Wyze Cordless Vacuum S: Multi-Surface, Powerful & Lightweight
Discover the Wyze Cordless Vacuum S with Multi-Surface Brush Roll Technology
Looking for a home cordless vacuum that combines powerful suction, lightweight design, and advanced brush roll technology for multi-surface cleaning? The Wyze Cordless Vacuum S is engineered to deliver exceptional cleaning performance across all floor types, making it the perfect choice for modern homes.
Wyze Cordless Vacuum S: Powerful Cleaning Meets Lightweight Design
The Wyze Cordless Vacuum S stands out with its impressive suction power and user-friendly features:
  • Suction Power: Up to 20,000 Pa in Turbo Mode, with 100 AW power for deep cleaning carpets, hardwood floors, and tiles.
  • Lightweight: Weighs only 2.8 lbs (main unit) and 4.9 lbs when fully assembled, making it easy to maneuver around furniture and stairs.
  • Battery Life: Equipped with a 6-cell lithium-ion battery offering up to 40 minutes of runtime in ECO mode, perfect for thorough cleaning sessions without interruption.
  • Dual Motors: Two powerful motors ensure efficient suction and brush roll rotation for multi-surface cleaning.
  • Brush Roll Technology: Features 6 daylight-bright LED lights on the brush head to illuminate dust and debris in dark corners.
  • Filtration: A 3-stage filtration system including a HEPA filter traps fine dust and allergens, improving indoor air quality.
  • Dust Cup Capacity: 0.7 liters, allowing for longer cleaning without frequent emptying.
  • Noise Level: Quiet operation at 65 dBA in Turbo Mode, so cleaning won’t disturb your household.
The vacuum’s steel grey body with Wyze green accents adds a sleek, modern look to your cleaning tools.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." – Wyze
Lifestyle vacuuming with pet-friendly home Enjoy effortless cleaning around your sofa and pets with the Wyze Cordless Vacuum S.
Essential Accessories to Enhance Your Wyze Cordless Vacuum S Experience
Wyze Cordless Vacuum S - Battery Pack
Extend your cleaning sessions with an additional battery pack designed specifically for the Wyze Cordless Vacuum S. Swap batteries on the go to double your runtime and clean larger areas without waiting for a recharge.
  • Compatible exclusively with Wyze Cordless Vacuum S
  • Hassle-free 30-day return policy
Clean hard-to-reach areas with ease using the foldable vacuum tube accessory. Its flexible design bends so you don’t have to, making it perfect for under furniture and tight spaces.
  • Designed only for Wyze Cordless Vacuum
  • Compact and easy to store
Wyze Cordless Vacuum - HEPA Filter
Maintain peak performance and air quality by regularly replacing your vacuum’s HEPA filter. This 2-pack ensures you always have a fresh filter ready.
  • Compatible with Wyze Cordless Vacuum
  • Helps trap allergens and fine dust
Wyze Cordless Vacuum - Mini Motorized Brush Head
Ideal for cleaning car seats, sofas, and upholstery, this mini motorized brush head attachment tackles pet hair and dirt in delicate areas.
  • Dimensions: 6 x 5.5 x 5 inches
  • Compatible only with Wyze Cordless Vacuum
Wyze Cordless Vacuum S - Charger
Keep your vacuum powered up with an official replacement charger designed for the Wyze Cordless Vacuum S.
  • 30-day hassle-free returns
Why Choose Wyze Cordless Vacuum S for Your Home?
  • Multi-Surface Brush Roll Technology: The brush roll adapts seamlessly to different floor types, from hardwood to carpet, ensuring thorough cleaning without switching tools.
  • Smart LED Display: Monitor battery life and suction mode easily with the built-in LED screen.
  • Compact & Portable: Its lightweight design and ergonomic handle make it perfect for quick cleanups and deep cleans alike.
  • Pet-Friendly: Powerful suction and specialized brush heads make it ideal for homes with pets, capturing hair and dander effectively.
Wyze Cordless Vacuum S in action at home Experience the freedom of cordless cleaning with Wyze’s lightweight and powerful vacuum.
Specifications at a Glance
FeatureWyze Cordless Vacuum S
Suction Power20,000 Pa (Turbo), 9,000 Pa (Medium), 6,000 Pa (ECO)
Weight2.8 lbs (main unit), 4.9 lbs (assembled)
Battery6-cell lithium-ion, 2,000mAh*6
Runtime40 min (ECO), 23 min (Medium), 10 min (Turbo)
Dust Cup Volume0.7 L
Noise Level65 dBA (Turbo)
Dimensions12.4 x 4.5 x 8.7 in (main unit)
Charging Time4-6 hours
ColorSteel grey with Wyze green accents
Filtration3-stage with HEPA filter
Attachments IncludedCrevice tool, floor brush, HEPA filter, dust cap, filter housing, standard tube
Conclusion
The Wyze Cordless Vacuum S is a top-tier choice for anyone seeking a powerful, lightweight, and versatile cordless vacuum with advanced multi-surface brush roll technology. Its long battery life, smart features, and range of compatible accessories make it a smart investment for maintaining a clean, healthy home environment. Upgrade your cleaning routine today with Wyze — where innovation meets convenience. Clean hardwood floors with Wyze vacuum Perfect for hardwood, carpet, and tile floors alike.
