Best Weatherproof Dual Wyze Security Cameras for Backyard
Weatherproof Dual Wyze Security Cameras Ideal for Backyard Monitoring
When it comes to securing your backyard, having reliable, weatherproof, and high-quality security cameras is essential. Wyze offers a range of dual camera solutions designed specifically for outdoor use, combining advanced features like color night vision, motion-activated spotlights, and robust weather resistance. Whether you want a versatile starter pack or a powerful floodlight camera, Wyze has you covered.
Wyze Security Starter Pack: Versatile Dual Camera Solution
Overview
The Wyze Security Starter Pack is an excellent choice for those looking to start backyard monitoring with two complementary cameras: the Wyze Cam Pan v3 and the Wyze Cam v4. This pack offers unmatched value and flexibility for outdoor security.
Key Features
  • Wyze Cam Pan v3:
  • 1080p Full HD video resolution
  • 360° horizontal and 180° vertical view range for complete backyard coverage
  • 4 IR LEDs for night vision (850 nm)
  • Matte polycarbonate body with glass + plastic lens
  • Multiple mounting options including wall, ceiling, and magnetic mounts
  • Compact and lightweight (11.29 oz)
  • Wyze Cam v4:
  • Crystal-clear 2.5K QHD resolution (2560x1440)
  • Enhanced Color Night Vision with 4 IR LEDs plus 2 white spotlight LEDs (72 lumens)
  • Wide dynamic range for balanced lighting in all conditions
  • Bluetooth® connectivity and compatibility with Alexa, Google Assistant, and IFTTT
  • Weatherproof design suitable for outdoor use
  • Multiple mounting options and compact size (0.49 lb)
Why Choose This Pack?
This starter pack is perfect for users who want a combination of a pan-and-tilt camera with a fixed high-resolution camera, providing comprehensive backyard coverage day and night. The weatherproof design ensures durability in all seasons. Outdoor security camera mounted on house exterior Wyze cameras installed outdoors for backyard security
Wyze Cam Floodlight v2: Brighten and Secure Your Backyard
Overview
For those who want to combine lighting and security, the Wyze Cam Floodlight v2 is a powerful outdoor camera with integrated floodlights. It’s designed to dominate the dark with bright illumination and sharp video.
Key Features
  • 2800 lumens of dimmable LED light panels with 5000K color temperature
  • 2K video resolution (2304 x 1296) with Color Night Vision
  • Wide 160° diagonal field of view to cover large backyard areas
  • AI-powered light control and dusk-to-dawn automation for smart lighting
  • Built-in 105dB siren and two-way audio for active deterrence and communication
  • IP65 weather resistance for reliable outdoor performance
  • Supports local storage up to 256GB microSD card
  • Compatible with Alexa, Google Assistant, and IFTTT
Ideal Use Case
This floodlight camera is perfect for backyards that need both bright lighting and vigilant monitoring. Its smart features and weatherproof design make it a top choice for outdoor security. Wyze Cam Floodlight v2 illuminating driveway at night Wyze Cam Floodlight v2 providing bright security lighting
Wyze v3 Bundle: Reliable Wired Outdoor Cameras with Local Storage
Overview
The Wyze v3 Bundle offers a pair of best-selling wired cameras with included MicroSD cards, ideal for users who want dependable wired security cameras for outdoor backyard monitoring.
Key Features
  • 1080p Full HD video resolution with 20 fps daytime and 15 fps nighttime
  • 360° horizontal and 180° vertical viewing range with 121° diagonal field of view
  • Color Night Vision with 4 IR LEDs (850 nm)
  • IP65 weather resistance for outdoor durability
  • Includes 32GB MicroSDHC card for local recording
  • Easy installation with included mounting kits and outdoor-rated USB cables
  • Motion tracking and two-way audio for interactive monitoring
Why It Stands Out
This bundle is perfect for those who prefer wired cameras with local storage and reliable weatherproofing, ensuring continuous backyard surveillance without worrying about battery life.
