Affordable Wyze Window Mount for Home Security Cameras Behind Glass
Low Cost Solution for Mounting a Home Security Camera Behind Glass
When it comes to mounting a home security camera behind glass, glare and reflections can seriously affect the camera’s performance. Fortunately, Wyze offers an affordable and effective solution designed specifically for this challenge. Whether you want to monitor your porch, driveway, or backyard through a window, the Wyze Window Mount combined with the Wyze Cam v4 Outdoor Bundle provides a clear, glare-free view at a budget-friendly price.
Wyze Window Mount: Perfect for Glass Surfaces
Clear View Without Glare or Reflection
The Wyze Window Mount is a specialized accessory that allows you to attach your Wyze Cam (v3, v3 Pro, v4, or OG series) directly to a glass surface such as a window. This mount is designed to reduce glare and reflections, ensuring your camera captures crisp, clear footage even when placed behind glass.
  • Compatible Models: Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto
  • Price: Only $9.98 for the latest v2 style
  • Easy Installation: Tool-free setup that sticks securely to your window
  • Ideal Use: Perfect for mounting cameras inside your home looking out through windows, protecting your camera from weather while maintaining excellent image quality
“Mount your cam on a glass surface with this accessory and enjoy a clear view free of glare or reflection.”
This mount is a cost-effective way to upgrade your exterior security without the hassle of outdoor installation or weatherproofing concerns. Wyze Cam Floodlight Outdoor Lifestyle Wyze Cam mounted outdoors providing clear security coverage
Wyze Cam v4 Outdoor Bundle: High-Quality Security Camera
Crystal-Clear 2.5K QHD Resolution
The Wyze Cam v4 Outdoor Bundle is the clearest Wyze camera ever made, offering stunning 2.5K Quad HD video quality. When paired with the Wyze Window Mount, it delivers exceptional clarity through glass, making it ideal for indoor window mounting.
  • Enhanced Color Night Vision: See vibrant colors even in low light, surpassing traditional night vision cameras
  • Motion-Activated Spotlight: Adds an extra layer of security by illuminating detected motion areas
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection for seamless streaming and alerts
  • 24/7 Local Recording: Built-in microSD card slot supports continuous recording for complete coverage
  • Smart Home Compatibility: Works with Alexa and Google Assistant for voice control and automation
Why Choose Wyze Cam v4 for Window Mounting?
The advanced image processor with Wide Dynamic Range (WDR) helps balance bright and dark areas, which is especially useful when shooting through glass where lighting conditions can vary. This means you get vibrant, detailed footage without distortion or glare.
Combining Wyze Window Mount with Wyze Cam v4: The Ideal Setup
By mounting the Wyze Cam v4 behind your window using the Wyze Window Mount, you get a secure, weather-protected camera setup that’s easy to install and maintain. This combination is perfect for renters or homeowners who want to avoid drilling holes or dealing with outdoor wiring.
  • Affordable: Total cost under $80 for a high-quality camera and mount
  • Non-Invasive: No exterior mounting or wiring required
  • Clear Visibility: Glare reduction ensures your camera sees clearly through glass
  • Versatile: Works on any glass window, including sliding doors and large panes
Additional Accessories to Enhance Your Setup
While the Wyze Window Mount and Cam v4 bundle are the core of your window-mounted security solution, consider these accessories for added convenience and style:
Wyze Cam Vase
  • Discreet Home Security: Stylish ceramic or cement-composite vase that hides your Wyze Cam (v3, v3 Pro, or v4) in plain sight
  • Cable Management: Keeps cords tidy and out of view
  • Tool-Free Installation: Easy to set up on shelves or tables near windows
This accessory is perfect if you want your camera to blend seamlessly into your home decor while still monitoring through a window.
Summary
For a low-cost, effective solution to mounting a home security camera behind glass, the Wyze Window Mount paired with the Wyze Cam v4 Outdoor Bundle is unbeatable. This setup offers:
  • Glare-free, clear video through glass
  • High-resolution 2.5K QHD footage with color night vision
  • Easy, non-invasive installation
  • Compatibility with smart home systems
Protect your home with confidence and clarity without breaking the bank.
Wyze Plug-In Cam Lifestyle Wyze Cam v4 providing reliable home security
FeatureWyze Window MountWyze Cam v4 Outdoor Bundle
Product TypeAccessoryCamera Bundle
Compatible CamerasWyze Cam v3, v3 Pro, v4, Wyze Cam OG seriesWyze Cam v4
PurposeMount camera on glass window, reduces glareOutdoor security camera with accessories
Price$9.98$69.99
Mounting SurfaceGlass (window)Outdoor mounting (various options)
Camera ResolutionN/A2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night Vision
SpotlightN/AMotion-activated spotlight
RecordingN/A24/7 local recording with microSD card
ConnectivityN/AWi-Fi 6 support
Smart Assistant IntegrationN/AAlexa and Google Assistant compatible
Included in BundleMount onlyWyze Cam v4, Outdoor Power Adapter, 128GB microSD Card
Weather ResistanceN/AIP65
WarrantyNot specified30-day hassle-free returns
What is the best way to mount a home security camera behind glass?The best way to mount a home security camera behind glass is by using the Wyze Window Mount. This specialized accessory attaches your Wyze Cam directly to a window, reducing glare and reflections for clear, crisp footage.
Which Wyze cameras are compatible with the Wyze Window Mount?The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto models.
How much does the Wyze Window Mount cost?The latest v2 style Wyze Window Mount is priced at only $9.98, making it an affordable solution for window-mounted security cameras.
Does mounting a security camera behind glass affect video quality?Mounting a security camera behind glass can cause glare and reflections, but the Wyze Window Mount is designed to minimize these issues, ensuring your camera captures clear, undistorted footage.
What are the benefits of using the Wyze Cam v4 Outdoor Bundle for window mounting?The Wyze Cam v4 Outdoor Bundle offers 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, Wi-Fi 6 support, and 24/7 local recording. When paired with the Wyze Window Mount, it delivers exceptional clarity through glass and is easy to install indoors.
Can I install the Wyze Window Mount without tools?Yes, the Wyze Window Mount features a tool-free installation process. It sticks securely to your window, making setup quick and easy.
Is the Wyze Cam v4 suitable for renters or people who can't drill holes?Absolutely. The Wyze Cam v4 with the Window Mount is a non-invasive solution that requires no exterior mounting or wiring, making it perfect for renters or anyone who wants to avoid drilling holes.
How much does it cost to set up a Wyze Cam v4 with a Window Mount?The total cost for a Wyze Cam v4 and a Wyze Window Mount is under $80, providing a high-quality, budget-friendly home security solution.
Does the Wyze Cam v4 work with smart home systems?Yes, the Wyze Cam v4 is compatible with Alexa and Google Assistant, allowing for voice control and smart home automation.
Are there any accessories to help hide my Wyze Cam indoors?Yes, the Wyze Cam Vase is a stylish accessory that discreetly hides your Wyze Cam (v3, v3 Pro, or v4) in plain sight, offers cable management, and is easy to set up near windows.
Can the Wyze Window Mount be used on any type of window?The Wyze Window Mount is versatile and works on any glass window, including sliding doors and large panes, making it suitable for various home setups.
Does the Wyze Cam v4 offer continuous recording?Yes, the Wyze Cam v4 has a built-in microSD card slot that supports 24/7 local recording for complete security coverage.
What are the compatible models for the Wyze Window Mount?How does the Wyze Window Mount help reduce glare and reflections?Do you have any deals, ongoing sales, discounts, or promotions?
