Affordable Keypad Upgrade for Wyze Lock Smart Home Security and Easy Access
Upgrading your Wyze Lock with an affordable keypad is the perfect way to enhance your smart home security while enjoying quick and easy access. Whether you want to replace your existing deadbolt or add a convenient keypad with fingerprint recognition, Wyze offers smart lock solutions designed for seamless integration, reliability, and user-friendly control.
Wyze Lock Bolt: The Ultimate Keypad Upgrade
The
Wyze Lock Bolt is an excellent choice for anyone looking to upgrade their home security with a modern, affordable keypad solution. This Bluetooth-enabled smart lock replaces your existing deadbolt and adds a luxurious backlit keypad combined with an ultra-fast fingerprint reader for effortless access.
Key Features:
- Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a touch of your finger.
- Backlit Keypad with Anti-Peep: Enter your code discreetly, even in low light.
- Auto-Lock Function: Never worry about forgetting to lock your door again.
- Lock and Unlock History: Monitor access through the Wyze app for enhanced security.
- Built-in Alarm: Detects jam attempts and alerts you immediately.
- Emergency One-Time Codes: Provide temporary access to guests or service providers.
- Easy Installation: Replaces your existing deadbolt without professional help.
Technical Specs:
- Power Source: 4x AA batteries (included) with 10-12 months battery life.
- Communication: Bluetooth 5.0 with a 16 ft range.
- Weather Resistance: Rated IPX5, suitable for various climates.
- Operating Temperature: Keypad works from -13°F to 122°F.
- Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick with backset options of 2-3/8” or 2-3/4”.
Available in stylish
Matte Black and
Satin Nickel finishes, the Wyze Lock Bolt blends security with modern aesthetics.
"Unlock your door in less than a second with the touch of a finger or a tap in the app."
Experience smart home security with Wyze Lock Bolt at your front door.
Wyze Lock: Smart Control for Your Existing Deadbolt
If you prefer to keep your current deadbolt but want to add smart functionality, the
Wyze Lock is the perfect upgrade. This device adds the "brains" to your lock, enabling remote access, auto-unlock, and voice control without changing your hardware.
Key Features:
- Auto-Unlock: Your door unlocks automatically as you approach.
- Remote Access: Lock or unlock your door from anywhere using the Wyze app.
- Voice Control: Compatible with Alexa and Google Assistant for hands-free operation.
- Virtual Keys: Send temporary or permanent virtual keys to family and friends.
- Quick Installation: Installs in under 15 minutes on most single cylinder deadbolts.
Technical Specs:
- Power Source: 4x AA batteries (included) with 5-6 months battery life.
- Communication: Bluetooth, Zigbee, and WiFi for versatile connectivity.
- Range: Up to 50 ft to gateway or lock, 16 ft Bluetooth to phone.
- Weather Resistance: Indoor use with IPX5 rating.
- Operating Temperature: Works between 14°F and 131°F.
Available in
Silver and
White, the Wyze Lock offers a sleek, compact design that fits seamlessly into your smart home ecosystem.
Smart control meets convenience with Wyze Lock’s keypad upgrade.
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning perfectly, Wyze offers affordable replacement parts that ensure longevity and easy maintenance.
Available Replacement Parts:
- Wyze Lock Bolt Screws: Set of screws compatible with Wyze Lock Bolt for secure installation.
- Wyze Lock Replacement Part Kit: Includes essential components to replace worn or lost parts.
- Wyze Lock Bolt Interior Assembly Metal Plate: Anchors the interior assembly firmly to your door.
- Wyze Lock Bolt Interior Assembly Battery Cover: Replacement battery cover to protect your lock’s power source.
These parts come with a 30-day hassle-free return policy, making it easy to maintain your smart lock without extra cost.
Why Choose Wyze for Your Keypad Upgrade?
Wyze smart locks combine affordability, advanced technology, and user-friendly features to provide a seamless upgrade for your home security. With options to replace your deadbolt or add smart control to your existing lock, Wyze offers flexible solutions tailored to your needs.
Enhance your smart home security with Wyze’s affordable keypad upgrades and enjoy easy, secure access every day.
Summary of Products Mentioned
Upgrade your Wyze Lock today with an affordable keypad and enjoy the perfect blend of security, convenience, and smart home integration!
What is the Wyze Lock Bolt and how does it enhance home security?
The Wyze Lock Bolt is a Bluetooth-enabled smart lock that replaces your existing deadbolt, offering a backlit keypad and ultra-fast fingerprint reader for secure and convenient access. It enhances home security with features like auto-lock, lock and unlock history, a built-in alarm for jam attempts, and emergency one-time codes for guests.Can I upgrade my existing deadbolt with Wyze Lock without replacing the hardware?
Yes, the Wyze Lock allows you to add smart functionality to your current deadbolt without replacing the hardware. It provides features like auto-unlock, remote access, voice control, and virtual keys, all while keeping your existing lock in place.What are the key features of the Wyze Lock Bolt keypad upgrade?
Key features of the Wyze Lock Bolt include an ultra-fast fingerprint sensor, backlit keypad with anti-peep technology, auto-lock function, access history monitoring via the Wyze app, a built-in alarm for jam detection, emergency one-time codes, and easy installation that doesn’t require professional help.How easy is it to install the Wyze Lock Bolt or Wyze Lock?
Both the Wyze Lock Bolt and Wyze Lock are designed for easy installation. The Wyze Lock Bolt replaces your existing deadbolt and can be installed without professional assistance, while the Wyze Lock installs in under 15 minutes on most single cylinder deadbolts.What is the battery life and power source for Wyze smart locks?
Both the Wyze Lock Bolt and Wyze Lock are powered by 4x AA batteries (included). The Wyze Lock Bolt offers a battery life of 10-12 months, while the Wyze Lock provides 5-6 months of battery life.Are Wyze smart locks weather resistant?
Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance and operates in temperatures from -13°F to 122°F, making it suitable for various climates. The Wyze Lock is also IPX5 rated but is intended for indoor use, operating between 14°F and 131°F.What connectivity options do Wyze smart locks offer?
The Wyze Lock Bolt uses Bluetooth 5.0 with a 16 ft range for secure local access. The Wyze Lock supports Bluetooth, Zigbee, and WiFi, offering up to 50 ft range to the gateway or lock and 16 ft Bluetooth range to your phone.Can I control Wyze smart locks remotely or with voice commands?
Yes, the Wyze Lock supports remote access via the Wyze app and is compatible with Alexa and Google Assistant for hands-free voice control. The Wyze Lock Bolt can be managed through the Wyze app within Bluetooth range.Are replacement parts available for Wyze Lock Bolt?
Yes, Wyze offers affordable replacement parts for the Wyze Lock Bolt, including screws, a replacement part kit, interior assembly metal plate, and battery cover. All parts come with a 30-day hassle-free return policy.What finishes are available for Wyze Lock Bolt and Wyze Lock?
The Wyze Lock Bolt is available in Matte Black and Satin Nickel finishes, while the Wyze Lock comes in Silver and White, allowing you to choose a style that matches your home décor.Why should I choose Wyze for my keypad upgrade?
Wyze offers affordable, advanced, and user-friendly smart lock solutions that seamlessly integrate with your smart home. Whether you want to replace your deadbolt or add smart control to your existing lock, Wyze provides flexible options to enhance your home security and convenience.
