How to Use Wyze Lock Keypad Without Phone or Keys
If you're looking for a convenient way to unlock your door without relying on your phone or physical keys, the
Wyze Lock Bolt combined with the
Wyze Lock Keypad offers a seamless solution. This smart lock system allows you to enter your home securely using a backlit keypad or fingerprint sensor, eliminating the need for keys or app access every time.
Wyze Lock Bolt: Key Features for Keyless Entry
The Wyze Lock Bolt is designed to replace your existing deadbolt with a smart, secure alternative that offers multiple ways to unlock your door without keys or a phone.
Keypad Access and Fingerprint Unlock
- Backlit Keypad with Anti-Peep: Enter your access code even in the dark, with the ability to add random digits before or after your code for extra security.
- Ultra-Fast Fingerprint Sensor: Unlock your door in less than a second with just a touch of your finger.
- Emergency One-Time Codes: Provide temporary access to guests or service providers without sharing permanent codes.
Auto-Lock and Security Features
- Auto-Lock Function: The lock automatically secures your door after a set time, so you never have to worry about forgetting to lock up.
- Built-in Alarm for Jam Detection: Alerts you if the lock mechanism is obstructed or tampered with.
- Pick Proof and Weather Resistant: Rated IPX5, the lock withstands rain and weather, and its design eliminates traditional keyholes to prevent lock picking.
Easy Installation and Battery Life
- Quick 20-Minute Installation: Fits most US doors with standard deadbolt dimensions.
- Long Battery Life: Powered by 4 AA batteries (included), lasting 10-12 months.
- Emergency USB-C Charging: If batteries run low, a quick charge lets you unlock with your code temporarily.
The Wyze Lock Bolt is perfect for those who want fast, secure, and keyless entry without relying on their smartphone.
Experience keyless convenience with Wyze Lock Bolt at your front door.
Using the Wyze Lock Keypad Without a Phone
The
Wyze Lock Keypad pairs directly with your Wyze Lock Bolt via Bluetooth, allowing you to unlock your door using a secure PIN code without needing your phone.
Setting Up the Keypad
- Installation: Mount the keypad using the included adhesive and screws. Insert the 2 AA batteries and attach the keypad to the mounting plate.
- Pairing: Press and hold the lock button on the keypad until the status light flashes green, then follow the Wyze app prompts to complete setup.
- Create Your Access Code: Set a 4-8 digit PIN code in the app, which you can use directly on the keypad to unlock your door.
Using the Keypad Daily
- Simply enter your PIN code on the backlit keypad to unlock the door.
- The keypad supports Anti-Peep mode, so you can add extra digits before or after your code to prevent others from guessing.
- You can create multiple unique codes for family members or guests.
- The keypad works within a Bluetooth range of about 50 feet from the lock.
Troubleshooting Tips
- If the keypad is unresponsive, try removing and reinserting the batteries to reboot it.
- Ensure the keypad is within Bluetooth range of the lock.
- Double-check your PIN code and create a new one if needed via the Wyze app.
- Make sure the Wyze Lock Bolt is online and responsive in the app.
Using the keypad means you can leave your phone and keys inside and still have secure, easy access to your home.
Wyze Lock Keypad offers secure, keyless entry with a simple PIN code.
Enhance Your Home Security with the Essential Security Bundle
For a comprehensive smart home security setup, consider the
Essential Security Bundle which includes the Wyze Lock Bolt and Keypad, plus additional devices to monitor and protect your home.
Bundle Includes:
- Wyze Video Doorbell v2: See and talk to visitors in crisp 1080p HD video with two-way audio.
- Wyze Lock Bolt: Keyless entry with fingerprint sensor and keypad.
- Wyze Cam Pan v3: Pan-and-tilt camera with 360° horizontal and 180° vertical coverage, color night vision, and motion tracking.
- Two Wyze Cam OG Cameras: Versatile indoor/outdoor cameras with motion-activated spotlights and color night vision.
This bundle ensures you can control access to your home without keys or phones while keeping an eye on your property from anywhere.
The Essential Security Bundle is your all-in-one solution for keyless entry and full home monitoring.
Secure your home with Wyze’s smart lock and cameras for peace of mind.
Summary
Using the
Wyze Lock Bolt with the
Wyze Lock Keypad allows you to unlock your door quickly and securely without needing your phone or keys. The keypad provides a reliable PIN code entry method with anti-peep security, while the lock offers fingerprint unlocking and auto-lock features. For enhanced home security, the Essential Security Bundle combines these with smart cameras and a video doorbell to keep your home safe from every angle.
### Product Tags and Highlights
How can I unlock my door without a phone or keys using Wyze Lock Bolt and Keypad?
You can unlock your door without a phone or physical keys by using the Wyze Lock Bolt in combination with the Wyze Lock Keypad. Simply enter your secure PIN code on the backlit keypad or use the ultra-fast fingerprint sensor for keyless entry.What are the main features of the Wyze Lock Bolt for keyless entry?
The Wyze Lock Bolt offers a backlit keypad with anti-peep technology, an ultra-fast fingerprint sensor, emergency one-time codes for guests, auto-lock functionality, a built-in alarm for jam detection, pick-proof and weather-resistant design, easy 20-minute installation, long battery life, and emergency USB-C charging.How do I set up the Wyze Lock Keypad without using my phone for daily access?
After installing and pairing the Wyze Lock Keypad with your Wyze Lock Bolt via Bluetooth, you can create a 4-8 digit PIN code in the Wyze app. Once set up, you can unlock your door by entering your PIN directly on the keypad, without needing your phone.What is anti-peep mode on the Wyze Lock Keypad and how does it work?
Anti-peep mode allows you to add random digits before or after your actual PIN code when entering it on the keypad. This prevents others from guessing your code by watching your finger movements, enhancing your home security.Can I create multiple PIN codes for family members or guests with the Wyze Lock Keypad?
Yes, the Wyze Lock Keypad allows you to create multiple unique PIN codes for different family members or guests. You can also generate emergency one-time codes for temporary access.What should I do if my Wyze Lock Keypad is unresponsive?
If your Wyze Lock Keypad is unresponsive, try removing and reinserting the batteries to reboot it. Ensure the keypad is within Bluetooth range of the lock, double-check your PIN code, and make sure the Wyze Lock Bolt is online and responsive in the app.How long does the Wyze Lock Bolt battery last and what happens if it runs low?
The Wyze Lock Bolt is powered by 4 AA batteries that typically last 10-12 months. If the batteries run low, you can use the emergency USB-C charging port to temporarily power the lock and unlock your door with your code.Is the Wyze Lock Bolt weather resistant and secure against lock picking?
Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance, making it suitable for outdoor use. Its design eliminates traditional keyholes, making it pick-proof and more secure against tampering.What is included in the Wyze Essential Security Bundle?
The Essential Security Bundle includes the Wyze Lock Bolt, Wyze Lock Keypad, Wyze Video Doorbell v2, Wyze Cam Pan v3, and two Wyze Cam OG Cameras. This bundle provides keyless entry and comprehensive home monitoring for enhanced security.How easy is it to install the Wyze Lock Bolt and Keypad?
The Wyze Lock Bolt is designed for quick installation, fitting most US doors with standard deadbolt dimensions in about 20 minutes. The Wyze Lock Keypad can be mounted using the included adhesive and screws, making setup simple and convenient.
