Outdoor Weatherproof Plug-In Floodlight Cameras: 2800-3000 Lumens
Outdoor Weatherproof Plug-In Floodlight Cameras with Motion Detection and High Lumen LED Brightness
When it comes to securing your outdoor spaces with bright, reliable lighting and smart surveillance, choosing the right floodlight camera with weatherproof plug-in capability is essential. Whether you want to illuminate your driveway, backyard, or porch, the combination of powerful LED brightness and intelligent motion detection ensures safety and convenience. Below, we explore the top Wyze products designed to meet your needs for outdoor weatherproof floodlight cameras with motion sensors and 2800 to 3000 lumen LED brightness.
Wyze Cam Floodlight Pro + Plug-In Mount: Ultimate Outdoor Security and Brightness
Powerful 3000 Lumen LED Lighting
The Wyze Cam Floodlight Pro delivers an impressive 3000 lumens of bright, clear light, making it one of the brightest floodlight cameras available. This high lumen output ensures your outdoor areas are well-lit, deterring unwanted visitors and enhancing nighttime visibility.
Advanced 2.5K QHD Camera with Ultra-Wide 180° Field of View
Capture every detail with a sharp 2.5K QHD resolution camera that offers a wide 180-degree field of view. This ultra-wide angle covers large outdoor spaces, reducing blind spots and providing comprehensive surveillance.
Intelligent Motion Detection and Alerts
Equipped with AI-powered detection, the Floodlight Pro can distinguish between people, pets, vehicles, and packages. Receive instant motion alerts on your phone, helping you stay informed and react quickly.
Easy Plug-In Installation with Included Mount
Forget complicated wiring or junction boxes. The included plug-in mount with a durable 20-foot cable allows for flexible placement and easy installation into any outdoor-rated outlet.
Weatherproof and Durable
Rated IP65 for water and dust resistance, this floodlight camera is built to withstand harsh outdoor conditions, from rain to snow, ensuring year-round protection.
"Say goodbye to the complexity and cost of installing a junction box. Go with an easy, plug-n-play floodlight solution instead."
Wyze Cam Floodlight Pro in Outdoor Setting Bright and secure outdoor lighting with Wyze Cam Floodlight Pro
Wyze Cam Floodlight v2 + Plug-In Mount: Bright 2800 Lumen Lighting with Smart Features
Bright 2800 Lumen LEDs for Clear Illumination
The Wyze Cam Floodlight v2 offers 2800 lumens of LED brightness, perfect for lighting up your porch, driveway, or backyard with vibrant, clear light.
Crisp 2K HD Video and Wide 160° Field of View
Enjoy high-definition 2K video quality with a wide 160-degree viewing angle, capturing detailed footage of your outdoor environment.
Enhanced Night Vision and Motion Detection
With vibrant color night vision and advanced motion detection, this floodlight camera keeps you aware of any movement around your home, day or night.
Plug-In Mount for Simple Setup
The included plug-in mount with a 20-foot cable and velcro strap for cable management makes installation quick and hassle-free—no electrician needed.
Weather-Resistant Design
Built to endure outdoor elements, this floodlight camera is designed for reliable performance in various weather conditions.
"Flexible power solution for all Wyze Cam Floodlights with easy installation and no junction box needed."
Wyze Cam Floodlight Installation Effortless outdoor installation with Wyze Cam Floodlight v2 Plug-In Mount
Wyze Cam Floodlight Plug-In Mount: Convenient Power Solution for Floodlight Cameras
Plug-and-Play Convenience
The Wyze Cam Floodlight Plug-In Mount eliminates the need for complex junction box installations. Simply plug into any outdoor-rated outlet and enjoy immediate floodlight camera functionality.
Compatible with Multiple Wyze Floodlight Models
This mount works seamlessly with Wyze Cam Floodlight v1, v2, and Pro models, providing a versatile power solution.
Long 20-Foot Cable with Cable Management
The durable 20-foot outdoor-rated cable allows flexible placement, while the included velcro strap keeps cables neat and tidy.
Designed for outdoor use, the mount and cable withstand rain, dust, and snow, ensuring reliable power delivery in all seasons.
"If you can plug in a cable, then you can enjoy the security of a Wyze Floodlight."
Wyze Plug Outdoor: Weatherproof Smart Plug for Outdoor Lighting Control
Reliable Outdoor Power with IP64 Weather Resistance
The Wyze Plug Outdoor is designed to power your outdoor devices rain or shine. Its IP64 rating protects against rain, dust, and snow, making it perfect for garden lights, holiday inflatables, and more.
Dual Outlets with Independent Control
Control two separate outlets independently, allowing you to manage multiple outdoor devices with ease.
Long-Range WiFi Connectivity
With up to 300 feet WiFi range in open spaces, you can place the plug almost anywhere outdoors and maintain a strong connection.
Energy Monitoring and Scheduling via App
Monitor energy usage, set schedules, and control your outdoor devices remotely through the Wyze app, adding convenience and energy savings.
Voice Control Compatibility
Works with Alexa and Google Assistant for hands-free control of your outdoor lighting and devices.
"Power up the outdoors, rain or shine, with an outdoor smart plug – because even your garden lights deserve a tech-savvy friend."
Why Choose Wyze Outdoor Floodlight Cameras and Plugs?
  • High Lumen Brightness: From 2800 to 3000 lumens, these floodlights provide powerful illumination for enhanced security.
  • Plug-In Convenience: Avoid costly and complex wiring with easy plug-in mounts and smart plugs.
  • Weatherproof Durability: Designed to withstand outdoor elements, ensuring reliable performance year-round.
  • Smart Features: Advanced motion detection, AI alerts, and app control keep you connected and informed.