ProductTypeCompatibilityPrice (USD)Key FeaturesWeightBattery Life / PowerAdditional Info
Wyze Cordless Vacuum SConnected HomeWyze Cordless Vacuum S139.9920,000 Pa suction, 2 motors, 2.8 lbs, 3-speed settings, 6 LED lights, 3-stage HEPA filtration2.8 lbs40-minute interchangeable lithium-ion batteryLED display, easy empty dust cup, washable filters
Wyze Cordless Vacuum S - Battery PackAccessoriesWyze Cordless Vacuum S59.99Extra battery pack for extended useN/AN/ALow stock: 36 left
Wyze Cordless Vacuum - Foldable Vacuum TubeAccessoriesWyze Cordless Vacuum15.99Foldable tube for easier cleaningN/AN/ABends for convenience
Wyze Cordless Vacuum - HEPA FilterAccessoriesWyze Cordless Vacuum15.992-pack replacement HEPA filtersN/AN/AReplace regularly
Wyze Cordless Vacuum - Mini Motorized Brush HeadAccessoriesWyze Cordless Vacuum29.99For car seats and sofas cleaning6 x 5.5 x 5 inN/ACompact size
Wyze Cordless Vacuum S - ChargerReplacement PartsWyze Cordless Vacuum S4.99Replacement chargerN/AN/A30-day hassle-free returns
What is the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S is a lightweight, powerful cordless vacuum designed for multi-surface cleaning. It features advanced brush roll technology, strong suction power, and a range of user-friendly features, making it ideal for modern homes.
How powerful is the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power in Turbo Mode and 100 AW, making it effective for deep cleaning carpets, hardwood floors, and tiles.
What is the battery life of the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S is equipped with a 6-cell lithium-ion battery that provides up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode.
Is the Wyze Cordless Vacuum S suitable for pet owners?Yes, the Wyze Cordless Vacuum S is pet-friendly. Its powerful suction and specialized brush heads effectively capture pet hair and dander, making it ideal for homes with pets.
What types of floors can the Wyze Cordless Vacuum S clean?The Wyze Cordless Vacuum S is designed for multi-surface cleaning, including hardwood, carpet, and tile floors. Its brush roll technology adapts seamlessly to different floor types.
How much does the Wyze Cordless Vacuum S weigh?The main unit of the Wyze Cordless Vacuum S weighs only 2.8 lbs, and it weighs 4.9 lbs when fully assembled, making it easy to maneuver around your home.
What filtration system does the Wyze Cordless Vacuum S use?The Wyze Cordless Vacuum S features a 3-stage filtration system, including a HEPA filter that traps fine dust and allergens to improve indoor air quality.
What is the dust cup capacity of the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S has a dust cup capacity of 0.7 liters, allowing for longer cleaning sessions without frequent emptying.
Does the Wyze Cordless Vacuum S have LED lights?Yes, the Wyze Cordless Vacuum S features 6 daylight-bright LED lights on the brush head to illuminate dust and debris in dark corners.
What accessories are available for the Wyze Cordless Vacuum S?Available accessories include an additional battery pack, foldable vacuum tube, HEPA filter 2-pack, mini motorized brush head, and an official replacement charger. These accessories enhance cleaning performance and convenience.
Is the Wyze Cordless Vacuum S easy to store?Yes, the Wyze Cordless Vacuum S is compact and lightweight, making it easy to store and perfect for quick cleanups as well as deep cleaning.
How loud is the Wyze Cordless Vacuum S during operation?The Wyze Cordless Vacuum S operates quietly at 65 dBA in Turbo Mode, so it won’t disturb your household while cleaning.
How long does it take to charge the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S takes approximately 4-6 hours to fully charge.
What is included with the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S comes with a crevice tool, floor brush, HEPA filter, dust cap, filter housing, and a standard tube.
Can I extend the runtime of my Wyze Cordless Vacuum S?Yes, you can extend the runtime by purchasing an additional battery pack designed specifically for the Wyze Cordless Vacuum S, allowing you to swap batteries and clean larger areas without waiting for a recharge.
What are the key features of the Wyze Cordless Vacuum S?How does the multi-surface brush roll technology work?Do you have any deals, ongoing sales, discounts, or promotions?
