Outdoor Weather Resistant Wireless Doorbell with 2K Night Vision
When it comes to securing your home’s entrance, having a reliable, weatherproof wireless doorbell with crystal-clear 2K night vision is essential. Whether you want to monitor visitors, packages, or simply enhance your home security, the latest smart doorbells combine advanced video quality, night vision, and weather resistance to keep you connected and protected around the clock.
Below, we explore the top Wyze products designed to meet your outdoor security needs with wireless convenience and superior night vision capabilities.
Wyze Duo Cam Battery Doorbell: Advanced Wireless Security with Dual Cameras
Experience dual-camera views and wireless freedom with Wyze Duo Cam Doorbell.
The
Wyze Duo Cam Battery Doorbell is Wyze’s most advanced battery-powered video doorbell, perfect for outdoor use with its IP65 weather resistance rating. It offers:
- Dual Camera Views: Front camera captures 2K (2048 x 1536) video, while the bottom camera covers packages in 1080p HD, ensuring no detail is missed.
- 2K Video Resolution: Crisp, high-definition video quality for clear identification day or night.
- 6 Infrared LEDs (850 nm): Enhanced night vision for clear images even in complete darkness.
- Wireless Battery Power: Includes a removable 6200 mAh lithium-ion battery pack with USB-C charging, offering flexible installation without wiring hassles.
- Two-Way Audio & Siren: Communicate with visitors or deter unwanted guests with a 90 dB siren and real-time two-way talk.
- Motion-Activated Voice Deterrence: Automatically warns visitors with a recorded message, “Hi, you’re currently being recorded.”
- Local and Cloud Storage: Supports up to 256 GB microSD card for local recording and cloud storage options.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home control.
This wireless doorbell is ideal for those seeking a versatile, weatherproof solution with excellent night vision and dual-camera coverage.
Wyze Video Doorbell v2: Wired 2K Video Doorbell with Color Night Vision
Wired smart doorbell with stunning 2K video and color night vision.
For users who prefer a wired setup, the
Wyze Video Doorbell v2 delivers exceptional 2K video quality and advanced features:
- 2K HD Video: Capture every visitor in crystal-clear detail with head-to-toe viewing.
- Color Night Vision: Equipped with an award-winning starlight sensor, it provides vivid color images even in low light.
- IP65 Weatherproof: Built to withstand rain, snow, and harsh outdoor conditions.
- Local microSD Storage: Continuous 24/7 local recording with onboard microSD card slot, so you never miss a moment.
- Two-Way Audio & Motion-Activated Voice Deterrence: Talk to visitors and deter suspicious activity with automated voice prompts.
- Works with Existing Chimes: Includes a chime controller to keep your traditional doorbell sound.
- Smart Alerts & AI Detection: With optional Cam Plus subscription, get person, package, and vehicle detection notifications.
- Smart Home Compatibility: Works with Alexa and Google Home for voice commands and live feed viewing.
This wired doorbell is perfect for homeowners wanting high-resolution video and reliable wired power with advanced night vision.
Wyze Video Doorbell v2 Wedge Kit: Perfect Your Doorbell’s Viewing Angle
If your doorbell installation area has an angled door frame or stairs, the
Wyze Video Doorbell v2 Wedge Kit accessory is a must-have:
- Adjustable Viewing Angles: Includes a 15° horizontal bracket and two 7.5° vertical brackets to eliminate blind spots.
- Weather Resistant: Made from durable plastic with IP65 rating to withstand outdoor conditions.
- Easy Installation: Quick setup with included screws and guide.
- Compatible Only with Wyze Video Doorbell v2: Designed specifically to enhance your doorbell’s field of view.
This accessory ensures your 2K video doorbell captures the perfect view of your porch or entryway.
Why Choose Wyze for Your Outdoor Wireless Doorbell Needs?
Wyze combines affordability with cutting-edge technology, offering smart doorbells that deliver 2K video clarity, robust night vision, and weather resistance. Whether you want the convenience of wireless battery power or the reliability of a wired connection, Wyze has you covered.
With features like two-way talk, motion-activated voice deterrence, local and cloud storage options, and smart home integration, Wyze doorbells provide comprehensive security and peace of mind.
