Wyze Battery Cam Pro: Best Outdoor Wireless Camera for Eaves
Outdoor Wireless Cameras Perfect for Mounting Under Eaves or Awnings
When it comes to securing your outdoor spaces such as under eaves or awnings, having a reliable, weatherproof, and wire-free camera is essential. The Wyze Battery Cam Pro series offers the perfect blend of advanced technology, flexible mounting options, and long-lasting power solutions to keep your home safe and monitored with ease.
Wyze Battery Cam Pro: Ultimate Wire-Free Security
High-Resolution Video & Smart Detection
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution, ensuring crystal-clear images day and night. Thanks to its advanced Radar + PIR motion detection system, it detects movement earlier and more accurately than traditional cameras. Customize detection zones in the Wyze app to receive precise alerts tailored to your property.
Integrated Spotlight & Siren
Mounted under eaves or awnings, this camera’s 150-lumen motion-activated spotlight illuminates potential intruders, while the built-in siren can deter unwanted visitors instantly. You can also manually control the spotlight via the app for added security during nighttime activities.
Weatherproof & Flexible Mounting
Rated IP65 for weather resistance, the Wyze Battery Cam Pro withstands rain, dust, and extreme temperatures, making it ideal for outdoor mounting under eaves or awnings. The camera supports both 2.4 GHz and 5 GHz Wi-Fi for a stable connection, and its removable, rechargeable battery packs allow for easy power management without the hassle of wires or hubs.
Easy Setup & Two-Way Audio
Setup is a breeze with BluetoothⓇ, eliminating the need for QR code scanning. The enhanced two-way audio lets you communicate through the camera, whether to greet guests or warn off intruders.
Wyze Battery Cam Pro + Solar Panel: Continuous Power Without Wires
Solar-Powered Freedom
For those looking to mount their camera in hard-to-reach places like under eaves or awnings where power outlets are unavailable, the Wyze Battery Cam Pro + Solar Panel bundle is the perfect solution. The solar panel converts sunlight into energy, extending your camera’s battery life significantly and reducing the need for frequent recharging.
Same Great Features, Extended Runtime
This bundle includes the Wyze Battery Cam Pro with all its pro-grade features plus the solar panel designed specifically for outdoor use. The solar panel is IP65 weatherproof and mounts easily with a 360° adjustable bracket, ensuring optimal sun exposure.
Local Storage & No Subscription Required
Record motion events locally to a microSD card (sold separately) without needing a subscription. This feature is perfect for users who want to keep their footage private and accessible at all times.
Accessories to Enhance Your Outdoor Setup
Wyze Battery Cam Solar Panel
If you already own a Wyze Battery Cam Pro, you can purchase the solar panel accessory separately. It’s designed to be weather-resistant and mountable anywhere, perfect for extending battery life when your camera is mounted under eaves or awnings.
Wyze Removable Battery Pack
Keep your camera powered longer with additional rechargeable battery packs. Each pack offers 6200mAh capacity, lasting up to 6 months on a single charge, and can be hot-swapped to avoid downtime.
Wyze Battery Charging Dock
Charge two battery packs simultaneously with this compact charging dock, ensuring you always have a fresh battery ready to go.
Why Choose Wyze Battery Cam Pro for Outdoor Mounting?
"The Wyze Battery Cam Pro is designed for flexible, wire-free outdoor security with professional-grade features. Its weatherproof design and smart motion detection make it ideal for mounting under eaves or awnings, where power access is limited but security is critical."
  • Wire-Free Convenience: No hubs or wiring needed.
  • Weatherproof Durability: IP65 rating protects against rain and dust.
  • Smart Motion Detection: Radar + PIR sensors for precise alerts.
  • Integrated Spotlight & Siren: Deter intruders effectively.
  • Solar Power Option: Extend battery life with the Wyze Solar Panel.
  • Flexible Mounting: Compatible with universal mounts for ceiling or eave installation.
Outdoor Security Camera Mounted Under Eaves
Summary
For anyone seeking an outdoor wireless camera perfect for mounting under eaves or awnings, the Wyze Battery Cam Pro and the Wyze Battery Cam Pro + Solar Panel bundle stand out as top choices. Their combination of high-resolution video, smart detection, weatherproof design, and flexible power options make them ideal for reliable, hassle-free outdoor security.
Product Highlights
Wyze Battery Cam Pro 2.5K HDR, wire-free, IP65 weatherproof, integrated spotlight & siren, radar + PIR motion detection, removable battery packs, dual-band Wi-Fi. Wyze Battery Cam Pro + Solar Panel All features of Battery Cam Pro plus solar panel for continuous power, weatherproof solar charging, easy mounting. Wyze Battery Cam Solar Panel Extend battery life with weather-resistant solar power accessory. Wyze Removable Battery Pack Rechargeable 6200mAh battery for extended use. Wyze Battery Charging Dock Charge two batteries simultaneously for uninterrupted security.
