Wyze Battery Cam Pro: Flexible Indoor & Outdoor Wireless Security
Wyze Battery Cam Pro: Ultimate Flexible Placement Camera
The Wyze Battery Cam Pro is designed for both indoor and outdoor use, offering unparalleled flexibility with its wire-free design and standalone battery power. Whether you want to monitor your front porch, backyard, or even inside your home, this camera delivers professional-grade security without the hassle of wiring or hubs.
Key Features and Specifications
  • 2.5K HDR Video Resolution: Capture crystal-clear footage with high dynamic range, ensuring balanced images and vibrant colors day or night.
  • Wire-Free & No Hub Required: Install anywhere without worrying about power outlets or complicated setups.
  • Integrated Spotlight & Siren: The built-in 150-lumen LED spotlight activates on motion to deter intruders, plus a siren for added security.
  • Radar + PIR Motion Detection: Dual sensors provide early and precise motion alerts, reducing false alarms.
  • Removable, Rechargeable Battery Packs: Easily swap batteries to keep your camera running continuously without downtime.
  • IP65 Weatherproof Rating: Built to withstand rain, dust, and extreme weather conditions.
  • Dual-Band Wi-Fi Support: Connects seamlessly to both 2.4 GHz and 5 GHz networks for faster, more reliable streaming.
  • Local Recording Option: Supports microSD cards for local video storage without subscription fees.
This camera is perfect for users seeking a versatile, portable security solution that can be placed anywhere with ease.
Wyze Battery Cam Pro + Solar Panel: Continuous Power Anywhere
For those who want to extend the battery life of their Wyze Battery Cam Pro, the Wyze Battery Cam Pro + Solar Panel bundle is the ideal choice. This package combines the powerful camera with a solar panel that converts sunlight into energy, allowing for longer, uninterrupted monitoring.
Why Choose the Solar Panel Bundle?
  • Continuous Solar Power: The solar panel keeps your camera charged by harnessing the sun’s energy, reducing the need for manual battery swaps.
  • Weather-Resistant Design: Both the camera and solar panel feature IP65 weatherproofing, ensuring reliable performance in all conditions.
  • Easy Installation: Mount the solar panel anywhere with the included hardware and enjoy hassle-free power.
  • All the Features of Wyze Battery Cam Pro: Enjoy 2.5K HDR video, integrated spotlight, radar + PIR motion detection, and more.
This bundle is perfect for outdoor enthusiasts, RV owners, or anyone wanting a truly wireless security camera with extended battery life.
Essential Accessories for Wyze Battery Cam Pro
Wyze Removable Battery Pack
Keep your camera powered longer with the Wyze Removable Battery Pack, a 6200mAh rechargeable battery designed specifically for the Battery Cam Pro.
  • Long Battery Life: Lasts up to 6 months on a single charge under typical usage.
  • Convenient USB-C Charging: Recharge quickly and easily with a built-in USB-C port.
  • Compact and Lightweight: Measures 2.9 x 1.6 x 0.9 inches and weighs just 3.9 oz.
Swapping batteries is simple, eliminating downtime and keeping your security system active.
Wyze Battery Charging Dock
Charge two batteries simultaneously with the Wyze Battery Charging Dock.
  • Dual Charging Slots: Charge up to two battery packs at once, saving time.
  • Compact Design: Small footprint fits easily on any desk or shelf.
  • Includes Power Adapter and USB-C Cable: Ready to use out of the box.
This dock is a must-have for users with multiple battery packs to keep their cameras running continuously.
Wyze Battery Cam Solar Panel
Extend your camera’s runtime with the Wyze Battery Cam Solar Panel accessory.
  • IP65 Weather Resistant: Designed to withstand outdoor elements.
  • Easy 360° Mounting: Adjust the panel for optimal sun exposure.
  • 13-Foot Power Cable: Flexible placement options for the solar panel.
Compatible with Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2, this solar panel is a smart investment for sustainable power.
"Protect anywhere with wire-free, weatherproof, and solar-powered security."
Summary
The Wyze Battery Cam Pro and its solar-powered variant offer unmatched flexibility for indoor and outdoor security needs. With high-resolution video, advanced motion detection, and weatherproof design, these cameras provide peace of mind wherever you place them. Complement your setup with removable batteries, charging docks, and solar panels to ensure continuous protection without the hassle of wiring or frequent recharging.
