Remote Farmland Surveillance with Wyze Battery Cam and Solar Power
Monitoring your farmland remotely requires reliable, weatherproof, and long-lasting surveillance solutions. Wyze offers an ideal combination of wireless battery-powered cameras and solar panels designed to keep your property secure without the hassle of frequent battery changes or complicated wiring. Discover how the Wyze Battery Cam Pro and the Wyze Battery Cam Solar Panel can transform your farmland surveillance setup.
Wyze Battery Cam Pro: Advanced Wireless Surveillance
High-Resolution Video & Smart Detection
The Wyze Battery Cam Pro delivers crisp 2.5K HDR video resolution (2560 x 1440), ensuring you capture every detail on your farmland. Equipped with a CMOS-Starlight sensor and an F1.6 lens, it provides clear images even in low-light conditions. The camera features integrated radar and PIR motion detection, allowing it to accurately detect movement and reduce false alerts caused by animals or weather.
Long-Lasting Battery & Weatherproof Design
Powered by a removable, rechargeable 6200mAh battery, the Wyze Battery Cam Pro can operate wire-free for up to 6 months on a single charge. Its IP65 weather resistance rating means it can withstand rain, dust, and extreme temperatures from -20°C to 50°C (-4°F to 122°F), making it perfect for outdoor farmland environments.
Smart Features & Connectivity
- Integrated spotlight and 100 dB siren for deterrence
- Two-way audio with built-in microphone and speaker
- Supports both 2.4 GHz and 5 GHz WiFi for flexible connectivity
- Compatible with Alexa, Google Assistant, and IFTTT for smart home integration
- Local storage support up to 256 GB microSD cards and optional cloud recording with Cam Plus
Easy Installation
The camera includes a wall mount and supports standard 1/4” - 20 mounting threads, allowing you to position it anywhere on your property for optimal coverage.
Wyze Battery Cam Solar Panel: Extend Your Camera’s Runtime
Harness Solar Power for Continuous Surveillance
The Wyze Battery Cam Solar Panel is designed to keep your Wyze Battery Cam Pro powered indefinitely by converting sunlight into energy. This accessory is perfect for remote farmland locations where frequent battery charging is inconvenient.
Durable and Weather Resistant
With an IP65 waterproof rating, the solar panel withstands harsh outdoor conditions including rain, dust, and dirt. Its compact size (173 mm x 120 mm x 17 mm) and 360° adjustable mount allow you to install it in the best sun-exposed location.
Convenient Features
- 2.5W, 5V DC solar power rating ensures efficient charging
- Comes with a 13-foot (4m) micro USB-C power cable for flexible placement
- Includes all mounting hardware and quick start guide for easy setup
- Compatible with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro
“Record for longer. Attach a solar panel to your Wyze Battery Cam Pro to extend the battery life.”
Wyze Battery Cam Pro + Solar Panel Bundle: The Ultimate Farmland Surveillance Solution
All-in-One Package for Remote Monitoring
This bundle combines the Wyze Battery Cam Pro with the Solar Panel accessory, providing a seamless solution for continuous, wire-free surveillance on your farmland. Enjoy the benefits of high-definition video, smart motion detection, and solar-powered battery life extension in one affordable package.
Key Benefits
- Up to 6 months of battery life with solar charging support
- IP65 weatherproof rating for reliable outdoor use
- Integrated spotlight, siren, and two-way audio for enhanced security
- Supports both local and cloud storage options
- Compatible with 2.4 GHz and 5 GHz WiFi networks
Why Choose Wyze for Farmland Surveillance?
Wyze’s combination of cutting-edge camera technology and solar power accessories offers a practical, cost-effective way to monitor large outdoor areas like farmland. The wireless design eliminates the need for complex wiring, while the solar panel ensures your cameras stay powered even in remote locations. With smart detection features and weatherproof durability, Wyze cameras provide peace of mind and reliable security day and night.
