Quiet Wyze Camera Mounts for Apartments—No Drilling, No Damage
Quiet Camera Mounting Solutions for Apartments: Wyze Window Mount & More
If you live in an apartment and want to install a Wyze security camera without damaging or disturbing your walls, choosing the right mounting solution is essential. Traditional drilling or screws can be noisy and may violate rental agreements. Fortunately, Wyze offers quiet, adhesive-based mounting accessories designed specifically to avoid wall damage while providing secure, stable camera placement. This guide highlights the best Wyze mounting accessories tailored for quiet, no-drill installation, focusing on the Wyze Window Mount and Wyze Cam Mounting Kit — perfect for apartment dwellers seeking hassle-free, damage-free security camera setups.
Wyze Window Mount: Perfect for Glass Surfaces and Quiet Installation
Overview
The Wyze Window Mount is an innovative accessory designed to attach your Wyze Cam directly to glass surfaces such as windows. This mount is ideal for apartment residents who want to avoid drilling into walls or frames.
Key Features
  • No Drilling Required: Uses a strong adhesive to mount securely on glass, eliminating noise and wall damage.
  • Glare and Reflection Reduction: Specially designed to reduce glare and reflections, ensuring clear, unobstructed video footage.
  • Compatibility: Works with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and Wyze Cam OG Telephoto.
  • Easy to Install and Remove: Perfect for renters who need a temporary but reliable mounting solution.
  • Outdoor-Ready: Allows you to upgrade your exterior security by mounting cameras on windows facing outside.
Mount your Wyze Cam on your apartment window for a clear, quiet, and damage-free security setup.
Wyze Window Mount Lifestyle Wyze Cam mounted on a window, providing clear outdoor surveillance without wall damage.
Wyze Cam Mounting Kit: Adhesive Mounting for Walls Without Noise
Overview
The Wyze Cam Mounting Kit offers a simple, quiet way to mount your Wyze Cam v2, v3, or v3 Pro without drilling. It includes adhesive mounting brackets and a longer Micro USB cable for flexible placement.
Key Features
  • Adhesive Mounting Bracket: Securely attaches to walls or other flat surfaces without screws or nails.
  • Longer Micro USB Cable: Provides extra length for convenient camera placement away from power outlets.
  • Compatible Models: Designed for Wyze Cam v2, v3, and v3 Pro.
  • Quiet Installation: No drilling or hammering means no noise disturbance in your apartment.
  • Hassle-Free Removal: Adhesive can be removed cleanly, preserving your walls.
Ideal for renters who want a quick, quiet, and damage-free way to mount their Wyze cameras indoors.
Why Choose Wyze Mounting Accessories for Apartments?
  • No Wall Damage: Both the Wyze Window Mount and Mounting Kit use adhesives, avoiding holes or marks.
  • Easy Setup: No tools or professional installation needed.
  • Flexible Placement: Mount on windows, walls, or other surfaces with minimal effort.
  • Maintain Apartment Rules: Perfect for renters who must avoid permanent modifications.
  • Clear Video Quality: Especially with the Window Mount, reduce glare and reflections for better footage.
Additional Quiet Mounting Options
Wyze Universal Mount (Long)
For those who want a more versatile mounting option with a longer neck for ceiling or patio mounting, the Wyze Universal Mount (Long) offers a durable metal mount with adjustable angles. While it requires screws, it’s designed for easy installation and can be used in spaces where drilling is allowed or on surfaces like patios.
Summary
For apartment residents seeking a quiet, no-drill camera mounting solution, the Wyze Window Mount and Wyze Cam Mounting Kit are the top choices. Both provide secure, damage-free installation options that preserve your walls and avoid noise disturbances. The Window Mount is especially great for mounting on glass surfaces with glare reduction, while the Mounting Kit offers adhesive mounting for walls indoors. Choose Wyze mounting accessories to enjoy peace of mind with your home security setup — without the hassle or noise of traditional mounting methods.
FeatureWyze Cam Mounting KitWyze Window Mount
Compatible CamerasWyze Cam v2, v3, v3 ProWyze Cam v3, v3 Pro, v4, Wyze Cam OG, Wyze Cam OG Telephoto
PurposeMounting bracket, adhesive, longer Micro USB cableMount cam on glass surface to reduce glare and reflection
Included ItemsMounting bracket, adhesive, longer Micro USB cableMounting accessory for window attachment
Price$5.99$9.98
Mounting SurfaceWall, ceiling, other surfacesGlass/window surface
Special FeaturesSpare mounting plateReduces glare, clear view free of reflection
Return Policy30-day hassle-free returns30-day hassle-free returns
CollectionsMounting Accessories, Camera AccessoriesCamera Accessories, RV's: Campers, Motorhomes, Vans, and Travel Trailers
AvailabilityIn stockIn stock
What are the best Wyze camera mounting solutions for apartments?The best Wyze camera mounting solutions for apartments are the Wyze Window Mount and the Wyze Cam Mounting Kit. Both options use adhesive-based mounting, allowing you to securely install your camera without drilling or damaging your walls, making them ideal for renters.
How does the Wyze Window Mount work for apartment security cameras?The Wyze Window Mount attaches your Wyze Cam directly to glass surfaces using a strong adhesive. This eliminates the need for drilling, reduces noise, and prevents wall damage. It also features glare and reflection reduction for clear video footage, making it perfect for apartment windows.
Which Wyze cameras are compatible with the Wyze Window Mount?The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and Wyze Cam OG Telephoto models.
Can I install a Wyze camera in my apartment without drilling or making noise?Yes, you can install a Wyze camera in your apartment without drilling or making noise by using the Wyze Window Mount or the Wyze Cam Mounting Kit. Both use adhesive mounting, ensuring a quiet and damage-free installation.
Is the Wyze Cam Mounting Kit suitable for renters?Yes, the Wyze Cam Mounting Kit is ideal for renters. It uses an adhesive mounting bracket that attaches securely to walls or flat surfaces without screws or nails, and the adhesive can be removed cleanly to preserve your walls.
What is included in the Wyze Cam Mounting Kit?The Wyze Cam Mounting Kit includes adhesive mounting brackets and a longer Micro USB cable, allowing for flexible camera placement away from power outlets. It is compatible with Wyze Cam v2, v3, and v3 Pro.
Will adhesive mounts damage my apartment walls or windows?No, both the Wyze Window Mount and Wyze Cam Mounting Kit use adhesives designed to be removed cleanly, so they will not damage your apartment walls or windows.
Are there any Wyze mounting options for ceilings or patios?Yes, the Wyze Universal Mount (Long) is a versatile option for mounting on ceilings or patios. However, it requires screws for installation and is best used in spaces where drilling is allowed.
Why should I choose Wyze mounting accessories for my apartment?Wyze mounting accessories are perfect for apartments because they offer no-drill, quiet installation, prevent wall damage, and comply with most rental agreements. They also provide flexible placement and clear video quality, especially with the Window Mount’s glare reduction feature.
Can I use Wyze mounting solutions outdoors?Yes, the Wyze Window Mount is outdoor-ready and allows you to mount your camera on windows facing outside, providing clear surveillance without damaging your apartment’s exterior.
Can you tell me more about the features of the Wyze Window Mount?Is the Wyze Cam Mounting Kit compatible with all Wyze camera models?Do you have any ongoing promotions or discounts for Wyze mounting accessories?
