Wyze Battery Cam Pro: Compact, Weatherproof Garage & Driveway Cam
Compact Weather Resistant Cameras for Garage and Driveway Monitoring
When it comes to monitoring your garage doors and driveways, having a reliable, compact, and weather-resistant camera is essential. The Wyze Battery Cam Pro series offers top-tier features designed specifically for outdoor security, combining high-resolution video, wireless convenience, and robust weatherproofing to keep your property safe and under watchful eyes.
Wyze Battery Cam Pro: Powerful and Portable Security
High-Definition Video and Advanced Detection
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution (2560 x 1440), ensuring crystal-clear footage of your garage and driveway day or night. Equipped with a CMOS-Starlight sensor and an F1.6 lens, it captures vivid details even in low light conditions. The camera features radar and PIR motion detection, providing precise alerts for any movement.
Weatherproof and Durable Design
Built to withstand the elements, the Wyze Battery Cam Pro boasts an IP65 weather resistance rating. It operates reliably in temperatures ranging from -20°C to 50°C (-4°F to 122°F), making it perfect for outdoor use in all seasons. Its compact size (2.5 x 1.8 x 3.5 inches) and lightweight design (0.94 lbs) allow for easy installation on garage walls or near driveways.
Wireless and Long-Lasting Battery
This camera is completely wire-free, powered by removable and rechargeable 6200mAh battery packs that last up to 6 months on a single charge. The battery charges fully in about 9 hours, providing hassle-free maintenance. It supports both 2.4 GHz and 5 GHz WiFi for stable connectivity without the need for a hub.
Smart Features and Integration
Enjoy two-way audio with a built-in speaker and microphone, a 100 dB siren for deterrence, and an integrated spotlight for color night vision. The Wyze Battery Cam Pro integrates seamlessly with Alexa, Google Assistant, and IFTTT, allowing you to control and monitor your camera hands-free.
Wyze Battery Cam Pro + Solar Panel: Extended Power for Continuous Monitoring
Solar-Powered Convenience
For those seeking uninterrupted surveillance, the Wyze Battery Cam Pro + Solar Panel bundle is an excellent choice. It includes the same powerful camera with 2.5K HDR video and weatherproof design, paired with a solar panel that extends battery life by harnessing sunlight.
Easy Installation and Weather Resistance
The solar panel is IP65 rated, weather-resistant, and comes with a 13-foot power cable for flexible mounting options. This setup ensures your camera stays powered longer without frequent recharging, ideal for monitoring garages and driveways where power outlets may be limited.
Enhanced Night Vision and Motion Detection
With integrated spotlight and radar + PIR motion detection, this camera provides clear color night vision and accurate alerts. The local storage supports up to 256 GB microSD cards, and cloud recording is available with Cam Plus subscription for added security.
Wyze Battery Cam Pro Solar Panel Accessory
If you already own a Wyze Battery Cam Pro, the Wyze Battery Cam Solar Panel accessory is a smart upgrade to keep your camera charged continuously. Designed for easy 360° mounting anywhere outdoors, it is IP65 weatherproof and includes all necessary mounting hardware.
  • Solar power rating: 2.5W, 5VDC
  • 13-foot micro USB cable for flexible placement
  • Compatible with Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2
This solar panel ensures your camera remains operational without manual battery swaps, perfect for long-term driveway and garage monitoring.
"Wyze Battery Cam Pro offers a compact, weatherproof, and wireless solution with 2.5K HDR video, making it ideal for garage and driveway security."
Summary of Key Features
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar Panel BundleWyze Battery Cam Solar Panel Accessory
Video Resolution2560 x 1440 (2.5K HDR)2560 x 1440 (2.5K HDR)N/A
WirelessYesYesN/A
Battery Capacity6200mAh, up to 6 months6200mAh, up to 6 months + solar chargingN/A
Weather ResistanceIP65IP65IP65
Motion DetectionRadar + PIRRadar + PIRN/A
Night VisionColor night vision with spotlightColor night vision with spotlightN/A
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTN/A
Dimensions2.5 x 1.8 x 3.5 inches2.5 x 1.8 x 3.5 inches173 mm x 120 mm x 17 mm
Garage Security Camera in Use Compact and weatherproof Wyze Battery Cam Pro securing a garage door. Driveway Monitoring with Solar Panel Wyze Battery Cam Pro paired with solar panel for continuous driveway surveillance.
