Wyze Lock Bolt: Remote Control Smart Lock via Wyze App
Wyze Lock Bolt: Smart Deadbolt with Remote Control via Wyze App
Upgrade your home security with the Wyze Lock Bolt, a cutting-edge Bluetooth smart lock designed to replace your traditional deadbolt. This smart lock offers seamless remote control through the Wyze app, allowing you to lock and unlock your door effortlessly from anywhere. Whether you’re coming home or letting in guests, the Wyze Lock Bolt provides a secure, keyless entry experience with multiple convenient access options.
Key Features of Wyze Lock Bolt
  • Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a quick fingerprint scan, eliminating the need for keys or codes.
  • Backlit Keypad with Anti-Peep Technology: Enter your access code securely even in the dark, with a keypad designed to prevent code peeking.
  • Remote Lock/Unlock via Wyze App: Control your lock from your smartphone using Bluetooth 5.0 with a range of up to 16 feet, perfect for remote access and monitoring.
  • Auto-Lock Function: Never worry about forgetting to lock your door again; the lock automatically secures itself after a set time.
  • Lock and Unlock History: Track who enters and exits your home with detailed logs accessible in the Wyze app.
  • Built-in Alarm for Jam Detection: Alerts you immediately if the lock is jammed or tampered with.
  • Emergency One-Time Codes: Provide temporary access to visitors or service personnel without sharing permanent codes.
Technical Specifications
  • Power Source: 4x AA batteries (included) with 10-12 months battery life.
  • Weather Resistance: Rated IPX5, suitable for various weather conditions.
  • Operating Temperature: Keypad works from -13°F to 122°F; lock assembly from 32°F to 122°F.
  • Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick with backset options of 2-3/8” or 2-3/4”.
  • Colors Available: Matte Black and Satin Nickel.
Experience the perfect blend of security and convenience with the Wyze Lock Bolt, designed to integrate smoothly into your smart home ecosystem.
Wyze Lock Bolt Lifestyle Secure your home effortlessly with Wyze Lock Bolt
Enhance Your Home Security with Wyze Lock Bolt Replacement Parts
To keep your Wyze Lock Bolt functioning flawlessly, Wyze offers essential replacement parts designed specifically for this smart lock:
Wyze Lock Bolt Screws
  • Compatible with Wyze Lock Bolt.
  • Sold as a set of screws for easy replacement.
  • Affordable and simple to install.
  • 30-day hassle-free return policy.
Wyze Lock Bolt Interior Assembly Battery Cover
  • Replacement battery cover for the interior assembly.
  • Ensures your lock’s battery compartment stays protected.
  • Compatible exclusively with Wyze Lock Bolt.
  • 30-day hassle-free returns.
Wyze Lock Bolt Interior Assembly Metal Plate
  • Metal plate anchors the interior assembly securely to your door.
  • Durable and reliable replacement part.
  • Available in multiple quantities.
These replacement parts help maintain the longevity and reliability of your Wyze Lock Bolt, ensuring your smart lock continues to operate smoothly.
Wyze Essential Security Bundle: Complete Smart Home Protection
For those looking to maximize home security, the Wyze Essential Security Bundle combines the Wyze Lock Bolt with other advanced security devices for comprehensive protection.
What’s Included in the Bundle?
  • Wyze Lock Bolt: Smart deadbolt with fingerprint sensor and backlit keypad.
  • Wyze Video Doorbell v2: Crisp 1080p HD video with two-way audio to monitor your front door.
  • Wyze Cam Pan v3: Pan-and-tilt camera with 360° horizontal and 180° vertical coverage, color night vision, and motion tracking.
  • Two Wyze Cam OG Cameras: Versatile plug-in cameras with motion-activated spotlights and color night vision for indoor or outdoor use.
Bundle Benefits
  • Monitor and control your home’s access points remotely via the Wyze app.
  • Receive real-time alerts and view live video feeds from anywhere.
  • Protect your home from every angle with a combination of smart locks and cameras.
  • Weather-resistant devices rated IP65 for outdoor durability.
The Essential Security Bundle is your all-in-one solution for smart, connected home safety.
Wyze Plug-in Cam Outdoor Comprehensive home monitoring with Wyze cameras
Why Choose Wyze Lock Bolt with Wyze App?
The Wyze Lock Bolt paired with the Wyze app offers a modern, secure, and user-friendly way to manage your home’s access:
  • Remote Control: Lock or unlock your door from anywhere using your smartphone.
  • Access Management: Share temporary or permanent access codes with family, friends, or service providers.
  • Activity Monitoring: Stay informed with detailed lock/unlock history and notifications.
  • Easy Installation: Replaces your existing deadbolt without complicated wiring.
  • Integration: Works seamlessly with other Wyze smart home devices for a connected experience.
Wyze Lock Bolt App Control Control your Wyze Lock Bolt remotely with the Wyze app
Conclusion
The Wyze Lock Bolt is an innovative smart lock solution that combines security, convenience, and smart home integration. Whether used alone or as part of the Wyze Essential Security Bundle, it offers peace of mind with advanced features like fingerprint access, remote control via the Wyze app, and auto-lock functionality. Keep your home safe and accessible with Wyze’s reliable and easy-to-use smart lock technology.
