use and is IPX5 weather resistant.How long do the batteries last in the Wyze Lock and Keypad?
Both the Wyze Lock and Keypad are battery-powered. The Wyze Lock uses 4 AA batteries that typically last 5-6 months, while the keypad also comes with batteries for easy setup.What is the difference between Wyze Lock Keypad and Wyze Lock Bolt?
The Wyze Lock Keypad is an accessory for the Wyze Lock, allowing code-based entry. The Wyze Lock Bolt is a smart deadbolt with a built-in backlit keypad and fingerprint sensor, replacing your existing deadbolt and offering advanced features like fingerprint unlocking and access code management.Can I manage access codes for the Wyze Lock Keypad through the Wyze app?
Yes, you can easily create, manage, and reset personal access codes for the Wyze Lock Keypad using the Wyze app, giving you full control over who can access your home.Does the Wyze Lock Keypad support voice assistant integration?
While the Wyze Lock itself supports integration with Alexa and Google Assistant for hands-free control, the Wyze Lock Keypad is used for code entry and does not directly support voice assistants.
