Achieve Wide-Angle Outdoor Views with Wyze Window Mount
Achieving Wide Angle Outside Views with Wyze Window Mount Camera Setup
If you're looking to capture expansive, glare-free outdoor views from inside your home or RV, the Wyze Window Mount is the perfect accessory to elevate your Wyze camera setup. This specialized mount allows you to attach compatible Wyze cameras directly to your window glass, providing a clear, wide-angle perspective without the usual reflections or distortions.
Wyze Window Mount: Clear, Wide-Angle Views from Your Window
Designed for Glass Surfaces
The Wyze Window Mount is engineered to securely attach your Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, or Wyze Cam OG Telephoto directly onto any glass surface. This means you can position your camera inside your home or vehicle and still get an unobstructed, wide-angle view of the outdoors.
  • Glare and Reflection Free: The mount ensures your camera lens sits flush against the glass, eliminating annoying glare and reflections that typically degrade image quality.
  • Versatile Compatibility: Works with multiple Wyze camera models, including the latest Cam v4 and OG series.
  • Ideal for RVs and Campers: Perfect for motorhomes, vans, and travel trailers where outdoor mounting options may be limited.
Upgrade your exterior security or nature viewing experience by simply mounting your camera on the window glass.
Specs at a Glance
  • Compatible with Wyze Cam v3, v3 Pro, v4, OG, and OG Telephoto
  • Easy suction-based installation
  • Durable and weather-resistant for long-term use on glass
  • Price: $9.98 USD
Wyze Cam Floodlight on Deck at Dusk Enjoy wide outdoor views with clear night vision using window-mounted Wyze cameras.
Wyze Cam v4 Outdoor Bundle: Crystal Clear Wide-Angle Coverage
For those who want to complement their window-mounted setup with a powerful outdoor camera, the Wyze Cam v4 Outdoor Bundle offers exceptional wide-angle coverage and advanced features:
  • 2.5K QHD Resolution: Capture stunningly sharp and detailed video footage.
  • Enhanced Color Night Vision: See vibrant colors even in low-light conditions.
  • Motion-Activated Spotlight: Automatically lights up your yard or driveway when motion is detected.
  • Wi-Fi 6 Support: Ensures fast, reliable connectivity for smooth streaming.
  • 24/7 Local Recording: Never miss a moment with continuous recording to a microSD card.
  • Smart Home Compatible: Works seamlessly with Alexa and Google Assistant.
This bundle includes the Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card, making it a complete solution for wide-angle outdoor surveillance.
Why Choose Wyze Cam v4 for Window Mounting?
While primarily designed for outdoor use, the Wyze Cam v4’s wide field of view and high resolution make it an excellent candidate for window mounting with the Wyze Window Mount accessory. This setup allows you to monitor large outdoor areas from inside your home with crystal-clear clarity.
Enhance Your Setup with Wyze Cam Floodlight Plug-In Mount
To further boost your outdoor security and wide-angle visibility, consider the Wyze Cam Floodlight Plug-In Mount. This accessory simplifies floodlight installation without the need for complex wiring or junction boxes.
  • Plug-and-Play Installation: Easy to set up with a 20 ft power cord.
  • Compatible with Wyze Cam Floodlight Series: Works with Floodlight v1, v2, and Floodlight Pro.
  • Outdoor Safe: Built to withstand temperatures from -22°F to 122°F.
  • Includes Mounting Kit: Comes with all necessary hardware for quick installation.
This mount is ideal for illuminating wide outdoor spaces, complementing your window-mounted camera views with bright, motion-activated lighting. Wyze Cam Floodlight Installation Easy floodlight installation enhances wide-angle outdoor security.
Summary: The Ultimate Wide-Angle Window Mounted Camera Setup
By combining the Wyze Window Mount with the Wyze Cam v4 Outdoor Bundle and optionally the Wyze Cam Floodlight Plug-In Mount, you can achieve:
  • Wide, clear, and glare-free outdoor views from inside your home or RV.
  • High-resolution video with enhanced night vision and motion detection.
  • Convenient, easy-to-install accessories that maximize your camera’s potential.
  • Seamless integration with smart home assistants for voice control and alerts.
This setup is perfect for homeowners, RV enthusiasts, and anyone wanting to monitor wide outdoor areas without complicated installations.
