Wyze Battery Cam Pro: Wireless Yard Camera with Continuous Recording
Wireless Camera for Yard Surveillance with Optional Continuous Recording: Wyze Battery Cam Pro
When it comes to securing your yard with a wireless camera that offers flexibility, high-quality video, and optional continuous recording, the Wyze Battery Cam Pro stands out as an excellent choice. Designed for outdoor use, this camera combines advanced features with the convenience of wire-free installation, making it perfect for yard surveillance.
Wyze Battery Cam Pro: Key Features for Yard Security
  • 2.5K HDR Video Resolution: Capture crystal-clear, high dynamic range footage that reveals every detail in vibrant color, day or night.
  • Wire-Free & No Hub Required: Install anywhere in your yard without the hassle of wiring or additional hubs.
  • Integrated Spotlight & Siren: The built-in 150-lumen spotlight and siren deter intruders and illuminate your yard when motion is detected.
  • Radar + PIR Motion Detection: Dual sensors provide earlier and more accurate motion alerts, reducing false alarms.
  • Removable, Rechargeable Battery Packs: Easily swap batteries to keep your camera running without downtime.
  • IP65 Weatherproof Rating: Built to withstand rain, snow, and dust, ensuring reliable outdoor performance.
  • Dual-Band Wi-Fi Support (2.4 & 5 GHz): Connect seamlessly to your home network for smooth streaming and notifications.
  • Optional Continuous Recording: Use a microSD card for local storage to record motion events without a subscription, or add a Wyze Solar Panel for extended power and longer recording intervals.
"Protect anywhere. See everything in 2.5K HDR. No power outlet or electrician needed."
Power and Mounting Flexibility
The Wyze Battery Cam Pro offers multiple power options to suit your yard setup:
  • Hot-Swappable Batteries: Keep your camera powered by swapping out batteries without removing the camera.
  • Solar Panel Compatibility: Convert your camera into a solar-powered security device to reduce charging frequency.
  • Universal Mount Options: Mount on walls, ceilings, or eaves with the Wyze Universal Mount for optimal coverage.
Enhanced Detection and Smart Alerts
With radar and PIR sensors working together, the Wyze Battery Cam Pro detects motion with precision. Customize detection zones in the Wyze app to focus on critical areas of your yard. For even smarter alerts, subscribe to Cam Plus for person, package, and vehicle detection.
Wyze Battery Cam Pro in Yard Reliable outdoor surveillance with Wyze Battery Cam Pro in snowy yard
Wired Alternative with Continuous Recording: Wyze Cam v4
If you prefer a wired camera with continuous 24/7 recording capabilities for your yard, the Wyze Cam v4 is a powerful option. While it requires a power source, it offers unmatched video clarity and smart features.
Wyze Cam v4 Highlights
  • 2.5K QHD Resolution with Wide Dynamic Range (WDR): Enjoy vibrant, detailed video with enhanced color night vision that reveals more than traditional night vision.
  • 24/7 Local Recording: Supports continuous recording to a microSD card (up to 256GB) without subscription fees.
  • Motion-Activated Spotlight & 99 dB Siren: Illuminate your yard and deter intruders instantly.
  • IP65 Weather Resistance: Designed for outdoor use in all weather conditions.
  • Wi-Fi 6 Support: Faster, more reliable connection for smooth streaming and alerts.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Advanced Motion & Sound Detection: Receive alerts for motion, sound, smoke, and CO alarms.
Convenience and Installation
Wyze Cam v4 features a magnetic base for easy, screw-free mounting and Bluetooth setup for quick installation. Its wide 115.9° diagonal field of view covers large yard areas effectively.
Wyze Cam Floodlight v2 Lifestyle Stay secure with smart lighting and camera integration in your yard
Why Choose Wyze for Yard Surveillance?
Wyze offers a range of cameras tailored to different yard security needs:
  • Wireless Freedom with Wyze Battery Cam Pro: Ideal for locations without power outlets or where wiring is impractical.
  • Continuous Power and Recording with Wyze Cam v4: Perfect for users wanting uninterrupted surveillance and advanced smart features.
  • Weatherproof and Durable: Both cameras are IP65 rated, ensuring reliable operation in rain, snow, or heat.
  • Smart Alerts and AI Detection: Customize notifications to reduce false alarms and focus on what matters.
  • Expandable Storage Options: Use microSD cards for local recording or subscribe to cloud plans for extended video storage.
Protect your yard with confidence using Wyze’s innovative cameras designed for easy installation, high-quality video, and smart security features.
