Portable Wireless Cameras with Long Standby Time for Seasonal Homes
When it comes to securing your seasonal home, a reliable, portable wireless camera with long battery life is essential. The
Wyze Battery Cam Pro series offers cutting-edge features designed to provide peace of mind, whether your home is occupied or vacant for months. These cameras combine high-resolution video, weatherproof durability, and flexible power options to keep your property safe year-round.
Wyze Battery Cam Pro: Ultimate Wireless Security
High-Resolution Video & Smart Detection
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution, ensuring crystal-clear images day and night. Its color night vision and integrated spotlight illuminate dark areas, capturing every detail with vibrant clarity. The camera uses a combination of radar and PIR motion sensors for precise, early detection of movement, reducing false alarms and keeping you informed of any activity around your home.
Wire-Free Convenience & Weatherproof Design
Completely wire-free and requiring no hub, this camera is easy to install anywhere around your seasonal home. Rated IP65 for weather resistance, it withstands rain, snow, and dust, making it perfect for outdoor use in all seasons. The removable, rechargeable battery packs provide up to six months of standby time on a single charge, ideal for homes that are not occupied year-round.
Flexible Power & Mounting Options
The camera supports dual-band Wi-Fi (2.4 & 5 GHz) for fast, reliable connectivity. You can mount it on walls, ceilings, or under eaves using the Wyze Universal Mount with a longer stem for versatile placement. The built-in siren and two-way audio allow you to communicate or deter intruders remotely.
"No wires. No hubs. The ultimate battery-operated go-anywhere, see-everything home security camera."
Wyze Battery Cam Pro + Solar Panel: Extended Power for Year-Round Protection
Continuous Power with Solar Charging
For seasonal homes where frequent battery charging is inconvenient, the
Wyze Battery Cam Pro + Solar Panel bundle is the perfect solution. The included solar panel converts sunlight into power, significantly extending the camera’s battery life and reducing the need for manual recharging.
All the Features of the Battery Cam Pro
This bundle retains all the advanced features of the Wyze Battery Cam Pro, including 2.5K HDR video, radar + PIR motion detection, integrated spotlight, and IP65 weatherproofing. The solar panel is also weather-resistant and easy to mount anywhere with a 13-foot power cable for flexible installation.
"Turn your wireless cam into a solar security cam for longer, hassle-free protection."
Essential Accessories to Maximize Battery Life and Convenience
Wyze Removable Battery Pack
Keep your camera powered without downtime by using additional rechargeable battery packs. Each pack offers 6200mAh capacity, lasting up to six months on a single charge. The USB-C charging port makes recharging quick and convenient.
Wyze Battery Charging Dock
Charge two battery packs simultaneously with the dual charging dock. This accessory ensures you always have a fully charged battery ready to swap in, eliminating security gaps during battery changes.
Wyze Battery Cam Solar Panel
Available separately, the solar panel accessory is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor models. It features IP65 weather resistance and a 360° adjustable mount, allowing you to harness solar power efficiently.
Why Choose Wyze Battery Cam Pro for Your Seasonal Home?
- Long Standby Time: Up to 6 months per battery charge, ideal for homes left unattended.
- Wireless & Portable: No wiring or hubs needed, easy to move and install.
- Weatherproof: IP65 rating protects against rain, dust, and snow.
- High-Quality Video: 2.5K HDR resolution with color night vision.
- Smart Motion Detection: Radar + PIR sensors for accurate alerts.
- Expandable Power Options: Removable batteries, charging dock, and solar panel support.
Protect your seasonal home effortlessly with Wyze Battery Cam Pro and its accessories — the smart, flexible, and long-lasting security solution.
Keep your seasonal home safe with wireless, weatherproof security cameras.
Extend your camera’s battery life with solar power for year-round monitoring.
Stay powered up with dual battery charging dock for continuous protection.
What makes the Wyze Battery Cam Pro ideal for seasonal homes?
The Wyze Battery Cam Pro is perfect for seasonal homes because it offers up to six months of standby time on a single charge, is completely wire-free for easy installation, and features IP65 weatherproofing to withstand rain, snow, and dust. Its high-resolution 2.5K HDR video and smart motion detection ensure your property is monitored even when you’re away for extended periods.How long does the Wyze Battery Cam Pro battery last on a single charge?
The Wyze Battery Cam Pro’s removable, rechargeable battery pack can last up to six months on a single charge, making it ideal for properties that are not occupied year-round.Can the Wyze Battery Cam Pro be used outdoors?
Yes, the Wyze Battery Cam Pro is rated IP65 for weather resistance, making it suitable for outdoor use in all seasons. It can withstand rain, snow, and dust, ensuring reliable performance year-round.Does the Wyze Battery Cam Pro require any wiring or a hub?
No, the Wyze Battery Cam Pro is completely wire-free and does not require a hub. This makes installation quick and easy, with flexible placement options around your home.What video quality does the Wyze Battery Cam Pro provide?
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution with color night vision and an integrated spotlight, ensuring clear and detailed footage both day and night.How does the Wyze Battery Cam Pro detect motion?
The camera uses a combination of radar and PIR (Passive Infrared) motion sensors for precise and early detection of movement, reducing false alarms and providing accurate alerts.What are the power options for the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro can be powered by its removable, rechargeable battery pack or extended with the Wyze Solar Panel for continuous solar charging. Additional battery packs and a dual charging dock are also available for uninterrupted power.How does the Wyze Battery Cam Pro + Solar Panel bundle work?
The Wyze Battery Cam Pro + Solar Panel bundle includes a weather-resistant solar panel that converts sunlight into power, significantly extending the camera’s battery life and reducing the need for manual recharging. It retains all the advanced features of the Wyze Battery Cam Pro.What accessories are available for the Wyze Battery Cam Pro?
Essential accessories include the Wyze Removable Battery Pack for quick battery swaps, the Wyze Battery Charging Dock for charging two batteries simultaneously, and the Wyze Battery Cam Solar Panel for continuous solar power. All accessories are designed to maximize convenience and battery life.Can I mount the Wyze Battery Cam Pro in different locations?
Yes, the Wyze Battery Cam Pro can be mounted on walls, ceilings, or under eaves using the Wyze Universal Mount with a longer stem, offering versatile placement options to suit your security needs.Does the Wyze Battery Cam Pro support two-way audio and a siren?
Yes, the camera features built-in two-way audio for remote communication and a siren to deter intruders, enhancing your home’s security.Is the Wyze Battery Cam Pro compatible with both 2.4 GHz and 5 GHz Wi-Fi networks?
Yes, the Wyze Battery Cam Pro supports dual-band Wi-Fi (2.4 GHz and 5 GHz) for fast and reliable connectivity.
