Affordable Wyze Window Mount for Front Yard Camera Monitoring
Affordable Indoor Window Camera Mount for Monitoring Your Front Yard
If you're looking for an affordable and effective way to monitor your front yard through your window, the Wyze Window Mount is the perfect accessory to enhance your home security setup. Designed specifically for Wyze cameras, this mount allows you to attach your camera directly to a glass surface, providing a clear, glare-free view of the outdoors.
Wyze Window Mount: Clear, Glare-Free Outdoor Monitoring
Key Features
  • Compatibility: Works seamlessly with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and Wyze Cam OG Telephoto.
  • Glare Reduction: Specially designed to reduce glare and reflections, ensuring your camera captures crisp, clear footage through the window.
  • Easy Installation: Simply attach the mount to your window and secure your Wyze camera for instant front yard monitoring.
  • Affordable Price: At just $9.98, it’s a budget-friendly solution to upgrade your exterior security without drilling holes or complicated setups.
Mount your Wyze camera on your window and enjoy uninterrupted views of your front yard, day or night.
Wyze Window Mount in Use Alt text: Wyze camera mounted on a window overlooking a front yard
Enhance Your Setup with Wyze Cam OG Stack Kit
If you want to expand your monitoring capabilities, the Wyze Cam OG Stack Kit is an excellent companion accessory. It allows you to stack and power two Wyze Cam OG or OG Telephoto cameras from a single power source, perfect for covering multiple angles of your front yard or other areas.
Stack Kit Highlights
  • Includes: USB cable splitter, power brick, and stack mount.
  • Dual Camera Setup: Power and mount two cameras stacked vertically, saving space and power outlets.
  • Versatile Use: Ideal for indoor or outdoor use with Wyze Cam OG series.
  • Affordable: Priced at $9.99, it’s a cost-effective way to double your surveillance coverage.
This kit is perfect if you want to monitor different parts of your front yard or combine indoor and outdoor views for comprehensive security.
Why Choose Wyze for Front Yard Monitoring?
Wyze offers a range of affordable, high-quality security accessories and cameras that make home monitoring accessible and easy. The Wyze Window Mount combined with Wyze cameras provides a simple, no-drill solution to keep an eye on your property through your window. Plus, accessories like the Wyze Cam OG Stack Kit help you scale your system without breaking the bank.
Affordable, easy to install, and designed for clear outdoor views — Wyze accessories are your go-to for front yard security.
Summary of Products for Front Yard Window Monitoring
Product NamePriceKey BenefitCompatible Cameras
Wyze Window Mount$9.98Glare-free window mountingCam v3, v3 Pro, v4, OG series
Wyze Cam OG Stack Kit$9.99Stack and power two OG camerasWyze Cam OG, OG Telephoto
By choosing the Wyze Window Mount and optionally the Wyze Cam OG Stack Kit, you get an affordable, effective, and scalable solution to monitor your front yard through your window with minimal hassle.
FeatureWyze Window MountWyze Cam OG Stack Kit
Product TypeAccessoryAccessory
Compatible CamerasWyze Cam v3, v3 Pro, v4, Wyze Cam OG seriesWyze Cam OG, Wyze Cam OG Telephoto
PurposeMount camera on glass/window to reduce glarePower and stack two Wyze Cam OG or OG Telephoto cameras
Included ItemsWindow mount accessoryUSB Cable Splitter, Power Brick, Stack Mount
Price$9.98$9.99
Mounting SurfaceGlass/window surfaceStack mount for vertical stacking
PowerN/AAllows powering two cameras from one power source
CollectionsShop All, Camera AccessoriesShop All, Camera Accessories
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the Wyze Window Mount and how does it improve front yard monitoring?The Wyze Window Mount is an affordable accessory designed to attach your Wyze camera directly to a glass window. It reduces glare and reflections, allowing your camera to capture clear, crisp footage of your front yard without the need for drilling or complicated installation.
Which Wyze cameras are compatible with the Wyze Window Mount?The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and Wyze Cam OG Telephoto models.
How much does the Wyze Window Mount cost?The Wyze Window Mount is priced at $9.98, making it a budget-friendly solution for enhancing your home security setup.
Does the Wyze Window Mount require drilling or permanent installation?No, the Wyze Window Mount does not require any drilling or permanent installation. It easily attaches to your window, allowing for a hassle-free setup.
How does the Wyze Window Mount reduce glare and reflections?The Wyze Window Mount is specially designed to minimize glare and reflections when your camera is placed against a window, ensuring you get clear and uninterrupted footage of your front yard.
What is the Wyze Cam OG Stack Kit and what are its benefits?The Wyze Cam OG Stack Kit is an accessory that allows you to stack and power two Wyze Cam OG or OG Telephoto cameras from a single power source. It includes a USB cable splitter, power brick, and stack mount, making it easy to monitor multiple angles while saving space and power outlets.
Which cameras are compatible with the Wyze Cam OG Stack Kit?The Wyze Cam OG Stack Kit is compatible with Wyze Cam OG and Wyze Cam OG Telephoto cameras.
Can the Wyze Cam OG Stack Kit be used both indoors and outdoors?Yes, the Wyze Cam OG Stack Kit is suitable for both indoor and outdoor use with the Wyze Cam OG series.
How much does the Wyze Cam OG Stack Kit cost?The Wyze Cam OG Stack Kit is available for $9.99, offering a cost-effective way to expand your surveillance coverage.
Why should I choose Wyze accessories for front yard window monitoring?Wyze accessories like the Window Mount and Cam OG Stack Kit offer affordable, easy-to-install, and scalable solutions for monitoring your front yard. They are designed to provide clear outdoor views and flexible setup options without breaking the bank.
What are the installation steps for the Wyze Window Mount?Can the Wyze Window Mount be used with other camera models besides the ones mentioned?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Window Mount?
