Reliable Wireless Home Monitoring Kit with Motion and Entry Sensors
When it comes to securing your home, having a reliable wireless monitoring system that includes both motion and entry sensors is essential. Wyze offers a comprehensive home monitoring kit designed to keep your property safe with smart, easy-to-install devices that work seamlessly together. Whether you want to monitor movement inside your home or detect when doors and windows open, Wyze’s wireless sensors and hub provide a robust solution.
Wyze Sense Motion Sensor: Smart Motion Detection
The
Wyze Sense Motion Sensor is engineered to detect motion up to 25 feet within a wide 120° field of view. This sensor is perfect for monitoring hallways, entryways, or any room where you want to be alerted to movement.
- Compatibility: Requires Wyze Sense Hub or Wyze Home Monitoring system (v2).
- Detection Range: Up to 25 feet with a 120° field of view.
- Pet-Friendly: Adjustable sensitivity and “large pet installation” options help avoid false alarms caused by pets.
- Installation: Easy adhesive backing for quick setup on walls, with optional screws for added security.
- Alerts: Instant notifications sent to your phone when motion is detected.
This sensor is ideal for anyone looking to enhance their home security with reliable motion detection that distinguishes between people and pets.
Wyze Sense Entry Sensor: Monitor Doors and Windows
Complement your motion detection with the
Wyze Sense Entry Sensor, designed to alert you whenever doors, windows, or cabinets are opened or closed.
- Compatibility: Works with Wyze Sense Hub or Wyze Home Monitoring (v2).
- Pack Size: Available in a convenient 3-pack to cover multiple entry points.
- Installation: Compact and easy to mount with adhesive backing.
- Functionality: Perfect for monitoring entry points to your home, alerting you instantly to any unauthorized access.
Together with the motion sensor, the entry sensor forms a comprehensive perimeter security system that keeps you informed about all critical access points.
Wyze Sense Hub: The Central Command for Your Sensors
At the heart of the Wyze monitoring system is the
Wyze Sense Hub, the essential device that connects all your sensors and manages alerts.
- Connectivity: Supports Ethernet, Wi-Fi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915 MHz RF communication.
- Range: Communicates with sensors up to 500 feet away, ensuring wide coverage.
- Battery Backup: Built-in rechargeable battery with up to 10 hours of backup power.
- Siren: Loud 88 dB siren to deter intruders.
- Capacity: Supports up to 100 sensors, allowing you to expand your system as needed.
- Indoor Use: Designed for indoor installation with a sleek white and grey matte finish.
The hub is the “brains” of your home monitoring kit, ensuring all sensors work in harmony and that you receive timely alerts.
Wyze Sense Keypad: Convenient Remote Control
For added convenience, the
Wyze Sense Keypad allows you to arm or disarm your home security system remotely.
- Functionality: Arm/disarm system and send emergency alerts.
- Compatibility: Requires Wyze Home Monitoring and the Wyze Sense Hub.
- Installation: Indoor use with permanent adhesive mounting.
- Emergency Button: Quickly notify first responders in case of an emergency.
This keypad adds an extra layer of control and peace of mind, especially useful for families or multi-user households.
Enhance Your Security with Wyze Cameras
While the focus is on motion and entry sensors, pairing these with Wyze’s advanced cameras like the
Wyze Cam v4 or
Wyze Cam Pan v3 can provide visual confirmation and continuous surveillance.
- Wyze Cam v4: Offers crystal-clear 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, and 24/7 local recording. It supports Wi-Fi 6 and integrates with Alexa and Google Assistant.
- Wyze Cam Pan v3: Features 360° horizontal and 180° vertical coverage with 1080p resolution, IP65 weather resistance, and two-way audio, making it perfect for indoor/outdoor use.
Together, these cameras complement the sensors by providing real-time video monitoring and alerts.
Wyze Cam Pan v3 offers weather-resistant 360° coverage for outdoor security.
Why Choose Wyze Wireless Home Monitoring Kit?
“Wyze’s wireless home monitoring kit combines smart sensors, a powerful hub, and convenient control options to deliver reliable, pet-friendly, and scalable home security.”
- Easy installation with adhesive or screws.
- Wide sensor compatibility and long communication range.
- Real-time alerts and emergency response features.
- Expandable system supporting up to 100 sensors.
- Integration with smart home assistants for seamless control.
