Wyze Battery Cam Pro: High-Res, Weatherproof Security Camera
High Resolution Cameras Built for Extreme Weather Conditions
When it comes to securing your home or property in harsh environments—whether facing windstorms, heavy snow, or fluctuating temperatures—you need a camera that delivers crystal-clear video and stands up to the elements. Wyze offers a range of high-resolution cameras designed to withstand tough weather while providing advanced features like wire-free operation, integrated spotlight, and smart motion detection.
Wyze Battery Cam Pro: Ultimate Weatherproof Wireless Security
The Wyze Battery Cam Pro is a top-tier choice for anyone seeking a high-resolution camera that can endure windstorms and heavy snow. With a stunning 2.5K HDR video resolution, this camera captures every detail in vivid clarity, day or night.
  • Weather Resistance: Rated IP65, it is built to withstand rain, snow, and dust, making it perfect for extreme weather conditions.
  • Battery Life: Equipped with removable, rechargeable 6200mAh battery packs that last up to 6 months on a single charge.
  • Advanced Detection: Features Radar + PIR motion detection for precise alerts and fewer false alarms.
  • Night Vision: Combines 2 IR LEDs and 2 powerful white LEDs (187 lumens) for clear color night vision.
  • Connectivity: Supports both 2.4 GHz and 5 GHz WiFi bands for reliable streaming.
  • Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home control.
  • Dimensions & Weight: Compact at 2.5 x 1.8 x 3.5 inches and weighing just 0.94 lbs, it’s easy to install anywhere.
This camera requires no hub and includes a wall mount for flexible placement. Its rugged PC plastic body with a matte finish ensures durability in freezing temperatures down to -20°C (-4°F).
Wyze Battery Cam Pro + Solar Panel: Extended Power for Continuous Protection
For those who want uninterrupted security without worrying about battery life, the Wyze Battery Cam Pro + Solar Panel bundle is an excellent solution.
  • Solar-Powered: The included solar panel (IP65 weatherproof) continuously charges the camera, extending battery life indefinitely under sunlight.
  • Easy Installation: The solar panel comes with a 13-foot USB-C cable and a 360° adjustable mount, allowing you to position it for optimal sun exposure.
  • Same High-Resolution Video: Enjoy the same 2.5K HDR video quality and smart features as the standalone Battery Cam Pro.
  • Weatherproof Design: Both camera and solar panel are designed to endure harsh weather, including heavy snow and windstorms.
  • Smart Features: Integrated spotlight, siren, and two-way audio keep your property safe and allow you to interact remotely.
This bundle is perfect for remote locations or areas where frequent battery charging is inconvenient. Outdoor Security Camera in Snowy Landscape
Wyze Cam v4: Wired High-Resolution Camera with Enhanced Night Vision
If you prefer a wired solution with high resolution and robust weather resistance, the Wyze Cam v4 is a compelling option.
  • Video Quality: Offers 2.5K QHD (2560x1440) resolution with wide dynamic range for sharp, detailed footage.
  • Night Vision: Enhanced color night vision with 4 IR LEDs plus 2 white spotlight LEDs (72 lumens) ensures clear images even in total darkness.
  • Weatherproof: Rated IP65, it can handle rain, snow, and windstorms with ease.
  • Connectivity: Supports Wi-Fi 6 and 2.4 GHz Wi-Fi for fast, stable connections.
  • Smart Features: Includes motion-activated spotlight, built-in siren, two-way audio, and compatibility with Alexa, Google Assistant, and IFTTT.
  • Local Storage: Supports microSD cards up to 512 GB for continuous local recording.
  • Mounting Options: Versatile mounting including stand, wall, ceiling, and magnetic mounts.
The Wyze Cam v4 is ideal for users who want a wired camera with superior image quality and advanced smart home integration. Home Security Camera Mounted Outdoors
Wyze Universal Mount (Long): Durable Mounting for Harsh Conditions
To ensure your Wyze cameras stay securely in place during windstorms and heavy snow, the Wyze Universal Mount (Long) is a must-have accessory.
  • Heavy-Duty Metal Construction: Built to withstand strong winds and outdoor elements.
  • Versatile Mounting: Longer neck design allows mounting on ceilings, patios, or walls.
  • Compatibility: Works with Wyze Battery Cam Pro, Wyze Cam v3/v3 Pro, and other Wyze cameras with a standard 1/4”-20 mount.
  • Easy Installation: Comes with screws and drywall anchors for quick setup.
  • Load Bearing: Supports up to 2 kg (70 oz), ensuring stability even in harsh weather.
This mount enhances your camera’s durability and positioning flexibility, making it perfect for outdoor security setups.
Why Choose Wyze Cameras for Extreme Weather?
Wyze cameras combine high-resolution imaging with rugged, weatherproof designs to provide reliable security in the toughest conditions. Whether you face heavy snow, strong winds, or freezing temperatures, Wyze’s IP65-rated cameras and accessories ensure your property stays monitored with crystal-clear video and smart alerts.
With options for wire-free battery operation, solar power extension, and wired connectivity, Wyze offers versatile solutions tailored to your security needs.
