Best Air Purifiers for Continuous 500 Sq Ft Room Cleaning
Best Air Purifiers for Continuous Cleaning of 500 Square Foot Rooms
When it comes to maintaining fresh, clean air in rooms up to 500 square feet, choosing the right air purifier is essential. Whether you want to reduce allergens, eliminate harmful gases, or protect your family from viruses and bacteria, Wyze offers a range of air purifiers and filters designed to keep your indoor air quality at its best—continuously and efficiently.
Wyze Air Purifier: Powerful and Smart Air Cleaning for Large Rooms
Coverage and Performance
The Wyze Air Purifier is engineered to effectively clean air in rooms ranging from 450 to 550 square feet, making it ideal for medium to large living spaces, bedrooms, or home offices. With a particulate matter CADR (Clean Air Delivery Rate) of up to 350 m³/h (206 CFM), it continuously circulates and purifies the air, removing dust, pollen, pet dander, and other airborne particles.
Whisper-Quiet Operation
Operating at a noise level as low as 21 decibels on its lowest setting, the Wyze Air Purifier ensures a peaceful environment without disruptive sounds, perfect for continuous use day and night.
Smart Features and Controls
  • Laser Particle Detection: Accurately detects particles as small as 0.3 microns.
  • Air Quality Alerts: Real-time notifications keep you informed about your indoor air quality.
  • Smart Home Compatibility: Works seamlessly with Google Home and Alexa for voice control.
  • Multiple Fan Speeds: Adjust airflow to your comfort and needs.
Filter Options
Choose from three premium filters tailored to your environment:
  • Allergen Filter (Standard): HEPA 13 filter captures allergens and dust.
  • Formaldehyde Filter (Premium): HEPA 12 with MnO2 and activated carbon targets formaldehyde and VOCs.
  • Wildfire Filter (Special Use): Designed for wildfire smoke and other hazardous particles.
Each filter lasts approximately 6 months, ensuring long-term air purification without frequent replacements.
"A luxury air purifier without a luxury price tag."
Wyze Air Purifier in Kitchen Experience clean air continuously in your living spaces with Wyze Air Purifier.
Wyze Air Purifier (Refurbished): Affordable Continuous Air Cleaning
For those seeking a budget-friendly option without compromising on performance, the refurbished Wyze Air Purifier offers the same powerful air cleaning capabilities at a reduced price.
Key Features
  • Room Size: Cleans rooms up to 550 sq. ft.
  • CADR: 350 m³/h particulate matter removal.
  • Noise Level: Quiet operation at 21 dBA.
  • Smart Controls: Includes air quality alerts and laser particle detection.
  • Filter Compatibility: Supports allergen, formaldehyde, and wildfire filters.
This refurbished model is CARB certified and recommended for continuous use with filter replacements every 6 months.
Wyze Air Filter: Customize Your Air Purification Needs
Tailored Filter Solutions
The Wyze Air Filter accessories allow you to customize your air purifier’s performance based on your specific air quality concerns:
  • Allergen Filter (Standard): HEPA 13 filter with activated carbon for everyday allergens.
  • Formaldehyde Filter (Premium): HEPA 12 with enhanced formaldehyde removal efficiency (up to 98.9% TVOC removal).
  • Wildfire Filter (Special Use): HEPA 12 filter optimized for wildfire smoke and hazardous gases.
Compact and Efficient
  • Dimensions: 8.1" x 8.1" x 11.3"
  • Lightweight: Between 1.5 to 1.9 lbs depending on filter type.
  • Pre-filter included to extend filter life.
  • Service life ranges from 4 to 12 months depending on filter type.
These filters are designed to fit Wyze Air Purifiers perfectly, ensuring continuous and effective air cleaning tailored to your environment. Changing Wyze Air Purifier Filter Easily replace filters to maintain optimal air quality continuously.
Why Choose Wyze Air Purifiers for 500 Sq. Ft. Rooms?
  • Continuous Air Cleaning: High CADR ratings ensure rapid and ongoing purification.
  • Smart Technology: Real-time air quality monitoring and smart home integration.
  • Customizable Filters: Target specific pollutants like allergens, formaldehyde, or wildfire smoke.
  • Quiet Operation: Suitable for bedrooms, offices, and living rooms without noise disturbance.
  • Affordable Options: New and refurbished models to fit your budget.
"You don’t breathe the same air as everyone else—customize your air like you customize your lifestyle."