With Wyze, you get a comprehensive, reliable, and affordable wireless home monitoring solution that keeps your home safe and connected.
Wyze Sense Keypad lets you arm and disarm your system with ease.
Summary of Wyze Wireless Home Monitoring Products
Product | Key Features | Price (USD) |
Wyze Sense Motion Sensor | Motion detection up to 25 ft, pet-friendly | $20.98 (1 Pack) |
Wyze Sense Entry Sensor | Detects open/close of doors/windows (3 Pack) | $41.98 |
Wyze Sense Hub | Central hub, supports 100 sensors, siren | $45.98 |
Wyze Sense Keypad | Arm/disarm system remotely, emergency button | $27.98 |
Conclusion
For a reliable wireless home monitoring kit with motion and entry sensors, Wyze offers a complete ecosystem that is easy to install, scalable, and packed with smart features. The combination of Wyze Sense Motion and Entry Sensors with the Wyze Sense Hub and Keypad ensures your home is monitored effectively, giving you peace of mind whether you’re home or away.
What is included in the Wyze Wireless Home Monitoring Kit?
The Wyze Wireless Home Monitoring Kit includes Wyze Sense Motion Sensors, Wyze Sense Entry Sensors, the Wyze Sense Hub, and the Wyze Sense Keypad. These components work together to provide comprehensive security coverage for your home.How does the Wyze Sense Motion Sensor work?
The Wyze Sense Motion Sensor detects movement up to 25 feet away within a 120° field of view. It sends instant notifications to your phone when motion is detected and features adjustable sensitivity to help avoid false alarms caused by pets.Can the Wyze Sense Motion Sensor distinguish between people and pets?
Yes, the Wyze Sense Motion Sensor is pet-friendly. It offers adjustable sensitivity settings and a 'large pet installation' option to help prevent false alarms triggered by pets.What does the Wyze Sense Entry Sensor monitor?
The Wyze Sense Entry Sensor monitors the open and close status of doors, windows, and cabinets. It alerts you instantly whenever an entry point is accessed, helping you detect unauthorized access.How do I install Wyze sensors?
Wyze sensors are designed for easy installation using adhesive backing. For added security, you can also use screws. The compact design allows for quick and discreet mounting on walls, doors, or windows.What is the function of the Wyze Sense Hub?
The Wyze Sense Hub acts as the central command center for your sensors. It connects all your Wyze sensors, manages alerts, supports up to 100 sensors, and features a loud 88 dB siren and up to 10 hours of battery backup.How far can Wyze sensors communicate with the Wyze Sense Hub?
Wyze sensors can communicate with the Wyze Sense Hub from up to 500 feet away, ensuring wide coverage throughout your home.What is the Wyze Sense Keypad used for?
The Wyze Sense Keypad allows you to arm or disarm your home security system remotely. It also features an emergency button to quickly notify first responders in case of an emergency.Are Wyze home monitoring products compatible with smart home assistants?
Yes, Wyze home monitoring products, including Wyze cameras, integrate with smart home assistants like Alexa and Google Assistant for seamless control.Can I expand my Wyze home monitoring system?
Yes, the Wyze Sense Hub supports up to 100 sensors, allowing you to expand your system as needed to cover more areas of your home.How do Wyze cameras enhance home security?
Wyze cameras, such as the Wyze Cam v4 and Wyze Cam Pan v3, provide real-time video monitoring, motion-activated alerts, and features like color night vision, 360° coverage, and two-way audio. They complement the sensors by offering visual confirmation and continuous surveillance.Is the Wyze home monitoring system easy to install?
Yes, the Wyze home monitoring system is designed for easy DIY installation with adhesive or screws, making it simple for anyone to set up without professional help.Does the Wyze Sense Hub have a backup battery?
Yes, the Wyze Sense Hub includes a built-in rechargeable battery that provides up to 10 hours of backup power in case of an outage.Is the Wyze home monitoring system suitable for families with pets?
Absolutely. The Wyze Sense Motion Sensor is pet-friendly, with adjustable sensitivity and installation options to minimize false alarms caused by pets.What is the price of Wyze home monitoring products?
As of the latest update, the Wyze Sense Motion Sensor is $20.98 (1 pack), the Wyze Sense Entry Sensor is $41.98 (3 pack), the Wyze Sense Hub is $45.98, and the Wyze Sense Keypad is $27.98.