Summary of Featured Cameras
Camera ModelWirelessVideo ResolutionContinuous RecordingWeatherproofPower SourceSpecial Features
Wyze Battery Cam ProYes2.5K HDROptional (microSD)IP65Battery / Solar PanelRadar + PIR motion, Spotlight, Siren
Wyze Cam v4No2.5K QHDYes (microSD)IP65Wired (Power Adapter)Color Night Vision, Wi-Fi 6, Siren
FeatureWyze Battery Cam ProWyze Cam v4
Video Resolution2.5K HDR2.5K QHD
Power SourceBattery (Removable, Rechargeable Packs)Wired
WirelessYes (2.4 & 5 GHz WiFi)No (Wired)
Weatherproof RatingIP65IP65
Night VisionColor Night VisionEnhanced Color Night Vision
SpotlightIntegrated, Motion-Activated (150 lumens)Integrated, Motion-Activated
SirenYesYes
Motion DetectionRadar + PIR Motion DetectionMotion and Sound Detection
Local RecordingYes (MicroSD card, impacts battery life)Yes (MicroSD card, up to 512GB)
Cloud StorageOptional (Cam Plus subscription)Optional (Cam Plus subscription)
Wi-Fi Support2.4 & 5 GHz WiFiWi-Fi 6
SetupBluetoothⓇ Setup, No Hub RequiredBluetoothⓇ Setup
AudioTwo-Way Talk with Built-in Mic and SpeakerEnhanced Two-Way Talk, 99 dB Speaker
Mounting OptionsFlexible, including ceiling mount with accessoryStand, Wall, Ceiling, Magnetic Mount
Battery Charging AccessoriesCharging Dock (sold separately), Solar PanelN/A (Wired)
Field of ViewNot specified115.8° DFOV, 98.5° HFOV, 53.1° VFOV
DimensionsNot specified2in x 2in x 2 3/8in
WeightNot specified0.49 lb (222 g)
Additional FeaturesHot-swap batteries, Bird Detection (with plan)Smoke & CO Alerts, Auto-Zoom with AI
Price (1 Pack, approximate)$89.98$35.98
What makes the Wyze Battery Cam Pro a good choice for yard surveillance?The Wyze Battery Cam Pro is ideal for yard surveillance due to its 2.5K HDR video resolution, wire-free installation, integrated spotlight and siren, radar + PIR motion detection, and IP65 weatherproof rating. It also offers optional continuous recording with a microSD card and supports both battery and solar panel power options.
Does the Wyze Battery Cam Pro require wiring or a hub for installation?No, the Wyze Battery Cam Pro is completely wire-free and does not require any additional hub for installation. You can easily mount it anywhere in your yard without the need for wiring or professional installation.
Can the Wyze Battery Cam Pro record continuously?Yes, the Wyze Battery Cam Pro supports optional continuous recording when you insert a microSD card. This allows you to record motion events locally without a subscription. You can also use a Wyze Solar Panel for extended power and longer recording intervals.
How is the Wyze Battery Cam Pro powered?The Wyze Battery Cam Pro uses removable, rechargeable battery packs that can be hot-swapped for uninterrupted operation. It is also compatible with the Wyze Solar Panel, allowing you to convert it into a solar-powered security camera.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro has an IP65 weatherproof rating, making it suitable for outdoor use in rain, snow, and dust.
What motion detection features does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro features dual radar and PIR motion sensors for earlier and more accurate motion alerts, reducing false alarms. You can also customize detection zones in the Wyze app to focus on specific areas of your yard.
Does the Wyze Battery Cam Pro support dual-band Wi-Fi?Yes, the Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz Wi-Fi bands, ensuring a reliable and fast connection for streaming and notifications.
What are the mounting options for the Wyze Battery Cam Pro?The Wyze Battery Cam Pro can be mounted on walls, ceilings, or eaves using the Wyze Universal Mount, providing flexible installation options for optimal yard coverage.
What is the best Wyze camera for continuous 24/7 yard recording?The Wyze Cam v4 is the best option for continuous 24/7 yard recording. It is a wired camera that supports nonstop local recording to a microSD card (up to 256GB) and offers 2.5K QHD resolution with wide dynamic range.
What are the key features of the Wyze Cam v4 for outdoor surveillance?The Wyze Cam v4 features 2.5K QHD resolution, color night vision, 24/7 local recording, motion-activated spotlight, 99 dB siren, IP65 weather resistance, Wi-Fi 6 support, smart home integration, and advanced motion and sound detection.
Is the Wyze Cam v4 weatherproof?Yes, the Wyze Cam v4 is IP65 rated, making it weather resistant and suitable for outdoor use in all conditions.
Can I use Wyze cameras with smart home devices?Yes, the Wyze Cam v4 is compatible with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
Do Wyze cameras require a subscription for recording?No, both the Wyze Battery Cam Pro and Wyze Cam v4 support local recording to a microSD card without a subscription. However, you can subscribe to Cam Plus for additional AI detection features and cloud storage.
How do Wyze cameras help reduce false motion alerts?Wyze cameras use advanced radar and PIR motion detection (Battery Cam Pro) and customizable detection zones to provide more accurate alerts and reduce false alarms. Cam Plus subscribers also benefit from person, package, and vehicle detection.
What storage options are available for Wyze yard cameras?Wyze cameras support expandable local storage via microSD cards for motion event or continuous recording. You can also subscribe to Wyze cloud plans for extended video storage and smart AI features.
What are the installation requirements for the Wyze Battery Cam Pro?Can the Wyze Battery Cam Pro be used in extreme weather conditions?Are there any ongoing promotions or discounts for the Wyze Battery Cam Pro?
