Best Smart Devices Package for Airbnb Short Term Rentals
Creating a seamless, secure, and comfortable experience for your Airbnb guests is essential to earning great reviews and repeat bookings. Equipping your rental property with smart devices tailored for convenience, security, and ambiance can elevate your guests' stay while simplifying your management tasks. Below, we highlight the best smart devices package designed specifically for Airbnb short term rentals, featuring top-rated products that combine functionality, ease of use, and modern technology.
Smart Home Control & Entertainment: Google Nest Hub (2nd Gen) + Wyze Bundles
Overview
The Google Nest Hub (2nd Gen) paired with Wyze smart cameras offers an all-in-one solution for entertainment, monitoring, and smart home control. This bundle is perfect for Airbnb hosts who want to provide guests with intuitive control over the home environment while ensuring safety and convenience.
Key Features
- Wyze Cam v3 and Wyze Cam Pan v3: Award-winning cameras that provide clear, reliable video monitoring to keep an eye on your property.
- Google Nest Hub 2nd Gen: A smart display that allows guests to control Wyze devices, play music, check weather, and manage smart home features with voice or touch.
- Privacy Controls: Easily turn off the microphone with a physical switch for guest privacy.
- Improved Audio: Enhanced speaker with 50% more bass for better entertainment.
- Sleep Sense Assistant: Helps guests improve their sleep quality with smart monitoring (free trial available).
- Seamless Integration: Works smoothly with Google Assistant and Wyze smart home devices.
This bundle not only enhances guest experience but also gives hosts peace of mind with remote monitoring capabilities.
Secure Access Management: Wyze Lock Bolt
Overview
Security is paramount for any short term rental. The Wyze Lock Bolt is a Bluetooth-enabled smart lock that replaces your traditional deadbolt, offering keyless entry with advanced features designed for Airbnb hosts and guests.
Key Features
- Ultra-Fast Fingerprint Sensor: Unlock the door instantly with a fingerprint scan.
- Backlit Keypad with Anti-Peep: Guests can enter access codes securely without worrying about prying eyes.
- Auto-Lock Function: Automatically locks the door after a set time, ensuring the property is always secure.
- Remote Access History: Hosts can monitor lock/unlock events via the Wyze app.
- Emergency One-Time Codes: Generate temporary access codes for guests or service personnel.
- Weather Resistant (IPX5): Durable for outdoor use in various climates.
- Easy Installation: Replaces existing deadbolts without complicated setup.
This smart lock enhances security and convenience, eliminating the hassle of physical keys and providing flexible access control.
Ambiance & Lighting: Wyze Light Party
Overview
Create the perfect atmosphere for your Airbnb with the Wyze Light Party smart lighting system. This package offers vibrant, customizable lighting options that guests can control easily via the Wyze app or voice assistants.
Key Features
- 16 Million Colors: Choose from a vast palette including RGB and tunable white to match any mood or occasion.
- Adjustable Brightness: Perfect for relaxing evenings or bright task lighting.
- Multiple Styles: Options include Wyze BR30 bulbs and a 32-foot Wyze Light Strip for versatile installation.
- Smart Control: Compatible with Alexa, Google Assistant, and IFTTT for voice or automated control.
- Long Life Expectancy: Up to 25,000 hours of use.
- Suitable for Damp Locations: Safe for kitchens, bathrooms, and covered outdoor areas.
With Wyze Light Party, you can impress guests with dynamic lighting scenes that enhance their stay.
Air Quality & Comfort: Wyze Air Filter
Overview
Air quality is a critical factor in guest comfort, especially in urban or wildfire-prone areas. The Wyze Air Filter offers customizable filtration options to ensure your Airbnb’s indoor air is clean and healthy.
Key Features
- Custom Filters: Choose from Allergen Filter (Standard), Formaldehyde Filter (Premium), or Wildfire Filter (Special Use) to target specific air quality concerns.
- HEPA Filtration: High-efficiency particulate air filters remove allergens, bacteria, and viruses.
- Activated Carbon Layer: Reduces odors and harmful gases.
- High CADR Ratings: Efficiently cleans air in medium to large rooms.
- Long Service Life: Filters last between 4 to 12 months depending on type.
- Compact Size: Fits easily in any room without taking up much space.
Providing clean air enhances guest satisfaction and promotes a healthier environment.
Essential Power Protection: Wyze Surge Protector
Overview
Protect your smart devices and provide convenient charging options with the Wyze Surge Protector. This accessory is a must-have for any Airbnb rental to safeguard electronics and keep devices powered.
Key Features
- 3 USB Ports: Charge multiple devices simultaneously with a total output of 5V/3.1A.