Remote farmland monitored with solar-powered wireless cameras
Summary of Key Specifications
Feature | Wyze Battery Cam Pro | Wyze Battery Cam Solar Panel | Bundle (Cam + Solar Panel) |
Video Resolution | 2.5K HDR (2560 x 1440) | N/A | 2.5K HDR (2560 x 1440) |
Battery Life | Up to 6 months | Extends battery life via solar | Up to 6 months + solar extension |
Weather Resistance | IP65 | IP65 | IP65 |
Motion Detection | Radar + PIR | N/A | Radar + PIR |
Power Source | Rechargeable battery packs | Solar power (2.5W, 5V DC) | Rechargeable battery + solar power |
Connectivity | 2.4 & 5 GHz WiFi | Wired connection to camera | 2.4 & 5 GHz WiFi |
Audio Features | Two-way audio, siren (100 dB) | N/A | Two-way audio, siren (100 dB) |
Mounting | Wall mount included, 1/4” - 20 thread | 360° adjustable mount | Both mounts included |
Harness the power of solar energy and advanced wireless technology with Wyze Battery Cam Pro and Solar Panel to keep your farmland safe and monitored effortlessly.
What makes the Wyze Battery Cam Pro suitable for remote farmland surveillance?
The Wyze Battery Cam Pro is ideal for remote farmland surveillance due to its wireless, battery-powered design, 2.5K HDR video resolution, advanced radar and PIR motion detection, and IP65 weatherproof rating. It operates for up to 6 months on a single charge and can withstand harsh outdoor conditions, making it perfect for monitoring large, remote areas without frequent maintenance.How does the Wyze Battery Cam Solar Panel extend camera battery life?
The Wyze Battery Cam Solar Panel continuously charges your Wyze Battery Cam Pro by converting sunlight into energy. With a 2.5W, 5V DC output and a 13-foot micro USB-C cable, it ensures your camera remains powered for extended periods, reducing the need for manual battery recharging—especially useful for remote farmland locations.Is the Wyze Battery Cam Pro weatherproof and suitable for outdoor use?
Yes, the Wyze Battery Cam Pro has an IP65 weather resistance rating, making it dustproof and waterproof. It can operate in extreme temperatures ranging from -20°C to 50°C (-4°F to 122°F), ensuring reliable performance in various outdoor environments, including farmland.What smart features does the Wyze Battery Cam Pro offer for farmland security?
The Wyze Battery Cam Pro includes smart features such as integrated radar and PIR motion detection, a built-in spotlight, a 100 dB siren for deterrence, two-way audio, and compatibility with Alexa, Google Assistant, and IFTTT. It also supports both local microSD card storage and optional cloud recording with Cam Plus.Can I install the Wyze Battery Cam Pro and Solar Panel easily on my property?
Yes, both the Wyze Battery Cam Pro and the Solar Panel are designed for easy installation. The camera comes with a wall mount and supports standard 1/4” - 20 mounting threads, while the solar panel includes a 360° adjustable mount and all necessary hardware, allowing flexible placement for optimal sun exposure.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The Wyze Battery Cam Pro + Solar Panel bundle includes the high-resolution wireless camera and the solar panel accessory. This all-in-one package provides continuous, wire-free surveillance with extended battery life, weatherproof durability, smart motion detection, and both local and cloud storage options.Is the Wyze Battery Cam Pro compatible with both 2.4 GHz and 5 GHz WiFi networks?
Yes, the Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz WiFi networks, offering flexible connectivity options for reliable remote monitoring of your farmland.What storage options are available for Wyze Battery Cam Pro recordings?
The Wyze Battery Cam Pro supports local storage with microSD cards up to 256 GB and offers optional cloud recording through the Cam Plus subscription, giving you flexible options for saving and accessing your surveillance footage.Can the Wyze Battery Cam Solar Panel be used with other Wyze cameras?
Yes, the Wyze Battery Cam Solar Panel is compatible with the Wyze Cam Outdoor v1/v2 and the Wyze Battery Cam Pro, making it a versatile accessory for various Wyze outdoor cameras.Why should I choose Wyze for my farmland surveillance needs?
Wyze offers a cost-effective, reliable solution for farmland surveillance with advanced camera technology, solar power accessories, wireless installation, smart detection features, and weatherproof durability. This combination ensures continuous, hassle-free monitoring and enhanced security for your property.
