Outdoor Wireless Cameras Built for Heavy Rain and Snow
When it comes to securing your outdoor spaces in harsh weather conditions like heavy rain and snow, choosing the right wireless camera is crucial. Wyze offers top-tier outdoor cameras designed to withstand tough environments while delivering crystal-clear video and smart features. Among these, the
Wyze Battery Cam Pro and its solar-powered variant stand out as excellent choices for reliable, weatherproof surveillance.
Wyze Battery Cam Pro: Ultimate Weatherproof Wireless Security
Rugged and Reliable in Any Weather
The Wyze Battery Cam Pro is engineered to endure the elements with an
IP65 weatherproof rating, making it resistant to heavy rain, snow, and dust. It operates flawlessly in temperatures ranging from
-20°C to 50°C (-4°F to 122°F), ensuring year-round protection for your home or business.
High-Definition Video and Smart Detection
- 2.5K HDR Video Resolution (2560 x 1440) delivers sharp, detailed footage day and night.
- Equipped with a CMOS-Starlight Sensor and F1.6 lens aperture for superior low-light performance.
- Radar + PIR Motion Detection enhances accuracy by combining radar sensing with passive infrared technology.
- Integrated spotlight and 100 dB siren provide active deterrence against intruders.
- Color Night Vision with 2 IR LEDs and 2 white LEDs (187 lumens) ensures clear nighttime monitoring.
Wireless and Long-Lasting Power
- Completely wire-free with no hub required.
- Powered by a removable, rechargeable 6200mAh battery pack lasting up to 6 months on a single charge.
- Supports both 2.4 GHz and 5 GHz WiFi for flexible connectivity.
- Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
Convenient Installation and Storage
- Compact size (2.5 x 1.8 x 3.5 inches) and lightweight (0.94 lbs) with a matte finish.
- Comes with a wall mount for easy setup.
- Supports local storage up to 256 GB microSD cards and optional cloud recording with Cam Plus.
Wyze Battery Cam Pro + Solar Panel: Continuous Power for Outdoor Security
Solar-Powered Convenience
For those seeking uninterrupted outdoor surveillance without frequent battery swaps, the
Wyze Battery Cam Pro + Solar Panel bundle is an ideal solution. The solar panel charges the camera’s battery continuously, extending its operation indefinitely under sufficient sunlight.
All the Features of the Battery Cam Pro
This bundle includes all the advanced features of the Wyze Battery Cam Pro:
- 2.5K HDR video quality with color night vision.
- IP65 weatherproof rating for protection against rain and snow.
- Radar + PIR motion detection and integrated spotlight with siren.
- Wireless connectivity on both 2.4 GHz and 5 GHz bands.
- Smart assistant compatibility and local/cloud storage options.
Eco-Friendly and Low Maintenance
- Solar panel dimensions: 173 mm x 120 mm x 17 mm.
- Weather-resistant with an IP65 rating to withstand outdoor conditions.
- Includes a 13 ft (4 m) micro USB cable for flexible installation.
Experience peace of mind with a camera that stays powered by the sun, reducing maintenance and ensuring your property is always monitored.
Wyze Cam Floodlight v2: Brighten and Secure Your Outdoor Spaces
Powerful Lighting Meets Smart Security
For enhanced outdoor security with superior illumination, the
Wyze Cam Floodlight v2 combines a high-powered floodlight with a smart camera:
- 2800 lumens of dimmable LED light panels brighten large areas.
- 2K video resolution (2304 x 1296) with color night vision and a wide 160° diagonal field of view.
- Motion-activated lighting and AI-powered light control for intelligent automation.
- Built-in 105 dB siren and two-way audio for active deterrence and communication.
Built to Brave the Elements
- Rated IP65 weatherproof, suitable for rain, snow, and extreme temperatures from -20°C to 60°C (-4°F to 140°F).
- Durable polycarbonate body with glass and plastic lens materials.
- Wall or ceiling mount options for versatile installation.
Smart Home Integration
- Compatible with Alexa, Google Assistant, and IFTTT.
- Supports local storage up to 256 GB microSD cards.
- Connects via 2.4 GHz WiFi for reliable streaming and alerts.
Accessories to Enhance Your Wyze Battery Cam Pro Experience
Wyze Battery Charging Dock
- Charge two batteries simultaneously with this compact dock.