- 3 Grounded Outlets: Plug in essential appliances and smart devices.
- Surge Protection: 268 joules suppression rating to protect against power spikes.
- Flame Resistant Design: Safety certified with UL and FCC approvals.
- Low Profile & Slim Design: Fits neatly behind furniture with a right-angle flat plug.
- Overload Protection: Automatically shuts off when current limits are exceeded.
This surge protector ensures your guests’ devices stay safe and charged throughout their stay.
Why Choose This Smart Devices Package for Your Airbnb?
"Smart technology in short term rentals not only enhances guest comfort but also streamlines property management, improves security, and adds a modern touch that guests appreciate."
By combining smart home control, secure access, customizable lighting, air quality management, and power protection, this package covers all essential aspects of a modern Airbnb rental. These devices are easy to install, user-friendly, and designed to work together seamlessly, making your property stand out in a competitive market.
Summary of Featured Products
Product Name | Key Benefit | Price Range (USD) |
Google Nest Hub + Wyze Bundles | Smart home control & camera | From $120.99 |
Wyze Lock Bolt | Secure keyless entry | $79.98 |
Wyze Light Party | Customizable smart lighting | From $59.98 |
Wyze Air Filter | Personalized air purification | From $37.99 |
Wyze Surge Protector | Device power & surge safety | $4.99 |
Equip your Airbnb with these smart devices to create a safer, smarter, and more inviting rental experience that guests will love.
What are the best smart devices for Airbnb short term rentals?
The best smart devices for Airbnb short term rentals include the Google Nest Hub (2nd Gen) with Wyze smart cameras for home control and monitoring, Wyze Lock Bolt for secure keyless entry, Wyze Light Party for customizable smart lighting, Wyze Air Filter for clean indoor air, and Wyze Surge Protector for device safety and convenient charging.How does the Google Nest Hub (2nd Gen) enhance the Airbnb guest experience?
The Google Nest Hub (2nd Gen) allows Airbnb guests to control smart home devices, play music, check the weather, and manage entertainment with voice or touch. It integrates seamlessly with Wyze cameras and other smart devices, offering intuitive control and improved security for both guests and hosts.What security features does the Wyze Lock Bolt offer for Airbnb hosts?
The Wyze Lock Bolt provides ultra-fast fingerprint unlocking, a backlit keypad with anti-peep technology, auto-lock functionality, remote access history via the Wyze app, emergency one-time codes for guests, weather resistance, and easy installation, making it ideal for secure and convenient Airbnb access management.Can guests control the smart lighting in the Airbnb rental?
Yes, with the Wyze Light Party smart lighting system, guests can choose from 16 million colors, adjust brightness, and control lighting via the Wyze app or voice assistants like Alexa and Google Assistant, creating the perfect ambiance for any occasion.How does the Wyze Air Filter improve air quality in Airbnb properties?
The Wyze Air Filter uses customizable HEPA filters to remove allergens, bacteria, and viruses, and features an activated carbon layer to reduce odors and harmful gases. It offers different filter options for allergens, formaldehyde, or wildfire smoke, ensuring clean and healthy air for guests.Why is a surge protector important for Airbnb rentals?
A surge protector like the Wyze Surge Protector safeguards smart devices and guest electronics from power spikes, offers multiple USB ports and grounded outlets for convenient charging, and features overload and flame-resistant protection, ensuring safety and convenience for both guests and hosts.Are these smart devices easy to install in an Airbnb property?
Yes, all featured smart devices are designed for easy installation and user-friendly operation. The Wyze Lock Bolt replaces existing deadbolts without complicated setup, and other devices like the Google Nest Hub, Wyze cameras, and smart lighting can be set up quickly and managed through intuitive apps.How do smart devices benefit Airbnb hosts?
Smart devices streamline property management, enhance security, improve guest comfort, and add a modern touch to Airbnb rentals. They allow for remote monitoring, flexible access control, customizable ambiance, better air quality, and device protection, helping hosts earn better reviews and attract more bookings.What is included in the recommended smart devices package for Airbnb?
The recommended package includes the Google Nest Hub (2nd Gen) with Wyze smart cameras, Wyze Lock Bolt smart lock, Wyze Light Party smart lighting system, Wyze Air Filter, and Wyze Surge Protector, covering all essential aspects of a modern and secure Airbnb rental.Are the smart devices compatible with popular voice assistants?
Yes, the smart devices such as Wyze Light Party and Google Nest Hub are compatible with popular voice assistants like Google Assistant and Alexa, allowing guests to control lighting and other features using simple voice commands.
