Upgrade Outdoor Security: Wyze Battery Cam Solar Panel Installation
Upgrade Your Outdoor Security with Wyze Solar Panel for Battery Cam
Enhance your Wyze Battery Cam installation with the Wyze Battery Cam Solar Panel, the perfect accessory to keep your outdoor security cameras powered continuously using solar energy. This upgrade is ideal for anyone looking to extend battery life, reduce maintenance, and enjoy uninterrupted surveillance in any outdoor environment.
Wyze Battery Cam Solar Panel: Power Your Camera with the Sun
Key Features
  • Extended Battery Life: The solar panel continuously charges your Wyze Battery Cam Pro or Wyze Cam Outdoor v1/v2, allowing for longer recording times without manual recharging.
  • Weather Resistant: Rated IP65, this solar panel withstands rain, snow, and dust, making it perfect for all seasons and climates.
  • Flexible Mounting: Comes with a 360° adjustable mount and a 13-foot USB-C power cable, enabling easy installation anywhere outdoors.
  • Compact and Efficient: Measures 173 mm x 120 mm x 17 mm with a 2.5W, 5VDC solar power rating, designed to harness sunlight efficiently.
What’s Included
  • Solar panel with white frame and black solar cells
  • Wall mount and screws for secure installation
  • Micro USB and USB-C adapter cables
  • Quick start guide for hassle-free setup
With the Wyze Battery Cam Solar Panel, you can enjoy peace of mind knowing your camera stays powered by clean, renewable energy — no more worrying about battery drain during extended outdoor monitoring.
Wyze Battery Cam Pro: The Ideal Camera for Solar Power
Outstanding Wireless Security Camera
  • 2.5K HDR Video: Crystal-clear 2560 x 1440 resolution captures every detail.
  • Wire-Free & Weatherproof: IP65 rating ensures reliable performance in harsh weather.
  • Integrated Spotlight & Siren: Deter intruders with a built-in spotlight and 100 dB siren.
  • Radar + PIR Motion Detection: Advanced sensors reduce false alerts and detect motion accurately.
  • Long Battery Life: Removable 6200mAh rechargeable battery lasts up to 6 months on a single charge.
  • Connectivity: Supports both 2.4 GHz and 5 GHz Wi-Fi for stable connections.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
Why Pair with the Solar Panel?
The Wyze Battery Cam Pro’s rechargeable battery combined with the solar panel means you can enjoy months of continuous surveillance without the hassle of frequent recharging or battery swaps.
Wyze Battery Cam Pro + Solar Panel Bundle: Ready for Outdoor Security
For a seamless upgrade, consider the Wyze Battery Cam Pro + Solar Panel bundle. This package offers the same high-quality camera features with the added convenience of solar charging, ensuring your outdoor security system is always active and reliable.
Additional Wyze Cameras for Outdoor Security
Wyze Cam v4: Advanced Wired Outdoor Camera
  • 2.5K QHD Resolution: Enhanced color night vision and motion-activated spotlight.
  • Wi-Fi 6 Support: Faster and more reliable wireless connectivity.
  • Multiple Mounting Options: Wall, ceiling, magnetic mounts for versatile placement.
  • Weather Resistant: IP65 rating for all-weather durability.
  • Smart Features: Alexa and Google Assistant compatibility, local and cloud storage options.
Wyze Cam Pan v3: 360° Pan and Tilt Outdoor Camera
  • Full 360° Horizontal & 180° Vertical View: Covers wide areas with smooth pan and tilt.
  • 1080p HD Video: Clear day and night vision with 4 IR LEDs.
  • Weatherproof Design: IP65 rating for outdoor use (requires separate outdoor power adapter).
  • Two-Way Audio: Built-in speaker and microphone with noise cancellation.
  • Smart Alerts: Push notifications for motion detection.
These cameras complement the Wyze Battery Cam Pro and solar panel setup, providing wired or pan-tilt options for comprehensive outdoor security coverage.
Why Choose Wyze for Your Outdoor Security Upgrade?
Wyze offers a range of affordable, high-quality security cameras and accessories designed for easy installation and reliable performance. The solar panel accessory is a smart investment for anyone using Wyze Battery Cam models, enabling sustainable power and reducing downtime.
“Record for longer. Attach a solar panel to your Wyze Battery Cam Pro to extend the battery life. Designed to be weather resistant and mountable anywhere.” – Wyze Battery Cam Solar Panel
Visual Inspiration for Your Outdoor Setup
Wyze Cam Pan v3 in Snowy Outdoor Setting Wyze Cam Pan v3 weather resistant outdoor camera in action Wyze Cam Pan v3 Mounted Outdoors Reliable outdoor security with Wyze Cam Pan v3 Two-Way Audio Feature with Wyze Camera Stay connected with two-way audio on Wyze cameras
Conclusion
Upgrading your outdoor security with the Wyze Battery Cam Solar Panel is a smart, eco-friendly way to keep your Wyze Battery Cam Pro powered and ready. Combined with Wyze’s range of outdoor cameras like the Battery Cam Pro, Cam v4, and Cam Pan v3, you can build a comprehensive, weatherproof security system that works day and night with minimal maintenance. Secure your home or property with Wyze’s innovative solar-powered solutions and enjoy peace of mind knowing your cameras are always recording.