Product Tags Summary
  • Wyze Lock Bolt:
  • Wyze Lock Bolt Screws:
  • Wyze Lock Bolt Interior Assembly Battery Cover:
  • Wyze Lock Bolt Interior Assembly Metal Plate:
  • Essential Security Bundle:
Feature / ProductWyze Lock BoltThe Front Porch Security BundleWyze Lock Bolt ScrewsWyze Lock Bolt Interior Assembly Battery CoverWyze Lock Bolt Interior Assembly Metal Plate
TypeConnected Home Smart LockSecurity Bundle (Lock + Cameras + Doorbell)Replacement PartsReplacement PartsReplacement Parts
DescriptionBluetooth smart lock with fingerprint sensor, backlit keypad, auto-lockIncludes Wyze Lock or Lock Bolt + Video Doorbell(s) + ChimeSet of screws for Wyze Lock BoltInterior battery cover replacement for Wyze Lock BoltMetal plate to anchor interior assembly to door
Key FeaturesFingerprint unlock, backlit keypad, anti-peep tech, auto-lock, pick-proof, weatherproof (IPX5), 12-month battery lifeFront porch security with video doorbell, chime, remote lock/unlock, lock historyScrews for installation or replacementBattery cover replacement partMetal plate replacement part
CompatibilityReplaces existing deadboltIncludes Wyze Lock or Wyze Lock Bolt variantsCompatible with Wyze Lock BoltCompatible with Wyze Lock BoltCompatible with Wyze Lock Bolt
Price$79.98$123.99 - $173.97 (varies by bundle variant)$2.99$9.99$4.99
VariantsMatte Black, Satin NickelMultiple bundles including Wyze Lock Bolt + Video Doorbell Pro or v2Default TitleDefault TitleDefault Title
Installation Time~20 minutesN/A (bundle)N/AN/AN/A
Battery LifeUp to 12 months (4 AA batteries)Includes Wyze Lock Bolt with same battery lifeN/AN/AN/A
Weather ResistanceIPX5Depends on included devices (Wyze Lock Bolt IPX5)N/AN/AN/A
Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns
Additional NotesLocal Bluetooth connection, hardware encryption, two-factor authenticationLock/unlock door from video doorbell viewerReplacement screws set for lock boltReplacement interior battery coverMetal plate anchors interior assembly to door
What is the Wyze Lock Bolt and how does it work?The Wyze Lock Bolt is a Bluetooth-enabled smart deadbolt designed to replace your traditional door lock. It allows you to lock and unlock your door using the Wyze app, a fingerprint sensor, or a backlit keypad. The lock offers keyless entry, remote control within Bluetooth range, and advanced security features for enhanced home protection.
How can I control the Wyze Lock Bolt remotely?You can control the Wyze Lock Bolt remotely via the Wyze app on your smartphone. Using Bluetooth 5.0, you can lock or unlock your door from up to 16 feet away, monitor access history, and manage user codes for family, friends, or service providers.
What security features does the Wyze Lock Bolt offer?The Wyze Lock Bolt features an ultra-fast fingerprint sensor, a backlit keypad with anti-peep technology, auto-lock functionality, lock and unlock history tracking, a built-in alarm for jam detection, and the ability to generate emergency one-time codes for temporary access.
Is the Wyze Lock Bolt weather resistant?Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance, making it suitable for various weather conditions. The keypad operates in temperatures from -13°F to 122°F, while the lock assembly functions from 32°F to 122°F.
What doors are compatible with the Wyze Lock Bolt?The Wyze Lock Bolt fits doors that are 1-3/8” to 1-3/4” thick and supports backset options of 2-3/8” or 2-3/4”. It is designed to replace most standard deadbolts without complicated wiring.
How long does the Wyze Lock Bolt battery last and what type does it use?The Wyze Lock Bolt is powered by 4 AA batteries, which are included with the lock. The batteries typically last 10-12 months under normal usage.
What replacement parts are available for the Wyze Lock Bolt?Wyze offers several replacement parts for the Lock Bolt, including Wyze Lock Bolt Screws, the Interior Assembly Battery Cover, and the Interior Assembly Metal Plate. All parts are designed for easy installation and come with a 30-day hassle-free return policy.
What is included in the Wyze Essential Security Bundle?The Wyze Essential Security Bundle includes the Wyze Lock Bolt, Wyze Video Doorbell v2, Wyze Cam Pan v3, and two Wyze Cam OG Cameras. This bundle provides comprehensive home security with smart locks and cameras that can be monitored and controlled via the Wyze app.
Can I monitor who enters and exits my home with the Wyze Lock Bolt?Yes, the Wyze Lock Bolt provides detailed lock and unlock history through the Wyze app, allowing you to track who enters and exits your home and when.
Does the Wyze Lock Bolt support temporary access codes?Yes, the Wyze Lock Bolt allows you to generate emergency one-time codes and share temporary or permanent access codes with guests, family members, or service personnel for secure, flexible access management.
What colors are available for the Wyze Lock Bolt?The Wyze Lock Bolt is available in Matte Black and Satin Nickel finishes to match your home’s style.
How does the auto-lock function work on the Wyze Lock Bolt?The auto-lock function automatically secures your door after a set period of time, ensuring your home remains locked even if you forget to do it manually.
Is the Wyze Lock Bolt easy to install?Yes, the Wyze Lock Bolt is designed for easy installation and can replace your existing deadbolt without the need for complicated wiring or professional assistance.
How does the Wyze Lock Bolt integrate with other Wyze smart home devices?The Wyze Lock Bolt works seamlessly with other Wyze smart home devices, such as cameras and video doorbells, allowing you to manage and monitor your home’s security from a single app for a connected smart home experience.
What are the key features of the Wyze Lock Bolt?How does the Wyze app enhance the functionality of the Wyze Lock Bolt?Do you have any deals, ongoing sales, discounts, or promotions?