FeatureWyze Battery Cam Pro + Solar PanelWyze Battery Cam ProWyze Battery Cam Solar Panel
Product TypeCamera BundleCameraAccessory (Solar Panel)
Price$109.98$89.98 (1 Pack)$24.99
Video Resolution2.5K HDR2.5K HDRN/A
Power SourceBattery + Solar PanelBatterySolar Panel
Battery PacksRemovable, RechargeableRemovable, RechargeableN/A
Solar Panel IncludedYesNoYes (sold separately)
Weatherproof RatingIP65IP65IP65
WiFi Support2.4 & 5 GHz2.4 & 5 GHzN/A
Motion DetectionRadar + PIRRadar + PIRN/A
Integrated Spotlight & SirenYesYesN/A
Local RecordingYes (with microSD card)Yes (with microSD card)N/A
Mounting OptionsFlexible (includes solar panel mount)Flexible360° mount included
SetupWireless, no hub requiredWireless, no hub requiredConnects to camera via 13 ft USB-C cable
Battery Life ExtensionYes, via included solar panelOptional with separate solar panel purchaseExtends battery life by solar charging
Included ItemsWyze Battery Cam Pro, Wyze Solar PanelWyze Battery Cam ProSolar panel, wall mount, USB-C cable, screws
DimensionsCamera: 2.5" x 1.8" x 3.5" (approx.)Camera: 2.5" x 1.8" x 3.5" (approx.)173 mm x 120 mm x 17 mm
Solar Power RatingIncluded solar panel: 2.5W, 5VDCN/A2.5W, 5VDC
Cable Length (Solar Panel)Included (13 ft USB-C cable)N/A13 ft (4m) USB-C cable
Color VariantsBlack, WhiteBlack, WhiteWhite frame and mount, Black solar cells
Additional FeaturesIntegrated spotlight, siren, dual-band WiFiIntegrated spotlight, siren, dual-band WiFiWeather resistant, mountable anywhere
What makes the Wyze Battery Cam Pro ideal for mounting under eaves or awnings?The Wyze Battery Cam Pro is designed for flexible, wire-free outdoor security, making it perfect for mounting under eaves or awnings. Its IP65 weatherproof rating protects against rain and dust, while the camera’s advanced motion detection, integrated spotlight, and siren provide reliable security even in areas with limited power access.
Is the Wyze Battery Cam Pro weatherproof for outdoor use?Yes, the Wyze Battery Cam Pro is rated IP65 for weather resistance, ensuring it can withstand rain, dust, and extreme temperatures. This makes it an excellent choice for outdoor mounting under eaves or awnings.
How does the Wyze Battery Cam Pro detect motion?The Wyze Battery Cam Pro uses a combination of advanced Radar and PIR (Passive Infrared) motion detection sensors. This system allows for earlier and more accurate detection of movement, and you can customize detection zones in the Wyze app for precise alerts.
Can I use the Wyze Battery Cam Pro without any wires or hubs?Yes, the Wyze Battery Cam Pro is completely wire-free and does not require any hubs or wiring. It operates on removable, rechargeable battery packs, making installation and maintenance simple and convenient.
What are the benefits of the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle provides continuous, wire-free power by converting sunlight into energy. This significantly extends the camera’s battery life, making it ideal for hard-to-reach outdoor locations like under eaves or awnings where power outlets are unavailable.
Does the Wyze Battery Cam Pro support local storage without a subscription?Yes, the Wyze Battery Cam Pro allows you to record motion events locally to a microSD card (sold separately), so you can access your footage without needing a subscription. This is perfect for users who want to keep their recordings private and always accessible.
How easy is it to set up the Wyze Battery Cam Pro?Setting up the Wyze Battery Cam Pro is quick and easy thanks to BluetoothⓇ connectivity, which eliminates the need for QR code scanning. The camera also features enhanced two-way audio for convenient communication with visitors or to deter intruders.
What accessories are available for the Wyze Battery Cam Pro?Accessories for the Wyze Battery Cam Pro include the Wyze Battery Cam Solar Panel for extended battery life, Wyze Removable Battery Packs for longer use and hot-swapping, and the Wyze Battery Charging Dock, which allows you to charge two battery packs simultaneously.
How long does the Wyze Removable Battery Pack last on a single charge?Each Wyze Removable Battery Pack offers a 6200mAh capacity and can last up to 6 months on a single charge, depending on usage and environmental conditions.
Can the Wyze Battery Cam Pro be mounted on ceilings or eaves?Yes, the Wyze Battery Cam Pro is compatible with universal mounts, making it easy to install on ceilings, eaves, or awnings for optimal outdoor security coverage.
Does the Wyze Battery Cam Pro have a spotlight and siren for security?Yes, the Wyze Battery Cam Pro features a 150-lumen motion-activated spotlight and a built-in siren. These features help deter intruders and can be controlled manually via the Wyze app for added security.
What video quality does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro delivers high-resolution 2.5K HDR video, ensuring crystal-clear images both day and night for superior outdoor surveillance.
Is the Wyze Battery Cam Solar Panel weather-resistant?Yes, the Wyze Battery Cam Solar Panel is IP65 weatherproof and designed specifically for outdoor use. It mounts easily with a 360° adjustable bracket to ensure optimal sun exposure.
Can you tell me more about the features of the Wyze Battery Cam Pro?How does the solar panel work with the Wyze Battery Cam Pro?Do you have any ongoing sales or discounts for the Wyze Battery Cam Pro?