Summary of Featured Products
Product NameResolutionWeatherproofPower SourceKey Features
Wyze Battery Cam Pro2.5K HDRIP65Rechargeable Battery (6200mAh)Radar + PIR, Spotlight, Siren
Wyze Battery Cam Pro + Solar Panel2.5K HDRIP65Battery + Solar PanelContinuous power, 360° mount
Wyze Cam v42.5K QHDIP65Wired (AC power)Enhanced night vision, Wi-Fi 6
Wyze Universal Mount (Long)N/ADurable metalN/AHeavy-duty, versatile mounting
Secure your home with Wyze’s high-resolution, weatherproof cameras designed to perform in windstorms and heavy snow.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Cam v4Wyze Universal Mount (Long)
TypeBattery Security CameraBattery Security Camera + Solar PanelWired Security CameraCamera Accessory (Mount)
Video Resolution2.5K HDR2.5K HDR2.5K QHD (2560x1440)N/A
Power SourceRemovable, Rechargeable Battery PacksBattery + Solar PanelWired (Indoor 5V/1A adapter included)N/A
Wireless Connectivity2.4 & 5 GHz WiFi2.4 & 5 GHz WiFi2.4 GHz Wi-Fi, Wi-Fi 6N/A
Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion DetectionYes, with motion detection zonesN/A
SpotlightIntegrated Spotlight (150 lumens)Integrated Spotlight (150 lumens)Motion-activated spotlight (72 lumens)N/A
SirenIntegrated SirenIntegrated SirenBuilt-in sirenN/A
Weatherproof RatingIP65IP65IP65N/A
Local StorageMicroSD card support (optional)MicroSD card support (optional)MicroSD card up to 512 GBN/A
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional subscription planN/A
Battery Charging OptionsRemovable battery packs, Charging dock (sold separately)Solar Panel included + removable battery packsWired power onlyN/A
Mounting OptionsWall, Ceiling (with Wyze Universal Mount)Wall, Ceiling (with Wyze Universal Mount)Stand, Wall, Ceiling, Magnetic wall mountCeiling, Wall, Patio (long neck mount)
DimensionsNot specifiedNot specified2in x 2in x 2 3/8in2in x 2in x 3.8in
WeightNot specifiedNot specified0.49 lb (222 g)2 oz (57 g)
Color OptionsBlack, WhiteBlack, WhiteBlack, White, Grey, ClearWhite
Price (approximate)$89.98 (1 pack)$109.98 (bundle)$100.00 (standard) / $107.94 (retail)$9.99
Included ItemsCamera onlyCamera + Solar PanelCamera, Power Adapter, Mount, Cable, ScrewsMount, Screw Assembly
Bluetooth SetupYesYesYesN/A
Two-Way AudioYesYesYesN/A
Additional FeaturesHot-swap batteries, Bird Detection (with Cam Plus), Dual-band Wi-FiContinuous power via solar, Bird Detection (with Cam Plus), Dual-band Wi-FiWi-Fi 6 support, Alexa/Google Assistant/IFTTT integration, Enhanced Color Night VisionHeavy-duty metal, adjustable, easy installation
WarrantyNot specifiedNot specified1 YearNot specified
Are Wyze cameras weatherproof and suitable for extreme weather conditions?Yes, Wyze cameras such as the Wyze Battery Cam Pro and Wyze Cam v4 are rated IP65, making them weatherproof and capable of withstanding rain, snow, windstorms, and freezing temperatures as low as -20°C (-4°F).
What is the video resolution of Wyze outdoor security cameras?Wyze outdoor security cameras like the Wyze Battery Cam Pro and Wyze Cam v4 offer high-resolution 2.5K HDR or QHD (2560x1440) video for crystal-clear footage in all lighting conditions.
How long does the Wyze Battery Cam Pro battery last?The Wyze Battery Cam Pro features removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge, depending on usage and environmental conditions.
Can I use a solar panel with Wyze cameras for continuous power?Yes, the Wyze Battery Cam Pro + Solar Panel bundle includes an IP65 weatherproof solar panel that continuously charges the camera, providing uninterrupted security without frequent battery changes.
Do Wyze cameras have night vision capabilities?Absolutely. Both the Wyze Battery Cam Pro and Wyze Cam v4 offer advanced night vision with IR LEDs and white spotlight LEDs, delivering clear color images even in total darkness.
Are Wyze cameras compatible with smart home systems?Yes, Wyze cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration and smart home control.
What mounting options are available for Wyze cameras in harsh weather?Wyze offers the Universal Mount (Long), a heavy-duty metal mount designed for secure installation on ceilings, patios, or walls. It is compatible with several Wyze camera models and built to withstand strong winds and outdoor elements.
Does the Wyze Cam v4 support local video storage?Yes, the Wyze Cam v4 supports microSD cards up to 512 GB for continuous local recording, ensuring your footage is always accessible.
What wireless connectivity options do Wyze cameras offer?Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz WiFi bands, while Wyze Cam v4 supports Wi-Fi 6 and 2.4 GHz Wi-Fi for fast and reliable streaming.
Do Wyze cameras require a hub for installation?No, Wyze cameras like the Wyze Battery Cam Pro do not require a hub and come with wall mounts for easy and flexible placement.
Can you tell me more about the features of the Wyze Battery Cam Pro?What is the installation process for the Wyze Battery Cam Pro + Solar Panel?Do you have any deals, ongoing sales, discounts, or promotions?
