Apartment Home Monitoring: Leak & Climate Sensors by Wyze
Home Monitoring System with Leak and Climate Sensors for Apartments
Creating a safe and comfortable apartment environment requires a reliable home monitoring system that can detect leaks and monitor climate conditions effectively. The Wyze Sense product line offers a comprehensive solution tailored for apartments, combining smart sensors with a central hub to keep you informed and in control.
Wyze Sense Hub: The Central Brain of Your Monitoring System
The Wyze Sense Hub acts as the command center for your home monitoring setup. It connects all your sensors and sends real-time alerts directly to your smartphone, ensuring you never miss critical updates.
  • Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1+ BLE 5.1, and 915MHz RF communication.
  • Range: Up to 500 feet to sensors, perfect for multi-room apartments.
  • Battery: Built-in rechargeable 3.7V, 2600 mAh battery with 10 hours backup.
  • Siren: Loud 88db siren to alert you immediately in case of emergencies.
  • Capacity: Supports up to 100 sensors, allowing extensive coverage.
  • Design: Compact matte white base with a grey speaker top, measuring 4.5” x 4” x 1”.
This hub is designed for indoor use and operates efficiently within typical apartment temperature and humidity ranges.
The Wyze Sense Hub is the essential foundation for a connected, smart apartment monitoring system.
Modern apartment living with smart home technology
Wyze Sense Climate Sensor: Monitor Temperature and Humidity Anywhere
Maintaining optimal climate conditions in your apartment is easy with the Wyze Sense Climate Sensor. It tracks temperature and humidity levels, helping you prevent mold growth and maintain comfort.
  • Range: Up to 500 feet from the hub, ideal for placing in distant rooms, basements, or attics.
  • Battery Life: Long-lasting CR2032 battery with up to 1.5 years of use.
  • Design: Sleek, unobtrusive white matte finish that blends seamlessly into any room.
  • Mounting: Place on any surface or use the peel-and-stick adhesive for wall mounting.
  • Operating Conditions: Works reliably between 32°F to 104°F and up to 85% humidity.
This sensor requires the Wyze Sense Hub to function and is perfect for apartment dwellers who want to keep an eye on their indoor environment.
Wyze Sense Leak Sensor & Probe: Early Leak Detection to Protect Your Home
Leaks can cause significant damage in apartments, especially in shared buildings. The Wyze Sense Leak Sensor & Probe provides early detection to help you act quickly.
  • Compatibility: Works with Wyze Sense v2 and Wyze Home Monitoring systems.
  • Range: Up to 500 feet from the hub, allowing flexible placement near potential leak sources.
  • Operating Temperature: 32°F to 104°F, suitable for indoor apartment environments.
  • Variants: Available with 2 probes or 3 sensors and 1 probe for customizable coverage.
  • Indoor Use: Designed specifically for indoor leak detection.
With this sensor, you receive instant notifications on your phone if water is detected, helping you prevent costly water damage.
Additional Home Monitoring Accessories for Apartments
Wyze Sense Keypad
Control your home security system remotely with the Wyze Sense Keypad. It allows you to arm or disarm your system conveniently and includes an emergency button for quick response.
  • Requires Wyze Sense Hub.
  • Indoor use with permanent adhesive mounting.
  • Supports up to 100 accessories.
  • Price-friendly and easy to install.
Wyze Sense Entry Sensor
Keep track of doors and windows opening or closing with the Wyze Sense Entry Sensor. It’s ideal for apartment security and integrates seamlessly with the Wyze Sense Hub.
  • Detects open/close status.
  • Comes in a 3-pack for multiple entry points.
  • Compatible with Wyze Sense v2 and Home Monitoring.
Why Choose Wyze Sense for Your Apartment?
Wyze Sense offers a scalable, affordable, and easy-to-install home monitoring system tailored for apartment living. Its combination of leak detection, climate monitoring, and security sensors ensures your home stays safe and comfortable.
With a robust hub, long-range sensors, and smart app integration, you can monitor your apartment’s environment and security from anywhere, giving you peace of mind.