Conclusion
For anyone looking to secure their garage doors and driveways with a compact, weather-resistant, and wireless camera, the Wyze Battery Cam Pro and its solar-powered variant provide an unbeatable combination of high-quality video, smart features, and long-lasting power. Whether you prefer battery-only operation or extended solar charging, these cameras offer peace of mind with easy installation and reliable performance in all weather conditions.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Battery Cam Solar Panel
Video Resolution2.5K HDR2.5K HDRN/A
Power SourceRemovable, Rechargeable Battery PacksBattery + Solar PanelSolar Panel only (extends battery life)
WirelessYes, Wire-Free, No Hub requiredYes, Wire-Free, No Hub requiredN/A
Integrated Spotlight & SirenYesYesN/A
Weatherproof RatingIP65IP65IP65
WiFi Support2.4 & 5 GHz2.4 & 5 GHzN/A
Local RecordingYes (with microSD card)Yes (with microSD card)N/A
Battery Life ExtensionNoYes, via included Solar PanelYes, extends battery life of compatible cams
Mounting OptionsFlexible, includes ceiling mount optionFlexible, includes ceiling mount optionWeather resistant, 360° mount included
Included ItemsCamera onlyCamera + Solar PanelSolar Panel, mount, cables, screws, guide
Price (USD)$89.98 (1 Pack White/Black)$109.98 (White/Black)$24.99 (Solar Panel), $5.99 (USB-C Adapter Cable)
SetupBluetoothⓇ Instant SetupBluetoothⓇ Instant SetupN/A
Additional FeaturesRemovable battery packs, Two-way audioRemovable battery packs, Two-way audio13-foot power cable, runs on sun power
What makes the Wyze Battery Cam Pro ideal for garage and driveway monitoring?The Wyze Battery Cam Pro is specifically designed for outdoor security, offering a compact, weather-resistant build (IP65 rating), high-definition 2.5K HDR video, advanced radar and PIR motion detection, and wireless convenience. Its robust features ensure reliable monitoring of garages and driveways in all weather conditions.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro is IP65 weather-resistant, making it suitable for outdoor use. It operates reliably in temperatures ranging from -20°C to 50°C (-4°F to 122°F), ensuring durability in various climates.
How long does the Wyze Battery Cam Pro battery last?The Wyze Battery Cam Pro is powered by a 6200mAh removable and rechargeable battery pack that can last up to 6 months on a single charge, depending on usage and environmental conditions.
Can the Wyze Battery Cam Pro be used wirelessly?Yes, the Wyze Battery Cam Pro is completely wire-free, supporting both 2.4 GHz and 5 GHz WiFi for stable wireless connectivity without the need for a hub.
What smart home integrations does the Wyze Battery Cam Pro support?The Wyze Battery Cam Pro integrates seamlessly with Alexa, Google Assistant, and IFTTT, allowing for hands-free control and monitoring.
Does the Wyze Battery Cam Pro have night vision?Yes, the Wyze Battery Cam Pro features color night vision with an integrated spotlight, ensuring clear footage even in low-light conditions.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes the high-resolution, weatherproof camera and a solar panel with a 13-foot power cable. The solar panel extends battery life by harnessing sunlight, providing continuous power for uninterrupted surveillance.
Can I add a solar panel to my existing Wyze Battery Cam Pro?Yes, the Wyze Battery Cam Solar Panel accessory is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2. It is IP65 weatherproof, easy to install, and includes a 13-foot micro USB cable for flexible placement.
How much local storage does the Wyze Battery Cam Pro support?The Wyze Battery Cam Pro supports local storage with microSD cards up to 256 GB, allowing you to record and store footage directly on the device.
What are the dimensions and weight of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro measures 2.5 x 1.8 x 3.5 inches and weighs 0.94 lbs, making it compact and easy to install on garage walls or near driveways.
Does the Wyze Battery Cam Pro offer two-way audio?Yes, the Wyze Battery Cam Pro is equipped with a built-in speaker and microphone, enabling two-way audio for real-time communication.
How is the Wyze Battery Cam Pro installed?The Wyze Battery Cam Pro is designed for easy installation thanks to its compact and lightweight design. It can be mounted on garage walls, near driveways, or anywhere outdoors using the included hardware.
What type of motion detection does the Wyze Battery Cam Pro use?The Wyze Battery Cam Pro uses advanced radar and PIR (Passive Infrared) motion detection to provide accurate and timely alerts for any movement in its field of view.
Is cloud recording available for the Wyze Battery Cam Pro?Yes, cloud recording is available with a Cam Plus subscription, offering additional security and remote access to your footage.
What are the installation requirements for the Wyze Battery Cam Pro?Can the Wyze Battery Cam Pro be used indoors as well as outdoors?Does the Wyze Battery Cam Pro come with a warranty?
