Portable Cordless Vacuum for Outdoor Patio and Garage Floors: Wyze Cordless Vacuum S
When it comes to cleaning outdoor patios and garage floors, having a powerful yet portable vacuum is essential. The
Wyze Cordless Vacuum S is designed to meet these needs with impressive suction power, lightweight design, and versatile attachments. Whether you’re tackling dust, dirt, or debris, this vacuum offers the freedom and efficiency you need without being tethered to a power outlet.
Why Choose Wyze Cordless Vacuum S for Outdoor and Garage Cleaning?
Powerful Suction for Tough Debris
The Wyze Cordless Vacuum S boasts an outstanding suction power of up to
20,000 Pa in Turbo Mode, making it highly effective for outdoor patios and garage floors where dirt and debris can be stubborn. It offers three suction modes to balance power and battery life:
- Turbo Mode: 20,000 Pa (10 minutes runtime)
- Medium Mode: 9,000 Pa (23 minutes runtime)
- ECO Mode: 6,000 Pa (40 minutes runtime)
This range allows you to customize cleaning intensity depending on the mess, ensuring thorough cleaning without wasting battery.
Ultra-Lightweight and Portable
Weighing only
2.8 lbs for the main unit and
4.9 lbs when fully assembled, the Wyze Cordless Vacuum S is easy to carry around your patio or garage. Its cordless design means no hassle with power cords, letting you move freely and reach tight corners or awkward spaces.
Long-Lasting Battery with Quick Recharge
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), this vacuum provides up to
40 minutes of runtime in ECO mode, perfect for extended cleaning sessions outdoors. When it’s time to recharge, the vacuum takes just
4-6 hours to reach full charge via AC charging.
“Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support.” – Wyze
Effortless cleaning on hard floors and patios with Wyze Cordless Vacuum S
Features That Make Wyze Cordless Vacuum S Ideal for Outdoor Use
Dual Motors and LED Lighting
The vacuum is powered by
two motors for enhanced suction and efficiency. Additionally, the brush head includes
6 daylight-bright LED lights, illuminating dark corners and under furniture or garage shelves, so you never miss hidden dirt.
Advanced Filtration System
A
3-stage filtration system with a HEPA filter traps fine dust and allergens, ensuring cleaner air even when vacuuming dusty outdoor areas.
Versatile Attachments Included
The Wyze Cordless Vacuum S comes with multiple attachments to tackle various surfaces and tight spaces:
- Crevice Tool for narrow gaps and corners
- Floor Brush for hard floors and patios
- Dust Cap to seal the dust cup
- HEPA Filter for clean exhaust air
- Standard Tube for extended reach
These tools make it easy to clean garage floors, patio furniture, and even car interiors.
Enhance Your Cleaning Experience with Wyze Accessories
To keep your Wyze Cordless Vacuum S running at peak performance or to extend its capabilities, consider these compatible accessories:
Wyze Cordless Vacuum S - Battery Pack
Need extra runtime? The
Battery Pack is designed specifically for the Wyze Cordless Vacuum S, allowing you to swap batteries and clean longer without waiting for a recharge.
Wyze Cordless Vacuum S - Charger
Keep a spare
replacement charger handy to ensure your vacuum is always ready to go.
This accessory bends for easier cleaning in hard-to-reach areas, reducing strain and improving maneuverability.
Wyze Cordless Vacuum - HEPA Filter
Replace your HEPA filters regularly to maintain optimal filtration and air quality.
Wyze Cordless Vacuum - Mini Motorized Brush Head
Perfect for cleaning car seats, sofas, and other upholstery, this brush head complements your outdoor cleaning by tackling vehicle interiors after a day in the garage or patio.
Wyze Cordless Vacuum S is pet-friendly and perfect for indoor/outdoor use
Specifications at a Glance
Feature | Specification |
Suction Power | 20,000 Pa (Turbo), 9,000 Pa (Med), 6,000 Pa (ECO) |
Weight | 2.8 lbs (main unit), 4.9 lbs (assembled) |
Battery | 6-cell lithium-ion, 2,000mAh*6 |
Runtime | 40 min (ECO), 23 min (Med), 10 min (Turbo) |
Charging Time | 4-6 hours |
Dust Cup Volume | 0.7 L |
Noise Level | 65 dBA (Turbo) |
Dimensions | 12.4 x 4.5 x 8.7 in (main unit) |
Color | Steel grey with Wyze green accents |
Operating Temperature | -4ºF to 169ºF (-20ºC to 75ºC) |
Filtration | 3-stage with HEPA filter |
LED Lights | 6 daylight-bright LEDs on brush head |
Conclusion
For anyone looking for a
portable cordless vacuum that excels at cleaning outdoor patios and garage floors, the
Wyze Cordless Vacuum S is a top choice. Its powerful suction, lightweight design, long battery life, and versatile attachments make it perfect for tackling tough outdoor messes with ease. Plus, with a range of accessories available, you can customize your cleaning setup to fit your specific needs.
Experience the freedom of cordless cleaning and keep your outdoor spaces spotless with Wyze Cordless Vacuum S.
What makes the Wyze Cordless Vacuum S ideal for cleaning outdoor patios and garage floors?
The Wyze Cordless Vacuum S is designed with powerful suction up to 20,000 Pa in Turbo Mode, a lightweight and portable build, and versatile attachments. These features make it highly effective for removing dust, dirt, and debris from outdoor patios and garage floors without the hassle of cords.How long does the Wyze Cordless Vacuum S battery last on a single charge?
The Wyze Cordless Vacuum S offers up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode. This allows you to choose the right balance between power and battery life for your cleaning needs.How powerful is the suction on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power in Turbo Mode, 9,000 Pa in Medium Mode, and 6,000 Pa in ECO Mode, making it suitable for tackling tough debris on outdoor and garage surfaces.Is the Wyze Cordless Vacuum S easy to carry and use in different areas?
Yes, the Wyze Cordless Vacuum S is ultra-lightweight, weighing only 2.8 lbs for the main unit and 4.9 lbs when fully assembled. Its cordless design allows for easy maneuverability around patios, garages, and other hard-to-reach spaces.What attachments come with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S includes a crevice tool for narrow gaps, a floor brush for hard floors and patios, a dust cap, a HEPA filter for clean exhaust air, and a standard tube for extended reach. These attachments help clean various surfaces and tight spaces.Does the Wyze Cordless Vacuum S have a HEPA filter?
Yes, the Wyze Cordless Vacuum S features a 3-stage filtration system with a HEPA filter, which traps fine dust and allergens to ensure cleaner air during and after vacuuming.How long does it take to recharge the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S takes approximately 4-6 hours to fully recharge using the included AC charger.Are there additional accessories available for the Wyze Cordless Vacuum S?
Yes, you can enhance your cleaning experience with accessories such as a replacement battery pack, spare charger, foldable vacuum tube for hard-to-reach areas, replacement HEPA filters, and a mini motorized brush head for upholstery and car interiors.Does the Wyze Cordless Vacuum S have LED lights for cleaning dark areas?
Yes, the brush head of the Wyze Cordless Vacuum S is equipped with 6 daylight-bright LED lights, making it easy to spot and clean dirt in dark corners and under furniture or shelves.What are the main specifications of the Wyze Cordless Vacuum S?
Key specifications include: suction power up to 20,000 Pa, weight of 2.8 lbs (main unit) and 4.9 lbs (assembled), 6-cell lithium-ion battery, up to 40 minutes runtime, 0.7 L dust cup volume, 65 dBA noise level, 3-stage HEPA filtration, and operating temperature range from -4ºF to 169ºF.
