Advanced Waterproof Floodlight Security Cameras with 160° Motion Sensor
Advanced Waterproof Outdoor Floodlight Security Cameras with 160° Wide-Angle Motion Sensor and LED Spotlight
When it comes to securing your home or business outdoors, having a reliable floodlight security camera that combines powerful illumination, wide-angle coverage, and smart motion detection is essential. Whether you want to deter intruders, monitor your driveway, or keep an eye on your property at night, these advanced waterproof floodlight cameras deliver exceptional performance with smart features designed for modern security needs. Below, we explore the top Wyze floodlight security cameras that meet your criteria: advanced waterproof design, 160° or wider motion sensor coverage, and bright LED spotlights.
Wyze Cam Floodlight v2: Bright, Smart, and Wide-Angle Security
Wyze Cam Floodlight v2 illuminating driveway at night Powerful floodlight camera lighting up a driveway with motion detection The Wyze Cam Floodlight v2 is a standout choice for anyone seeking an advanced outdoor floodlight camera with a 160° wide-angle view and robust LED lighting. This model offers:
  • 160° Wide-Angle View: Double the visibility compared to previous generations, covering a broad area to reduce blind spots.
  • 2800 Lumens LED Spotlight: Two adjustable, motion-activated floodlights that turn night into day, deterring unwanted visitors effectively.
  • 2K Video with Color Night Vision: Crystal-clear video quality ensures you capture every detail, even in low light.
  • AI-Powered Light Control & Ambient Light Mode: The floodlight provides a constant low-level glow and brightens instantly when motion is detected.
  • 24/7 Local Recording: Continuous recording to a microSD card (up to 256GB) without subscription fees.
  • Two-Way Talk & Loud Siren: Communicate with visitors or scare off intruders with a 105dB siren.
  • Dusk-to-Dawn Automation: Automatically turns on and off based on ambient light.
  • IP65 Weather Resistance: Built to withstand rain, snow, and harsh outdoor conditions.
  • Smart Assistant Integration: Compatible with Alexa and Google Home for voice control and smart alerts.
This floodlight camera is perfect for homeowners who want a powerful, easy-to-install security solution that lights up and watches over large outdoor spaces with precision.
Wyze Cam Floodlight Pro: Ultimate Coverage and Intelligent Detection
Woman with dog near Wyze Cam Floodlight Pro Lifestyle image showing Wyze Cam Floodlight Pro providing security and communication For those who demand the highest level of outdoor security, the Wyze Cam Floodlight Pro offers an enhanced experience with:
  • 180° Wide-Angle Lens: Expansive diagonal field of view covers your yard end-to-end.
  • 2.5K QHD Video Resolution: Ultra-clear video quality with color night vision for detailed monitoring.
  • 3,000 Lumens LED Lighting: Three dimmable floodlight panels provide bright, customizable illumination.
  • AI-Powered Motion Detection: Onboard AI detects people, vehicles, and other objects, triggering lights only for selected targets.
  • Dual-Band WiFi (2.4 & 5 GHz): Ensures a stable connection even in crowded wireless environments.
  • 105dB Siren: Loud enough to deter intruders effectively.
  • IP65 Waterproof Rating: Reliable performance in all weather conditions.
  • Smart Home Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
This model is ideal for users who want a high-powered, intelligent floodlight camera that acts like a personal security guard, combining bright lighting with smart detection and crisp video.
Wyze Cam v4 Outdoor Bundle: Compact Spotlight Camera with Enhanced Night Vision
While not a floodlight camera per se, the Wyze Cam v4 Outdoor Bundle deserves mention for its advanced spotlight and wide-angle motion detection capabilities:
  • 2.5K QHD Resolution: Superior video clarity with enhanced color night vision.
  • Motion-Activated Spotlight: Bright LED spotlight activates on motion to illuminate and deter.
  • 115.9° Diagonal Field of View: Wide enough to cover most outdoor areas effectively.
  • 24/7 Local Recording: Continuous recording with included 128GB microSD card.
  • IP65 Weather Resistance: Built for outdoor durability.
  • Wi-Fi 6 Support: Faster, more reliable wireless connection.