FeatureWyze Sense HubWyze Sense Climate SensorWyze Sense Leak Sensor & Probe
TypeHome Monitoring HubHome Monitoring SensorHome Monitoring Sensor
DescriptionConnects monitoring components and sends alerts. Core of Wyze Home Monitoring System.Tracks temperature and humidity. Requires Wyze Sense Hub.Notifies of leaks. Use with Wyze Sense v2 or Wyze Home Monitoring. Requires Wyze Sense Hub.
RequiresNoneWyze Sense HubWyze Sense Hub
CompatibilityWyze Home Monitoring SystemWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home Monitoring
Incompatible WithN/AWyze Sense v1Wyze Sense v1
Sensor RangeN/AUp to 500 ftUp to 500 ft
Operating Temperature RangeN/AN/A32-104°F (0 to 40°C)
Operating Humidity RangeN/AN/A≤ 85% at 86°F (30°C)
Indoor Use OnlyYesYesYes
Price$45.98$41.98 (3 Pack)$13.98 (2 Probes), $55.98 (3 Sensors + 1 Probe)
What is the Wyze Sense Hub and how does it work in apartments?The Wyze Sense Hub is the central command center for your home monitoring system. It connects all Wyze sensors and sends real-time alerts to your smartphone, ensuring you stay informed about leaks, climate changes, and security events in your apartment. The hub supports up to 100 sensors, has a 500-foot range, and features a built-in siren for emergencies.
How does the Wyze Sense Climate Sensor help monitor apartment conditions?The Wyze Sense Climate Sensor tracks temperature and humidity levels in your apartment, helping you prevent mold growth and maintain a comfortable environment. It operates within 32°F to 104°F and up to 85% humidity, and can be placed anywhere within 500 feet of the hub. The sensor requires the Wyze Sense Hub to function.
What are the benefits of using the Wyze Sense Leak Sensor & Probe in apartments?The Wyze Sense Leak Sensor & Probe provides early detection of water leaks, helping you prevent costly damage in your apartment. It sends instant notifications to your phone if water is detected and can be placed up to 500 feet from the hub. The sensor is designed for indoor use and is compatible with Wyze Sense v2 and Wyze Home Monitoring systems.
Can I monitor multiple rooms in my apartment with Wyze Sense products?Yes, the Wyze Sense Hub supports up to 100 sensors, allowing you to monitor multiple rooms, entry points, and potential leak sources throughout your apartment. The sensors have a range of up to 500 feet from the hub, making them ideal for multi-room apartments.
Is the Wyze Sense system easy to install in apartments?Wyze Sense products are designed for easy installation in apartments. The sensors and accessories use peel-and-stick adhesive for mounting, and the system is scalable and affordable. The Wyze Sense Hub connects to your home network via Ethernet or WiFi, and setup is managed through the Wyze app.
What accessories are available for the Wyze Sense home monitoring system?Wyze Sense offers several accessories for apartment monitoring, including the Wyze Sense Keypad for arming/disarming your system, and the Wyze Sense Entry Sensor for monitoring doors and windows. These accessories require the Wyze Sense Hub and are designed for easy indoor installation.
How does the Wyze Sense Entry Sensor improve apartment security?The Wyze Sense Entry Sensor detects when doors or windows are opened or closed, providing real-time alerts to your smartphone. It integrates with the Wyze Sense Hub and is ideal for enhancing apartment security by monitoring multiple entry points.
Why is Wyze Sense a good choice for apartment home monitoring?Wyze Sense is a scalable, affordable, and easy-to-install home monitoring system tailored for apartment living. It combines leak detection, climate monitoring, and security sensors with smart app integration, allowing you to monitor your apartment’s environment and security from anywhere.
What is the battery life of Wyze Sense sensors?The Wyze Sense Climate Sensor uses a CR2032 battery that lasts up to 1.5 years. The Wyze Sense Hub has a built-in rechargeable battery with up to 10 hours of backup power, ensuring continued operation during power outages.
Are Wyze Sense products suitable for indoor use in apartments?Yes, all Wyze Sense products, including the hub, climate sensor, leak sensor, keypad, and entry sensor, are designed specifically for indoor use and operate efficiently within typical apartment temperature and humidity ranges.
What features does the Wyze Sense Hub offer for home monitoring?How does the Wyze Sense Climate Sensor help in maintaining indoor comfort?Do you have any deals, ongoing sales, discounts, or promotions?