FeatureWyze Battery Cam Solar PanelWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Cam v4Wyze Cam Pan v3
TypeAccessoryCameraCamera BundleCameraCamera
Video ResolutionN/A2.5K HDR (2560x1440)2.5K HDR (2560x1440)2.5K QHD (2560x1440)1080p (1920x1080)
WirelessN/AYesYesYesYes
Power SourceSolar Panel (extends battery life)Removable, Rechargeable Battery PacksRemovable, Rechargeable Battery Packs + SolarWired (Indoor USB Power Adapter)Wired (5V/2000mA adapter)
Battery LifeExtends battery lifeUp to 6 MonthsUp to 6 Months (with solar extension)N/AN/A
Weather ResistanceIP65IP65IP65IP65IP65
Motion DetectionN/ARadar + PIRRadar + PIRYesYes
Night VisionN/AColor Night Vision (2 IR LEDs + 2 White LEDs)Color Night Vision (2 IR LEDs + 2 White LEDs)Enhanced Color Night Vision (4 IR LEDs + 2 White LEDs)IR Night Vision (4 IR LEDs)
SpotlightN/AIntegrated Spotlight (150 lumens)Integrated Spotlight (150 lumens)Motion-activated spotlightNo spotlight
AudioN/ATwo-way audio, built-in mic & speakerTwo-way audio, built-in mic & speakerTwo-way audioTwo-way audio
Local StorageN/ASupports microSD up to 256GBSupports microSD up to 256GBSupports microSD up to 512GBSupports microSD up to 256GB
Cloud StorageN/ACam Plus subscription availableCam Plus subscription availableSubscription plan requiredSubscription plan available
Mounting360° Freestyle Mount, 13 ft cableStandard 1/4" - 20 mountStandard 1/4" - 20 mountStand, Wall, Ceiling, Magnetic mountScrew 1/4" - 20 mount
DimensionsN/A2.5 x 1.8 x 3.5 inches2.5 x 1.8 x 3.5 inches2 x 2 x 2 3/8 inches124mm x 60mm x 63mm
WeightN/A0.94 lbs0.94 lbs0.49 lbs11.29 oz (320 g)
Wi-Fi SupportN/A2.4 & 5 GHz2.4 & 5 GHz2.4 GHz & Wi-Fi 62.4 GHz only
Operating TemperatureN/A-20°C to +50°C (-4°F to 122°F)-20°C to +50°C (-4°F to 122°F)-20°C to +50°C (-4°F to 122°F)-20°C to +50°C (-4°F to 122°F)
Price$24.99 (Solar Panel), $5.99 (USB-C Cable)$89.98 - $219.98 (depending on pack)$109.98$35.98 - $107.94 (depending on pack)$39.98 - $114.94 (depending on pack)
What is the Wyze Battery Cam Solar Panel and how does it work?The Wyze Battery Cam Solar Panel is an accessory designed to keep your Wyze Battery Cam Pro or Wyze Cam Outdoor v1/v2 continuously powered using solar energy. It charges your camera’s battery with sunlight, reducing the need for manual recharging and ensuring uninterrupted outdoor surveillance.
Which Wyze cameras are compatible with the Wyze Solar Panel?The Wyze Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 models. It is not designed for use with other Wyze camera models.
What are the key features of the Wyze Battery Cam Solar Panel?Key features include extended battery life for your camera, IP65 weather resistance for all-season durability, a 360° adjustable mount, a 13-foot USB-C power cable for flexible installation, and a compact, efficient design with a 2.5W, 5VDC solar power rating.
What is included with the Wyze Battery Cam Solar Panel?The package includes the solar panel with a white frame and black solar cells, a wall mount and screws, micro USB and USB-C adapter cables, and a quick start guide for easy setup.
How weatherproof is the Wyze Solar Panel?The Wyze Solar Panel is rated IP65, making it resistant to rain, snow, and dust. It is designed to function reliably in all seasons and climates.
How does pairing the Wyze Battery Cam Pro with the solar panel benefit me?Pairing the Wyze Battery Cam Pro with the solar panel allows for months of continuous surveillance without frequent battery recharging or swaps. The solar panel keeps the camera’s rechargeable battery topped up, reducing maintenance and downtime.
What are the main features of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro offers 2.5K HDR video, wire-free and weatherproof design (IP65), integrated spotlight and 100 dB siren, radar and PIR motion detection, a long-lasting 6200mAh rechargeable battery, dual-band Wi-Fi (2.4 GHz and 5 GHz), and smart home integration with Alexa, Google Assistant, and IFTTT.
Is there a bundle available for the Wyze Battery Cam Pro and Solar Panel?Yes, Wyze offers a bundle that includes the Wyze Battery Cam Pro and the Solar Panel. This package provides high-quality camera features with the added convenience of solar charging for reliable, always-on outdoor security.
Are there other Wyze cameras suitable for outdoor security?Yes, Wyze offers additional outdoor cameras such as the Wyze Cam v4, which features 2.5K QHD resolution, color night vision, Wi-Fi 6 support, and multiple mounting options, and the Wyze Cam Pan v3, which provides 360° pan and 180° tilt, 1080p HD video, two-way audio, and weatherproof design.
Why should I choose Wyze for my outdoor security needs?Wyze provides affordable, high-quality security cameras and accessories that are easy to install and reliable. The solar panel accessory offers sustainable power for Wyze Battery Cam models, reducing maintenance and ensuring your cameras are always ready to record.
How easy is it to install the Wyze Battery Cam Solar Panel?Installation is straightforward with the included wall mount, screws, and a 13-foot USB-C power cable. The 360° adjustable mount allows you to position the panel for optimal sunlight exposure, and the quick start guide provides step-by-step instructions.
What are the key features of the Wyze Battery Cam Solar Panel?How does the solar panel enhance the performance of the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Solar Panel?