Wyze Cam v4 Outdoor Bundle: Advanced 2.5K QHD Outdoor Security
Overview
The Wyze Cam v4 Outdoor Bundle is a premium option for backyard security, featuring the latest Wyze Cam v4 with enhanced outdoor capabilities.
Key Features
  • Stunning 2.5K QHD video resolution for crystal-clear footage
  • Enhanced Color Night Vision with motion-activated spotlight
  • 24/7 local recording with included 128GB MicroSD card
  • Wi-Fi 6 support for faster and more reliable connectivity
  • Wide Dynamic Range (WDR) for balanced lighting in challenging conditions
  • Motion detection zones and sound detection for precise alerts
  • Compatible with Alexa and Google Assistant
  • Wired power source for uninterrupted operation
  • IP65 weatherproof rating for all-weather protection
Perfect For
Backyard owners who want the highest video quality and smart features combined with robust weatherproofing and local storage.
Wyze Cam v4: Single Weatherproof Camera for Flexible Backyard Monitoring
Overview
The Wyze Cam v4 is also available as a standalone weatherproof camera, ideal for users who want to customize their backyard security setup with a single, powerful device.
Key Features
  • 2.5K QHD resolution with enhanced color night vision
  • Motion-activated spotlight and 8x digital zoom
  • IP65 weather resistance for outdoor use
  • Multiple mounting options including magnetic mounts
  • Two-way audio with built-in siren and noise cancellation
  • Wi-Fi 6 support and compatibility with Alexa, Google Assistant, and IFTTT
  • Supports microSD cards up to 512GB for local storage
Why It’s a Great Choice
This camera offers flexibility and high performance for any backyard, whether as a standalone unit or part of a multi-camera system. Wyze Cam v4 mounted outdoors monitoring backyard Wyze Cam v4 providing clear backyard surveillance
Conclusion
For backyard monitoring, Wyze provides a variety of weatherproof dual camera options tailored to different needs:
  • Security Starter Pack for versatile dual-camera coverage
  • Wyze Cam Floodlight v2 for bright, illuminated security
  • Wyze v3 Bundle for reliable wired cameras with local storage
  • Wyze Cam v4 Outdoor Bundle for advanced 2.5K QHD outdoor security
  • Wyze Cam v4 standalone for flexible, high-quality monitoring
Each option offers robust weather resistance (IP65), excellent night vision, and smart home compatibility, making them ideal for keeping your backyard safe and secure around the clock.
Product Tags Summary
FeatureSecurity Starter PackWyze Cam Floodlight v2Wyze v3 BundleWyze Cam v4 Outdoor BundleWyze Cam v4
Price$64.99$89.98$92.94$69.99$107.94 (1 pack) / $35.98 (single)
Included Cameras1x Wyze Cam Pan v3 + 1x Wyze Cam v4Wyze Cam Floodlight v22x Wyze Cam v3 + 32GB MicroSD cardsWyze Cam v4 + Outdoor Power Adapter + 128GB MicroSDWyze Cam v4 (single or multi-pack)
Video ResolutionPan v3: 1080p (1920x1080), Cam v4: 2.5K QHD2K (2304x1296)1080p (1920x1080)2.5K QHD2.5K QHD (2560x1440)
Night VisionPan v3: 4 IR LEDs (850 nm), Cam v4: 4 IR LEDs + 2 white spotlight LEDsColor Night Vision4 IR LEDs (850 nm)Enhanced Color Night Vision4 IR LEDs + 2 white spotlight LEDs
Field of ViewPan v3: 360° horizontal, 180° vertical; Cam v4: DFOV 115.8°, HFOV 98.5°, VFOV 53.1°160° diagonal360° horizontal, 180° verticalNot specifiedDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
AudioNot specifiedBuilt-in speaker and microphone; 2-way audioTwo-way audioNot specified99dB waterproof speaker, 2-way talk
Motion FeaturesNot specifiedAdvanced motion detectionMotion trackingMotion detection, motion detection zonesMotion-activated spotlight, person detection
StorageNot specifiedSupports up to 256GB microSD32GB MicroSD includedmicroSD card slot includedmicroSD card up to 512GB, cloud storage available
