Silent Bedroom Air Purifiers: Ultra-Quiet, Low Noise Solutions
Silent Air Purifiers for Bedroom with Low Noise Operation
Creating a peaceful and healthy bedroom environment is essential for restful sleep and overall well-being. If you're searching for a silent air purifier that operates quietly while effectively cleaning your bedroom air, Wyze offers top-tier solutions designed to blend powerful purification with whisper-quiet operation. Below, we explore the best Wyze air purifiers tailored for bedrooms, highlighting their specs, features, and how they ensure low noise without compromising performance.
Wyze Air Purifier: Whisper-Quiet, Smart, and Powerful
Ultra-Quiet Operation for Bedrooms
The Wyze Air Purifier is engineered to operate at an impressively low noise level of 21 decibels—quieter than a purring kitten (25 dB) and softer than light rainfall (50 dB). This makes it ideal for bedrooms where silence is key to a good night's sleep.
High-Efficiency Air Cleaning
With a Clean Air Delivery Rate (CADR) of 350 m³/h (12,000 cubic feet per hour), this purifier cycles the air in your bedroom rapidly, removing allergens, dust, pet dander, smoke, and other pollutants efficiently. It covers rooms up to 550 sq. ft (42 m²), perfect for most bedroom sizes.
Customizable Filters for Your Needs
Choose from three premium filters to match your specific air quality concerns:
  • Allergen Filter (Standard): Combats common allergens with HEPA 13 and granulated carbon.
  • Formaldehyde Filter (Premium): Targets harmful gases and odors including formaldehyde, a carcinogenic VOC found in new furniture and building materials.
  • Wildfire Filter (Special Use): Designed for wildfire smoke and heavy pollution with chemically modified carbon.
Smart Features and Controls
  • Laser Particle Detection: Monitors ultra-fine particles down to 0.3 microns with 100 checks per second for real-time air quality updates.
  • Smart App Integration: Control the purifier remotely via the Wyze app, compatible with Google Home and Alexa. Adjust fan speeds, set schedules, and receive air quality alerts.
  • Auto Mode: Automatically adjusts purification based on detected air quality, so you can set it and forget it.
  • Child Lock and Display Dimming: Perfect for bedrooms with kids, ensuring safe and distraction-free operation.
Easy Maintenance
The purifier features a convenient handle for moving between rooms and simple filter replacement in just three steps, making upkeep hassle-free. Wyze Air Purifier in Bedroom Setting Experience clean, quiet air purification in your bedroom with Wyze Air Purifier.
Refurbished Wyze Air Purifier: Affordable Quiet Air Cleaning
For budget-conscious buyers, the Refurbished Wyze Air Purifier offers the same whisper-quiet operation at 21 decibels and 350 CADR, with premium filters included. Certified CARB compliant and suitable for rooms up to 550 sq. ft, it’s a smart choice for silent bedroom air purification without sacrificing quality.
  • Smart Controls & AQ Alerts: Like the new model, it supports smart home integration and real-time air quality monitoring.
  • Recommended Filter Replacement: Every 6 months to maintain optimal performance.
This refurbished option provides excellent value while maintaining the quiet, effective air cleaning needed for restful sleep.
Wyze Air Filters: Tailor Your Bedroom Air Quality
Customize Your Purification
Wyze offers a range of replacement and custom filters compatible with all Wyze Air Purifiers, allowing you to adapt your air cleaning to seasonal changes or specific concerns:
  • Allergen Filter: Ideal for spring allergies and everyday dust.
  • Formaldehyde Filter: Best for new homes or rooms with chemical odors.
  • Wildfire Filter: Essential during wildfire season or heavy pollution days.
Easy Filter Replacement
Filters are designed for quick swaps, ensuring your purifier runs at peak efficiency with minimal effort. Replacing Wyze Air Purifier Filter Simple and quick filter changes keep your air purifier running silently and efficiently.
Why Choose Wyze for Your Bedroom Air Purifier?
"A luxury air purifier without the luxury price tag."
Wyze combines quiet operation, smart technology, and customizable filtration to deliver clean, fresh air in your bedroom without disturbing your sleep. Whether you prefer a brand-new unit or a refurbished model, Wyze ensures you get premium air quality with whisper-quiet performance.
Summary of Key Specs
FeatureWyze Air Purifier (New & Refurbished)
Noise Level21 decibels (whisper-quiet)
CADR350 m³/h (12,000 cubic feet per hour)
Room CoverageUp to 550 sq. ft (42 m²)
Filter OptionsAllergen, Formaldehyde, Wildfire
Smart ControlsWyze app, Alexa, Google Home
Particle DetectionLaser sensor, 0.3 microns
Filter ReplacementEvery 6 months
CertificationsCARB certified
Invest in a Wyze Air Purifier today to enjoy silent, smart, and effective air purification in your bedroom, ensuring a healthier and more restful environment every night.