- Fully charges batteries in approximately 8.5 to 9 hours.
- Includes power adapter and USB-A to USB-C cable.
- Compatible exclusively with Wyze Battery Cam Pro battery packs.
Wyze Removable Battery Pack
- Replacement 6200mAh rechargeable battery for extended camera use.
- Lasts up to 6 months per charge.
- Features a built-in USB-C charging port for convenience.
- Operates reliably in temperatures from -20°C to 50°C (-4°F to 122°F).
Why Choose Wyze Outdoor Wireless Cameras?
Wyze outdoor cameras combine advanced technology, weatherproof durability, and smart home compatibility to provide reliable security in any climate. Whether you need a wire-free camera with long battery life, solar-powered convenience, or powerful floodlight security, Wyze has you covered.
With features like
2.5K HDR video,
radar motion detection, and
IP65 weather resistance, these cameras are built to handle heavy rain and snow, ensuring your property stays protected year-round.
Summary of Wyze Outdoor Wireless Cameras
Product | Video Resolution | Weatherproof | Power Source | Special Features |
Wyze Battery Cam Pro | 2.5K HDR | IP65 | Rechargeable Battery (6200mAh) | Radar + PIR Motion, Spotlight, Siren |
Wyze Battery Cam Pro + Solar | 2.5K HDR | IP65 | Battery + Solar Panel | Continuous Solar Charging |
Wyze Cam Floodlight v2 | 2K Color Night | IP65 | Hardwired | 2800 Lumens Floodlight, AI Lighting |
Protect your home with Wyze’s outdoor wireless cameras designed to brave the toughest weather while delivering smart, high-quality security.
Are Wyze outdoor wireless cameras weatherproof for heavy rain and snow?
Yes, Wyze outdoor wireless cameras such as the Wyze Battery Cam Pro and Wyze Cam Floodlight v2 are rated IP65 weatherproof, making them resistant to heavy rain, snow, and dust. They are designed to operate reliably in extreme temperatures, ensuring year-round protection.What is the video quality of Wyze outdoor cameras?
Wyze outdoor cameras offer high-definition video quality. The Wyze Battery Cam Pro provides 2.5K HDR video resolution (2560 x 1440), while the Wyze Cam Floodlight v2 delivers 2K video resolution (2304 x 1296) with color night vision for clear footage day and night.How long does the Wyze Battery Cam Pro battery last?
The Wyze Battery Cam Pro is powered by a removable, rechargeable 6200mAh battery pack that can last up to 6 months on a single charge, depending on usage and environmental conditions.Can I use solar power with Wyze outdoor cameras?
Yes, the Wyze Battery Cam Pro + Solar Panel bundle allows you to power your camera continuously using solar energy. The included solar panel charges the camera’s battery, reducing maintenance and ensuring uninterrupted surveillance under sufficient sunlight.Do Wyze outdoor cameras support local and cloud storage?
Yes, Wyze outdoor cameras support local storage with microSD cards up to 256 GB and offer optional cloud recording with the Cam Plus subscription for added flexibility and security.Are Wyze outdoor cameras compatible with smart home systems?
Wyze outdoor cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing seamless integration with your smart home devices for voice control and automation.What motion detection features do Wyze outdoor cameras offer?
Wyze outdoor cameras feature advanced motion detection, including radar and PIR (passive infrared) sensors for accurate detection. The cameras also include integrated spotlights and sirens for active deterrence.What accessories are available for Wyze Battery Cam Pro?
Accessories for the Wyze Battery Cam Pro include a battery charging dock that charges two batteries simultaneously and a removable 6200mAh rechargeable battery pack for extended use.How do I install Wyze outdoor wireless cameras?
Wyze outdoor cameras are designed for easy installation. The Wyze Battery Cam Pro is wire-free and comes with a wall mount, while the Wyze Cam Floodlight v2 offers both wall and ceiling mounting options.What is the difference between Wyze Battery Cam Pro and Wyze Cam Floodlight v2?
The Wyze Battery Cam Pro is a wire-free, battery-powered camera with 2.5K HDR video and optional solar charging, ideal for flexible placement. The Wyze Cam Floodlight v2 is a hardwired camera with 2K video, a powerful 2800-lumen floodlight, and AI-powered lighting for enhanced security and illumination.