Summary of Key Features
Feature | Wyze Duo Cam Battery Doorbell | Wyze Video Doorbell v2 | Wedge Kit (Accessory) |
Video Resolution | 2K Front / 1080p Bottom | 2K HD | N/A |
Night Vision | 6x IR LEDs (850 nm) | Color Night Vision | N/A |
Power | Battery (Removable) | Wired | N/A |
Weather Resistance | IP65 | IP65 | IP65 |
Two-Way Audio | Yes | Yes | N/A |
Local Storage | microSD up to 256 GB | microSD slot | N/A |
Motion-Activated Voice Deterrence | Yes | Yes (with subscription) | N/A |
Smart Home Integration | Alexa, Google, IFTTT | Alexa, Google | N/A |
Adjustable Viewing Angle | No | No | Yes (15° horizontal, 7.5° vertical) |
Enhance your home’s security with Wyze’s outdoor weather resistant wireless doorbells featuring 2K night vision. Choose the model that fits your installation preference and enjoy peace of mind knowing your front porch is protected day and night.
What is the best outdoor weather resistant wireless doorbell with 2K night vision?
The Wyze Duo Cam Battery Doorbell is an excellent choice for an outdoor weather resistant wireless doorbell with 2K night vision. It features dual cameras, 2K video resolution, 6 infrared LEDs for enhanced night vision, and an IP65 weather resistance rating, making it ideal for monitoring your home’s entrance in any weather conditions.Does the Wyze Duo Cam Battery Doorbell work wirelessly?
Yes, the Wyze Duo Cam Battery Doorbell is a wireless, battery-powered video doorbell. It comes with a removable 6200 mAh lithium-ion battery pack and USB-C charging, allowing for flexible installation without the need for wiring.Is the Wyze Duo Cam Battery Doorbell weatherproof?
Absolutely. The Wyze Duo Cam Battery Doorbell is rated IP65 for weather resistance, ensuring reliable performance in rain, snow, and harsh outdoor conditions.What night vision features does the Wyze Duo Cam Battery Doorbell offer?
The Wyze Duo Cam Battery Doorbell is equipped with 6 infrared LEDs (850 nm) that provide enhanced night vision, allowing you to see clear images even in complete darkness.Can I store video locally on Wyze doorbells?
Yes, both the Wyze Duo Cam Battery Doorbell and Wyze Video Doorbell v2 support local storage via a microSD card. The Duo Cam supports up to 256 GB, and the v2 offers continuous 24/7 local recording.Does the Wyze Video Doorbell v2 have color night vision?
Yes, the Wyze Video Doorbell v2 features color night vision thanks to its award-winning starlight sensor, providing vivid color images even in low-light conditions.Is the Wyze Video Doorbell v2 weather resistant?
Yes, the Wyze Video Doorbell v2 is IP65 weatherproof, making it suitable for outdoor use in various weather conditions.Can I use my existing chime with the Wyze Video Doorbell v2?
Yes, the Wyze Video Doorbell v2 includes a chime controller, allowing it to work with your existing traditional doorbell chime.What smart home systems are Wyze doorbells compatible with?
Wyze doorbells are compatible with popular smart home systems. The Wyze Duo Cam Battery Doorbell works with Alexa, Google Assistant, and IFTTT, while the Wyze Video Doorbell v2 works with Alexa and Google Home.What is the Wyze Video Doorbell v2 Wedge Kit used for?
The Wyze Video Doorbell v2 Wedge Kit is an accessory designed to adjust your doorbell’s viewing angle. It includes a 15° horizontal bracket and two 7.5° vertical brackets, helping eliminate blind spots and ensuring the perfect view of your porch or entryway.Are Wyze doorbells easy to install?
Yes, Wyze doorbells are designed for easy installation. The wireless Duo Cam Battery Doorbell requires no wiring, and the Video Doorbell v2 and its Wedge Kit come with all necessary hardware and guides for quick setup.Do Wyze doorbells offer two-way audio?
Yes, both the Wyze Duo Cam Battery Doorbell and Wyze Video Doorbell v2 feature two-way audio, allowing you to communicate with visitors in real time.What security features do Wyze doorbells provide?
Wyze doorbells offer advanced security features such as motion-activated voice deterrence, a 90 dB siren (Duo Cam), AI-powered smart alerts (with Cam Plus subscription), and high-definition video recording to help protect your home.What is the difference between the Wyze Duo Cam Battery Doorbell and Wyze Video Doorbell v2?
The Wyze Duo Cam Battery Doorbell is a wireless, battery-powered model with dual cameras (2K front and 1080p bottom), while the Wyze Video Doorbell v2 is a wired model with 2K HD video and color night vision. Both are IP65 weather resistant and support local storage, but the Duo Cam offers wireless convenience and dual-camera coverage.