FeatureWyze Window MountWyze Cam v4 Outdoor BundleWyze Cam Floodlight Plug-In Mount
TypeAccessoryCamera BundleCamera Accessory
Compatible DevicesWyze Cam v3, v3 Pro, v4, Wyze Cam OG seriesWyze Cam v4Wyze Cam Floodlight v1, v2, Floodlight Pro
PurposeMount camera on glass window, reduce glareOutdoor security camera with 2.5K QHD, spotlight, night visionPlug-in mount for floodlight cameras, no junction box needed
Price$9.98$69.99$19.98
Mounting SurfaceGlass (window)N/A (camera included)Floodlight fixture
Video ResolutionN/A2.5K QHD (2560x1440)N/A
Night VisionN/AEnhanced Color Night VisionN/A
PowerN/AWired, includes power adapter and microSD cardPlug-in power cord, 20 ft cable
Weather ResistanceN/AIP65Outdoor safe
Additional FeaturesReduces glare and reflectionMotion-activated spotlight, Wi-Fi 6, Alexa/Google AssistantOperating temp: -22°F to 122°F, UL and RoHS certified
Included ItemsMount only1x Wyze Cam v4, 1x Outdoor Power Adapter, 1x 128GB microSD1x Plug-in Mount, mounting kit, screws, foam tape, guide
WarrantyNot specified1 YearNot specified
What is the Wyze Window Mount and how does it work?The Wyze Window Mount is a specialized accessory designed to securely attach compatible Wyze cameras directly to your window glass. It allows you to capture wide, glare-free outdoor views from inside your home, RV, or camper by positioning the camera lens flush against the glass, eliminating reflections and image distortion.
Which Wyze cameras are compatible with the Wyze Window Mount?The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and Wyze Cam OG Telephoto models. This ensures versatility for users with different Wyze camera versions.
How do I install the Wyze Window Mount?The Wyze Window Mount features an easy suction-based installation. Simply attach the mount to any clean glass surface, then secure your compatible Wyze camera to the mount for a stable, wide-angle outdoor view.
Does the Wyze Window Mount eliminate glare and reflections?Yes, the Wyze Window Mount is engineered to position your camera lens flush against the glass, effectively eliminating glare and reflections that can degrade image quality. This ensures clear, unobstructed footage.
Is the Wyze Window Mount suitable for use in RVs and campers?Absolutely. The Wyze Window Mount is ideal for RVs, motorhomes, vans, and travel trailers where outdoor mounting options may be limited. It allows you to monitor the outdoors from inside your vehicle with ease.
What are the key features of the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4, outdoor power adapter, and a 128GB microSD card. Key features are 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, Wi-Fi 6 support, 24/7 local recording, and compatibility with Alexa and Google Assistant.
Can I use the Wyze Cam v4 with the Wyze Window Mount?Yes, the Wyze Cam v4 is compatible with the Wyze Window Mount. Its wide field of view and high resolution make it an excellent choice for window-mounted surveillance, providing crystal-clear coverage of large outdoor areas.
What is the Wyze Cam Floodlight Plug-In Mount and what are its benefits?The Wyze Cam Floodlight Plug-In Mount is an accessory that allows for easy, plug-and-play installation of Wyze Cam Floodlight series cameras without complex wiring. It comes with a 20 ft power cord, is outdoor safe, and includes all necessary mounting hardware, making it ideal for illuminating wide outdoor spaces.
Which Wyze Cam Floodlight models are compatible with the Plug-In Mount?The Wyze Cam Floodlight Plug-In Mount is compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro models, providing flexible installation options for enhanced outdoor security.
How much does the Wyze Window Mount cost?The Wyze Window Mount is priced at $9.98 USD, making it an affordable solution for achieving wide-angle, glare-free outdoor views from your window.
What are the advantages of using a window-mounted Wyze camera setup?A window-mounted Wyze camera setup offers wide, clear, and glare-free outdoor views from inside your home or RV. It provides high-resolution video, enhanced night vision, motion detection, easy installation, and seamless integration with smart home assistants for voice control and alerts.
What are the installation steps for the Wyze Window Mount?Can the Wyze Window Mount be used with any other camera models besides the ones mentioned?Do you have any deals, ongoing sales, discounts, or promotions?
