Radar PIR Motion Detection Battery Camera with Solar Power Upgrade
Looking for a cutting-edge security camera that combines radar and PIR motion detection with battery power and solar charging capabilities? Discover the
Wyze Battery Cam Pro, a versatile wireless camera designed to keep your property safe with advanced sensing technology and flexible power options. Alongside it, explore other Wyze cameras that complement your security setup with high-resolution video, weather resistance, and smart features.
Wyze Battery Cam Pro: The Ultimate Radar + PIR Battery Camera with Solar Power
Advanced Motion Detection Technology
Wyze Battery Cam Pro stands out with its
dual motion sensors — combining radar and PIR (Passive Infrared) detection for earlier and more precise alerts. This "motion detection superstar" minimizes false alarms and lets you set custom detection zones for targeted monitoring.
Stunning 2.5K HDR Video Quality
Capture every detail in vibrant color and clarity with 2.5K HDR resolution. Whether day or night, the camera’s color night vision and integrated spotlight (150 lumens) ensure you never miss a moment.
Wire-Free and Weatherproof
Enjoy true wireless freedom with
removable, rechargeable battery packs and no hub required. Rated
IP65 weatherproof, this camera withstands rain, dust, and extreme temperatures, making it perfect for outdoor use.
Solar Power Upgrade
Extend your camera’s runtime by adding the
Wyze Solar Panel. This eco-friendly upgrade converts sunlight into power, reducing the need for frequent battery charging and keeping your camera running longer.
Smart Features and Connectivity
- Supports both 2.4 GHz and 5 GHz Wi-Fi for reliable connections
- Bluetooth setup for quick installation without QR codes
- Two-way audio with built-in mic and speaker for easy communication
- Local recording via microSD card (optional) for continuous capture without subscription
- Compatible with Wyze Cam Plus subscription for enhanced AI detections like person, package, and vehicle alerts
"No wires. No hubs. The ultimate battery-operated go-anywhere, see-everything home security camera."
Wyze Battery Cam Pro in snowy outdoor setting — weather resistant and solar ready
Wyze Cam v4: Wired 2.5K QHD Camera with Enhanced Color Night Vision
Crystal-Clear 2.5K QHD Resolution
Wyze Cam v4 delivers unmatched image clarity with 2.5K Quad HD video and Wide Dynamic Range (WDR) for vibrant colors and balanced lighting, even in challenging conditions.
Enhanced Color Night Vision & Motion-Activated Spotlight
See more at night with enhanced color night vision and a motion-activated spotlight that deters intruders and lights your path.
Robust Weather Resistance and Smart Integration
- IP65 rating for reliable outdoor use
- Supports Wi-Fi 6 for faster, more stable connections
- Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home control
- 24/7 local recording with microSD card support (up to 256GB) without subscription fees
Additional Smart Features
- Auto-zoom with AI-powered Smart Focus to track important subjects
- Smoke and CO alarm alerts with video capture
- Customizable motion detection zones and sound detection alerts
Wyze Cam v4 is ideal for users who want a wired camera with continuous power and advanced smart home compatibility.
Wyze Cam Pan v3: 360° Pan & 180° Tilt Battery Camera with IP65 Weatherproofing
Full Coverage with Pan and Tilt
Wyze Cam Pan v3 offers a
360° horizontal and
180° vertical field of view, allowing you to monitor every corner of your space with smooth pan and tilt controls.
Crisp 1080p HD Video and Night Vision
Enjoy clear 1080p video quality with 4 IR LEDs for night vision, ensuring your property is monitored day and night.
Weather-Resistant and Flexible Mounting
Rated IP65, this camera is built for indoor and outdoor use (requires Wyze Outdoor Power Adapter for outdoor). Its screw mount and magnetic base make installation easy and versatile.
Smart Features
- Two-way audio with noise and echo cancellation
- Push notifications for motion alerts
- Supports up to 256GB microSD card for local storage
- Integrates with Alexa, Google Assistant, and IFTTT
Wyze Cam Pan v3 in snowy outdoor environment, showcasing weather resistance and wide coverage
Wyze Cam Floodlight v2: Bright 2800 Lumens LED Floodlight with 2K Video
Powerful Lighting and Security
Illuminate your property with
2800 lumens of dimmable LED light panels paired with 2K video resolution and color night vision for superior visibility.
Wide-Angle 160° Field of View
Cover large outdoor areas such as driveways or backyards with a broad 160° diagonal viewing angle.
Smart Features for Enhanced Safety
- Motion-activated spotlight and 105dB siren for deterrence
- Two-way audio for communication
- Ambient Light Mode and dusk-to-dawn automation for energy efficiency
- IP65 weather resistance for all-season durability
Wyze Cam Floodlight v2 is perfect for those who want to combine bright security lighting with smart camera features.
Wyze Cam Floodlight v2 illuminating a garage at night with two-way audio in action
Why Choose Wyze for Your Radar PIR Motion Detection Battery Camera Needs?
- Radar + PIR Motion Detection: Enhanced accuracy and early alerts
- Battery Powered with Solar Upgrade: Flexible installation without wiring hassles
- High-Resolution Video: Crisp 2.5K HDR or QHD for detailed monitoring
- Weatherproof Designs: IP65 rating for reliable outdoor use
- Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT
- Local and Cloud Storage Options: Choose what fits your privacy and convenience needs
- Two-Way Audio & Sirens: Communicate or deter intruders instantly
Upgrade your home or business security with Wyze’s innovative cameras that combine the latest technology with user-friendly features and flexible power options.