Weather ResistanceNot specifiedIP65IP65IP65IP65
ConnectivityBluetooth®802.11 b/g/n, 2.4 GHz Wi-FiNot specifiedWi-Fi 6Wi-Fi 6, Bluetooth 5.2
CompatibilityAndroid 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+Not specifiedAlexa, Google AssistantAlexa, Google Assistant, IFTTT
Power SourceIndoor 5V/1A adapterHardwiredNot specifiedWiredIndoor 5V/1A adapter
DimensionsPan v3: 124mm x 60mm x 63mm; Cam v4: 2in x 2in x 2 3/8in9.5in x 7.7in x 7.0in124mm x 60mm x 63mmNot specified2in x 2in x 2 3/8in
WeightPan v3: 11.29 oz (320 g); Cam v4: 0.49 lb (222 g)2.76 lbs (1.25 kg)11.29 oz (320 g)Not specified0.49 lb (222 g)
Warranty1 Year1 YearNot specifiedNot specified1 Year
What makes Wyze security cameras ideal for backyard monitoring?Wyze security cameras are designed with weatherproof (IP65) construction, advanced night vision, motion-activated spotlights, and smart home compatibility, making them perfect for reliable backyard monitoring in all weather conditions.
What is included in the Wyze Security Starter Pack for backyard security?The Wyze Security Starter Pack includes two cameras: the Wyze Cam Pan v3, which offers 360° pan and 180° tilt for complete coverage, and the Wyze Cam v4, which features 2.5K QHD resolution and enhanced color night vision. Both are weatherproof and come with multiple mounting options.
How does the Wyze Cam Floodlight v2 enhance backyard security?The Wyze Cam Floodlight v2 combines a powerful 2800-lumen floodlight with a 2K resolution camera, color night vision, AI-powered light control, a built-in siren, and two-way audio. It provides bright illumination and vigilant monitoring for large backyard areas.
Are Wyze outdoor cameras weatherproof?Yes, all Wyze outdoor cameras featured, including the Cam Pan v3, Cam v4, and Floodlight v2, have an IP65 weather resistance rating, ensuring reliable performance in rain, snow, and extreme temperatures.
Can Wyze security cameras record video locally?Yes, Wyze cameras support local video recording via microSD cards. For example, the Wyze v3 Bundle includes 32GB microSD cards, and the Wyze Cam v4 supports up to 512GB microSD cards for continuous local storage.
What smart home systems are Wyze backyard cameras compatible with?Wyze backyard cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration with your smart home ecosystem.
What is the difference between the Wyze Cam v4 Outdoor Bundle and the Wyze v3 Bundle?The Wyze Cam v4 Outdoor Bundle features the latest 2.5K QHD camera with Wi-Fi 6 support, enhanced color night vision, and a 128GB microSD card for 24/7 recording. The Wyze v3 Bundle includes two 1080p wired cameras with 32GB microSD cards, offering reliable wired performance and local storage.
Does the Wyze Cam v4 offer night vision for backyard monitoring?Yes, the Wyze Cam v4 features enhanced color night vision with motion-activated spotlights and 4 IR LEDs, ensuring clear footage even in low-light or nighttime conditions.
Can I use Wyze cameras as a standalone solution for backyard security?Absolutely. The Wyze Cam v4 is available as a standalone weatherproof camera, offering 2.5K QHD resolution, motion-activated spotlight, two-way audio, and flexible mounting options for customized backyard security.
Do Wyze backyard cameras support two-way audio and sirens?Yes, many Wyze outdoor cameras, including the Cam v4 and Floodlight v2, feature two-way audio and built-in sirens for active deterrence and real-time communication.
What are the key features of the Wyze Security Starter Pack?Can you tell me more about the Wyze Cam Floodlight v2 and its capabilities?Are there any ongoing promotions or discounts available for Wyze products?
