Wyze Indoor Security Keypad with Emergency Alarm Function
When it comes to enhancing your home security, having a reliable indoor security keypad with an emergency alarm function is essential. Wyze offers a smart and efficient solution with the
Wyze Sense Keypad, designed to seamlessly integrate with your Wyze Home Monitoring system. This keypad not only allows you to arm and disarm your security system remotely but also features an emergency button to alert first responders instantly, providing peace of mind for you and your family.
Wyze Sense Keypad: Smart Indoor Security Control
Key Features and Specifications
- Remote Arm and Disarm: Control your home security system from anywhere using the Wyze app.
- Emergency Alarm Button: Quickly send alerts to first responders in case of emergencies.
- Indoor Use: Designed specifically for indoor environments with a sleek, compact design.
- Permanent Adhesive: Easy installation with a secure adhesive mount.
- Supports Up to 100 Accessories: Expand your security system with multiple sensors and devices.
- Requires Wyze Sense Hub: Works in conjunction with the Wyze Sense Hub and Wyze Home Monitoring service.
The Wyze Sense Keypad is an indispensable part of a comprehensive home security setup, offering quick access to system controls and emergency assistance at your fingertips.
"Disarm your home security remotely and stay safe with the emergency alarm function."
Wyze Sense Keypad - Smart indoor security control
Complementary Wyze Security Cameras for Enhanced Monitoring
To complement the Wyze Sense Keypad and maximize your home security, consider integrating Wyze’s advanced indoor/outdoor cameras. These cameras provide real-time video surveillance, motion detection, and two-way audio, making them perfect partners for your security keypad.
Wyze Cam Pan v3
- 360° Pan and 180° Tilt: Complete coverage with smooth, fast rotation up to 110° per second.
- 1080p Full HD Video: Crisp, clear video quality day and night.
- Night Vision: Equipped with 4 IR LEDs for clear night-time monitoring.
- Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation.
- IP65 Weather Resistant: Suitable for both indoor and outdoor use (outdoor use requires separate power adapter).
- Smart Alerts: Receive push notifications for motion and sound detection.
- Compatibility: Works with Alexa, Google Assistant, and IFTTT for smart home integration.
Pan v3 Security Bundle
This bundle includes two Wyze Cam Pan v3 cameras with all necessary accessories, ideal for securing multiple areas of your home.
"Experience 360° security coverage with smart alerts and two-way communication."
Wyze Cam Pan v3 - Weather-resistant security camera
Pan v3 Outdoor Bundle
For those needing robust outdoor surveillance, the Pan v3 Outdoor Bundle offers the same advanced camera features with enhanced weather resistance (IP67 rating) and extended cable lengths for flexible installation.
Why Choose Wyze for Your Home Security?
Wyze products are designed to work together seamlessly, providing a comprehensive and affordable home security ecosystem. The
Wyze Sense Keypad with its emergency alarm function is a vital component that enhances your control and safety. Paired with the
Wyze Cam Pan v3 cameras, you get a powerful combination of monitoring and quick response capabilities.
"Wyze delivers smart, reliable, and easy-to-use home security solutions that keep your family safe."
Summary of Relevant Products
Wyze Sense Keypad
Disarm your home security remotely with an emergency button for quick alerts. Requires Wyze Sense Hub and Wyze Home Monitoring.
Wyze Cam Pan v3
Indoor/outdoor 360° pan and 180° tilt camera with 1080p HD video, night vision, and two-way audio.
Two Wyze Cam Pan v3 cameras with accessories for multi-area security coverage.
Weather-resistant Pan v3 cameras with extended cables for outdoor installation.
Enhance your home security today with Wyze’s innovative keypad and camera solutions, combining smart technology with user-friendly features to keep your home safe and secure.
What is the Wyze Sense Keypad and how does it enhance home security?
The Wyze Sense Keypad is an indoor security keypad designed to work with the Wyze Home Monitoring system. It allows you to arm and disarm your security system remotely and features an emergency alarm button to instantly alert first responders, providing enhanced safety and peace of mind for your home.How do I install the Wyze Sense Keypad?
The Wyze Sense Keypad is designed for easy indoor installation using a permanent adhesive mount. Simply attach the keypad to a convenient location inside your home and connect it to your Wyze Sense Hub to start using it.Does the Wyze Sense Keypad require any additional equipment?
Yes, the Wyze Sense Keypad requires the Wyze Sense Hub and an active Wyze Home Monitoring subscription to function properly. It is designed to integrate seamlessly with the Wyze security ecosystem.What is the emergency alarm function on the Wyze Sense Keypad?
The emergency alarm function is a dedicated button on the Wyze Sense Keypad that, when pressed, sends an instant alert to first responders through your Wyze Home Monitoring service, ensuring quick assistance during emergencies.Can I control my Wyze security system remotely with the Wyze Sense Keypad?
Yes, you can arm and disarm your Wyze security system remotely using the Wyze app in conjunction with the Wyze Sense Keypad, giving you flexible control over your home security from anywhere.How many accessories can the Wyze Sense Keypad support?
The Wyze Sense Keypad supports up to 100 accessories, allowing you to expand your home security system with additional sensors and devices for comprehensive protection.What are the key features of the Wyze Cam Pan v3 security camera?
The Wyze Cam Pan v3 offers 360° pan and 180° tilt for complete coverage, 1080p Full HD video, night vision with 4 IR LEDs, two-way audio with noise and echo cancellation, IP65 weather resistance, smart alerts for motion and sound detection, and compatibility with Alexa, Google Assistant, and IFTTT.Is the Wyze Cam Pan v3 suitable for outdoor use?
Yes, the Wyze Cam Pan v3 is IP65 weather resistant and can be used outdoors with a separate power adapter. For enhanced outdoor durability, the Pan v3 Outdoor Bundle offers cameras with an IP67 rating and extended cable lengths.What is included in the Pan v3 Security Bundle?
The Pan v3 Security Bundle includes two Wyze Cam Pan v3 cameras along with all necessary accessories, making it ideal for securing multiple areas of your home with advanced monitoring features.Why should I choose Wyze for my home security needs?
Wyze offers smart, reliable, and affordable home security solutions that work together seamlessly. With products like the Wyze Sense Keypad and Wyze Cam Pan v3, you get comprehensive monitoring, quick emergency response, and user-friendly controls to keep your family safe.