Summary of Featured Products
Product Name | Key Features | Power Type | Motion Detection | Video Resolution | Weatherproof | Solar Power Compatible |
Wyze Battery Cam Pro | Radar + PIR, Spotlight, Removable Battery | Battery + Solar | Radar + PIR | 2.5K HDR | IP65 | Yes |
Wyze Cam v4 | Wired, Color Night Vision, Wi-Fi 6 | Wired | PIR Motion | 2.5K QHD | IP65 | No |
Wyze Cam Pan v3 | 360° Pan/Tilt, Two-Way Audio | Wired (battery indoor) | PIR Motion | 1080p HD | IP65 | No |
Wyze Cam Floodlight v2 | 2800 Lumens LED, Siren, Two-Way Audio | Hardwired | PIR Motion | 2K | IP65 | No |
Enhance your security with Wyze’s radar PIR motion detection battery camera and solar power upgrade options today!
What is the Wyze Battery Cam Pro and how does it enhance home security?
The Wyze Battery Cam Pro is a wireless security camera that combines radar and PIR (Passive Infrared) motion detection for highly accurate and early alerts. It features a removable, rechargeable battery and can be upgraded with a solar panel for extended runtime. With 2.5K HDR video quality, color night vision, and IP65 weatherproofing, it provides reliable, high-resolution monitoring for both indoor and outdoor use.How does radar and PIR motion detection work in Wyze Battery Cam Pro?
Wyze Battery Cam Pro uses dual motion sensors—radar and PIR—to detect movement more precisely and reduce false alarms. Radar detects motion based on movement, while PIR senses heat signatures. This combination allows for earlier and more accurate alerts, and you can set custom detection zones for targeted monitoring.Can the Wyze Battery Cam Pro be powered by solar energy?
Yes, the Wyze Battery Cam Pro is compatible with the Wyze Solar Panel, which converts sunlight into power. This solar upgrade reduces the need for frequent battery charging and keeps your camera running longer, making it an eco-friendly and convenient option for outdoor security.Is the Wyze Battery Cam Pro weatherproof?
Absolutely. The Wyze Battery Cam Pro is rated IP65 weatherproof, meaning it can withstand rain, dust, and extreme temperatures. This makes it ideal for outdoor installation in various climates.What video quality does the Wyze Battery Cam Pro offer?
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution, ensuring you capture every detail in vibrant color and clarity. It also features color night vision and a 150-lumen integrated spotlight for clear footage day or night.Does the Wyze Battery Cam Pro require a hub or wires for installation?
No, the Wyze Battery Cam Pro is completely wire-free and does not require a hub. It operates on removable, rechargeable battery packs and connects directly to your Wi-Fi network for easy installation and flexible placement.What smart features are available with Wyze Battery Cam Pro?
Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz Wi-Fi, offers Bluetooth setup for quick installation, two-way audio with a built-in mic and speaker, and local recording via microSD card. It is also compatible with the Wyze Cam Plus subscription for advanced AI detections like person, package, and vehicle alerts.What are the main differences between Wyze Battery Cam Pro and Wyze Cam v4?
Wyze Battery Cam Pro is a battery-powered, wire-free camera with radar and PIR motion detection, solar compatibility, and 2.5K HDR video. Wyze Cam v4 is a wired camera with 2.5K QHD resolution, enhanced color night vision, Wi-Fi 6 support, and continuous 24/7 local recording. Both are IP65 weatherproof and offer smart home integration.Can Wyze cameras be integrated with smart home systems?
Yes, Wyze cameras including Battery Cam Pro, Cam v4, Cam Pan v3, and Floodlight v2 are compatible with Alexa, Google Assistant, and IFTTT, allowing seamless integration with your smart home devices and routines.What storage options are available for Wyze security cameras?
Wyze cameras support both local and cloud storage. You can use a microSD card (up to 256GB on select models) for continuous local recording without subscription fees, or subscribe to Wyze Cam Plus for cloud-based storage and advanced AI detection features.What is the Wyze Cam Pan v3 and what makes it unique?
The Wyze Cam Pan v3 is a camera with 360° horizontal and 180° vertical pan and tilt capabilities, providing full coverage of your space. It features 1080p HD video, night vision, two-way audio, and IP65 weather resistance, making it suitable for both indoor and outdoor use (with the Wyze Outdoor Power Adapter).What features does the Wyze Cam Floodlight v2 offer?
Wyze Cam Floodlight v2 combines a powerful 2800-lumen LED floodlight with a 2K video camera, color night vision, and a 160° wide-angle field of view. It includes motion-activated lighting, a 105dB siren, two-way audio, ambient light mode, dusk-to-dawn automation, and IP65 weatherproofing for enhanced outdoor security.Why should I choose Wyze for radar PIR motion detection battery cameras?
Wyze offers advanced radar and PIR motion detection for accurate alerts, flexible battery and solar power options, high-resolution video, weatherproof designs, smart home integration, and both local and cloud storage. These features make Wyze cameras a reliable and user-friendly choice for home and business security.