Outdoor Security Camera in Use Experience flexible placement with Wyze Battery Cam Pro outdoors. Solar Panel Powering Camera Extend your camera’s battery life with the Wyze Solar Panel. Charging Dock with Batteries Keep your batteries charged and ready with the Wyze Battery Charging Dock.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Removable Battery PackWyze Battery Charging DockWyze Battery Cam Solar Panel
TypeCameraCamera + Accessory BundleAccessory (Battery)Accessory (Charging Dock)Accessory (Solar Panel)
Video Resolution2.5K HDR2.5K HDRN/AN/AN/A
Power SourceRemovable rechargeable batteryRemovable rechargeable battery + solar power6200mAh rechargeable batteryCharges up to two batteries simultaneouslySolar panel (2.5W, 5VDC)
Battery CapacityIncluded battery packsIncluded battery packs6200mAh Lithium IonN/AN/A
Battery TypeLithium IonLithium IonLithium IonN/AN/A
Charging MethodUSB-C (via battery pack)USB-C (via battery pack) + solar panelUSB-C charging portUSB-A to USB-C power adapterSolar power with 13 ft cable
Weatherproof RatingIP65IP65N/AN/AIP65
Motion DetectionRadar + PIRRadar + PIRN/AN/AN/A
Spotlight & SirenIntegrated spotlight & sirenIntegrated spotlight & sirenN/AN/AN/A
WiFi Support2.4 & 5 GHz2.4 & 5 GHzN/AN/AN/A
Local RecordingYes (microSD card, not included)Yes (microSD card, not included)N/AN/AN/A
Mounting OptionsFlexible, includes universal mount optionFlexible, includes universal mount optionN/AN/AWeather resistant, 360° mount included
DimensionsN/AN/A2.9 in x 1.6 in x 0.9 in (75 x 40 x 22 mm)Charging Dock: 2.6in x 2in x 1in173 mm x 120 mm x 17 mm
WeightN/AN/A3.9 oz (110g)2.75 oz (78 g)N/A
Price (USD)$89.98 (1 pack)$109.98 (bundle)$22.99$17.99$24.99
Additional FeaturesWire-free, no hub, removable battery packsWire-free, no hub, solar powered optionLong battery life (up to 6 months per charge)Charges two batteries simultaneouslyExtends battery life, weather resistant
Included ItemsCamera onlyCamera + Solar PanelBattery pack onlyCharging dock, adapter cable, power adapterSolar panel, mount, cables, screws, anchors
What is the Wyze Battery Cam Pro?The Wyze Battery Cam Pro is a wire-free, battery-powered security camera designed for both indoor and outdoor use. It offers 2.5K HDR video resolution, advanced motion detection, and weatherproof durability, making it ideal for flexible placement anywhere around your home or property.
Does the Wyze Battery Cam Pro require wiring or a hub for installation?No, the Wyze Battery Cam Pro features a completely wire-free design and does not require a hub. You can install it anywhere without worrying about power outlets or complicated setups.
What video quality does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro provides 2.5K HDR video resolution, ensuring crystal-clear footage with balanced images and vibrant colors, both day and night.
How does the Wyze Battery Cam Pro detect motion?The camera uses dual motion detection technology, combining radar and PIR (Passive Infrared) sensors. This setup provides early and precise motion alerts while reducing false alarms.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro has an IP65 weatherproof rating, making it resistant to rain, dust, and extreme weather conditions for reliable outdoor use.
Can I use the Wyze Battery Cam Pro with both 2.4 GHz and 5 GHz Wi-Fi networks?Yes, the Wyze Battery Cam Pro supports dual-band Wi-Fi, allowing you to connect to both 2.4 GHz and 5 GHz networks for faster and more reliable streaming.
Does the Wyze Battery Cam Pro support local video storage?Yes, the camera supports local recording via microSD cards, enabling you to store video footage without subscription fees.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes the camera and a weather-resistant solar panel. The solar panel harnesses sunlight to keep your camera charged, reducing the need for manual battery swaps and ensuring continuous power.
How do I extend the battery life of my Wyze Battery Cam Pro?You can extend the battery life by using the Wyze Battery Cam Solar Panel, which provides continuous solar power, or by keeping extra Wyze Removable Battery Packs charged and ready for quick swaps.
What accessories are available for the Wyze Battery Cam Pro?Essential accessories include the Wyze Removable Battery Pack for extended battery life, the Wyze Battery Charging Dock for charging two batteries simultaneously, and the Wyze Battery Cam Solar Panel for sustainable, solar-powered operation.
How long does the Wyze Removable Battery Pack last on a single charge?The Wyze Removable Battery Pack can last up to 6 months on a single charge under typical usage conditions.
Is the Wyze Battery Cam Solar Panel compatible with other Wyze cameras?Yes, the Wyze Battery Cam Solar Panel is compatible with both the Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 models.
How easy is it to install the Wyze Battery Cam Pro and its accessories?Installation is simple and hassle-free. The camera and solar panel are wire-free and come with mounting hardware, while the battery and charging dock are designed for easy swapping and charging.
What are the key features of the Wyze Battery Cam Pro?How does the Wyze Battery Cam Pro handle motion detection?Do you have any deals, ongoing sales, discounts, or promotions?