  • Flexible Installation: Long cables and plug-in mounts allow placement wherever you need bright, smart lighting.
Enhance your outdoor security and lighting with Wyze’s innovative floodlight cameras and weatherproof smart plugs — the perfect combination for a safer, smarter home.
FeatureWyze Cam Floodlight Plug-In MountWyze Cam Floodlight v2 + Plug-In MountWyze Cam Floodlight Pro + Plug-In MountWyze Plug Outdoor
Product TypeMount accessoryCamera + Mount bundleCamera + Mount bundleOutdoor smart plug
Price (USD)$19.98$109.96$169.96$15.99 (1 Pack), $34.98 (2 Pack)
Camera ResolutionN/A2K (2304 x 1296)2.5K QHD (2560 x 1440)N/A
Field of ViewN/A160° wide-angle180° ultra-wideN/A
Lighting OutputN/A2800 lumens (2 LED panels)3000 lumens (3 LED panels)N/A
Night VisionN/AColor Night VisionColor Night VisionN/A
Power SupplyPlug-in mount with 20ft cableHardwired or via Plug-In MountHardwired or via Plug-In Mount120V AC, 2 outlets
Mount TypePlug-In MountWall/CeilingWall/CeilingN/A
Installation ComplexityEasy, no junction box neededEasy with Plug-In Mount, no junction boxEasy with Plug-In Mount, no junction boxPlug and play
Cable Length20 feetIncluded via Plug-In MountIncluded via Plug-In MountN/A
Motion DetectionN/AAdvanced motion detectionAI-powered motion detectionN/A
SirenN/A105 dB105 dBN/A
ConnectivityN/A2.4 GHz Wi-Fi2.4 & 5 GHz dual-band Wi-Fi2.4 GHz Wi-Fi, Bluetooth V4.2
Weather ResistanceN/AIP65IP65IP64
Audio FeaturesN/A2-way audio (built-in speaker & mic)Siren and 2-way audioN/A
Local Storage SupportN/AmicroSD up to 256 GBmicroSD up to 256 GBN/A
Compatible CamerasWyze Cam Floodlight seriesWyze Cam Floodlight v2Wyze Cam Floodlight ProN/A
Operating Temperature RangeN/A-4°F to 140°F (-20°C to 60°C)-22°F to 122°F (-30°C to 50°C)-4°F to 120°F (-20°C to 49°C)
Smart Assistant IntegrationN/AAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa
WarrantyN/A1 Year1 Year1 Year
What are the key features of Wyze outdoor weatherproof plug-in floodlight cameras?Wyze outdoor weatherproof plug-in floodlight cameras offer high lumen LED brightness (2800 to 3000 lumens), advanced motion detection with AI-powered alerts, easy plug-in installation with a 20-foot cable, weatherproof durability (IP65 rating), and high-definition video with wide field of view. These features ensure reliable outdoor security and convenient smart surveillance.
How bright are Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2?The Wyze Cam Floodlight Pro delivers an impressive 3000 lumens of LED brightness, while the Wyze Cam Floodlight v2 provides 2800 lumens. Both models offer powerful illumination to enhance security and visibility in your outdoor spaces.
Do Wyze floodlight cameras require hardwiring or a junction box for installation?No, Wyze floodlight cameras come with a plug-in mount and a 20-foot outdoor-rated cable, allowing for easy installation into any outdoor-rated outlet. There is no need for hardwiring or a junction box, making setup quick and hassle-free.
Are Wyze floodlight cameras weatherproof?Yes, Wyze floodlight cameras are designed for outdoor use and are rated IP65 for water and dust resistance. This ensures reliable performance in various weather conditions, including rain and snow.
What smart features do Wyze outdoor floodlight cameras offer?Wyze outdoor floodlight cameras feature AI-powered motion detection that can distinguish between people, pets, vehicles, and packages. They also provide instant motion alerts, app control, and advanced night vision for comprehensive security monitoring.
What is the field of view and video quality of Wyze Cam Floodlight Pro and v2?The Wyze Cam Floodlight Pro offers a 2.5K QHD camera with an ultra-wide 180° field of view, while the Wyze Cam Floodlight v2 features 2K HD video quality with a 160° field of view. Both models capture detailed footage and cover large outdoor areas.
Can I use the Wyze Cam Floodlight Plug-In Mount with different Wyze floodlight models?Yes, the Wyze Cam Floodlight Plug-In Mount is compatible with Wyze Cam Floodlight v1, v2, and Pro models, providing a versatile and convenient power solution for your outdoor security needs.
What is the Wyze Plug Outdoor and how does it enhance outdoor lighting control?The Wyze Plug Outdoor is a weatherproof smart plug with an IP64 rating, designed for outdoor use. It features dual independently controlled outlets, long-range WiFi connectivity, energy monitoring, scheduling via the Wyze app, and voice control compatibility with Alexa and Google Assistant, making it easy to manage outdoor lighting and devices.
How long is the cable included with Wyze plug-in floodlight cameras and mounts?Wyze plug-in floodlight cameras and mounts come with a durable 20-foot outdoor-rated cable, allowing for flexible placement and easy cable management with the included velcro strap.
Why should I choose Wyze outdoor floodlight cameras and plugs for my home security?Wyze outdoor floodlight cameras and plugs offer high lumen brightness, plug-in convenience, weatherproof durability, advanced smart features, and flexible installation options. These benefits make them an ideal choice for enhancing outdoor security and lighting in a cost-effective and user-friendly way.
What are the key features of the Wyze Cam Floodlight Pro?How does the motion detection work on the Wyze floodlight cameras?Are there any ongoing promotions or discounts for Wyze products?
