Best Low Profile Wyze Camera Window Mounts for Small Apartments – Discreet, No-Drill Solutions
The Best Low Profile Window Mounting Solutions for Wyze Cameras in Small Apartments
Looking for a discreet, effective way to mount your Wyze camera on a window in your small apartment? Whether you want to maximize your security or simply keep an eye on your surroundings without bulky hardware, Wyze offers several low-profile window mounting solutions. Discover the best options for a seamless, glare-free view and a clutter-free living space.
Why Choose a Window Mount for Your Wyze Camera?
Window mounts are ideal for renters and small apartment dwellers who want to enhance security without drilling holes or making permanent changes. They offer a clear, unobstructed view and are easy to install and remove.
1. Wyze Window Mount: The Ultimate Low Profile Solution
The Wyze Window Mount is specifically designed for those who want a sleek, nearly invisible way to attach their Wyze Cam to a glass surface. Perfect for small apartments, this accessory allows you to: Mount your Wyze Cam v3, v3 Pro, v4, Cam OG, or Cam OG Telephoto directly to your window Enjoy a clear view free of glare or reflection Install and remove easily without tools or permanent fixtures
Key Features:
  • Low profile design: Blends seamlessly with your window for a discreet look.
  • No drilling required: Ideal for renters and those who want to avoid wall damage.
  • Compatible with multiple Wyze Cam models: Works with v3, v3 Pro, v4, Cam OG, and Cam OG Telephoto.
  • Affordable: Priced for budget-conscious users.
"Upgrade your exterior security by attaching a Wyze Cam to your window. Enjoy a clear view free of glare or reflection."
2. Wyze Cam Mounting Kit: Flexible Mounting for Tight Spaces
If you need a bit more flexibility in your mounting options, the Wyze Cam Mounting Kit is a great choice. While not exclusively a window mount, it includes:
  • Mounting bracket and adhesive: Allows for secure placement on various surfaces, including glass.
  • Longer Micro USB cable: Ensures you can reach power outlets even in compact spaces.
  • Wall plate and screw set: For those who may want to switch to wall mounting in the future.
Compatible With:
  • Wyze Cam v2
  • Wyze Cam v3
  • Wyze Cam v3 Pro
This kit is perfect for those who want a versatile, all-in-one mounting solution that adapts to different apartment layouts.
3. Wyze Universal Mount (Long): For Versatile, Adjustable Placement
For users who want more adjustability, the Wyze Universal Mount (Long) offers a durable, heavy-duty option that can be used on ceilings, patios, or even windows (if your camera uses a standard 1/4”-20 mount). Adjustable and easy to install Heavy-duty metal construction Compatible with most Wyze Cams (except Cam OG and OG Telephoto)
Specs:
  • Color: White, matte finish
  • Load bearing: Up to 2 kg
  • Dimensions: 2 in x 2 in x 3.8 in
Note: This mount is not compatible with Wyze Cam OG or OG Telephoto.
Choosing the Right Mount for Your Small Apartment
When selecting a window mounting solution for your Wyze camera, consider:
  • Compatibility: Ensure the mount fits your specific Wyze Cam model.
  • Space constraints: Opt for low-profile designs to keep your apartment uncluttered.
  • Ease of installation: Look for mounts that require no drilling or permanent fixtures.
Lifestyle Inspiration: Wyze Cameras in Action
Wyze camera mounted in a modern apartment, blending seamlessly with the window for discreet home security.
Summary Table: Wyze Window Mounting Solutions
Product NameBest ForCompatible CamerasKey Features
Wyze Window MountDiscreet window mountingCam v3/v3 Pro/v4, Cam OG/TelephotoGlare-free, no drilling, low profile
Wyze Cam Mounting KitFlexible, adhesive mountingCam v2, Cam v3, Cam v3 ProBracket, adhesive, long USB cable
Wyze Universal Mount (Long)Adjustable, versatile placementMost Wyze Cams (not OG/Telephoto)Heavy-duty, adjustable, easy install
Final Thoughts
For small apartments, the Wyze Window Mount stands out as the best low-profile, renter-friendly solution for mounting your Wyze camera on a window. Pair it with the Wyze Cam Mounting Kit or Universal Mount for added flexibility and security coverage throughout your home.