  • Smart Assistant Integration: Compatible with Alexa and Google Assistant.
This bundle includes the camera, outdoor power adapter, and microSD card, making it a convenient all-in-one solution for outdoor security with spotlight functionality.
Why Choose a Floodlight Security Camera with 160°+ Wide-Angle and LED Spotlight?
"A wide-angle motion sensor combined with a powerful LED floodlight ensures maximum coverage and visibility, reducing blind spots and deterring intruders effectively."
Outdoor floodlight cameras with wide-angle sensors and bright LED spotlights provide several key benefits:
  • Enhanced Security Coverage: Wide-angle lenses and motion sensors cover large areas, minimizing blind spots.
  • Improved Nighttime Visibility: Bright LED floodlights illuminate dark areas, making it easier to identify people or objects.
  • Smart Motion Detection: AI-powered sensors reduce false alarms by detecting specific objects like people or vehicles.
  • Weatherproof Durability: IP65-rated devices withstand rain, snow, and extreme temperatures.
  • Convenient Smart Features: Integration with voice assistants and mobile apps allows remote monitoring and control.
Summary of Top Advanced Waterproof Outdoor Floodlight Security Cameras
ProductVideo ResolutionField of ViewLED Brightness (Lumens)Motion Sensor CoverageWeather ResistanceSmart FeaturesPrice Range
Wyze Cam Floodlight v22K160°2800270° PIRIP65AI Light Control, Two-Way Talk$89.98
Wyze Cam Floodlight Pro2.5K QHD180°3000AI-PoweredIP65AI Object Detection, Dual-Band WiFi$149.98
Wyze Cam v4 Outdoor Bundle2.5K QHD115.9°Motion-ActivatedWide-AngleIP65Wi-Fi 6, Enhanced Night Vision$69.99
Conclusion
For advanced waterproof outdoor floodlight security cameras with a 160° wide-angle motion sensor and LED spotlight, the Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro stand out as top choices. They combine powerful illumination, wide coverage, and smart AI features to keep your property safe day and night. The Wyze Cam v4 Outdoor Bundle offers a compact alternative with excellent video quality and spotlight capabilities. Choose the model that best fits your security needs and enjoy peace of mind with smart, reliable outdoor surveillance.
FeatureWyze Cam Floodlight v2Wyze Cam v4Wyze Cam Floodlight Pro
Price$89.98$35.98 (single)$149.98
Color VariantsBlack, WhiteBlack, White, Grey, Clear (some sold out)Black, White
Video Resolution2K (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Field of View160° wide-angle115.9° (D) x 98.5° (H) x 53.1° (V)180° Diagonal, 170° Horizontal, 95° Vertical
Night VisionColor Night VisionEnhanced Color Night VisionColor Night Vision
LED Floodlight Brightness2 floodlight heads, 2800 lumensMotion-activated spotlight (brightness not specified)3 dimmable light panels, 3000 lumens total
Motion Detection270° PIR motion detection areaYes, with custom detection zonesAI computer vision with selectable object detection
Two-Way TalkYesYes, enhanced two-way audioNot explicitly stated (likely yes)
Siren105 dB99 dB105 dB
Local StoragemicroSD card up to 256 GB (no subscription required)microSD card up to 256 GB (no subscription required)microSD card up to 256 GB (no subscription required)
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscription
Power SourceHardwiredWired (requires outdoor power adapter sold separately for outdoor use)Hardwired 110-120V AC
Weather ResistanceIP65IP65IP65
AI FeaturesAI-Powered Light Control, Person/Package/Vehicle detection (with Cam Plus)Person, Package, Vehicle detection (with Cam Plus)Onboard AI computer vision for selective motion detection
Connectivity2.4 GHz Wi-Fi2.4 GHz Wi-Fi, Wi-Fi 62.4 & 5 GHz dual-band Wi-Fi
Smart Assistant IntegrationAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Ambient Light ModeYesNoNo
Dusk-to-Dawn AutomationYesNoNo
DimensionsNot specified2in x 2in x 2 3/8in10.2 in x 9.1 in x 7.8 in
WeightNot specified0.49 lb (222 g)2.9 lbs (1.32 kg)
Mounting OptionsWall mount (plug-in mount optional)Stand, Wall, Ceiling, Magnetic wall mountWall, Ceiling
Frame RateNot specifiedDaytime: 20 FPS, Nighttime: 15 FPSDaytime: 20 FPS, Nighttime: 15 FPS
WarrantyNot specified1 Year1 Year
What are the benefits of using a floodlight security camera with a 160° wide-angle motion sensor and LED spotlight?Floodlight security cameras with a 160° wide-angle motion sensor and LED spotlight provide enhanced security coverage by minimizing blind spots, improving nighttime visibility with bright illumination, and deterring intruders. They also offer smart motion detection to reduce false alarms, weatherproof durability for outdoor use, and convenient integration with smart home assistants for remote monitoring and control.