FeatureWyze Air Purifier (Refurbished)Wyze Air PurifierWyze Air Filter
TypeRefurbishedConnected HomeConnected Home (Accessory)
Price$139.99$169.99 - $194.99 (depending on filter)$37.99 - $63.99 (depending on filter)
Pre-installed Filter VariantsAny FilterAllergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)Allergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)
CADR (Clean Air Delivery Rate)350 CADR350 CADR (12,000 cu ft/hr)214 - 186 CFM (varies by filter type)
Noise Level21 decibels (whisper-quiet)21 - 54 decibelsN/A
Filter TypePremium filtersTrue HEPA + Activated Carbon (varies by filter)Pre-filter + True HEPA + Activated Carbon (varies by filter)
Smart Controls & AQ AlertsYesYes, with app, Alexa & Google Home compatibleNo
Particle DetectionLaser particle detectionLaser particle sensor (0.3 microns accuracy)N/A
Filter Service LifeNot specifiedNot specified4-12 months (varies by filter type)
DimensionsNot specified8.1" x 8.1" x 11.3"8.1" x 8.1" x 11.3"
WeightNot specified1.5 - 1.9 lb (varies by filter)1.5 - 1.9 lb (varies by filter)
Return PolicyFinal Sale, no returns30-day hassle-free returnsNo returns
Additional FeaturesLuxury air purifier without luxury priceAuto Mode, child lock, dimmable display, app control, hyper-local AQ insightsCustom filters for allergens, formaldehyde, wildfire smoke
What makes the Wyze Air Purifier ideal for bedrooms?The Wyze Air Purifier is engineered for ultra-quiet operation at just 21 decibels, making it quieter than a purring kitten. Its low noise level ensures a peaceful environment for restful sleep while effectively cleaning the air in bedrooms up to 550 sq. ft.
How quiet is the Wyze Air Purifier during operation?The Wyze Air Purifier operates at an impressively low noise level of 21 decibels, which is softer than light rainfall and quieter than a purring kitten, making it perfect for silent bedroom air purification.
What size room can the Wyze Air Purifier cover?The Wyze Air Purifier is designed to cover rooms up to 550 square feet (42 square meters), making it suitable for most bedroom sizes.
What types of filters are available for Wyze Air Purifiers?Wyze offers three premium filter options: the Allergen Filter (HEPA 13 and granulated carbon) for common allergens, the Formaldehyde Filter for harmful gases and odors, and the Wildfire Filter for smoke and heavy pollution.
How often should I replace the filter in my Wyze Air Purifier?For optimal performance, it is recommended to replace the filter in your Wyze Air Purifier every 6 months.
Does the Wyze Air Purifier have smart features?Yes, the Wyze Air Purifier includes smart features such as laser particle detection, real-time air quality monitoring, smart app integration, compatibility with Google Home and Alexa, auto mode, child lock, and display dimming.
Can I control the Wyze Air Purifier remotely?Yes, you can control the Wyze Air Purifier remotely using the Wyze app, which allows you to adjust fan speeds, set schedules, and receive air quality alerts. It is also compatible with Google Home and Alexa for voice control.
What is the Clean Air Delivery Rate (CADR) of the Wyze Air Purifier?The Wyze Air Purifier has a high Clean Air Delivery Rate (CADR) of 350 m³/h (12,000 cubic feet per hour), ensuring rapid and efficient air cleaning.
Is there a refurbished option for the Wyze Air Purifier?Yes, Wyze offers a Refurbished Air Purifier that provides the same whisper-quiet operation, 350 CADR, and premium filters as the new model, making it an affordable choice for silent bedroom air purification.
How easy is it to replace filters in the Wyze Air Purifier?Filter replacement in the Wyze Air Purifier is simple and quick, requiring just three steps. The design includes a convenient handle for easy movement and maintenance.
Are Wyze Air Purifiers CARB certified?Yes, both new and refurbished Wyze Air Purifiers are CARB certified, ensuring they meet strict air quality and safety standards.
What are the benefits of using a Wyze Air Purifier in the bedroom?Using a Wyze Air Purifier in the bedroom provides silent operation, smart controls, customizable filtration for allergens, odors, and smoke, and ensures a healthier, more restful sleeping environment.
What are the specific features of the Wyze Air Purifier that make it suitable for bedrooms?How does the laser particle detection work in the Wyze Air Purifier?Do you have any ongoing sales or discounts for the Wyze Air Purifier?