Summary of Wyze Air Purifier Models for 500 Sq. Ft. Rooms
ProductCoverage AreaCADR (m³/h)Noise Level (dBA)Filter Types AvailablePrice Range (USD)
Wyze Air Purifier (New)450-550 sq. ft.Up to 35021 - 52Allergen, Formaldehyde, Wildfire$169.99 - $194.99
Wyze Air Purifier (Refurbished)Up to 550 sq. ft.35021Allergen, Formaldehyde, Wildfire$139.99
Wyze Air Filter (Replacement)Fits Wyze Purifiers317-362N/AAllergen, Formaldehyde, Wildfire$37.99 - $63.99
Optimize your indoor air quality with Wyze Air Purifiers designed for continuous cleaning in rooms up to 500 square feet. Whether you want smart features, customizable filters, or budget-friendly options, Wyze has you covered.
FeatureWyze Air Purifier (Refurbished)Wyze Air PurifierWyze Air Filter
TypeRefurbishedConnected HomeConnected Home (Accessory)
Price$139.99$169.99 - $194.99 (depending on filter variant)$37.99 - $63.99 (depending on filter type)
Filter VariantsAny Filter (pre-installed)Allergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)Allergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)
CADR (Clean Air Delivery Rate)350 CADR350 CADRVaries by filter: 362, 317, 342 m³/h
Noise Level21 decibels (whisper-quiet)21 to 54 decibelsN/A
Smart ControlsYesYes, with app, Alexa, Google Home compatibilityN/A
Air Quality AlertsYesYesN/A
Particle DetectionLaser particle detectionLaser particle detectionN/A
Filter TypePremium filtersTrue HEPA + Activated Carbon (varies by filter)True HEPA + Activated Carbon (varies by filter)
Filter Service LifeNot specified4-12 months depending on filter4-12 months depending on filter
DimensionsNot specified8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)
WeightNot specified1.5 - 1.9 lb (depending on filter)1.5 - 1.9 lb (depending on filter)
Return PolicyFinal Sale, no returns30-day hassle-free returnsNo returns
Additional FeaturesLuxury air purifier without luxury price tagAuto Mode, child lock, dimmable display, app control, hyper-local AQ data, filter subscription availableCustom filters for specific needs (allergens, formaldehyde, wildfire smoke)
What size room can the Wyze Air Purifier clean effectively?The Wyze Air Purifier is designed to clean rooms ranging from 450 to 550 square feet, making it ideal for medium to large living spaces, bedrooms, and home offices.
What is the Clean Air Delivery Rate (CADR) of the Wyze Air Purifier?The Wyze Air Purifier has a particulate matter CADR of up to 350 m³/h (206 CFM), ensuring rapid and continuous air purification in rooms up to 550 square feet.
How quiet is the Wyze Air Purifier during operation?The Wyze Air Purifier operates as quietly as 21 decibels on its lowest setting, making it suitable for bedrooms, offices, and other quiet environments.
What smart features does the Wyze Air Purifier offer?The Wyze Air Purifier includes laser particle detection, real-time air quality alerts, compatibility with Google Home and Alexa for voice control, and multiple fan speeds for customized airflow.
What types of filters are available for the Wyze Air Purifier?Wyze offers three filter options: the Allergen Filter (HEPA 13 for allergens and dust), the Formaldehyde Filter (HEPA 12 with MnO2 and activated carbon for formaldehyde and VOCs), and the Wildfire Filter (HEPA 12 for wildfire smoke and hazardous particles).
How often should I replace the filters in my Wyze Air Purifier?Wyze Air Purifier filters typically last about 6 months, depending on usage and air quality. Some filters may last between 4 to 12 months based on the specific type and environmental conditions.
Are there affordable options for Wyze Air Purifiers?Yes, Wyze offers a refurbished air purifier model that provides the same powerful air cleaning capabilities as the new model but at a reduced price, making it a budget-friendly option.
Can I customize my Wyze Air Purifier for specific air quality concerns?Absolutely. Wyze Air Purifiers support customizable filters, allowing you to target specific pollutants such as allergens, formaldehyde, VOCs, or wildfire smoke based on your needs.
Are Wyze Air Purifiers compatible with smart home systems?Yes, Wyze Air Purifiers are compatible with Google Home and Alexa, enabling convenient voice control and integration with your smart home ecosystem.
What are the dimensions and weight of Wyze Air Filters?Wyze Air Filters measure 8.1" x 8.1" x 11.3" and weigh between 1.5 to 1.9 lbs, depending on the filter type.
Is the Wyze Air Purifier suitable for continuous use?Yes, both new and refurbished Wyze Air Purifiers are designed for continuous air cleaning, with high CADR ratings and quiet operation for 24/7 use.
What certifications do Wyze Air Purifiers have?The refurbished Wyze Air Purifier is CARB certified, ensuring it meets strict air quality and safety standards.
How do I know when to change the filter in my Wyze Air Purifier?The Wyze Air Purifier provides real-time air quality alerts and notifications, helping you monitor filter status and know when it's time for a replacement.
What are the different filter options available for the Wyze Air Purifier?How often do I need to replace the filters in the Wyze Air Purifier?Do you have any ongoing sales or discounts for the Wyze Air Purifier?
