Wyze Battery Cam Pro: Extended Range Wireless Security Camera
Extended Range Wireless Security with Wyze Battery Cam Pro
When it comes to reliable, extended range wireless cameras that maintain a strong connection from afar, the Wyze Battery Cam Pro stands out as a top choice. Designed for wire-free convenience and robust performance, this camera offers exceptional video quality and smart features to keep your property secure no matter the distance.
Wyze Battery Cam Pro: Powerful Wireless Security
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution, ensuring crystal-clear footage day and night. Its wire-free design means no complicated wiring or hubs are required, making installation quick and flexible. Equipped with both 2.4 GHz and 5 GHz WiFi support, it maintains a stable connection even at extended ranges, perfect for large properties or remote monitoring. Key features include:
  • 2.5K HDR Video Resolution with H.264 encoding for sharp, detailed images.
  • Radar + PIR Motion Detection for accurate alerts and reduced false alarms.
  • Integrated Spotlight & Siren to deter intruders and illuminate dark areas.
  • Removable, Rechargeable 6200mAh Battery Packs offering up to 6 months of battery life on a single charge.
  • IP65 Weatherproof Rating to withstand harsh outdoor conditions.
  • Wide Field of View: 134° diagonal, 108° horizontal, and 56° vertical.
  • Two-Way Audio with built-in speaker and microphone for real-time communication.
  • Smart Home Integrations including Alexa, Google Assistant, and IFTTT.
With a compact size of 2.5 x 1.8 x 3.5 inches and weighing just 0.94 lbs, the Wyze Battery Cam Pro is easy to mount anywhere using the included wall mount.
Experience peace of mind with a camera that stays connected and keeps watch, no matter how far your property extends.
Outdoor security camera in use Alt text: Wyze Battery Cam Pro mounted outdoors monitoring a large yard
Wyze Battery Cam Pro + Solar Panel: Extended Power for Remote Locations
For users seeking even longer-lasting power without the hassle of frequent recharging, the Wyze Battery Cam Pro + Solar Panel bundle is an ideal solution. This combination pairs the powerful Wyze Battery Cam Pro with a weather-resistant solar panel that continuously charges the camera’s battery using sunlight. Highlights of this bundle include:
  • All the features of the Wyze Battery Cam Pro.
  • Solar Panel with IP65 Weather Resistance designed to mount easily anywhere with a 360° adjustable mount.
  • Continuous Charging to extend battery life indefinitely in sunny locations.
  • A 13-foot power cable for flexible installation options.
  • Supports local storage up to 256GB microSD and cloud recording with Cam Plus.
This setup is perfect for remote cabins, large outdoor spaces, or any location where power outlets are scarce.
Wyze Battery Cam Solar Panel Accessory: Power Up Your Camera
If you already own a Wyze Battery Cam Pro and want to extend its battery life, the Wyze Battery Cam Solar Panel accessory is a smart add-on. Designed specifically for the Wyze Battery Cam Pro and compatible with Wyze Cam Outdoor v1/v2, this solar panel harnesses solar energy to keep your camera powered longer. Features include:
  • IP65 Weatherproof Design for reliable outdoor use.
  • Easy 360° mounting for optimal sun exposure.
  • 2.5W, 5V DC solar power rating with a 13-foot micro USB cable.
  • Includes all mounting hardware and adapter cables for quick setup.
This accessory ensures your camera stays charged and connected, reducing downtime and maintenance.
Why Choose Wyze Battery Cam Pro for Extended Range Wireless Security?
The Wyze Battery Cam Pro series is engineered to provide dependable wireless security with extended range capabilities. Its dual-band WiFi support, combined with a powerful radar and PIR motion detection system, ensures your camera maintains a strong connection and accurate monitoring even from a distance. The rechargeable battery packs with optional solar charging make it a versatile choice for locations without easy access to power. Plus, the IP65 weatherproof rating guarantees durability in all seasons. Whether you want a standalone camera or a solar-powered setup, Wyze offers flexible options to suit your security needs.