Enhance your home security with a clean, unobtrusive look—choose the right Wyze window mount for your space today!
ProductBest ForCompatibilityInstallation TypeKey FeaturesPriceStock
Wyze Window MountLow profile window mountingWyze Cam v3, v3 Pro, v4, Cam OG, Cam OG TelephotoAdhesive (glass mount)Glare-free view, flush design, no drilling, easy removal$4.99Available
Wyze Cam Mounting KitFlexible mounting on various surfacesWyze Cam v2, v3, v3 ProAdhesive or screwsMounting bracket, adhesive, 5ft USB extension cable, screw set included$5.99Available
Wyze Universal Mount (Long)Custom angles, ceiling/window frame useMost Wyze cams with 1/4”-20 mount (not Cam OG/OG Telephoto)Screws (hardware mount)Adjustable neck, heavy-duty metal, supports up to 2kg, matte white finishNot specified
If you would like more help, you can chat with an agent via our Wyze Support chat.
What is the best low profile window mount for Wyze cameras in small apartments?The Wyze Window Mount is the best low profile solution for mounting Wyze cameras on windows in small apartments. It offers a sleek, nearly invisible design, requires no drilling, and is easy to install and remove, making it ideal for renters and those who want a clutter-free living space.
Which Wyze camera models are compatible with the Wyze Window Mount?The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, Cam OG, and Cam OG Telephoto models.
Does the Wyze Window Mount require drilling or permanent installation?No, the Wyze Window Mount does not require any drilling or permanent installation. It attaches directly to glass surfaces, making it perfect for renters and those who want to avoid wall damage.
How can I mount a Wyze camera on a window without glare or reflection?The Wyze Window Mount is designed to provide a clear, glare-free view when mounting your Wyze camera on a window. Its low profile design ensures minimal reflection and maximum visibility.
What is included in the Wyze Cam Mounting Kit and is it suitable for window mounting?The Wyze Cam Mounting Kit includes a mounting bracket, adhesive for secure placement on various surfaces (including glass), a longer Micro USB cable, and a wall plate with screws. While not exclusively a window mount, it offers flexible mounting options for tight spaces and is suitable for window mounting.
Which Wyze cameras are compatible with the Wyze Cam Mounting Kit?The Wyze Cam Mounting Kit is compatible with Wyze Cam v2, Wyze Cam v3, and Wyze Cam v3 Pro.
What is the Wyze Universal Mount (Long) and can it be used for window mounting?The Wyze Universal Mount (Long) is a heavy-duty, adjustable mount that can be used on ceilings, patios, or windows if your camera uses a standard 1/4”-20 mount. It is compatible with most Wyze Cams except Cam OG and OG Telephoto.
Is the Wyze Universal Mount (Long) compatible with all Wyze cameras?No, the Wyze Universal Mount (Long) is not compatible with Wyze Cam OG or Cam OG Telephoto. It works with most other Wyze Cam models that use a standard 1/4”-20 mount.
What should I consider when choosing a window mount for my Wyze camera in a small apartment?When choosing a window mount for your Wyze camera, consider compatibility with your camera model, the available space in your apartment, and whether the mount requires drilling or permanent installation. Low-profile, adhesive-based mounts are ideal for renters and small spaces.
Are Wyze window mounts suitable for renters?Yes, Wyze window mounts like the Wyze Window Mount are perfect for renters because they do not require drilling or permanent fixtures, making them easy to install and remove without damaging walls or windows.
What are the key features of the Wyze Window Mount?Can the Wyze Cam Mounting Kit be used for window mounting as well?Do you have any ongoing sales or discounts for the Wyze Window Mount?