What makes the Wyze Cam Floodlight v2 a good choice for outdoor security?The Wyze Cam Floodlight v2 is an excellent choice for outdoor security because it features a 160° wide-angle view, 2800 lumens of adjustable LED lighting, 2K video with color night vision, AI-powered light control, 24/7 local recording, two-way talk, a loud 105dB siren, dusk-to-dawn automation, IP65 weather resistance, and compatibility with Alexa and Google Home.
How does the Wyze Cam Floodlight Pro differ from the Wyze Cam Floodlight v2?The Wyze Cam Floodlight Pro offers a wider 180° field of view, higher 2.5K QHD video resolution, brighter 3,000 lumens LED lighting with three dimmable panels, advanced AI-powered motion detection for people and vehicles, dual-band WiFi (2.4 & 5 GHz), and compatibility with Alexa, Google Assistant, and IFTTT. It is designed for users seeking ultimate coverage and intelligent detection.
Is the Wyze Cam v4 Outdoor Bundle suitable for outdoor security?Yes, the Wyze Cam v4 Outdoor Bundle is suitable for outdoor security. It features 2.5K QHD resolution, enhanced color night vision, a motion-activated LED spotlight, a 115.9° diagonal field of view, 24/7 local recording with a 128GB microSD card, IP65 weather resistance, Wi-Fi 6 support, and smart assistant integration. It is a compact and convenient solution for outdoor surveillance.
Are Wyze floodlight security cameras weatherproof?Yes, all featured Wyze floodlight security cameras, including the Wyze Cam Floodlight v2, Wyze Cam Floodlight Pro, and Wyze Cam v4 Outdoor Bundle, have an IP65 weather resistance rating. This means they are built to withstand rain, snow, and harsh outdoor conditions.
Do Wyze floodlight security cameras support smart home integration?Yes, Wyze floodlight security cameras support smart home integration. They are compatible with Alexa and Google Assistant, and the Wyze Cam Floodlight Pro also works with IFTTT, allowing for voice control and smart alerts.
Can Wyze floodlight security cameras record video locally without a subscription?Yes, Wyze floodlight security cameras offer 24/7 local recording to a microSD card (up to 256GB for some models) without requiring a subscription. This allows continuous video storage and playback directly from the device.
What is the video resolution of Wyze outdoor floodlight cameras?The Wyze Cam Floodlight v2 records in 2K resolution, while the Wyze Cam Floodlight Pro and Wyze Cam v4 Outdoor Bundle both offer 2.5K QHD video resolution. All models provide clear, detailed video with color night vision for effective monitoring.
How bright are the LED spotlights on Wyze floodlight security cameras?The Wyze Cam Floodlight v2 features 2800 lumens of adjustable LED lighting, while the Wyze Cam Floodlight Pro offers even brighter 3,000 lumens with three dimmable panels. The Wyze Cam v4 Outdoor Bundle includes a motion-activated LED spotlight for targeted illumination.
Do Wyze floodlight security cameras have two-way audio and siren features?Yes, both the Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro include two-way talk functionality and a loud 105dB siren, allowing you to communicate with visitors or deter intruders directly from your mobile device.
What are the key features of the Wyze Cam Floodlight v2?How does the AI-powered motion detection work in the Wyze Cam Floodlight Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam Floodlight cameras?