Summary of Wyze Battery Cam Pro Products
ProductKey FeaturesPrice Range
Wyze Battery Cam Pro2.5K HDR, Radar + PIR, Spotlight & Siren, Up to 6 months battery$89.98 - $219.98
Wyze Battery Cam Pro + Solar PanelIncludes solar panel for continuous charging$109.98
Wyze Battery Cam Solar PanelSolar panel accessory for extended battery life$24.99
Invest in Wyze Battery Cam Pro for a wireless security camera that truly maintains connection from afar, with options to keep it powered longer through solar energy.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Battery Cam Solar Panel
Product TypeCameraCamera + Solar Panel BundleAccessory (Solar Panel)
Video Resolution2.5K HDR2.5K HDRN/A
Power SourceRemovable, Rechargeable Battery PacksRemovable, Rechargeable Battery + Solar PanelSolar Panel (extends battery life)
WirelessYes, Wire-Free, No Hub RequiredYes, Wire-Free, No Hub RequiredN/A
Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion DetectionN/A
Integrated Spotlight & SirenYesYesN/A
Weatherproof RatingIP65IP65IP65
WiFi Support2.4 & 5 GHz2.4 & 5 GHzN/A
Local RecordingYes (with MicroSD card)Yes (with MicroSD card)N/A
Battery LifeUp to 6 months per charge (6200mAh battery)Extended with Solar PanelN/A
Solar Power RatingN/AIncluded (2.5W, 5VDC)2.5W, 5VDC
Solar Panel DimensionsN/AIncluded (173 mm x 120 mm x 17 mm)173 mm x 120 mm x 17 mm
Solar Panel Cable LengthN/AIncluded (13 ft / 4 m)13 ft (4 m)
Mounting OptionsWall, Ceiling (with Universal Mount)Wall, Ceiling (with Universal Mount)360° Mount, Weather Resistant
Price (USD)$89.98 (1 Pack White/Black)$109.98 (Bundle White/Black)$24.99 (Solar Panel), $5.99 (USB-C Adapter Cable)
Included ItemsCamera onlyCamera + Solar PanelSolar panel, wall mount, USB cables, screws, anchors, guide
Charging Dock CompatibilityYes (sold separately)Yes (sold separately)N/A
What is the Wyze Battery Cam Pro and how does it enhance wireless security?The Wyze Battery Cam Pro is a wire-free, extended range wireless security camera designed for reliable performance and easy installation. It features 2.5K HDR video resolution, dual-band WiFi (2.4 GHz and 5 GHz) for stable connections over long distances, radar and PIR motion detection, integrated spotlight and siren, and up to 6 months of battery life. Its IP65 weatherproof rating and smart home integrations make it ideal for securing large properties or remote locations.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro is equipped with removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge, depending on usage and environmental conditions.
Can the Wyze Battery Cam Pro be used in outdoor environments?Yes, the Wyze Battery Cam Pro is designed for outdoor use with an IP65 weatherproof rating, allowing it to withstand harsh weather conditions and provide reliable security monitoring year-round.
What are the benefits of the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle provides continuous charging for your camera using sunlight, reducing the need for manual recharging. The solar panel is weather-resistant, features a 360° adjustable mount, and comes with a 13-foot power cable for flexible installation. This setup is perfect for remote locations or areas without easy access to power outlets.
Is there a solar panel accessory available for the Wyze Battery Cam Pro?Yes, the Wyze Battery Cam Solar Panel accessory is available and designed specifically for the Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2. It features an IP65 weatherproof design, 2.5W solar power output, a 13-foot micro USB cable, and all necessary mounting hardware for easy installation.
Does the Wyze Battery Cam Pro support local and cloud storage?Yes, the Wyze Battery Cam Pro supports local storage with microSD cards up to 256GB and offers cloud recording through the Cam Plus subscription service.
What smart home integrations are available with the Wyze Battery Cam Pro?The Wyze Battery Cam Pro integrates with popular smart home platforms including Amazon Alexa, Google Assistant, and IFTTT, allowing for voice control and automation.
How easy is it to install the Wyze Battery Cam Pro?The Wyze Battery Cam Pro features a compact, wire-free design and comes with a wall mount, making installation quick and flexible without the need for complicated wiring or hubs.
What is the video quality of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution with H.264 encoding, providing sharp, detailed images both day and night.
What motion detection features does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro uses a combination of radar and PIR (Passive Infrared) motion detection to provide accurate alerts and reduce false alarms, ensuring reliable monitoring of your property.
What are the key features of the Wyze Battery Cam Pro?How does the Wyze Battery Cam Pro compare to other wireless cameras?Is there a warranty available for the Wyze Battery Cam Pro?
